[U-Boot] [PATCH v3 00/22] imx: vybrid: Update BK4 and PCM052 boards to only use DM/DTS
This patch series converts PCM052 and BK4 to use Driver Model and Device Tree.
Some notable changes: - The way how MAC address is read from fuses can now be adjusted - DTS improvement/sync with kernel (also extract u-boot specific properties) - Using generic code instead of one from board
The output of u-boot boot: U-Boot 2019.01-rc3-00076-gc149229be0 (Jan 14 2019 - 08:38:48 +0100)
CPU: Freescale Vybrid VF610 at 396 MHz Reset cause: POWER ON RESET Model: Liebherr (LVF) BK4 Vybrid Board Board: BK4r1 (L333) DRAM: 512 MiB NAND: 1024 MiB MMC: FSL_SDHC: 0 Loading Environment from NAND... OK In: serial@40028000 Out: serial@40028000 Err: serial@40028000 Net: eth0: fec@400d0000, eth1: fec@400d1000 Enter passphrase to stop autoboot, booting in 3 seconds
Buildman CI: ./tools/buildman/buildman.py --branch=HEAD vf610 mx6 vybrid --detail --verbose --show_errors --force-build --count=22 --output-dir=../BUILD/
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/487979522
U-boot master branch: SHA1: db4a29993d207fec33c07de8b8cb8a3fd22c9e6c
Changes in v3: - Add code to enable I2C0 code as suggested by Stefan (so the code can be reused by other boards without regressions) - Exclude the pcm052.c related code to a separate patch - New patch (separate board code patch)
Changes in v2: - Rename pcm052.dts to vf610-pcm052.dts - Rename bk4r1.dts to vf610-bk4r1.dts - Extract 'u-boot,dm-pre-reloc;' property to separate file (to facilitate sync with Linux kernel dts files) - New patch - Disable EFI related support and commands (as we do not plan to use EFI on this setup)
Lukasz Majewski (22): net: FEC: Add compatible for vybrid (vf610) to reuse fec_mxc.c driver net: Kconfig: FEC: Add dependency on VF610 vybrid: ddr: Extend vf610-pinfunc.h with DDR pads definitions vybrid: clock: Provide enable_i2c_clk() function for Vybrid pcm052: board: Do not enable I2C2 code in the board file vybrid: Define the imx_get_mac_from_fuse() as a __weak function pcm052: board: Remove "m4go" command as it is superseded by "bootaux" pcm052: board: vybrid: Update the board name for BK4 device ARM: DTS: vybrid: Update vf.dtsi file to descibe more vf610 hardware pcm052: board: cosmetic: Add copyright notice to pcm052.c ARM: DTS: Update pcm052 based dts files (bk4r1/pcm052) ARM: DTS: Provide vf610-bk4r1-u-boot.dtsi for U-Boot specific properties defconfig: bk4/pcm052: Update bk4r1|pcm052_defconfig to support DM/DT config: pcm052: Use SZ_X{MK} from linux/sizes.h for include/configs/pcm052.h config: bk4: Update include/configs/bk4r1.h file pcm052: board: Remove in-board setup code (it is now replaced by DM setup) config: bk4: Update u-boot script to support recovery via SD card config: bk4: Update u-boot envs to support NOR memories initial setup pcm052: bk4: sdcard: Add support for SD card booting/recovery pcm052: board: Add code to setup LED default states pcm052: mac: Provide board specific imx_get_mac_from_fuse() function pcm052: bk4: Add board_phy_config() for BK4 to setup ksz8081 phy
arch/arm/cpu/armv7/vf610/Kconfig | 1 + arch/arm/cpu/armv7/vf610/generic.c | 24 +- arch/arm/dts/Makefile | 4 +- arch/arm/dts/bk4r1.dts | 47 ---- arch/arm/dts/vf.dtsi | 62 +++++ arch/arm/dts/vf610-bk4r1-u-boot.dtsi | 27 ++ arch/arm/dts/vf610-bk4r1.dts | 97 +++++++ arch/arm/dts/{pcm052.dts => vf610-pcm052.dts} | 6 +- arch/arm/dts/vf610-pcm052.dtsi | 259 +++++++++++++++++ arch/arm/dts/vf610-pinfunc.h | 50 ++++ arch/arm/include/asm/arch-vf610/clock.h | 3 + arch/arm/include/asm/arch-vf610/imx-regs.h | 2 + board/phytec/pcm052/pcm052.c | 386 ++++++-------------------- configs/bk4r1_defconfig | 49 +++- configs/pcm052_defconfig | 36 ++- drivers/net/Kconfig | 2 +- drivers/net/fec_mxc.c | 1 + include/configs/bk4r1.h | 263 +++++++++++++++++- include/configs/pcm052.h | 51 +--- 19 files changed, 959 insertions(+), 411 deletions(-) delete mode 100644 arch/arm/dts/bk4r1.dts create mode 100644 arch/arm/dts/vf610-bk4r1-u-boot.dtsi create mode 100644 arch/arm/dts/vf610-bk4r1.dts rename arch/arm/dts/{pcm052.dts => vf610-pcm052.dts} (81%) create mode 100644 arch/arm/dts/vf610-pcm052.dtsi
The NXP's FEC driver can be reused on vf610 device (with DM).
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Stefan Agner stefan.agner@toradex.com ---
drivers/net/fec_mxc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 1a59026a62..5ff49224f4 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1486,6 +1486,7 @@ static const struct udevice_id fecmxc_ids[] = { { .compatible = "fsl,imx6ul-fec" }, { .compatible = "fsl,imx53-fec" }, { .compatible = "fsl,imx7d-fec" }, + { .compatible = "fsl,mvf600-fec" }, { } };
Hi Lukasz
- { .compatible = "fsl,mvf600-fec" }, { }
For some reason while the FEC prior to DM was rock solid on Vybrid with DM it at times only sends stuff but refuses to receive packets. Do you recall having any such issues? Could it have to do with us using FEC1 by default rather than FEC0? But then at times it works just fine again which is rather strange...
Cheers
Marcel
Hi Marcel,
Hi Lukasz
I had also some problems when I switched to DM (but for other NXP IMX6Q based board - mccmon6). It turned out that the time between probe in the driver and first read of MDIO was just as in spec (or too short).
As a result the PHY was sometimes in uninitialized state, and silently read 0xFFFFFFFF as ID, which prevent us from normal work.
The fix in this case was to increase the delay between powering up PHY and exiting the ETH driver probe: http://patchwork.ozlabs.org/patch/1034050/
Please check if this patch (from this series): "pcm052: bk4: Add board_phy_config() for BK4 to setup ksz8081 phy"
is not solving your problem.
