[U-Boot] [PATCH 0/6] x86: pci: Various bug fixes/enhancements
This series contains various bug fixes/enhancements to x86 pci related VGA card support, as a result of attempting to support booting SeaBIOS.
Bin Meng (6): pci: Set PCI_COMMAND_IO bit for VGA device video: vesa_fb: Fix wrong return value check of pci_find_class() dm: pci: Fix pci_last_busno() to return the real last bus no dm: pci: Enable VGA address forwarding on bridges x86: ivybridge: Remove the dead codes that programs pci bridge x86: Allow disabling IGD on Intel Queensbay
arch/x86/cpu/ivybridge/bd82x6x.c | 32 ----------------------- arch/x86/cpu/queensbay/Kconfig | 8 ++++++ arch/x86/cpu/queensbay/tnc.c | 19 ++++++++++++++ arch/x86/include/asm/arch-queensbay/tnc.h | 5 ++++ drivers/pci/pci-uclass.c | 43 ++++++++++++++----------------- drivers/pci/pci_auto.c | 6 +++++ drivers/video/vesa_fb.c | 2 +- include/configs/crownbay.h | 1 + 8 files changed, 59 insertions(+), 57 deletions(-)
PCI_COMMAND_IO bit must be set for VGA device as it needs to respond to legacy VGA IO address.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pci_auto.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 41d5447..e2c239e 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -89,6 +89,7 @@ void pciauto_setup_device(struct pci_controller *hose, struct pci_region *bar_res; int found_mem64 = 0; #endif + u16 class;
pci_hose_read_config_word(hose, dev, PCI_COMMAND, &cmdstat); cmdstat = (cmdstat & ~(PCI_COMMAND_IO | PCI_COMMAND_MEMORY)) | PCI_COMMAND_MASTER; @@ -205,6 +206,11 @@ void pciauto_setup_device(struct pci_controller *hose, } #endif
+ /* PCI_COMMAND_IO must be set for VGA device */ + pci_hose_read_config_word(hose, dev, PCI_CLASS_DEVICE, &class); + if (class == PCI_CLASS_DISPLAY_VGA) + cmdstat |= PCI_COMMAND_IO; + pci_hose_write_config_word(hose, dev, PCI_COMMAND, cmdstat); pci_hose_write_config_byte(hose, dev, PCI_CACHE_LINE_SIZE, CONFIG_SYS_PCI_CACHE_LINE_SIZE);
Applied to u-boot-x86, thanks!
When pci_find_class() fails to find a device, it returns -ENODEV. But now we check the return value against -1. Fix it.
drivers/video/vesa_fb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/vesa_fb.c b/drivers/video/vesa_fb.c index 4e6d070..a19651f 100644 --- a/drivers/video/vesa_fb.c +++ b/drivers/video/vesa_fb.c @@ -34,7 +34,7 @@ void *video_hw_init(void) } if (vbe_get_video_info(gdev)) { dev = pci_find_class(PCI_CLASS_DISPLAY_VGA << 8, 0); - if (dev == -1) { + if (dev < 0) { printf("no card detected\n"); return NULL; }
Acked-by: Anatolij Gustschin agust@denx.de
Currently pci_last_busno() only checks the last bridge device under the first UCLASS_PCI device. This is not the case when there are multiple bridge devices.
drivers/pci/pci-uclass.c | 25 +------------------------ 1 file changed, 1 insertion(+), 24 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 0756bbe..0035ac7 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -85,30 +85,7 @@ static int pci_get_bus_max(void)
int pci_last_busno(void) { - struct pci_controller *hose; - struct udevice *bus; - struct uclass *uc; - int ret; - - debug("pci_last_busno\n"); - ret = uclass_get(UCLASS_PCI, &uc); - if (ret || list_empty(&uc->dev_head)) - return -1; - - /* Probe the last bus */ - bus = list_entry(uc->dev_head.prev, struct udevice, uclass_node); - debug("bus = %p, %s\n", bus, bus->name); - assert(bus); - ret = device_probe(bus); - if (ret) - return ret; - - /* If that bus has bridges, we may have new buses now. Get the last */ - bus = list_entry(uc->dev_head.prev, struct udevice, uclass_node); - hose = dev_get_uclass_priv(bus); - debug("bus = %s, hose = %p\n", bus->name, hose); - - return hose->last_busno; + return pci_get_bus_max(); }
int pci_get_ff(enum pci_size_t size)
To support graphics card behind a PCI bridge, the bridge control register (offset 0x3e) in the configuration space must turn on VGA address forwarding.
