[PATCH v1 0/4] Fix rtl8169 compile warning and add a new device ID
StarFive JH7110 uboot support PCIe and using rtl8169 network adapter PCIe device. But compile warning in rtl8169 driver cause CI test fail. So commit this patch set to fix it, Also a new device ID to adjust the PCI bar regions in rtl8169.
The StarFive JH7110 PCIe driver link: https://patchwork.ozlabs.org/project/uboot/cover/20230509082617.119018-1-min...
patch 1 is fix make pointer from integer warning. eg: /home/minda/vf2/visionfive/u-boot/drivers/net/rtl8169.c:103:52: warning: passing argument 2 of ‘writew’ makes pointer from integer without a cast [-Wint-conversion] patch 2 fix RISC-V 8169 descriptor less than DMA min aligned size warning patch 3 add new device ID patch 4 enable 8169 in JH7110 SoC configs file.
Minda Chen (4): net: rtl8169: Fix compile warning in rtl8169 network adapter net: rtl8169: Fix DMA min aligned compile warning in riscv net: rtl8169: Add one more device ID configs: starfive-jh7110: Add CONFIG_RTL8169
configs/starfive_visionfive2_defconfig | 1 + drivers/net/rtl8169.c | 22 +++++++++++++--------- 2 files changed, 14 insertions(+), 9 deletions(-)
base-commit: 50842b217fef505a0ec6662cc2acdc55d0bb23c5
Fix make pointer from integer without a cast compile warning.
Signed-off-by: Minda Chen minda.chen@starfivetech.com --- drivers/net/rtl8169.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index 2276a465e7..dcba51590d 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -96,12 +96,12 @@ static int media[MAX_UNITS] = { -1, -1, -1, -1, -1, -1, -1, -1 }; #define TX_TIMEOUT (6*HZ)
/* write/read MMIO register. Notice: {read,write}[wl] do the necessary swapping */ -#define RTL_W8(reg, val8) writeb((val8), ioaddr + (reg)) -#define RTL_W16(reg, val16) writew((val16), ioaddr + (reg)) -#define RTL_W32(reg, val32) writel((val32), ioaddr + (reg)) -#define RTL_R8(reg) readb(ioaddr + (reg)) -#define RTL_R16(reg) readw(ioaddr + (reg)) -#define RTL_R32(reg) readl(ioaddr + (reg)) +#define RTL_W8(reg, val8) writeb((val8), (void *)(ioaddr + (reg))) +#define RTL_W16(reg, val16) writew((val16), (void *)(ioaddr + (reg))) +#define RTL_W32(reg, val32) writel((val32), (void *)(ioaddr + (reg))) +#define RTL_R8(reg) readb((void *)(ioaddr + (reg))) +#define RTL_R16(reg) readw((void *)(ioaddr + (reg))) +#define RTL_R32(reg) readl((void *)(ioaddr + (reg)))
#define bus_to_phys(a) pci_mem_to_phys((pci_dev_t)(unsigned long)dev->priv, \ (pci_addr_t)(unsigned long)a)
On Wed, Jun 21, 2023 at 12:05 PM Minda Chen minda.chen@starfivetech.com wrote:
#define bus_to_phys(a) pci_mem_to_phys((pci_dev_t)(unsigned long)dev->priv, \ (pci_addr_t)(unsigned long)a) -- 2.17.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Fix rtl8169 descriptor less the DMA min aligned compile warning for RISC-V SoC platform.
Signed-off-by: Minda Chen minda.chen@starfivetech.com --- drivers/net/rtl8169.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index dcba51590d..34e4cff1e9 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -311,10 +311,12 @@ static unsigned char rxdata[RX_BUF_LEN]; * * This can be fixed by defining CONFIG_SYS_NONCACHED_MEMORY which will cause * the driver to allocate descriptors from a pool of non-cached memory. + * + * Hardware maintain D-cache coherency in RISC-V architecture. */ #if RTL8169_DESC_SIZE < ARCH_DMA_MINALIGN #if !defined(CONFIG_SYS_NONCACHED_MEMORY) && \ - !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) && !defined(CONFIG_X86) + !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) && !defined(CONFIG_X86) && !defined(CONFIG_RISCV) #warning cache-line size is larger than descriptor size #endif #endif
- This can be fixed by defining CONFIG_SYS_NONCACHED_MEMORY which will cause
- the driver to allocate descriptors from a pool of non-cached memory.
- Hardware maintain D-cache coherency in RISC-V architecture.
#endif
2.17.1
Add the NIC device ID and adjust the PCI bar regions.
Signed-off-by: Minda Chen minda.chen@starfivetech.com --- drivers/net/rtl8169.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index 34e4cff1e9..963702777c 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -353,10 +353,11 @@ static const unsigned int rtl8169_rx_config = (RX_FIFO_THRESH << RxCfgFIFOShift) | (RX_DMA_BURST << RxCfgDMAShift);
static struct pci_device_id supported[] = { + { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8125) }, + { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8161) }, { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8167) }, { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8168) }, { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8169) }, - { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8125) }, {} };
@@ -1051,8 +1052,9 @@ static int rtl8169_eth_probe(struct udevice *dev) int ret;
switch (pplat->device) { - case 0x8168: case 0x8125: + case 0x8161: + case 0x8168: region = 2; break; default:
case 0x8161:
-- 2.17.1
Add PCIe device rtl8169 net adapter driver support.
Signed-off-by: Minda Chen minda.chen@starfivetech.com --- configs/starfive_visionfive2_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index ffbc4b9476..360160200f 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_RTL8169=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y
Hi Joe and Ramon
Sorry to disturb you. Could you please review this patchset. Thanks
Minda Chen
Ramon Fried
