[PATCH] pci: When disabling pref MEM set all base bits
It is common to set all base address bits to one and all limit address bits to zero for disabling address forwarding. Forwarding is disabled when base address is higher than limit address, so this change should not have any effect.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/pci/pci_auto.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 6e5ed194f247..c0acf331398d 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -243,7 +243,7 @@ void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) cmdstat |= PCI_COMMAND_MEMORY; } else { /* We don't support prefetchable memory for now, so disable */ - dm_pci_write_config16(dev, PCI_PREF_MEMORY_BASE, 0x1000 | + dm_pci_write_config16(dev, PCI_PREF_MEMORY_BASE, 0xfff0 | prefechable_64); dm_pci_write_config16(dev, PCI_PREF_MEMORY_LIMIT, 0x0 | prefechable_64);
Again, does it make sense to add / use a macro for this 0xfff0 above?
Other than this:
Thanks, Stefan
Viele Grüße, Stefan Roese
This is again setting all range bits in this register to ones. So (~0 & PCI_PREF_RANGE_MASK) or (0xffff & PCI_PREF_RANGE_MASK).
Other than this:
Thanks, Stefan
And then 0x0 here can be expressed similarly via that macro by: (0x0 & PCI_PREF_RANGE_MASK)
It is verbose, but would follow style if want to use macros for values.
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Again, no real issue IMHO - was just checking. Perhaps someone else has more thoughts on this.
Thanks, Stefan
Other than this:
Thanks, Stefan
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Stefan Roese sr@denx.de
Pali Rohár
Stefan Roese