drivers/pci/pci-uclass.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 0035ac7..7b01a13 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -364,9 +364,23 @@ int dm_pci_read_config32(struct udevice *dev, int offset, u32 *valuep) return 0; }
+static void set_vga_bridge_bits(struct udevice *dev) +{ + struct udevice *parent = dev->parent; + u16 bc; + + while (parent->seq != 0) { + dm_pci_read_config16(parent, PCI_BRIDGE_CONTROL, &bc); + bc |= PCI_BRIDGE_CTL_VGA; + dm_pci_write_config16(parent, PCI_BRIDGE_CONTROL, bc); + parent = parent->parent; + } +} + int pci_auto_config_devices(struct udevice *bus) { struct pci_controller *hose = bus->uclass_priv; + struct pci_child_platdata *pplat; unsigned int sub_bus; struct udevice *dev; int ret; @@ -382,6 +396,10 @@ int pci_auto_config_devices(struct udevice *bus) debug("%s: device %s\n", __func__, dev->name); max_bus = pciauto_config_device(hose, pci_get_bdf(dev)); sub_bus = max(sub_bus, max_bus); + + pplat = dev_get_parent_platdata(dev); + if (pplat->class == (PCI_CLASS_DISPLAY_VGA << 8)) + set_vga_bridge_bits(dev); } debug("%s: done\n", __func__);
Remove bd82x6x_pci_bus_enable_resources() that is not called anywhere.
arch/x86/cpu/ivybridge/bd82x6x.c | 32 -------------------------------- 1 file changed, 32 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index ca8cccf..3e7a907 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -55,38 +55,6 @@ void bd82x6x_pci_init(pci_dev_t dev) x86_pci_write_config16(dev, SECSTS, reg16); }
-#define PCI_BRIDGE_UPDATE_COMMAND -void bd82x6x_pci_dev_enable_resources(pci_dev_t dev) -{ - uint16_t command; - - command = x86_pci_read_config16(dev, PCI_COMMAND); - command |= PCI_COMMAND_IO; -#ifdef PCI_BRIDGE_UPDATE_COMMAND - /* - * If we write to PCI_COMMAND, on some systems this will cause the - * ROM and APICs to become invisible. - */ - debug("%x cmd <- %02x\n", dev, command); - x86_pci_write_config16(dev, PCI_COMMAND, command); -#else - printf("%s cmd <- %02x (NOT WRITTEN!)\n", dev_path(dev), command); -#endif -} - -void bd82x6x_pci_bus_enable_resources(pci_dev_t dev) -{ - uint16_t ctrl; - - ctrl = x86_pci_read_config16(dev, PCI_BRIDGE_CONTROL); - ctrl |= PCI_COMMAND_IO; - ctrl |= PCI_BRIDGE_CTL_VGA; - debug("%x bridge ctrl <- %04x\n", dev, ctrl); - x86_pci_write_config16(dev, PCI_BRIDGE_CONTROL, ctrl); - - bd82x6x_pci_dev_enable_resources(dev); -} - static int bd82x6x_probe(struct udevice *dev) { const void *blob = gd->fdt_blob;
Add a Kconfig option to disable the Integrated Graphics Device (IGD) so that it does not show in the PCI configuration space as a VGA disaplay controller. This gives a chance for U-Boot to run PCI/PCIe based graphics card's VGA BIOS and use that for the graphics console.
