[U-Boot] Pull request: u-boot-arm/master -- from a temporary repository
Hello Tom,
The following changes since commit aaf5e825606a70ddc8fca8e366d8c16a6fd3cc7c:
Merge branch 'master' of git://git.denx.de/u-boot-nds32 (2013-07-25 08:51:51 -0400)
git://88.191.163.10/u-boot-arm master
for you to fetch changes up to 9ed887caecb9ecb0c68773a1870d143b9f28d3da:
Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' (2013-08-17 18:24:13 +0200)
Albert ARIBAUD (2): Merge branch 'u-boot/master' into u-boot-arm/master Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'
Andreas Bießmann (1): omap3/sys_info: fix printout of OMAP36XX L3 freqency
Ash Charles (1): omap: overo: Use 200MHz SDRC timings for revision 1, 2 & 3 boards
Christian Riesch (1): da850evm: Use clrbits function with correct endianess
Dan Murphy (2): gpio: tca642x: Add the tca642x gpio expander driver gpio: omap5-uevm: Configure the tca6424 gpio expander
Dinh Nguyen (1): socfpga: Move board/socfpga_cyclone5 to board/socfpga
Dirk Behme (1): mxc_gpio: Correct the GPIO handling in gpio_direction_output()
Enric Balletbo i Serra (5): ARM: IGEP0033: Remove undef of CONFIG_CMD_MEMTEST ARM: IGEP0033: Remove CYGNUS name from header. ARM: IGEP0033: Add support to boot from NAND. ARM: IGEP0033: Remove duplicate / unused #defines. ARM: igep00x0.h: Enable the use of CMD_EXT4, CMD_FS_GENERIC and zImage.
Enric Balletbò i Serra (1): ARM: IGEP0033: Add support for Flattened Device Tree.
Eric Nelson (1): mxc_ipuv3: fix memory alignment of framebuffer
Fabio Estevam (1): mx6qsabrelite: Remove mx6qsabrelite code in favor of nitrogen6x
Heiko Schocher (6): net, phy, cpsw: fix gigabit register access ARM: AM33xx: Move s_init to a common place arm/davinci/da850: add uart0_pins_rtscts and RMII_MHz_50_CLK in emac_pins_rmii pinmux bootstage: get more BOOTSTAGE_ID* in show_boot_progress() arm, da850: enable the correct uart in arch_cpu_init() arm, da850: add ipam390 board support
Javier Martinez Canillas (1): OMAP3: igep00x0: allow booting with a FDT from MMC
Justin Waters (6): am335x_evm: Make NAND support modular am335x_evm: Add command line editing am335x_evm: Rework bootcmd to handle two MMC devs Add additional MLO images to .gitignore am335x_evm: Add support for eMMC environment am335x_evm: Add am335x_boneblack variant
Lokesh Vutla (10): ARM: DRA7xx: Lock DPLL_GMAC ARM: AM33xx: Cleanup dplls data ARM: AM33xx: Cleanup clocks layer musb: Disable extra prints ARM: AM43xx: Add Board files ARM: AM43xx: Add header files ARM: AM43xx: clocks: Add dpll and clock data ARM: OMAP: Add CONFIG_OMAP_COMMON ARM: AM43xx: Add build support ARM: AM43xx: Add config file
Marek Vasut (1): ARM: mxs: Consolidate configuration options
Masahiro Yamada (1): ARM: omap24xx: remove remainders of dead board
Mugunthan V N (6): drivers: net: cpsw: remove hard coding bd ram for cpsw drivers: net: cpsw: Enable statistics for all port ARM: DRA7xx: Enable GMAC clock control ARM: DRA7xx: Add CPSW support to DRA7xx EVM ARM: DRA7xx: Add CPSW and MDIO pinmux support ARM: DRA7xx: Enable CPSW Ethernet support
Naumann Andreas (1): ARM: omap3: Implement dpll5 (HSUSB clk) workaround for OMAP36xx/AM/DM37xx according to errata sprz318e.
Nishanth Menon (6): omap3_beagle: remove JFFS2 support. omap3_beagle: replace uImage.beagle with generic uImage beagleboard: remove RevB support for BeagleBoard Xm omap3_beagle: enable CMD_FS_GENERIC and simplify load of image/ramdisk omap3_beagle: support findfdt and loadfdt for devicetree support omap3_beagle: support booting from zImage and device tree as last option
Otavio Salvador (1): wandboard: Use splash image at screen center by default
Pardeep Kumar Singla (2): mx6: Factor out common HDMI setup code mx6qsabresd: Add splash screen support via HDMI
Rob Herring (10): ARM: move interrupt_init to before relocation net: calxedaxgmac: enable rx cut-thru ARM: highbank: update config options ARM: highbank: fix get_tbclk value to timer rate ARM: highbank: set timer prescaler to 256 ARM: highbank: avoid bss write in timer_init ARM: highbank: enable reset on command timeout ARM: highbank: setup peripherals based on power domain status ARM: highbank: compile misc_init_r only if CONFIG_MISC_INIT_R highbank: enable keyed autoboot stop
Robert Winkler (2): imx: Add documentation for imx specific commands imx: nitrogen6x: mx6qsabrelite: Add support for DVI monitors
Stefan Roese (1): arm: omap3: spl: Fix problem with 8bit NAND devices
Stefano Babic (1): Merge git://git.denx.de/u-boot-arm
Steve Kipisz (2): am335x_evm: Add support for the NOR module on the memory cape am335x_evm: Add support to boot from NOR.
