[U-Boot] [PATCH] USB: gadget: save driver name before registering it
g_dnl_register() currently first attempts to register a composite driver by name, and then saves the driver name once it's registered. Internally to the registration code, g_dnl_do_config() is called and attempts to compare the composite device's name with the list of known device names. This fails since the composite device's name has not yet been stored. This means that the first time "ums 0 0" is run, it fails, but subsequent attempts succeed.
Re-order the name-saving and registration code to solve this.
Fixes: e5b834e07f51 ("USB: gadget: added a saner gadget downloader registration API") Signed-off-by: Stephen Warren swarren@nvidia.com --- This should likely be applied to u-boot-dfu/master along with Mateusz's original patch, or folded into it.
drivers/usb/gadget/g_dnl.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 743bae535ac8..25611acd607f 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -245,11 +245,12 @@ static struct usb_composite_driver g_dnl_driver = { */ int g_dnl_register(const char *name) { - int ret = usb_composite_register(&g_dnl_driver); + int ret;
debug("%s: g_dnl_driver.name = %s\n", __func__, name); g_dnl_driver.name = name;
+ ret = usb_composite_register(&g_dnl_driver); if (ret) { printf("%s: failed!, error: %d\n", __func__, ret); return ret;
Hi Stephen,
Applied to u-boot-dfu. Thanks.
Lukasz Majewski
Stephen Warren
