Pull request for UEFI sub-system for efi-2021-04-rc2
Dear Tom,
The following changes since commit fdcb93e1709ab1a2ebb562455621617c29e2099c:
Merge branch '2021-02-01-assorted-fixes' (2021-02-02 09:24:10 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2021-04-rc2
for you to fetch changes up to 5489448cd7d46554f7f45a180754be78eff9f54d:
doc: dm: describe end of life of plat_auto (2021-02-04 20:36:07 +0100)
Gitlab CI showed no problems: https://gitlab.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/6216
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2021-04-rc2
Bug fixes:
* do not allow creating of files with filenames on FAT file system * install UEFI System Partition GUID on ESP handle * in dtbdump.efi test tool use GUID to find ESP handle
Documentation:
* man-page for load command * describe end of life of plat_auto
---------------------------------------------------------------- Heinrich Schuchardt (10): fs: fat: usage basename in file_fat_write_at, fat_mkdir fs: fat: must not write directory '.' and '..' fs: fat: remove trailing periods from long name efi_loader: only check size if EFI_DT_APPLY_FIXUPS efi_loader: install UEFI System Partition GUID efi_selftest: use GUID to find ESP in dtbdump efi_loader: VenMedia device path node doc: describe load command doc: return value exception command doc: dm: describe end of life of plat_auto
cmd/efidebug.c | 5 ++ doc/driver-model/design.rst | 6 +-- doc/usage/exception.rst | 5 -- doc/usage/index.rst | 1 + doc/usage/load.rst | 74 +++++++++++++++++++++++++++ fs/fat/fat_write.c | 70 ++++++++++++++++---------- lib/efi_loader/efi_device_path_to_text.c | 15 ++++++ lib/efi_loader/efi_disk.c | 15 +++--- lib/efi_loader/efi_dt_fixup.c | 25 +++++----- lib/efi_selftest/dtbdump.c | 85 +++++++++++++++++++------------- 10 files changed, 214 insertions(+), 87 deletions(-) create mode 100644 doc/usage/load.rst
On Thu, Feb 04, 2021 at 09:26:06PM +0100, Heinrich Schuchardt wrote:
Dear Tom,
