[U-Boot] [PATCH 0/2] vf610: Add I2C support for Freescale Vybrid VF610 platform
This series contain the I2C support for Freescale Vybrid VF610 platform and VF610TWR board.
Alison Wang (2): vf610: Add I2C support for Vybrid VF610 platform I2C: mxc_i2c: Add support for Vybrid VF610 platform
arch/arm/cpu/armv7/vf610/generic.c | 7 +++++++ arch/arm/include/asm/arch-vf610/clock.h | 1 + arch/arm/include/asm/arch-vf610/crm_regs.h | 1 + arch/arm/include/asm/arch-vf610/imx-regs.h | 1 + arch/arm/include/asm/arch-vf610/iomux-vf610.h | 4 ++++ board/freescale/vf610twr/vf610twr.c | 14 +++++++++++++- drivers/i2c/mxc_i2c.c | 62 +++++++++++++++++++++++++++++++++++++++++++++++++++++++------- include/configs/vf610twr.h | 7 +++++++ 8 files changed, 89 insertions(+), 8 deletions(-)
This patch adds I2C support for Vybrid VF610 platform and adds I2C0 support to VF610TWR board.
Signed-off-by: Alison Wang b18965@freescale.com --- arch/arm/cpu/armv7/vf610/generic.c | 7 +++++++ arch/arm/include/asm/arch-vf610/clock.h | 1 + arch/arm/include/asm/arch-vf610/crm_regs.h | 1 + arch/arm/include/asm/arch-vf610/imx-regs.h | 1 + arch/arm/include/asm/arch-vf610/iomux-vf610.h | 4 ++++ board/freescale/vf610twr/vf610twr.c | 14 +++++++++++++- include/configs/vf610twr.h | 7 +++++++ 7 files changed, 34 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index 87f2a86..f6ef495 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -204,6 +204,11 @@ u32 get_fec_clk(void) return freq; }
+static u32 get_i2c_clk(void) +{ + return get_ipg_clk(); +} + unsigned int mxc_get_clock(enum mxc_clock clk) { switch (clk) { @@ -219,6 +224,8 @@ unsigned int mxc_get_clock(enum mxc_clock clk) return get_sdhc_clk(); case MXC_FEC_CLK: return get_fec_clk(); + case MXC_I2C_CLK: + return get_i2c_clk(); default: break; } diff --git a/arch/arm/include/asm/arch-vf610/clock.h b/arch/arm/include/asm/arch-vf610/clock.h index 04e418c..3cbae0b 100644 --- a/arch/arm/include/asm/arch-vf610/clock.h +++ b/arch/arm/include/asm/arch-vf610/clock.h @@ -29,6 +29,7 @@ enum mxc_clock { MXC_UART_CLK, MXC_ESDHC_CLK, MXC_FEC_CLK, + MXC_I2C_CLK, };
void enable_ocotp_clk(unsigned char enable); diff --git a/arch/arm/include/asm/arch-vf610/crm_regs.h b/arch/arm/include/asm/arch-vf610/crm_regs.h index e3f703d..6a67eb0 100644 --- a/arch/arm/include/asm/arch-vf610/crm_regs.h +++ b/arch/arm/include/asm/arch-vf610/crm_regs.h @@ -190,6 +190,7 @@ struct anadig_reg { #define CCM_CCGR4_WKUP_CTRL_MASK (0x3 << 20) #define CCM_CCGR4_CCM_CTRL_MASK (0x3 << 22) #define CCM_CCGR4_GPC_CTRL_MASK (0x3 << 24) +#define CCM_CCGR4_I2C0_CTRL_MASK (0x3 << 12) #define CCM_CCGR6_OCOTP_CTRL_MASK (0x3 << 10) #define CCM_CCGR6_DDRMC_CTRL_MASK (0x3 << 28) #define CCM_CCGR7_SDHC1_CTRL_MASK (0x3 << 4) diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index c9df32a..742e20a 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -103,6 +103,7 @@ #define CONFIG_IOMUX_SHARE_CONF_REG
#define FEC_QUIRK_ENET_MAC +#define I2C_QUIRK_REG
