[U-Boot] [PATCH v2 1/1] configs: qemu: enable CONFIG_UT
Some library functions are implemented in a architecture dependent way, e.g. the memory functions memset(), memcopy(), memmove.
So let's enable unit tests for QEMU targets. Later we should ensure they are actually called on Travis CI.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 use the correct CONFIG option --- configs/qemu-ppce500_defconfig | 1 + configs/qemu-riscv32_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-riscv64_defconfig | 1 + configs/qemu-riscv64_smode_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu_arm64_defconfig | 1 + configs/qemu_arm_defconfig | 1 + configs/qemu_mips64_defconfig | 1 + configs/qemu_mips64el_defconfig | 1 + configs/qemu_mips_defconfig | 1 + configs/qemu_mipsel_defconfig | 1 + 13 files changed, 13 insertions(+)
diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index fd276f2d04..40629a2a5d 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -28,3 +28,4 @@ CONFIG_E1000=y CONFIG_SYS_NS16550=y CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y +CONFIG_UT=y diff --git a/configs/qemu-riscv32_defconfig b/configs/qemu-riscv32_defconfig index 6334d8c0fc..ce247bd44a 100644 --- a/configs/qemu-riscv32_defconfig +++ b/configs/qemu-riscv32_defconfig @@ -7,3 +7,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_UT=y diff --git a/configs/qemu-riscv32_smode_defconfig b/configs/qemu-riscv32_smode_defconfig index 0a84ec1874..fb581504ea 100644 --- a/configs/qemu-riscv32_smode_defconfig +++ b/configs/qemu-riscv32_smode_defconfig @@ -8,3 +8,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_UT=y diff --git a/configs/qemu-riscv64_defconfig b/configs/qemu-riscv64_defconfig index 2d9ead93a2..ee0b7e9c23 100644 --- a/configs/qemu-riscv64_defconfig +++ b/configs/qemu-riscv64_defconfig @@ -8,3 +8,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_UT=y diff --git a/configs/qemu-riscv64_smode_defconfig b/configs/qemu-riscv64_smode_defconfig index b012443370..3b255afaa7 100644 --- a/configs/qemu-riscv64_smode_defconfig +++ b/configs/qemu-riscv64_smode_defconfig @@ -9,3 +9,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_UT=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 8d43acd480..0ecfa3129f 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -72,3 +72,4 @@ CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_USER=y CONFIG_FRAMEBUFFER_VESA_MODE=0x144 CONFIG_CONSOLE_SCROLL_LINES=5 +CONFIG_UT=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 12ea72f562..e58d48575f 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -51,3 +51,4 @@ CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_USER=y CONFIG_FRAMEBUFFER_VESA_MODE=0x144 CONFIG_CONSOLE_SCROLL_LINES=5 +CONFIG_UT=y diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index f2e759cee9..74fa6bfc65 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -35,3 +35,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y +CONFIG_UT=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 27c427dd82..0843c57690 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -36,3 +36,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y +CONFIG_UT=y diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index aff109512e..c305d43b7b 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -23,3 +23,4 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NS16550=y CONFIG_LZMA=y +CONFIG_UT=y diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index 63cbd44c0d..59729e7719 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -24,3 +24,4 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NS16550=y CONFIG_LZMA=y +CONFIG_UT=y diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index 37bf69f9e8..92007e9fe5 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -21,3 +21,4 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NS16550=y CONFIG_LZMA=y +CONFIG_UT=y diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index 82091b97df..96532058de 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -22,3 +22,4 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NS16550=y CONFIG_LZMA=y +CONFIG_UT=y
