[U-Boot-Users] Patch for Cogent CSB336 (3)
Here http://www.dave-tech.it/download/misc/sw/csb336/up-csb336-3 it is available for download the latest patch for the Cogent CSB336. It has been tested with Linux 2.6.7. SDRAM clock settings are still conservative.
llandre
DAVE Electronics System House - R&D Department www.dave-tech.it
After checking in some previous patches, you patch does not apply any more. Do you think you can provide an update?
Hi Wolfgang,
the latest patch (the 3rd) provides just few changes respect to the 2nd one: - board init invokes SetAsynchMode(); - bi_arch_number has been updated with the master database hosted at http://www.arm.linux.org.uk/developer/machines/ - fixed PCDR clock settings for TFT LCD panel Sharp LQ050Q5DR01 - copy of ramdisk from Flash to RAM before booting Linux kernel (we chose to not patch the kernel 2.6 basically for tight schedule constraints)
Regards,
llandre
Dear Andrea,
Well, it would definitely help if you followed the instructions for submitting patches as given in the README (read: I will reject this patch until you do).
Problems:
* There is no CHANGELOG entry nor any description what the patch does or why.
* There is no description that there is more than just one patch; in your posting you wrote "download the latest patch" - how should I know if the "-3" suffix indicates a version or a sequence number?
* Even if I try to apply the two other patches (which you did not mention in your posting) it does not work. An I wrote: the code has changed a lot - there is for example no such directory as cpu/mc9328/
Please also check which oiof your modifications are still relevant to the current CVS source tree.
Remove this, please, from the patch you submit here.
Best regards, Viele Grüße,
Well, it would definitely help if you followed the instructions for submitting patches as given in the README (read: I will reject this patch until you do). ...
you are perfectly right. Unfortunatley time does not permit me to clean it up. I'm afraid I won't be able to clean the code soon. I used the CSB336 as a temporary platform for a demo, while waiting for the custom hardware. If anybody could use my patch as starting point and perform the necessary clean ups, I'd be glad to help him/her.
llandre
llandre
