Re: [PATCH v13 00/19] RISC-V SiFive FU540 support SPL
Hi Jagan
From: Jagan Teki [mailto:jagan@amarulasolutions.com] Sent: Wednesday, June 03, 2020 2:57 AM To: Rick Jian-Zhi Chen(陳建志) Cc: U-Boot-Denx; Atish Patra; Palmer Dabbelt; Bin Meng; Paul Walmsley; Anup Patel; Sagar Kadam; Pragnesh Patel Subject: Re: [PATCH v13 00/19] RISC-V SiFive FU540 support SPL
Hi Rick,
On Fri, May 29, 2020 at 11:34 AM Pragnesh Patel pragnesh.patel@sifive.com wrote:
This series add support for SPL to FU540. U-Boot SPL can boot from L2 LIM (0x0800_0000) and jump to OpenSBI(FW_DYNAMIC firmware) and U-Boot proper from MMC devices.
This series is also available here [1] for testing [1] https://github.com/pragnesh26992/u-boot/tree/spl
How to test this patch:
- Go to OpenSBI-dir : make PLATFORM=generic FW_DYNAMIC=y
- export OPENSBI=<path to
opensbi/build/platform/generic/firmware/fw_dynamic.bin> 3) Change to u-boot-dir 4) make sifive_fu540_defconfig 5) make all 6) Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch)
# sudo sgdisk --clear \ > --set-alignment=2 \ > --new=1:34:2081 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ > --new=2:2082:10273 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ > --new=3:10274: --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ > /dev/sda
- sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34
- sudo dd if=u-boot.itb of=/dev/sda seek=2082
Changes in v13:
- Add a new patch to set the ethernet clock rate (riscv: sifive: dts: fu540: set ethernet clock rate)
Changes in v12:
Rebase on mainline U-Boot Added necessary include files which are not part of common header now Remove unnecessary include files
drivers/misc/sifive-otp.c +#include <linux/bitops.h> +#include <linux/delay.h>
board/sifive/fu540/fu540.c -#include <common.h> +#include <log.h>
board/sifive/fu540/spl.c +#include <init.h> +#include <log.h> +#include <linux/delay.h>
drivers/ram/sifive/fu540_ddr.c +#include <linux/bitops.h>
arch/riscv/cpu/fu540/cpu.c -#include <common.h> +#include <asm/cache.h>
arch/riscv/cpu/fu540/spl.c -#include <common.h> +#include <log.h>
board/sifive/fu540/spl.c -#include <common.h> +#include <init.h> +#include <log.h> +#include <linux/delay.h>
Update commit description for Release ethernet clock reset
Update OpenSBI building section in "doc/board/sifive/fu540.rst"
Changes in v11:
- Remove TPL related code and OF_PLATDATA from FU540 DDR driver (drivers/ram/sifive/fu540_ddr.c)
- Update FU540 doc (doc/board/sifive/fu540.rst) Remove unnecessary print
Changes in v10:
- Update commit description for ethernet clock reset (https://patchwork.ozlabs.org/patch/1289003)
- Update commit description for ddr clock initialization (https://patchwork.ozlabs.org/patch/1289000)
Changes in v9:
- Remove cache related patches from this series sifive: dts: fu540: Enable L2 Cache in U-Boot (https://patchwork.ozlabs.org/patch/1286705) riscv: sifive: fu540: enable all cache ways from U-Boot proper (https://patchwork.ozlabs.org/patch/1286706)
- Rename SiFive DDR driver from sdram_fu540.c to fu540_ddr.c and also do some typo correction in driver
- Remove CONFIG_SPL_BUILD for __prci_ddr_release_reset()
- Release ethernet clock reset instead of ethernet clock initialization (https://patchwork.ozlabs.org/patch/1286697)
- Squash fu540 cpu patches (https://patchwork.ozlabs.org/patch/1286699) (https://patchwork.ozlabs.org/patch/1286700)
- Use spl_boot_device() instead of board_boot_order()
Changes in v8:
- Remove SPL_CRC7_SUPPORT Kconfig option and compile crc7.o when CONFIG_MMC_SPI selected
- Add "TODO" in drivers/ram/sifive/sdram_fu540.c
- Remove unnecessary TODO from drivers/clk/sifive/fu540-prci.c
- Make fu540-hifive-unleashed-a00-sdram-ddr4.dtsi file dual-licensed
- Add 2 new patches sifive: fu540: Add sample SD gpt partition layout (https://patchwork.ozlabs.org/patch/1092) sifive: fu540: Add U-Boot proper sector start (https://patchwork.ozlabs.org/patch/1093)
- Remove patch riscv: Enable cpu clock if it is present (https://patchwork.ozlabs.org/patch/1281573)
- Update doc/board/sifive/fu540.rst for PLATFORM=generic
Changes in v7:
- Standardize SD gpt partition layout
- Add delay for SiFive OTP driver
- Use DM way for corepll and ddrpll
- Add new cpu fu540 (arch/riscv/cpu/fu540)
- Update document for FU540 (doc/board/sifive/fu540.rst)
Changes in v6:
- Typo Correction
- Make fu540-c000-u-boot.dtsi and hifive-unleashed-a00-u-boot.dtsi Dual Licensed
- Sync Hifive unleashed dts from Linux
- Add arch/riscv/fu540 for FU540 specific code
Changes in v5:
- Return read/write bytes for sifive_otp_read and sifive_otp_write
- Correct Palmer's email address
Changes in v4:
- Split misc DM driver patch into multiple patches
- Added new SPL_CRC7_SUPPORT Kconfig option
- Added DM driver for DDR
- Added clk_enable and clk_disable ops in SiFive PRCI driver
- Added early clock initialization for SPL in SiFive PRCI driver
- Added SPL config options in sifive_fu540_defconfig instead of creatiing a new config file for SPL
- Update fu540.rst on how to build and flash U-boot SPL
Changes in v3:
- Remove arch-fu540 and arch-sifive from arch/riscv/include/asm/
- Split SPL patches into DDR and SPL and spl defconfig
- Update fu540/MAINTAINERS file
Changes in v2:
- Add DM driver Sifive OTP
- Split SPL patches into multiple patches
- Add a seprate patch for _image_binary_end and crc7.c
- Add a seprate patch to add board -u-boot.dtsi files
- Update FU540 RISC-V documentation
Jagan Teki (2): sifive: fu540: Add sample SD gpt partition layout sifive: fu540: Add U-Boot proper sector start
Pragnesh Patel (17): misc: add driver for the SiFive otp controller riscv: sifive: fu540: Use OTP DM driver for serial environment variable riscv: Add _image_binary_end for SPL lib: Makefile: build crc7.c when CONFIG_MMC_SPI riscv: sifive: dts: fu540: Add board -u-boot.dtsi files sifive: fu540: add ddr driver sifive: dts: fu540: Add DDR controller and phy register settings riscv: sifive: dts: fu540: add U-Boot dmc node clk: sifive: fu540-prci: Add clock enable and disable ops clk: sifive: fu540-prci: Add ddr clock initialization clk: sifive: fu540-prci: Release ethernet clock reset riscv: sifive: dts: fu540: set ethernet clock rate riscv: dts: sifive: Sync hifive-unleashed-a00 dts from linux riscv: cpu: fu540: Add support for cpu fu540 riscv: sifive: fu540: add SPL configuration configs: fu540: Add config options for U-Boot SPL doc: sifive: fu540: Add description for OpenSBI generic platform
Any plan to pull this for the release?
Applied to u-boot-riscv/master! CI is running ..., will send a PR later.
Thanks, Rick
Jagan.
Rick Chen