arch/x86/cpu/queensbay/Kconfig | 8 ++++++++ arch/x86/cpu/queensbay/tnc.c | 19 +++++++++++++++++++ arch/x86/include/asm/arch-queensbay/tnc.h | 5 +++++ include/configs/crownbay.h | 1 + 4 files changed, 33 insertions(+)
diff --git a/arch/x86/cpu/queensbay/Kconfig b/arch/x86/cpu/queensbay/Kconfig index fbf85f2..6136d75 100644 --- a/arch/x86/cpu/queensbay/Kconfig +++ b/arch/x86/cpu/queensbay/Kconfig @@ -42,4 +42,12 @@ config CPU_ADDR_BITS int default 32
+config DISABLE_IGD + bool "Disable Integrated Graphics Device (IGD)" + help + Disable the Integrated Graphics Device (IGD) so that it does not + show in the PCI configuration space as a VGA disaplay controller. + This gives a chance for U-Boot to run PCI/PCIe based graphics + card's VGA BIOS and use that card for the graphics console. + endif diff --git a/arch/x86/cpu/queensbay/tnc.c b/arch/x86/cpu/queensbay/tnc.c index 9682cff..0c02a44 100644 --- a/arch/x86/cpu/queensbay/tnc.c +++ b/arch/x86/cpu/queensbay/tnc.c @@ -23,6 +23,16 @@ static void unprotect_spi_flash(void) x86_pci_write_config32(TNC_LPC, 0xd8, bc); }
+static void __maybe_unused disable_igd(void) +{ + u32 gc; + + gc = x86_pci_read_config32(TNC_IGD, IGD_GC); + gc &= ~GMS_MASK; + gc |= VGA_DISABLE; + x86_pci_write_config32(TNC_IGD, IGD_GC, gc); +} + int arch_cpu_init(void) { int ret; @@ -39,6 +49,15 @@ int arch_cpu_init(void) return 0; }
+int arch_early_init_r(void) +{ +#ifdef CONFIG_DISABLE_IGD + disable_igd(); +#endif + + return 0; +} + void cpu_irq_init(void) { struct tnc_rcba *rcba; diff --git a/arch/x86/include/asm/arch-queensbay/tnc.h b/arch/x86/include/asm/arch-queensbay/tnc.h index ad9a6c4..2365394 100644 --- a/arch/x86/include/asm/arch-queensbay/tnc.h +++ b/arch/x86/include/asm/arch-queensbay/tnc.h @@ -7,6 +7,11 @@ #ifndef _X86_ARCH_TNC_H_ #define _X86_ARCH_TNC_H_
+/* IGD Control Register */ +#define IGD_GC 0x50 +#define VGA_DISABLE 0x00020000 +#define GMS_MASK 0x00700000 + /* Memory BAR Enable */ #define MEM_BAR_EN 0x00000001
diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h index 3153a74..7f91fff 100644 --- a/include/configs/crownbay.h +++ b/include/configs/crownbay.h @@ -15,6 +15,7 @@
#define CONFIG_SYS_MONITOR_LEN (1 << 20) #define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_ARCH_MISC_INIT
#define CONFIG_SMSC_LPC47M
Hi Bin,
But do we really want configs for such device-specific things? I wonder if device tree would be better. E.g. add 'status = "disabled"' in the PCI node.
+config DISABLE_IGD
help
u32 gc;
gc &= ~GMS_MASK;
gc |= VGA_DISABLE;
disable_igd();
1.8.2.1
Hi Simon,
On Sat, Oct 3, 2015 at 10:29 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
I am not sure if I understand you correctly. To me 'status = "disabled"' is a generic device binding, and when it comes to PCI device, how do we define a device is in a 'disabled' state? Is it we program the COMMAND register to disable bus master, mem and I/O access? Or we program a chipset-specific register (Intel chipset normally has such) to make it invisible from PCI configuration space completely? And as you said, this is really chipset-specific thing, so I chose to do via a platform-specific configuration macro, instead of doing such work under a generic bindings ..
[snip]
Regards, Bin
Hi Bin,
On 7 October 2015 at 09:24, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Yes we don't have a good way to notice that a driver is disabled - it will never be bound in that case.
If there were a driver for the SoC, then perhaps we could add config options to that node. Then the chipset-specific SoC driver could do the required init.
Hi Bin,
+config DISABLE_IGD
help
u32 gc;
gc &= ~GMS_MASK;
gc |= VGA_DISABLE;
disable_igd();
1.8.2.1
Anatolij Gustschin
Bin Meng
