[U-Boot-Users] [patch] add-features-to-trab-board-standalone-test-application
Add features to TRAB board standalone test application.
- add "touch read" command - the crc16 command now verifies the crc value written to the EEPROM - use i2c_write_multiple() instead of i2c_write(), because i2c_write_mulitple() waites for the EEPROM to finish its write cycle
Signed-off-by Martin Krause martin.krause@tqs.de
CHANGELOG:
* Add features to TRAB board standalone test application. Patch by Martin Krause, 4 May 2006
In message 47F3F98010FF784EBEE6526EAAB078D1024F8130@tq-mailsrv.tq-net.de you wrote:
- use i2c_write_multiple() instead of i2c_write(), because =
Sorry, this patch does not apply. Please clean up and resubmit.
Maybe you can also use this opportunity and through out the duplicated CRC16 code from this file?
wd@denx.de wrote on Wednesday, July 19, 2006 2:57 PM:
- use i2c_write_multiple() instead of i2c_write(), because = i2c_write_mulitple() waites for the EEPROM to finish its write
cycle
OK. The attached patch should apply cleanly to top of git.
Regards, Martin
CHANGELOG:
* Add features to TRAB board standalone test application. - add "touch read" command - the crc16 command now verifies the crc value written to the EEPROM - use i2c_write_multiple() instead of i2c_write(), because i2c_write_mulitple() waites for the EEPROM to finish its write cycle Patch by Martin Krause, 7 Aug 2006
Martin Krause