/* MSCM interrupt rounter */ #define MSCM_IRSPRC_CP0_EN 1 diff --git a/arch/arm/include/asm/arch-vf610/iomux-vf610.h b/arch/arm/include/asm/arch-vf610/iomux-vf610.h index 1c728fa..7aeadce 100644 --- a/arch/arm/include/asm/arch-vf610/iomux-vf610.h +++ b/arch/arm/include/asm/arch-vf610/iomux-vf610.h @@ -30,6 +30,8 @@ #define VF610_ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_50ohm | \ PAD_CTL_OBE_IBE_ENABLE) #define VF610_DDR_PAD_CTRL PAD_CTL_DSE_25ohm +#define VF610_I2C_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_50ohm | \ + PAD_CTL_SPEED_HIGH | PAD_CTL_OBE_IBE_ENABLE)
enum { VF610_PAD_PTA6__RMII0_CLKIN = IOMUX_PAD(0x0000, 0x0000, 2, __NA_, 0, VF610_ENET_PAD_CTRL), @@ -50,6 +52,8 @@ enum { VF610_PAD_PTA27__ESDHC1_DAT1 = IOMUX_PAD(0x0044, 0x0044, 5, __NA_, 0, VF610_SDHC_PAD_CTRL), VF610_PAD_PTA28__ESDHC1_DAT2 = IOMUX_PAD(0x0048, 0x0048, 5, __NA_, 0, VF610_SDHC_PAD_CTRL), VF610_PAD_PTA29__ESDHC1_DAT3 = IOMUX_PAD(0x004c, 0x004c, 5, __NA_, 0, VF610_SDHC_PAD_CTRL), + VF610_PAD_PTB14__I2C0_SCL = IOMUX_PAD(0x0090, 0x0090, 2, 0x033c, 1, VF610_I2C_PAD_CTRL), + VF610_PAD_PTB15__I2C0_SDA = IOMUX_PAD(0x0094, 0x0094, 2, 0x0340, 1, VF610_I2C_PAD_CTRL), VF610_PAD_DDR_A15__DDR_A_15 = IOMUX_PAD(0x0220, 0x0220, 0, __NA_, 0, VF610_DDR_PAD_CTRL), VF610_PAD_DDR_A14__DDR_A_14 = IOMUX_PAD(0x0224, 0x0224, 0, __NA_, 0, VF610_DDR_PAD_CTRL), VF610_PAD_DDR_A13__DDR_A_13 = IOMUX_PAD(0x0228, 0x0228, 0, __NA_, 0, VF610_DDR_PAD_CTRL), diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index f14df8b..391f97e 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -27,6 +27,7 @@ #include <fsl_esdhc.h> #include <miiphy.h> #include <netdev.h> +#include <i2c.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -280,6 +281,16 @@ static void setup_iomux_enet(void) imx_iomux_v3_setup_multiple_pads(enet0_pads, ARRAY_SIZE(enet0_pads)); }
+static void setup_iomux_i2c(void) +{ + static const iomux_v3_cfg_t i2c0_pads[] = { + VF610_PAD_PTB14__I2C0_SCL, + VF610_PAD_PTB15__I2C0_SDA, + }; + + imx_iomux_v3_setup_multiple_pads(i2c0_pads, ARRAY_SIZE(i2c0_pads)); +} + #ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[1] = { {ESDHC1_BASE_ADDR}, @@ -328,7 +339,7 @@ static void clock_init(void) CCM_CCGR3_ANADIG_CTRL_MASK); clrsetbits_le32(&ccm->ccgr4, CCM_REG_CTRL_MASK, CCM_CCGR4_WKUP_CTRL_MASK | CCM_CCGR4_CCM_CTRL_MASK | - CCM_CCGR4_GPC_CTRL_MASK); + CCM_CCGR4_GPC_CTRL_MASK | CCM_CCGR4_I2C0_CTRL_MASK); clrsetbits_le32(&ccm->ccgr6, CCM_REG_CTRL_MASK, CCM_CCGR6_OCOTP_CTRL_MASK | CCM_CCGR6_DDRMC_CTRL_MASK); clrsetbits_le32(&ccm->ccgr7, CCM_REG_CTRL_MASK, @@ -387,6 +398,7 @@ int board_early_init_f(void)
setup_iomux_uart(); setup_iomux_enet(); + setup_iomux_i2c();
return 0; } diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 77fe893..cc9e56f 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -81,6 +81,13 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_MICREL
+/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_HARD_I2C +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_BASE I2C0_BASE_ADDR +#define CONFIG_SYS_I2C_SPEED 100000 + #define CONFIG_BOOTDELAY 3
#define CONFIG_SYS_TEXT_BASE 0x3f008000
This patch adds support for Vybrid VF610 platform.
