Re: [U-Boot-Users] [DNX#2006110242000047] [PATCH 02/10 v3]: mpc7448hpc2 platf [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006110242000047] was created:
<snip>
Add mpc7448hpc2 (mpc7448 + tsi108) board associated code support. The mpc7448hpc2 board support low level assemble language init code .
Signed-off-by: Alexandre Bounine alexandreb@tundra.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
board/mpc7448hpc2/asm_init.S | 955 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 955 insertions(+), 0 deletions(-)
diff --git a/board/mpc7448hpc2/asm_init.S b/board/mpc7448hpc2/asm_init.S new file mode 100644 index 0000000..8c15a3d --- /dev/null +++ b/board/mpc7448hpc2/asm_init.S @@ -0,0 +1,955 @@ +/*****************************************************************************
- (C) Copyright 2004-05; Tundra Semiconductor Corp.
- Added automatic detect of SDC settings
- Copyright (c) 2005 Freescale Semiconductor, Inc.
- Maintainer tie-fei.zang@freescale.com
- MA 02111-1307 USA
- FILENAME: asm_init.s
- Originator: Alex Bounine
- DESCRIPTION:
- Initialization code for the Tundra Tsi108 bridge chip
+#include <config.h> +#include <version.h>
+#include <ppc_asm.tmpl> +#include <ppc_defs.h> +#include <asm/processor.h>
+#include <tsi108.h>
- Build Configuration Options
+/* #define DISABLE_PBM disables usage of PB Master */ +/* #define SDC_HARDCODED_INIT config SDRAM controller with hardcoded values */ +/* #define SDC_AUTOPRECH_EN enable SDRAM auto precharge */
- Hardcoded SDC settings
+#ifdef SDC_HARDCODED_INIT
+/* Micron MT9HTF6472AY-40EA1 : Unbuffered, 512MB, 400, CL3, Single Rank */
+#define VAL_SD_REFRESH (0x61A) +#define VAL_SD_TIMING (0x0308336b) +#define VAL_SD_D0_CTRL (0x07100021) /* auto-precharge disabled */ +#define VAL_SD_D0_BAR (0x0FE00000) /* 512MB @ 0x00000000 */ +#define VAL_SD_D1_CTRL (0x07100021) /* auto-precharge disabled */ +#define VAL_SD_D1_BAR (0x0FE00200) /* 512MB @ 0x20000000 */
+#endif /* SDC_HARDCODED_INIT */
- CPU Configuration:
- CPU Address and Data Parity enables.
+#define CPU_AP +#define CPU_DP
- Macros
- !!! Attention !!! Macros LOAD_PTR, LOAD_U32 and LOAD_MEM defined below
are
- expected to work correctly for the CSR space within 32KB range.
</snip>
Your U-Boot support team
DENX Support System
