[PATCH] mkimage: Allow 'auto-conf' signing of scripts
U-Boot configured for verified boot with the "required" option set to "conf" also checks scripts put in FIT images for a valid signature, and refuses to source and run such a script if the signature for the configuration is bad or missing. Such a script could not be packaged before, because mkimage failed like this:
% tools/mkimage -T script -C none -d tmp/my.scr -f auto-conf -k tmp -g dev -o sha256,rsa4096 my.uimg Failed to find any images for configuration 'conf-1/signature' tools/mkimage Can't add hashes to FIT blob: -1 Error: Bad parameters for FIT image type
This is especially unfortunate if LEGACY_IMAGE_FORMAT is disabled as recommended.
Listing the script configuration in a "sign-images" subnode instead, would have added even more complexity to the already complex auto fit generation code.
Signed-off-by: Alexander Dahl ada@thorsis.com --- tools/image-host.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/image-host.c b/tools/image-host.c index 7bfc0cb6b18..49ce7436bb9 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -730,7 +730,7 @@ static const char *fit_config_get_image_list(const void *fit, int noffset, int *lenp, int *allow_missingp) { static const char default_list[] = FIT_KERNEL_PROP "\0" - FIT_FDT_PROP; + FIT_FDT_PROP "\0" FIT_SCRIPT_PROP; const char *prop;
/* If there is an "sign-image" property, use that */
base-commit: fe2ce09a0753634543c32cafe85eb87a625f76ca
Alexander Dahl