There are some differences between i.MX6 and Vybrid for I2C controller. (1) The registers' offset are different. (2) The I2C clock divider values are different. (3) In I2C control register, the enable/disable/reset bit is inverted for Vybrid comparing to i.MX6. (4) In I2C status register, the interrupt flag bit is cleared by writing "1" for Vybrid. For i.MX6, this bit is cleared by writing "0". (5) In I2C status register, the arbitration lost flag bit is cleared by writing "1" for Vybrid. For i.MX6, this bit is cleared by writing "0".
Signed-off-by: Alison Wang b18965@freescale.com --- drivers/i2c/mxc_i2c.c | 62 +++++++++++++++++++++++++++++++++++++++++++++------ 1 file changed, 55 insertions(+), 7 deletions(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index a73b10b..85e3e8b 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -38,6 +38,15 @@ #include <i2c.h> #include <watchdog.h>
+#ifdef I2C_QUIRK_REG +struct mxc_i2c_regs { + uint8_t iadr; + uint8_t ifdr; + uint8_t i2cr; + uint8_t i2sr; + uint8_t i2dr; +}; +#else struct mxc_i2c_regs { uint32_t iadr; uint32_t ifdr; @@ -45,8 +54,8 @@ struct mxc_i2c_regs { uint32_t i2sr; uint32_t i2dr; }; +#endif
-#define I2CR_IEN (1 << 7) #define I2CR_IIEN (1 << 6) #define I2CR_MSTA (1 << 5) #define I2CR_MTX (1 << 4) @@ -59,10 +68,39 @@ struct mxc_i2c_regs { #define I2SR_IIF (1 << 1) #define I2SR_RX_NO_AK (1 << 0)
+#ifdef I2C_QUIRK_REG +#define I2CR_IEN (0 << 7) +#define I2CR_IDIS (1 << 7) +#define I2SR_IIF_CLEAR (1 << 1) +#else +#define I2CR_IEN (1 << 7) +#define I2CR_IDIS (0 << 7) +#define I2SR_IIF_CLEAR (0 << 1) +#endif + #if defined(CONFIG_HARD_I2C) && !defined(CONFIG_SYS_I2C_BASE) #error "define CONFIG_SYS_I2C_BASE to use the mxc_i2c driver" #endif
+#ifdef I2C_QUIRK_REG +static u16 i2c_clk_div[60][2] = { + { 20, 0x00 }, { 22, 0x01 }, { 24, 0x02 }, { 26, 0x03 }, + { 28, 0x04 }, { 30, 0x05 }, { 32, 0x09 }, { 34, 0x06 }, + { 36, 0x0A }, { 40, 0x07 }, { 44, 0x0C }, { 48, 0x0D }, + { 52, 0x43 }, { 56, 0x0E }, { 60, 0x45 }, { 64, 0x12 }, + { 68, 0x0F }, { 72, 0x13 }, { 80, 0x14 }, { 88, 0x15 }, + { 96, 0x19 }, { 104, 0x16 }, { 112, 0x1A }, { 128, 0x17 }, + { 136, 0x4F }, { 144, 0x1C }, { 160, 0x1D }, { 176, 0x55 }, + { 192, 0x1E }, { 208, 0x56 }, { 224, 0x22 }, { 228, 0x24 }, + { 240, 0x1F }, { 256, 0x23 }, { 288, 0x5C }, { 320, 0x25 }, + { 384, 0x26 }, { 448, 0x2A }, { 480, 0x27 }, { 512, 0x2B }, + { 576, 0x2C }, { 640, 0x2D }, { 768, 0x31 }, { 896, 0x32 }, + { 960, 0x2F }, { 1024, 0x33 }, { 1152, 0x34 }, { 1280, 0x35 }, + { 1536, 0x36 }, { 1792, 0x3A }, { 1920, 0x37 }, { 2048, 0x3B }, + { 2304, 0x3C }, { 2560, 0x3D }, { 3072, 0x3E }, { 3584, 0x7A }, + { 3840, 0x3F }, { 4096, 0x7B }, { 5120, 0x7D }, { 6144, 0x7E }, +}; +#else static u16 i2c_clk_div[50][2] = { { 22, 0x20 }, { 24, 0x21 }, { 26, 0x22 }, { 28, 0x23 }, { 30, 0x00 }, { 32, 0x24 }, { 36, 0x25 }, { 40, 0x26 }, @@ -78,6 +116,7 @@ static u16 i2c_clk_div[50][2] = { { 1920, 0x1B }, { 2048, 0x3F }, { 2304, 0x1C }, { 2560, 0x1D }, { 3072, 0x1E }, { 3840, 0x1F } }; +#endif