Cheers
Marcel
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
drivers/net/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 39ce4e8a1f..f00ab79050 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -187,7 +187,7 @@ config FEC_MXC_MDIO_BASE
config FEC_MXC bool "FEC Ethernet controller" - depends on MX5 || MX6 || MX7 || IMX8 + depends on MX5 || MX6 || MX7 || IMX8 || VF610 help This driver supports the 10/100 Fast Ethernet controller for NXP i.MX processors.
This patch provides definitions necessary for VF610 DDR pad configurations.
arch/arm/dts/vf610-pinfunc.h | 50 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 50 insertions(+)
diff --git a/arch/arm/dts/vf610-pinfunc.h b/arch/arm/dts/vf610-pinfunc.h index fcad7132c8..24d7126756 100644 --- a/arch/arm/dts/vf610-pinfunc.h +++ b/arch/arm/dts/vf610-pinfunc.h @@ -807,4 +807,54 @@ #define VF610_PAD_PTA7__GPIO_134 0x218 0x000 ALT0 0x0 #define VF610_PAD_PTA7__VIU_PIX_CLK 0x218 0x3AC ALT1 0x1
+#define VF610_PAD_DDR_RESETB 0x21c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A15__DDR_A_15 0x220 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A14__DDR_A_14 0x224 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A13__DDR_A_13 0x228 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A12__DDR_A_12 0x22c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A11__DDR_A_11 0x230 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A10__DDR_A_10 0x234 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A9__DDR_A_9 0x238 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A8__DDR_A_8 0x23c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A7__DDR_A_7 0x240 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A6__DDR_A_6 0x244 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A5__DDR_A_5 0x248 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A4__DDR_A_4 0x24c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A3__DDR_A_3 0x250 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A2__DDR_A_2 0x254 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A1__DDR_A_1 0x258 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A0__DDR_A_0 0x25c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_BA2__DDR_BA_2 0x260 0x000 ALT0 0x0 +#define VF610_PAD_DDR_BA1__DDR_BA_1 0x264 0x000 ALT0 0x0 +#define VF610_PAD_DDR_BA0__DDR_BA_0 0x268 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CAS__DDR_CAS_B 0x26c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CKE__DDR_CKE_0 0x270 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CLK__DDR_CLK_0 0x274 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CS__DDR_CS_B_0 0x278 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D15__DDR_D_15 0x27c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D14__DDR_D_14 0x280 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D13__DDR_D_13 0x284 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D12__DDR_D_12 0x288 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D11__DDR_D_11 0x28c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D10__DDR_D_10 0x290 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D9__DDR_D_9 0x294 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D8__DDR_D_8 0x298 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D7__DDR_D_7 0x29c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D6__DDR_D_6 0x2a0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D5__DDR_D_5 0x2a4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D4__DDR_D_4 0x2a8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D3__DDR_D_3 0x2ac 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D2__DDR_D_2 0x2b0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D1__DDR_D_1 0x2b4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D0__DDR_D_0 0x2b8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQM1__DDR_DQM_1 0x2bc 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQM0__DDR_DQM_0 0x2c0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQS1__DDR_DQS_1 0x2c4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQS0__DDR_DQS_0 0x2c8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_RAS__DDR_RAS_B 0x2cc 0x000 ALT0 0x0 +#define VF610_PAD_DDR_WE__DDR_WE_B 0x2d0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_ODT1__DDR_ODT_0 0x2d4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_ODT0__DDR_ODT_1 0x2d8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 0x2dc 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0 0x2e0 0x000 ALT0 0x0 #endif
Hi Lukasz
BTW: Thanks for this work which greatly helped us getting Colibri VF50/VF61 up to speed concerning device tree resp. driver model integration/migration. Hopefully, I can send that out later this week.
diff --git a/arch/arm/dts/vf610-pinfunc.h b/arch/arm/dts/vf610- pinfunc.h index fcad7132c8..24d7126756 100644 --- a/arch/arm/dts/vf610-pinfunc.h +++ b/arch/arm/dts/vf610-pinfunc.h @@ -807,4 +807,54 @@ #define VF610_PAD_PTA7__GPIO_134 0x218 0x000 ALT0 0x0 #define VF610_PAD_PTA7__VIU_PIX_CLK 0x218 0x3AC ALT1 0x1
As far as I can tell from the reference manual there is no such thing as a DDRBYTE0 but it is rather called DDRBYTE2, not?
#endif
Cheers
Marcel
Hi Marcel,
Hi Lukasz
diff --git a/arch/arm/dts/vf610-pinfunc.h b/arch/arm/dts/vf610- pinfunc.h index fcad7132c8..24d7126756 100644 --- a/arch/arm/dts/vf610-pinfunc.h +++ b/arch/arm/dts/vf610-pinfunc.h @@ -807,4 +807,54 @@ #define VF610_PAD_PTA7__GPIO_134 0x218 0x000 ALT0 0x0 #define VF610_PAD_PTA7__VIU_PIX_CLK 0x218 0x3AC ALT1 0x1 +#define VF610_PAD_DDR_RESETB 0x21c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A15__DDR_A_15 0x220 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A14__DDR_A_14 0x224 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A13__DDR_A_13 0x228 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A12__DDR_A_12 0x22c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A11__DDR_A_11 0x230 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A10__DDR_A_10 0x234 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A9__DDR_A_9 0x238 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A8__DDR_A_8 0x23c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A7__DDR_A_7 0x240 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A6__DDR_A_6 0x244 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A5__DDR_A_5 0x248 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A4__DDR_A_4 0x24c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A3__DDR_A_3 0x250 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A2__DDR_A_2 0x254 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A1__DDR_A_1 0x258 0x000 ALT0 0x0 +#define VF610_PAD_DDR_A0__DDR_A_0 0x25c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_BA2__DDR_BA_2 0x260 0x000 ALT0 0x0 +#define VF610_PAD_DDR_BA1__DDR_BA_1 0x264 0x000 ALT0 0x0 +#define VF610_PAD_DDR_BA0__DDR_BA_0 0x268 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CAS__DDR_CAS_B 0x26c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CKE__DDR_CKE_0 0x270 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CLK__DDR_CLK_0 0x274 0x000 ALT0 0x0 +#define VF610_PAD_DDR_CS__DDR_CS_B_0 0x278 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D15__DDR_D_15 0x27c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D14__DDR_D_14 0x280 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D13__DDR_D_13 0x284 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D12__DDR_D_12 0x288 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D11__DDR_D_11 0x28c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D10__DDR_D_10 0x290 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D9__DDR_D_9 0x294 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D8__DDR_D_8 0x298 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D7__DDR_D_7 0x29c 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D6__DDR_D_6 0x2a0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D5__DDR_D_5 0x2a4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D4__DDR_D_4 0x2a8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D3__DDR_D_3 0x2ac 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D2__DDR_D_2 0x2b0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D1__DDR_D_1 0x2b4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_D0__DDR_D_0 0x2b8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQM1__DDR_DQM_1 0x2bc 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQM0__DDR_DQM_0 0x2c0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQS1__DDR_DQS_1 0x2c4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DQS0__DDR_DQS_0 0x2c8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_RAS__DDR_RAS_B 0x2cc 0x000 ALT0 0x0 +#define VF610_PAD_DDR_WE__DDR_WE_B 0x2d0 0x000 ALT0 0x0 +#define VF610_PAD_DDR_ODT1__DDR_ODT_0 0x2d4 0x000 ALT0 0x0 +#define VF610_PAD_DDR_ODT0__DDR_ODT_1 0x2d8 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 0x2dc 0x000 ALT0 0x0 +#define VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0 0x2e0 0x000 ALT0 0x0
Yes, correct. This indeed shall be DDRBYTE2, not 0.
