Re: Missing variable in *_defconfig of MT7628/MT7688
Hi Tom,
please find below a mail from Ruben, remarking that the Kconfig conversion of CONFIG_SPL_PAD_TO seems to have gone wrong. At least for MIPS MT7620/88. This was the commit from you:
ca8a329a1b7f ("Convert CONFIG_SPL_PAD_TO et al to Kconfig")
I just double checked this and Ruben is correct. Before the conversion SPL_PAD_TO was 0x0 and now its 0x10000.
I can easily generate a patch changing these defconfig values for these MIPS boards. But there might be other boards that could be affected, so I wanted to put this issue to the list.
Thanks, Stefan
On 27.10.22 14:39, Ruben Winters wrote:
Hi guys,
The CONFIG_SPL_PAD_TO=0 is missing from the defconf.
After removing it from the .h file it was not placed in the _defconf file.
If not placed it will default to 0x10000 e.g. equals to CONFIG_SPL_MAX_SIZE, and you will get an error spl: failed to boot from all boot devices.
Met vriendelijke groet,
Mit freundlichen Grüßen,
*Ruben Winters*
*Research & Development Engineer*
On Fri, Oct 28, 2022 at 01:00:45PM +0200, Stefan Roese wrote:
Hi Tom,
Please just fix the MIPS boards that you can see need fixing, thanks!
Stefan Roese
