[U-Boot] [PATCH REPOST] ARM: tegra: use standard variables to define load addresses
Currently, Tegra's default environment uses non-standard variables to define where boot scripts should load the kernel, FDT, and initrd. This change both changes the variable names to match those described in U-Boot's README, and shuffles their values around a little so that the values make a little more sense; see comments in the patch for rationale behind the values chosen.
Note that this patch does remove the old non-standard variable "fdt_load" from the default environment, so this patch requires people to change their boot scripts.
Signed-off-by: Stephen Warren swarren@nvidia.com Acked-by: Simon Glass sjg@chromium.org --- include/configs/tegra-common-post.h | 31 ++++++++++++++++++++++++++++--- 1 files changed, 28 insertions(+), 3 deletions(-)
diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 1e7aea9..048ecbb 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -95,8 +95,6 @@ #endif
#define BOOTCMDS_COMMON \ - "scriptaddr=0x400000\0" \ - \ "rootpart=1\0" \ \ "script_boot=" \ @@ -140,9 +138,36 @@
#endif
+/* + * Memory layout for where various images get loaded by boot scripts: + * + * scriptaddr can be pretty much anywhere that doesn't conflict with something + * else. Put it above BOOTMAPSZ to eliminate conflicts. + * + * kernel_addr_r must be within the first 128M of RAM in order for the + * kernel's CONFIG_AUTO_ZRELADDR option to work. Since the kernel will + * decompress itself to 0x8000 after the start of RAM, kernel_addr_r + * should not overlap that area, or the kernel will have to copy itself + * somewhere else before decompression. Similarly, the address of any other + * data passed to the kernel shouldn't overlap the start of RAM. Pushing + * this up to 16M allows for a sizable kernel to be decompressed below the + * compressed load address. + * + * fdt_addr_r simply shouldn't overlap anything else. Choosing 32M allows for + * the compressed kernel to be up to 16M too. + * + * ramdisk_addr_r simply shouldn't overlap anything else. Choosing 33M allows + * for the FDT/DTB to be up to 1M, which is hopefully plenty. + */ +#define MEM_LAYOUT_ENV_SETTINGS \ + "scriptaddr=0x10000000\0" \ + "kernel_addr_r=0x01000000\0" \ + "fdt_addr_r=0x02000000\0" \ + "ramdisk_addr_r=0x02100000\0" \ + #define CONFIG_EXTRA_ENV_SETTINGS \ TEGRA_DEVICE_SETTINGS \ - "fdt_load=0x01000000\0" \ + MEM_LAYOUT_ENV_SETTINGS \ BOOTCMDS_COMMON
/* overrides for SPL build here */
Stephen Warren