Thanks for spotting it.
#endif
Cheers
Marcel
Lukasz Majewski
Provide function to enable I2C clocks for vf610 - in the generic code. This function overrides the default weak function implementation (which only returns 1).
Changes in v2: None
arch/arm/cpu/armv7/vf610/generic.c | 22 ++++++++++++++++++++++ arch/arm/include/asm/arch-vf610/clock.h | 3 +++ 2 files changed, 25 insertions(+)
diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index cbd3391918..e0c0b1bcb0 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -375,3 +375,25 @@ void enable_caches(void) mmu_set_region_dcache_behaviour(IRAM_BASE_ADDR, IRAM_SIZE, option); } #endif + +#ifdef CONFIG_SYS_I2C_MXC +/* i2c_num can be from 0 - 3 */ +int enable_i2c_clk(unsigned char enable, unsigned int i2c_num) +{ + struct ccm_reg *ccm = (struct ccm_reg *)CCM_BASE_ADDR; + + switch (i2c_num) { + case 0: + clrsetbits_le32(&ccm->ccgr4, CCM_CCGR4_I2C0_CTRL_MASK, + CCM_CCGR4_I2C0_CTRL_MASK); + case 2: + clrsetbits_le32(&ccm->ccgr10, CCM_CCGR10_I2C2_CTRL_MASK, + CCM_CCGR10_I2C2_CTRL_MASK); + break; + default: + return -EINVAL; + } + + return 0; +} +#endif diff --git a/arch/arm/include/asm/arch-vf610/clock.h b/arch/arm/include/asm/arch-vf610/clock.h index 3bd73a01f3..72184fd608 100644 --- a/arch/arm/include/asm/arch-vf610/clock.h +++ b/arch/arm/include/asm/arch-vf610/clock.h @@ -22,6 +22,9 @@ enum mxc_clock { void enable_ocotp_clk(unsigned char enable); unsigned int mxc_get_clock(enum mxc_clock clk); u32 get_lpuart_clk(void); +#ifdef CONFIG_SYS_I2C_MXC +int enable_i2c_clk(unsigned char enable, unsigned int i2c_num); +#endif
#define imx_get_fecclk() mxc_get_clock(MXC_FEC_CLK)
-- Stefan
Changes in v3:
Changes in v2: None
- struct ccm_reg *ccm = (struct ccm_reg *)CCM_BASE_ADDR;
- switch (i2c_num) {
- case 0:
- case 2:
break;
- default:
return -EINVAL;
Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Changes in v3:
Changes in v2: None
- case 0:
- case 2:
break;
- default:
return -EINVAL;
As the I2C2 clock is now enabled in the generic clock code, we can remove this code from a board file.
Changes in v3: - New patch (separate board code patch)
Changes in v2: None
board/phytec/pcm052/pcm052.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index f988af2abc..cfc8009102 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -485,7 +485,7 @@ static void clock_init(void) clrsetbits_le32(&ccm->ccgr9, CCM_REG_CTRL_MASK, CCM_CCGR9_FEC0_CTRL_MASK | CCM_CCGR9_FEC1_CTRL_MASK); clrsetbits_le32(&ccm->ccgr10, CCM_REG_CTRL_MASK, - CCM_CCGR10_NFC_CTRL_MASK | CCM_CCGR10_I2C2_CTRL_MASK); + CCM_CCGR10_NFC_CTRL_MASK);
clrsetbits_le32(&anadig->pll2_ctrl, ANADIG_PLL2_CTRL_POWERDOWN, ANADIG_PLL2_CTRL_ENABLE | ANADIG_PLL2_CTRL_DIV_SELECT);
Hi Lukasz
Changes in v3:
Changes in v2: None
I can confirm that a similar change also works on Colibri VF50/VF61 albeit there on I2C0 rather than I2C2.
Cheers
Marcel
The proposed way of reading fused MAC in the imx_get_mac_from_fuse() may be different for other boards.
This commit defines the imx_get_mac_from_fuse() as a weak function to allow board file overriding it with customized function.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
arch/arm/cpu/armv7/vf610/generic.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index e0c0b1bcb0..90fa695e98 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -252,7 +252,7 @@ U_BOOT_CMD( );
#ifdef CONFIG_FEC_MXC -void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) +__weak void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) { struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; struct fuse_bank *bank = &ocotp->bank[4];
The "m4go" provides exactly the same functionality as the IMX generic "bootaux" command. Remove it to not duplicate the code.
board/phytec/pcm052/pcm052.c | 38 -------------------------------------- 1 file changed, 38 deletions(-)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index cfc8009102..4e4b870304 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -577,41 +577,3 @@ int checkboard(void)
return 0; } - -static int do_m4go(cmd_tbl_t *cmdtp, int flag, int argc, - char * const argv[]) -{ - ulong addr; - - /* Consume 'm4go' */ - argc--; argv++; - - /* - * Parse provided address - default to load_addr in case not provided. - */ - - if (argc) - addr = simple_strtoul(argv[0], NULL, 16); - else - addr = load_addr; - - /* - * Write boot address in PERSISTENT_ENTRY1[31:0] aka SRC_GPR2[31:0] - */ - writel(addr + 0x401, 0x4006E028); - - /* - * Start secondary processor by enabling its clock - */ - writel(0x15a5a, 0x4006B08C); - - return 1; -} - -U_BOOT_CMD( - m4go, 2 /* one arg max */, 1 /* repeatable */, do_m4go, - "start the secondary Cortex-M4 from scatter file image", - "[<addr>]\n" - " - start secondary Cortex-M4 core using a scatter file image\n" - "The argument needs to be a scatter file\n" -);
Hi Lukasz
Makes sense but as far as I can tell from its Kconfig so far bootaux is only for i.MX 7 and i.MX 6. Should I send a patch for this? Plus you would also have to enable bootaux support in your defconfig.
Cheers
Marcel
return 0; }
- ulong addr;
- argc--; argv++;
provided.