Steve Sakoman (1): omap: overo: update support for Micron 1GB POP
TENART Antoine (3): Prepare for TI816X : reuse existing code from TI814X Add TI816X support Add TI816X evm board support
Taras Kondratiuk (1): omap: emif: Set initial DDR PHY config first
Tom Rini (21): spl_mmc.c: Detect missing kernel image in RAW MMC README.falcon: Note how we determine if we can boot the OS or not am335x_evm: Correct DFU ALT settings for falcon mode am335x_evm: Update eMMC falcon mode locations am335x_evm: Correct CONFIG_CMD_SPL_WRITE_SIZE am335x_evm: Add basic README board/ti/am335x/README: Document NAND programming am335x_evm: Drop useless CONFIG_ENV_IS_NOWHERE am335x_evm: Update SPI_BOOT support, add MTDPARTS info am335x_evm: Rework board_is_foo() checks am33xx: Correct gpmc_cfg->irqstatus/enable board/ti/am335x/README: Document NOR programming am33xx: CONFIG_DMA_COHERENT defines are unused, remove am33xx: Stop using PHYS_DRAM_1 define am335x_evm: Use default baud rate table arm: spl: For Falcon Mode, set a default machid of ~0 am335x_evm: Bring in 'boot_fdt' logic from i.MX TI:am33xx: Create common config files for TI ARMv7 platforms, and AM33xx TI:omap5/dra7xx: Convert to ti_armv7_common.h TI:armv7: Enable CONFIG_CMD_SPI TI:armv7: Enable CONFIG_CMD_GPIO
.gitignore | 2 +- MAINTAINERS | 7 +- Makefile | 2 +- README | 15 + arch/arm/config.mk | 2 +- arch/arm/cpu/arm1136/omap24xx/reset.S | 26 - arch/arm/cpu/arm1136/omap24xx/timer.c | 136 ---- arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 4 + arch/arm/cpu/arm926ejs/davinci/da850_pinmux.c | 6 + arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/am33xx/Makefile | 7 + arch/arm/cpu/armv7/am33xx/board.c | 70 +- arch/arm/cpu/armv7/am33xx/clock.c | 171 +++++ arch/arm/cpu/armv7/am33xx/clock_am33xx.c | 495 +++--------- arch/arm/cpu/armv7/am33xx/clock_am43xx.c | 110 +++ arch/arm/cpu/armv7/am33xx/clock_ti814x.c | 120 +-- arch/arm/cpu/armv7/am33xx/clock_ti816x.c | 445 +++++++++++ arch/arm/cpu/armv7/am33xx/emif4.c | 17 +- arch/arm/cpu/armv7/am33xx/mem.c | 8 +- arch/arm/cpu/armv7/highbank/timer.c | 10 +- arch/arm/cpu/armv7/mx6/clock.c | 8 + arch/arm/cpu/armv7/mx6/soc.c | 43 ++ arch/arm/cpu/armv7/omap-common/Makefile | 2 +- arch/arm/cpu/armv7/omap-common/boot-common.c | 3 +- arch/arm/cpu/armv7/omap-common/clocks-common.c | 18 + arch/arm/cpu/armv7/omap-common/emif-common.c | 2 +- arch/arm/cpu/armv7/omap3/clock.c | 20 +- arch/arm/cpu/armv7/omap3/lowlevel_init.S | 18 + arch/arm/cpu/armv7/omap3/mem.c | 12 + arch/arm/cpu/armv7/omap3/sys_info.c | 6 +- arch/arm/cpu/armv7/omap5/hw_data.c | 18 +- arch/arm/cpu/armv7/omap5/prcm-regs.c | 7 + arch/arm/imx-common/cmd_hdmidet.c | 3 +- arch/arm/include/asm/arch-am33xx/clock.h | 98 +++ arch/arm/include/asm/arch-am33xx/clock_ti81xx.h | 142 ++++ arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 6 +- arch/arm/include/asm/arch-am33xx/cpu.h | 164 +++- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 35 +- arch/arm/include/asm/arch-am33xx/hardware.h | 18 +- arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 15 + arch/arm/include/asm/arch-am33xx/hardware_am43xx.h | 54 ++ arch/arm/include/asm/arch-am33xx/hardware_ti814x.h | 15 + arch/arm/include/asm/arch-am33xx/hardware_ti816x.h | 61 ++ arch/arm/include/asm/arch-am33xx/mem.h | 9 + arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 3 + arch/arm/include/asm/arch-am33xx/mux.h | 4 + arch/arm/include/asm/arch-am33xx/mux_am43xx.h | 142 ++++ arch/arm/include/asm/arch-am33xx/mux_ti816x.h | 363 +++++++++ arch/arm/include/asm/arch-am33xx/omap.h | 11 +- arch/arm/include/asm/arch-am33xx/spl.h | 15 +- arch/arm/include/asm/arch-am33xx/sys_proto.h | 9 +- arch/arm/include/asm/arch-armv7/systimer.h | 2 + arch/arm/include/asm/arch-davinci/pinmux_defs.h | 3 +- arch/arm/include/asm/arch-mx6/clock.h | 2 +- arch/arm/include/asm/arch-mx6/mxc_hdmi.h | 8 + arch/arm/include/asm/arch-omap3/clock.h | 1 + arch/arm/include/asm/arch-omap3/clocks_omap3.h | 22 + arch/arm/include/asm/arch-omap5/cpu.h | 6 + arch/arm/include/asm/arch-omap5/omap.h | 26 + arch/arm/include/asm/omap_common.h | 10 + arch/arm/lib/board.c | 3 +- arch/arm/lib/spl.c | 7 +- .../omap24xx => board/Barix/ipam390}/Makefile | 22 +- board/Barix/ipam390/README.ipam390 | 229 ++++++ board/Barix/ipam390/ipam390-ais-uart.cfg | 202 +++++ board/Barix/ipam390/ipam390.c | 348 +++++++++ board/Barix/ipam390/u-boot-spl-ipam390.lds | 53 ++ .../altera/{socfpga_cyclone5 => socfpga}/Makefile | 0 .../socfpga_cyclone5.c | 0 .../nitrogen6x/README.mx6qsabrelite} | 0 board/boundary/nitrogen6x/nitrogen6x.c | 46 +- board/davinci/da8xxevm/da850evm.c | 14 +- board/freescale/mx6qsabrelite/Makefile | 28 - board/freescale/mx6qsabrelite/mx6qsabrelite.c | 832 --------------------- board/freescale/mx6sabresd/mx6sabresd.c | 64 +- board/highbank/highbank.c | 33 +- board/isee/igep0033/board.c | 59 +- board/isee/igep0033/board.h | 2 +- board/isee/igep00x0/igep00x0.c | 14 + board/overo/overo.c | 22 +- board/overo/overo.h | 1 + board/phytec/pcm051/board.c | 59 +- board/ti/am335x/Makefile | 2 +- board/ti/am335x/README | 160 ++++ board/ti/am335x/board.c | 167 ++--- board/ti/am335x/board.h | 31 + board/ti/am335x/mux.c | 84 ++- board/ti/am335x/u-boot.lds | 117 +++ board/ti/am43xx/Makefile | 38 + board/ti/am43xx/board.c | 57 ++ board/ti/am43xx/board.h | 17 + board/ti/am43xx/mux.c | 27 + board/ti/beagle/beagle.c | 28 +- board/ti/beagle/beagle.h | 3 +- board/ti/dra7xx/evm.c | 150 +++- board/ti/dra7xx/mux_data.h | 14 + board/ti/omap5_uevm/evm.c | 22 + board/ti/omap5_uevm/mux_data.h | 2 + board/ti/ti814x/evm.c | 68 +- board/ti/ti816x/Makefile | 37 + board/ti/ti816x/evm.c | 229 ++++++ board/wandboard/wandboard.c | 44 +- boards.cfg | 24 +- common/spl/spl_mmc.c | 4 + doc/README.falcon | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/mxc_gpio.c | 4 +- drivers/gpio/tca642x.c | 333 +++++++++ drivers/net/calxedaxgmac.c | 2 +- drivers/net/cpsw.c | 7 +- drivers/net/phy/phy.c | 6 +- drivers/serial/ns16550.c | 5 +- drivers/usb/musb-new/musb_core.c | 20 +- drivers/video/mxc_ipuv3_fb.c | 5 +- include/bootstage.h | 1 + include/configs/am335x_evm.h | 423 ++++------- include/configs/am3517_crane.h | 1 + include/configs/am3517_evm.h | 1 + include/configs/am43xx_evm.h | 135 ++++ include/configs/apx4devkit.h | 120 +-- include/configs/cm_t35.h | 1 + include/configs/devkit8000.h | 1 + include/configs/dig297.h | 1 + include/configs/dra7xx_evm.h | 30 +- include/configs/highbank.h | 20 +- include/configs/igep0033.h | 86 ++- include/configs/igep00x0.h | 25 +- include/configs/ipam390.h | 331 ++++++++ include/configs/m28evk.h | 192 +---- include/configs/mcx.h | 1 + include/configs/mx23_olinuxino.h | 142 +--- include/configs/mx23evk.h | 115 +-- include/configs/mx28evk.h | 173 +---- include/configs/mx6qsabrelite.h | 284 ------- include/configs/mx6sabre_common.h | 3 +- include/configs/mx6sabresd.h | 19 + include/configs/mxs.h | 191 +++++ include/configs/nitrogen6x.h | 81 +- include/configs/nokia_rx51.h | 1 + include/configs/omap3_beagle.h | 45 +- include/configs/omap3_evm_common.h | 1 + include/configs/omap3_logic.h | 1 + include/configs/omap3_mvblx.h | 1 + include/configs/omap3_overo.h | 1 + include/configs/omap3_pandora.h | 1 + include/configs/omap3_sdp3430.h | 1 + include/configs/omap3_zoom1.h | 1 + include/configs/omap3_zoom2.h | 1 + include/configs/omap4_common.h | 1 + include/configs/omap5_common.h | 191 +---- include/configs/omap5_uevm.h | 11 +- include/configs/pcm051.h | 9 +- include/configs/sc_sps_1.h | 139 +--- include/configs/tam3517-common.h | 1 + include/configs/ti814x_evm.h | 9 +- include/configs/ti816x_evm.h | 180 +++++ include/configs/ti_am335x_common.h | 60 ++ include/configs/ti_armv7_common.h | 250 +++++++ include/configs/tricorder.h | 1 + include/configs/wandboard.h | 2 + include/cpsw.h | 1 + include/tca642x.h | 69 ++ spl/Makefile | 2 +- 163 files changed, 6620 insertions(+), 3544 deletions(-) delete mode 100644 arch/arm/cpu/arm1136/omap24xx/reset.S delete mode 100644 arch/arm/cpu/arm1136/omap24xx/timer.c create mode 100644 arch/arm/cpu/armv7/am33xx/clock.c create mode 100644 arch/arm/cpu/armv7/am33xx/clock_am43xx.c create mode 100644 arch/arm/cpu/armv7/am33xx/clock_ti816x.c create mode 100644 arch/arm/include/asm/arch-am33xx/clock_ti81xx.h create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_am43xx.h create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_ti816x.h create mode 100644 arch/arm/include/asm/arch-am33xx/mux_am43xx.h create mode 100644 arch/arm/include/asm/arch-am33xx/mux_ti816x.h rename {arch/arm/cpu/arm1136/omap24xx => board/Barix/ipam390}/Makefile (53%) create mode 100644 board/Barix/ipam390/README.ipam390 create mode 100644 board/Barix/ipam390/ipam390-ais-uart.cfg create mode 100644 board/Barix/ipam390/ipam390.c create mode 100644 board/Barix/ipam390/u-boot-spl-ipam390.lds rename board/altera/{socfpga_cyclone5 => socfpga}/Makefile (100%) rename board/altera/{socfpga_cyclone5 => socfpga}/socfpga_cyclone5.c (100%) rename board/{freescale/mx6qsabrelite/README => boundary/nitrogen6x/README.mx6qsabrelite} (100%) delete mode 100644 board/freescale/mx6qsabrelite/Makefile delete mode 100644 board/freescale/mx6qsabrelite/mx6qsabrelite.c create mode 100644 board/ti/am335x/README create mode 100644 board/ti/am335x/u-boot.lds create mode 100644 board/ti/am43xx/Makefile create mode 100644 board/ti/am43xx/board.c create mode 100644 board/ti/am43xx/board.h create mode 100644 board/ti/am43xx/mux.c create mode 100644 board/ti/ti816x/Makefile create mode 100644 board/ti/ti816x/evm.c create mode 100644 drivers/gpio/tca642x.c create mode 100644 include/configs/am43xx_evm.h create mode 100644 include/configs/ipam390.h delete mode 100644 include/configs/mx6qsabrelite.h create mode 100644 include/configs/mxs.h create mode 100644 include/configs/ti816x_evm.h create mode 100644 include/configs/ti_am335x_common.h create mode 100644 include/configs/ti_armv7_common.h create mode 100644 include/tca642x.h
Amicalement,
On Sun, Aug 18, 2013 at 02:17:11PM +0200, Albert ARIBAUD wrote:
Hello Tom,
Andreas Bie??mann (1): omap3/sys_info: fix printout of OMAP36XX L3 freqency
Enric Balletb?? i Serra (1): ARM: IGEP0033: Add support for Flattened Device Tree.
Albert ARIBAUD