/* * Calculate and set proper clock divider @@ -125,7 +164,7 @@ static int bus_i2c_set_bus_speed(void *base, int speed) writeb(idx, &i2c_regs->ifdr);
/* Reset module */ - writeb(0, &i2c_regs->i2cr); + writeb(I2CR_IDIS, &i2c_regs->i2cr); writeb(0, &i2c_regs->i2sr); return 0; } @@ -157,7 +196,11 @@ static int wait_for_sr_state(struct mxc_i2c_regs *i2c_regs, unsigned state) for (;;) { sr = readb(&i2c_regs->i2sr); if (sr & I2SR_IAL) { +#ifdef I2C_QUIRK_REG + writeb(sr | I2SR_IAL, &i2c_regs->i2sr); +#else writeb(sr & ~I2SR_IAL, &i2c_regs->i2sr); +#endif printf("%s: Arbitration lost sr=%x cr=%x state=%x\n", __func__, sr, readb(&i2c_regs->i2cr), state); return -ERESTART; @@ -178,7 +221,7 @@ static int tx_byte(struct mxc_i2c_regs *i2c_regs, u8 byte) { int ret;
- writeb(0, &i2c_regs->i2sr); + writeb(I2SR_IIF_CLEAR, &i2c_regs->i2sr); writeb(byte, &i2c_regs->i2dr); ret = wait_for_sr_state(i2c_regs, ST_IIF); if (ret < 0) @@ -214,14 +257,18 @@ static int i2c_init_transfer_(struct mxc_i2c_regs *i2c_regs, int ret;
/* Enable I2C controller */ +#ifdef I2C_QUIRK_REG + if (readb(&i2c_regs->i2cr) & I2CR_IDIS) { +#else if (!(readb(&i2c_regs->i2cr) & I2CR_IEN)) { +#endif writeb(I2CR_IEN, &i2c_regs->i2cr); /* Wait for controller to be stable */ udelay(50); } if (readb(&i2c_regs->iadr) == (chip << 1)) writeb((chip << 1) ^ 2, &i2c_regs->iadr); - writeb(0, &i2c_regs->i2sr); + writeb(I2SR_IIF_CLEAR, &i2c_regs->i2sr); ret = wait_for_sr_state(i2c_regs, ST_BUS_IDLE); if (ret < 0) return ret; @@ -269,7 +316,8 @@ static int i2c_init_transfer(struct mxc_i2c_regs *i2c_regs, printf("%s: failed for chip 0x%x retry=%d\n", __func__, chip, retry); if (ret != -ERESTART) - writeb(0, &i2c_regs->i2cr); /* Disable controller */ + /* Disable controller */ + writeb(I2CR_IDIS, &i2c_regs->i2cr); udelay(100); if (i2c_idle_bus(i2c_regs) < 0) break; @@ -309,7 +357,7 @@ int bus_i2c_read(void *base, uchar chip, uint addr, int alen, uchar *buf, if (len == 1) temp |= I2CR_TX_NO_AK; writeb(temp, &i2c_regs->i2cr); - writeb(0, &i2c_regs->i2sr); + writeb(I2SR_IIF_CLEAR, &i2c_regs->i2sr); readb(&i2c_regs->i2dr); /* dummy read to clear ICF */
/* read data */ @@ -331,7 +379,7 @@ int bus_i2c_read(void *base, uchar chip, uint addr, int alen, uchar *buf, temp |= I2CR_TX_NO_AK; writeb(temp, &i2c_regs->i2cr); } - writeb(0, &i2c_regs->i2sr); + writeb(I2SR_IIF_CLEAR, &i2c_regs->i2sr); buf[i] = readb(&i2c_regs->i2dr); } i2c_imx_stop(i2c_regs);
Hi, Stefano, Heiko,
What's your suggestions about my two patches?
Thanks!
Best Regards, Alison Wang
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Alison Wang Sent: Monday, June 17, 2013 3:31 PM To: sbabic@denx.de; Estevam Fabio-R49496; Liu Hui-R64343 Cc: u-boot@lists.denx.de Subject: [U-Boot] [PATCH 0/2] vf610: Add I2C support for Freescale Vybrid VF610 platform
Alison Wang
Wang Huan-B18965