- if (argc)
- else
addr = load_addr;
SRC_GPR2[31:0]
- return 1;
-U_BOOT_CMD(
- "[<addr>]\n"
image\n"
Hi Marcel,
Hi Lukasz
Yes, please prepare a patch on top of this series.
(I'm now build testing v4 of this patch series, and plan to post it tonight).
It turned out that BK4 is finally not using it, so I don't need to enable it.
Cheers
Marcel
return 0; }
- ulong addr;
- argc--; argv++;
not provided.
- if (argc)
- else
addr = load_addr;
SRC_GPR2[31:0]
- return 1;
-U_BOOT_CMD(
- "[<addr>]\n"
image\n"
Lukasz Majewski
This commit provides distinction between PCM052 and BK4.
board/phytec/pcm052/pcm052.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index 4e4b870304..5f2c9a9c12 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -573,7 +573,10 @@ int board_init(void)
int checkboard(void) { +#ifdef CONFIG_TARGET_BK4R1 + puts("Board: BK4r1 (L333)\n"); +#else puts("Board: PCM-052\n"); - +#endif return 0; }
This patch allows moving vf610 based boards to a device tree and model. Ported from Linux kernel - v4.20 (tag)
arch/arm/dts/vf.dtsi | 62 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 62 insertions(+)
diff --git a/arch/arm/dts/vf.dtsi b/arch/arm/dts/vf.dtsi index ad30059b9a..5e3b2c5b9d 100644 --- a/arch/arm/dts/vf.dtsi +++ b/arch/arm/dts/vf.dtsi @@ -22,6 +22,10 @@ spi1 = &dspi1; ehci0 = &ehci0; ehci1 = &ehci1; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; };
soc { @@ -89,6 +93,22 @@ status = "disabled"; };
+ i2c0: i2c@40066000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,vf610-i2c"; + reg = <0x40066000 0x1000>; + status = "disabled"; + }; + + i2c1: i2c@40067000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,vf610-i2c"; + reg = <0x40067000 0x1000>; + status = "disabled"; + }; + iomuxc: iomuxc@40048000 { compatible = "fsl,vf610-iomuxc"; reg = <0x40048000 0x1000>; @@ -156,6 +176,48 @@ reg = <0x400b4000 0x800>; status = "disabled"; }; + + esdhc1: esdhc@400b2000 { + compatible = "fsl,esdhc"; + reg = <0x400b2000 0x1000>; + status = "disabled"; + }; + + fec0: fec@400d0000 { + compatible = "fsl,mvf600-fec"; + reg = <0x400d0000 0x1000>; + status = "disabled"; + }; + + fec1: fec@400d1000 { + compatible = "fsl,mvf600-fec"; + reg = <0x400d1000 0x1000>; + status = "disabled"; + }; + + nfc: nand@400e0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,vf610-nfc"; + reg = <0x400e0000 0x4000>; + status = "disabled"; + }; + + i2c2: i2c@400e6000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,vf610-i2c"; + reg = <0x400e6000 0x1000>; + status = "disabled"; + }; + + i2c3: i2c@400e7000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,vf610-i2c"; + reg = <0x400e7000 0x1000>; + status = "disabled"; + }; }; }; };
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
soc {
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
board/phytec/pcm052/pcm052.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index 5f2c9a9c12..95df0be6c1 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -1,5 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* + * (C) Copyright 2018 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de. + * * Copyright 2013 Freescale Semiconductor, Inc. */
This commit provides update and renames the bk4r1.dts to vf610-bk4r1.dts file with more on SoC HW description. The pcm052.dts has been renamed to vf610-pcm052.dts as well.
Moreover, a new vf610-pcm052.drsi file has been introduced to reuse the common code between devices based on Phytec's pcm052 modules. Ported from Linux kernel - v4.20 (tag)
Changes in v3: None Changes in v2: - Rename pcm052.dts to vf610-pcm052.dts - Rename bk4r1.dts to vf610-bk4r1.dts - Extract 'u-boot,dm-pre-reloc;' property to separate file (to facilitate sync with Linux kernel dts files)
arch/arm/dts/Makefile | 4 +- arch/arm/dts/bk4r1.dts | 47 ----- arch/arm/dts/vf610-bk4r1.dts | 97 ++++++++++ arch/arm/dts/{pcm052.dts => vf610-pcm052.dts} | 6 +- arch/arm/dts/vf610-pcm052.dtsi | 259 ++++++++++++++++++++++++++ configs/bk4r1_defconfig | 2 +- configs/pcm052_defconfig | 2 +- 7 files changed, 361 insertions(+), 56 deletions(-) delete mode 100644 arch/arm/dts/bk4r1.dts create mode 100644 arch/arm/dts/vf610-bk4r1.dts rename arch/arm/dts/{pcm052.dts => vf610-pcm052.dts} (81%) create mode 100644 arch/arm/dts/vf610-pcm052.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 46f1d693dc..7fe8554e14 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -429,8 +429,8 @@ dtb-$(CONFIG_MACH_SUN9I) += \ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ vf610-colibri.dtb \ vf610-twr.dtb \ - pcm052.dtb \ - bk4r1.dtb + vf610-pcm052.dtb \ + vf610-bk4r1.dtb
dtb-$(CONFIG_MX53) += imx53-cx9020.dtb
diff --git a/arch/arm/dts/bk4r1.dts b/arch/arm/dts/bk4r1.dts deleted file mode 100644 index 866b80e0b0..0000000000 --- a/arch/arm/dts/bk4r1.dts +++ /dev/null @@ -1,47 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * Copyright 2016 Toradex AG - */ - -/dts-v1/; -#include "vf.dtsi" - -/ { - model = "Phytec phyCORE-Vybrid"; - compatible = "phytec,pcm052", "fsl,vf610"; - - chosen { - stdout-path = &uart1; - }; - - aliases { - spi0 = &qspi0; - }; - -}; - -&uart1 { - status = "okay"; -}; - -&qspi0 { - bus-num = <0>; - num-cs = <2>; - status = "okay"; - - qflash0: spi_flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "spi-flash"; - spi-max-frequency = <108000000>; - reg = <0>; - }; - - qflash1: spi_flash@1 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "spi-flash"; - spi-max-frequency = <66000000>; - reg = <1>; - }; -}; diff --git a/arch/arm/dts/vf610-bk4r1.dts b/arch/arm/dts/vf610-bk4r1.dts new file mode 100644 index 0000000000..55cd53384a --- /dev/null +++ b/arch/arm/dts/vf610-bk4r1.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * (C) Copyright 2018 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de. + * + * Copyright 2016 Toradex AG + */ + +/dts-v1/; +#include "vf610-pcm052.dtsi" +#include "vf610-pinfunc.h" + +/ { + model = "Liebherr (LVF) BK4 Vybrid Board"; + compatible = "lvf,bk4", "fsl,vf610"; + + leds { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + compatible = "gpio-leds"; + + /* PTE15 PORT3[24] H6 green */ + led@0 { + label = "0"; + gpios = <&gpio3 24 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + /* PTA12 PORT0[5] H5 green */ + led@1 { + label = "1"; + gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + /* PTE20 PORT3[39] H4 green */ + led@2 { + label = "2"; + gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + /* PTE12 PORT3[21] H3 green */ + led@3 { + label = "3"; + gpios = <&gpio3 21 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + /* LED6 is now PRESET ETH -> PTA16 PORT0[6] H6 red */ + /* PTE9 PORT3[18] H5 red */ + led@4 { + label = "5"; + gpios = <&gpio3 18 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + /* PTE23 PORT4[0] H4 red */ + led@5 { + label = "6"; + gpios = <&gpio4 0 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + /* PTE16 PORT3[25] H3 red */ + led@6 { + label = "7"; + gpios = <&gpio3 25 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + }; +}; + +&iomuxc { + pinctrl-0 = <&pinctrl_ddr &pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + /* ETH control pins */ + VF610_PAD_PTE17__GPIO_122 0x1183 + VF610_PAD_PTA16__GPIO_6 0x1183 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + /* LEDS */ + VF610_PAD_PTE15__GPIO_120 0x1183 + VF610_PAD_PTA12__GPIO_5 0x1183 + VF610_PAD_PTE9__GPIO_114 0x1183 + VF610_PAD_PTE20__GPIO_125 0x1183 + VF610_PAD_PTE23__GPIO_128 0x1183 + VF610_PAD_PTE16__GPIO_121 0x1183 + >; + }; +}; diff --git a/arch/arm/dts/pcm052.dts b/arch/arm/dts/vf610-pcm052.dts similarity index 81% rename from arch/arm/dts/pcm052.dts rename to arch/arm/dts/vf610-pcm052.dts index 6489fdc6f4..22026024ea 100644 --- a/arch/arm/dts/pcm052.dts +++ b/arch/arm/dts/vf610-pcm052.dts @@ -4,7 +4,7 @@ */
/dts-v1/; -#include "vf.dtsi" +#include "vf610-pcm052.dtsi"
/ { model = "Phytec phyCORE-Vybrid"; @@ -15,7 +15,3 @@ };
}; - -&uart1 { - status = "okay"; -}; diff --git a/arch/arm/dts/vf610-pcm052.dtsi b/arch/arm/dts/vf610-pcm052.dtsi new file mode 100644 index 0000000000..2b5451a037 --- /dev/null +++ b/arch/arm/dts/vf610-pcm052.dtsi @@ -0,0 +1,259 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * (C) Copyright 2018 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de. + * + */ + +/dts-v1/; +#include "vf.dtsi" +#include "vf610-pinfunc.h" + +/ { + chosen { + stdout-path = &uart1; + }; + + aliases { + spi0 = &qspi0; + mmc0 = &esdhc1; + }; +}; + +&esdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_esdhc1>; + bus-width = <4>; + cd-gpios = <&gpio3 2 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&fec0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eth>; + + phy-mode = "rmii"; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eth1>; + + phy-mode = "rmii"; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + eeprom: eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + pagesize = <64>; + u-boot,i2c-offset-len = <2>; + }; + + m41t62: rtc@68 { + compatible = "st,m41t62"; + reg = <0x68>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ddr>; + + pinctrl_ddr: ddrgrp { + fsl,pins = < + VF610_PAD_DDR_A15__DDR_A_15 0x1c0 + VF610_PAD_DDR_A14__DDR_A_14 0x1c0 + VF610_PAD_DDR_A13__DDR_A_13 0x1c0 + VF610_PAD_DDR_A12__DDR_A_12 0x1c0 + VF610_PAD_DDR_A11__DDR_A_11 0x1c0 + VF610_PAD_DDR_A10__DDR_A_10 0x1c0 + VF610_PAD_DDR_A9__DDR_A_9 0x1c0 + VF610_PAD_DDR_A8__DDR_A_8 0x1c0 + VF610_PAD_DDR_A7__DDR_A_7 0x1c0 + VF610_PAD_DDR_A6__DDR_A_6 0x1c0 + VF610_PAD_DDR_A5__DDR_A_5 0x1c0 + VF610_PAD_DDR_A4__DDR_A_4 0x1c0 + VF610_PAD_DDR_A3__DDR_A_3 0x1c0 + VF610_PAD_DDR_A2__DDR_A_2 0x1c0 + VF610_PAD_DDR_A1__DDR_A_1 0x1c0 + VF610_PAD_DDR_A0__DDR_A_0 0x1c0 + VF610_PAD_DDR_BA2__DDR_BA_2 0x1c0 + VF610_PAD_DDR_BA1__DDR_BA_1 0x1c0 + VF610_PAD_DDR_BA0__DDR_BA_0 0x1c0 + VF610_PAD_DDR_CAS__DDR_CAS_B 0x1c0 + VF610_PAD_DDR_CKE__DDR_CKE_0 0x1c0 + VF610_PAD_DDR_CLK__DDR_CLK_0 0x101c0 + VF610_PAD_DDR_CS__DDR_CS_B_0 0x1c0 + VF610_PAD_DDR_D15__DDR_D_15 0x1c0 + VF610_PAD_DDR_D14__DDR_D_14 0x1c0 + VF610_PAD_DDR_D13__DDR_D_13 0x1c0 + VF610_PAD_DDR_D12__DDR_D_12 0x1c0 + VF610_PAD_DDR_D11__DDR_D_11 0x1c0 + VF610_PAD_DDR_D10__DDR_D_10 0x1c0 + VF610_PAD_DDR_D9__DDR_D_9 0x1c0 + VF610_PAD_DDR_D8__DDR_D_8 0x1c0 + VF610_PAD_DDR_D7__DDR_D_7 0x1c0 + VF610_PAD_DDR_D6__DDR_D_6 0x1c0 + VF610_PAD_DDR_D5__DDR_D_5 0x1c0 + VF610_PAD_DDR_D4__DDR_D_4 0x1c0 + VF610_PAD_DDR_D3__DDR_D_3 0x1c0 + VF610_PAD_DDR_D2__DDR_D_2 0x1c0 + VF610_PAD_DDR_D1__DDR_D_1 0x1c0 + VF610_PAD_DDR_D0__DDR_D_0 0x1c0 + VF610_PAD_DDR_DQM1__DDR_DQM_1 0x1c0 + VF610_PAD_DDR_DQM0__DDR_DQM_0 0x1c0 + VF610_PAD_DDR_DQS1__DDR_DQS_1 0x101c0 + VF610_PAD_DDR_DQS0__DDR_DQS_0 0x101c0 + VF610_PAD_DDR_RAS__DDR_RAS_B 0x1c0 + VF610_PAD_DDR_WE__DDR_WE_B 0x1c0 + VF610_PAD_DDR_ODT1__DDR_ODT_0 0x1c0 + VF610_PAD_DDR_ODT0__DDR_ODT_1 0x1c0 + VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 0x1c0 + VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0 0x1c0 + VF610_PAD_DDR_RESETB 0x1006c + >; + }; + + pinctrl_esdhc1: esdhc1grp { + fsl,pins = < + VF610_PAD_PTA24__ESDHC1_CLK 0x31ef + VF610_PAD_PTA25__ESDHC1_CMD 0x31ef + VF610_PAD_PTA26__ESDHC1_DAT0 0x31ef + VF610_PAD_PTA27__ESDHC1_DAT1 0x31ef + VF610_PAD_PTA28__ESDHC1_DATA2 0x31ef + VF610_PAD_PTA29__ESDHC1_DAT3 0x31ef + VF610_PAD_PTB28__GPIO_98 0x219d + >; + }; + + pinctrl_eth: ethgrp { + fsl,pins = < + VF610_PAD_PTA6__RMII_CLKIN 0x30dd + VF610_PAD_PTC0__ENET_RMII0_MDC 0x30de + VF610_PAD_PTC1__ENET_RMII0_MDIO 0x30df + VF610_PAD_PTC2__ENET_RMII0_CRS 0x30dd + VF610_PAD_PTC3__ENET_RMII0_RXD1 0x30dd + VF610_PAD_PTC4__ENET_RMII0_RXD0 0x30dd + VF610_PAD_PTC5__ENET_RMII0_RXER 0x30dd + VF610_PAD_PTC6__ENET_RMII0_TXD1 0x30de + VF610_PAD_PTC7__ENET_RMII0_TXD0 0x30de + VF610_PAD_PTC8__ENET_RMII0_TXEN 0x30de + >; + }; + + pinctrl_eth1: eth1grp { + fsl,pins = < + VF610_PAD_PTC9__ENET_RMII1_MDC 0x30de + VF610_PAD_PTC10__ENET_RMII1_MDIO 0x30df + VF610_PAD_PTC11__ENET_RMII1_CRS 0x30dd + VF610_PAD_PTC12__ENET_RMII1_RXD1 0x30dd + VF610_PAD_PTC13__ENET_RMII1_RXD0 0x30dd + VF610_PAD_PTC14__ENET_RMII1_RXER 0x30dd + VF610_PAD_PTC15__ENET_RMII1_TXD1 0x30de + VF610_PAD_PTC16__ENET_RMII1_TXD0 0x30de + VF610_PAD_PTC17__ENET_RMII1_TXEN 0x30de + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + VF610_PAD_PTA22__I2C2_SCL 0x34df + VF610_PAD_PTA23__I2C2_SDA 0x34df + >; + }; + + pinctrl_nfc: nfcgrp { + fsl,pins = < + VF610_PAD_PTD31__NF_IO15 0x28df + VF610_PAD_PTD30__NF_IO14 0x28df + VF610_PAD_PTD29__NF_IO13 0x28df + VF610_PAD_PTD28__NF_IO12 0x28df + VF610_PAD_PTD27__NF_IO11 0x28df + VF610_PAD_PTD26__NF_IO10 0x28df + VF610_PAD_PTD25__NF_IO9 0x28df + VF610_PAD_PTD24__NF_IO8 0x28df + VF610_PAD_PTD23__NF_IO7 0x28df + VF610_PAD_PTD22__NF_IO6 0x28df + VF610_PAD_PTD21__NF_IO5 0x28df + VF610_PAD_PTD20__NF_IO4 0x28df + VF610_PAD_PTD19__NF_IO3 0x28df + VF610_PAD_PTD18__NF_IO2 0x28df + VF610_PAD_PTD17__NF_IO1 0x28df + VF610_PAD_PTD16__NF_IO0 0x28df + VF610_PAD_PTB24__NF_WE_B 0x28c2 + VF610_PAD_PTB25__NF_CE0_B 0x28c2 + VF610_PAD_PTB27__NF_RE_B 0x28c2 + VF610_PAD_PTC26__NF_RB_B 0x283d + VF610_PAD_PTC27__NF_ALE 0x28c2 + VF610_PAD_PTC28__NF_CLE 0x28c2 + >; + }; + + pinctrl_qspi0: qspi0grp { + fsl,pins = < + VF610_PAD_PTD0__QSPI0_A_QSCK 0x397f + VF610_PAD_PTD1__QSPI0_A_CS0 0x397f + VF610_PAD_PTD2__QSPI0_A_DATA3 0x397f + VF610_PAD_PTD3__QSPI0_A_DATA2 0x397f + VF610_PAD_PTD4__QSPI0_A_DATA1 0x397f + VF610_PAD_PTD5__QSPI0_A_DATA0 0x397f + VF610_PAD_PTD7__QSPI0_B_QSCK 0x397f + VF610_PAD_PTD8__QSPI0_B_CS0 0x397f + VF610_PAD_PTD11__QSPI0_B_DATA1 0x397f + VF610_PAD_PTD12__QSPI0_B_DATA0 0x397f + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + VF610_PAD_PTB4__UART1_TX 0x21a2 + VF610_PAD_PTB5__UART1_RX 0x21a1 + >; + }; +}; + +&nfc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nfc>; + + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + + status = "okay"; +}; + +&qspi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi0>; + + bus-num = <0>; + num-cs = <2>; + status = "okay"; + + qflash0: spi_flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <108000000>; + reg = <0>; + }; + + qflash1: spi_flash@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <66000000>; + reg = <1>; + }; +}; diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 9e31b4ac97..b67a3946ac 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -25,7 +25,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=NAND,nor0=NOR" CONFIG_MTDPARTS_DEFAULT="mtdparts=NAND:640k(bootloader),128k(env1),128k(env2),128k(dtb),6144k(kernel),-(root);NOR:-(nor)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="bk4r1" +CONFIG_DEFAULT_DEVICE_TREE="vf610-bk4r1" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_DM_GPIO=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index e207df51a8..26ee823df3 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -24,7 +24,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=NAND" CONFIG_MTDPARTS_DEFAULT="mtdparts=NAND:640k(bootloader),128k(env1),128k(env2),128k(dtb),6144k(kernel),-(root)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="pcm052" +CONFIG_DEFAULT_DEVICE_TREE="vf610-pcm052" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_DM_GPIO=y
This commit brings a separate file in which the U-Boot specific properties (like 'dm-pre-reloc') are provided.
Such approach allows easy sync with upstream Linux kernel in the future.
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Tom Rini trini@konsulko.com
Changes in v3: None Changes in v2: - New patch
arch/arm/dts/vf610-bk4r1-u-boot.dtsi | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+) create mode 100644 arch/arm/dts/vf610-bk4r1-u-boot.dtsi
diff --git a/arch/arm/dts/vf610-bk4r1-u-boot.dtsi b/arch/arm/dts/vf610-bk4r1-u-boot.dtsi new file mode 100644 index 0000000000..088926bde2 --- /dev/null +++ b/arch/arm/dts/vf610-bk4r1-u-boot.dtsi @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + */ + +/ { + soc { + u-boot,dm-pre-reloc; + }; +}; + +&aips0 { + u-boot,dm-pre-reloc; +}; + +&pinctrl_ddr { + u-boot,dm-pre-reloc; +}; + +&pinctrl_uart1 { + u-boot,dm-pre-reloc; +}; + +&uart1 { + u-boot,dm-pre-reloc; +};
This commit updates BK4's and PCM052's config files to support as much as possible device tree and model in u-boot.
Moreover, remove CONFIG_* from pcm052.h (as those are now in bk4|pcm052_defconfig)
Changes in v3: None Changes in v2: - Disable EFI related support and commands (as we do not plan to use EFI on this setup)
configs/bk4r1_defconfig | 47 ++++++++++++++++++++++++++++++++++++++++++----- configs/pcm052_defconfig | 34 ++++++++++++++++++++++++++++++++-- include/configs/pcm052.h | 34 ---------------------------------- 3 files changed, 74 insertions(+), 41 deletions(-)
diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index b67a3946ac..e3852f4856 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -2,15 +2,18 @@ CONFIG_ARM=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 +CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_TARGET_BK4R1=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_EEPROM=y +# CONFIG_CMD_ELF is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DM=y +CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y @@ -19,19 +22,45 @@ CONFIG_CMD_SF=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y +CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_FAT=y -CONFIG_MTDIDS_DEFAULT="nand0=NAND,nor0=NOR" -CONFIG_MTDPARTS_DEFAULT="mtdparts=NAND:640k(bootloader),128k(env1),128k(env2),128k(dtb),6144k(kernel),-(root);NOR:-(nor)" +CONFIG_MTDIDS_DEFAULT="nand0=vf610_nfc,nor0=NOR" +CONFIG_MTDPARTS_DEFAULT="mtdparts=vf610_nfc:2048k(bootloader),128k(env1),128k(env2),10240k(initrd),40960k(dtbkernel),-(system);NOR:-(nor)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="vf610-bk4r1" CONFIG_ENV_IS_IN_NAND=y +CONFIG_NETCONSOLE=y CONFIG_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_SYS_BOOTCOUNT_ADDR=0x4006e02c CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0x2 +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_MXC_OCOTP=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SYS_I2C_EEPROM_BUS=2 +CONFIG_SYS_EEPROM_SIZE=32768 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y +CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y @@ -39,10 +68,18 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_VYBRID=y +CONFIG_DM_RTC=y CONFIG_RTC_M41T62=y +# CONFIG_SPL_SERIAL_PRESENT is not set +# CONFIG_TPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 26ee823df3..906abbfd69 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -9,7 +9,6 @@ CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y -CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -18,7 +17,6 @@ CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=NAND" CONFIG_MTDPARTS_DEFAULT="mtdparts=NAND:640k(bootloader),128k(env1),128k(env2),128k(dtb),6144k(kernel),-(root)" @@ -29,12 +27,44 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0x2 +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_MISC=y +CONFIG_MXC_OCOTP=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SYS_I2C_EEPROM_BUS=2 +CONFIG_SYS_EEPROM_SIZE=32768 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y +CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_VYBRID=y +CONFIG_DM_RTC=y CONFIG_RTC_M41T62=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index e125a38e7d..c2ecb7ec18 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -24,48 +24,14 @@ /* NAND support */ #define CONFIG_SYS_NAND_ONFI_DETECTION
-#ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR - -#define CONFIG_JFFS2_NAND - -/* Dynamic MTD partition support */ - -#endif - -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 -#define CONFIG_SYS_FSL_ESDHC_NUM 1 - -/*#define CONFIG_ESDHC_DETECT_USE_EXTERN_IRQ1*/ - -#define CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RMII -#define CONFIG_FEC_MXC_PHYADDR 0 - /* QSPI Configs*/ - #ifdef CONFIG_FSL_QSPI #define FSL_QSPI_FLASH_SIZE (1 << 24) #define FSL_QSPI_FLASH_NUM 2 #define CONFIG_SYS_FSL_QSPI_LE #endif
-/* I2C Configs */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC_I2C3 -#define CONFIG_SYS_I2C_MXC - -/* RTC (actually an RV-4162 but M41T62-compatible) */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 -#define CONFIG_SYS_RTC_BUS_NUM 2 - -/* EEPROM (24FC256) */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_I2C_EEPROM_BUS 2 -
#define CONFIG_LOADADDR 0x82000000
include/configs/pcm052.h | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index c2ecb7ec18..fb8f3c8609 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -9,6 +9,7 @@ #define __CONFIG_H
#include <asm/arch/imx-regs.h> +#include <linux/sizes.h>
#define CONFIG_SKIP_LOWLEVEL_INIT
@@ -16,7 +17,7 @@ #define CONFIG_CMDLINE_TAG
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * SZ_1M)
/* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE @@ -27,7 +28,7 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* QSPI Configs*/ #ifdef CONFIG_FSL_QSPI -#define FSL_QSPI_FLASH_SIZE (1 << 24) +#define FSL_QSPI_FLASH_SIZE (SZ_16M) #define FSL_QSPI_FLASH_NUM 2 #define CONFIG_SYS_FSL_QSPI_LE #endif @@ -154,7 +155,7 @@
/* Physical memory map */ #define PHYS_SDRAM (0x80000000) -#define PHYS_SDRAM_SIZE (CONFIG_PCM052_DDR_SIZE * 1024 * 1024) +#define PHYS_SDRAM_SIZE (CONFIG_PCM052_DDR_SIZE * SZ_1M)
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR @@ -167,17 +168,17 @@
/* environment organization */ #ifdef CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_SIZE (SZ_8K)
-#define CONFIG_ENV_OFFSET (12 * 64 * 1024) +#define CONFIG_ENV_OFFSET (12 * SZ_64K) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
#ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_SECT_SIZE (SZ_128K) +#define CONFIG_ENV_SIZE (SZ_8K) #define CONFIG_ENV_OFFSET 0xA0000 -#define CONFIG_ENV_SIZE_REDUND (8 * 1024) +#define CONFIG_ENV_SIZE_REDUND (SZ_8K) #define CONFIG_ENV_OFFSET_REDUND 0xC0000 #endif
Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com
- 1024 * 1024)
- SZ_1M)
The BK4's config file has changed since its initial posting to main line. This commit reflects those changes.
include/configs/bk4r1.h | 214 ++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 206 insertions(+), 8 deletions(-)
diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index a012705870..bbd3e4e636 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -1,24 +1,222 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* + * Copyright (C) 2018 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * * Copyright 2016 3ADEV http://3adev.com * Written-by: Albert ARIBAUD albert.aribaud@3adev.fr * - * Configuration settings for the phytec PCM-052 SoM-based BK4R1. + * Configuration settings for BK4R1. */
+#ifndef __CONFIG_H +#define __CONFIG_H + /* Define the BK4r1-specific env commands */ -#define PCM052_EXTRA_ENV_SETTINGS \ +#define BK4_EXTRA_ENV_SETTINGS \ + "bootlimit=3\0" \ + "eraseuserdata=false\0" \ + "altbootcmd=led 5 on; " \ + "boot\0" \ "set_gpio103=mw 0x400ff0c4 0x0080; mw 0x4004819C 0x000011bf\0" \ - "set_gpio122=mw 0x400481e8 0x0282; mw 0x400ff0c4 0x04000000\0" + "set_gpio102=mw 0x400ff0c4 0x40; mw 0x40048198 0x000011bf\0" \ + "set_gpio96=mw 0x40048180 0x282; mw 0x400ff0c4 0x1\0"\ + "set_gpio122=mw 0x400481e8 0x0282; mw 0x400ff0c4 0x04000000\0"\ + "set_gpio6=mw 0x40048018 0x282; mw 0x400ff008 0x40\0"\ + "manage_userdata=" MANAGE_USERDATA "\0"\ + "ncenable=true\0"\ + "ncserverip=192.168.0.77\0"\ + "if_netconsole=ping $ncserverip\0"\ + "start_netconsole=setenv ncip $serverip; setenv bootdelay 10;" \ + "setenv stdin nc; setenv stdout nc; setenv stderr nc; version;\0" \ + "preboot=" BK4_NET_INIT \ + "if ${ncenable}; then run if_netconsole start_netconsole; fi\0"
/* BK4r1 boot command sets GPIO103/PTC30 to force USB hub out of reset*/ -#define PCM052_BOOTCOMMAND "run set_gpio103; sf probe; " +#define BK4_BOOTCOMMAND "run set_gpio122; run set_gpio96; sf probe; " \ + "run manage_userdata; " + +/* Enable PREBOOT variable */ +#define CONFIG_PREBOOT + +/* Set ARP_TIMEOUT to 500ms */ +#define CONFIG_ARP_TIMEOUT 500UL + +/* Set ARP_TIMEOUT_COUNT to 3 repetitions */ +#define CONFIG_NET_RETRY_COUNT 5
/* BK4r1 net init sets GPIO122/PTE17 to enable Ethernet */ -#define PCM052_NET_INIT "run set_gpio122; " +#define BK4_NET_INIT "run set_gpio122;" + +/* Check if userdata volume shall be erased */ +#define MANAGE_USERDATA "if ${eraseuserdata}; " \ + "then ubi part system; " \ + "ubi remove userdata; " \ + "ubi create userdata; " \ + "ubi detach; " \ + "setenv eraseuserdata false; " \ + "saveenv; " \ + "fi; " + +/* Autoboot options */ +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT \ + "Enter passphrase to stop autoboot, booting in %d seconds\n" +#define CONFIG_AUTOBOOT_STOP_STR "123" + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> + +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* Enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 4 * SZ_1M) + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* NAND support */ +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +#define IMX_FEC1_BASE ENET1_BASE_ADDR + +/* QSPI Configs*/ +#ifdef CONFIG_FSL_QSPI +#define FSL_QSPI_FLASH_SIZE (SZ_16M) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SYS_FSL_QSPI_LE +#endif + +#define CONFIG_LOADADDR 0x82000000 + +/* We boot from the gfxRAM area of the OCRAM. */ +#define CONFIG_BOARD_SIZE_LIMIT 520192 + +/* boot command, including the target-defined one if any */ +#define CONFIG_BOOTCOMMAND BK4_BOOTCOMMAND "run bootcmd_nand" + +/* Extra env settings (including the target-defined ones if any) */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + BK4_EXTRA_ENV_SETTINGS \ + "autoload=no\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "blimg_file=u-boot.vyb\0" \ + "blimg_addr=0x81000000\0" \ + "dtbkernel_file=fitImage\0" \ + "dtbkernel_addr=0x82000000\0" \ + "ram_file=uRamdisk\0" \ + "ram_addr=0x83000000\0" \ + "filesys=rootfs.ubifs\0" \ + "sys_addr=0x81000000\0" \ + "nfs_root=/path/to/nfs/root\0" \ + "tftptimeout=1000\0" \ + "tftptimeoutcountmax=1000000\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "ipaddr=192.168.0.60\0" \ + "serverip=192.168.0.1\0" \ + "bootargs_base=setenv bootargs rw " \ + "console=ttyLP1,115200n8\0" \ + "bootargs_sd=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 rootwait\0" \ + "bootargs_nand=setenv bootargs ${bootargs} " \ + "ubi.mtd=5 rootfstype=" \ + "ubifs root=ubi0:rootfs${active_workset}\0" \ + "bootargs_ram=setenv bootargs ${bootargs} " \ + "root=/dev/ram rw initrd=${ram_addr}\0" \ + "bootargs_mtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "bootcmd_sd=run bootargs_base bootargs_sd bootargs_mtd; " \ + "fatload mmc 0:2 ${dtbkernel_addr} ${dtbkernel_file}; " \ + "bootm ${dtbkernel_addr}\0" \ + "bootcmd_nand=sf probe;run bootargs_base bootargs_nand bootargs_mtd; " \ + "ubi part dtbkernel; " \ + "ubi readvol ${dtbkernel_addr} dtbkernel${active_workset}; " \ + "led 0 on; " \ + "bootm ${dtbkernel_addr}\0" \ + "bootcmd_ram=run bootargs_base bootargs_ram bootargs_mtd; " \ + "nand read ${fdt_addr} dtb; " \ + "nand read ${kernel_addr} kernel; " \ + "nand read ${ram_addr} root; " \ + "bootz ${kernel_addr} ${ram_addr} ${fdt_addr}\0" \ + "update_bootloader_from_sd=if fatload mmc 0:2 ${blimg_addr} " \ + "${blimg_file}; " \ + "then sf probe; " \ + "mtdparts default; " \ + "nand erase.part bootloader; " \ + "nand write ${blimg_addr} bootloader ${filesize}; fi\0" \ + "update_bootloader_from_tftp=if tftp ${blimg_addr} "\ + "${tftpdir}${blimg_file}; "\ + "then sf probe; " \ + "mtdparts default; " \ + "nand erase.part bootloader; " \ + "nand write ${blimg_addr} bootloader ${filesize}; fi\0" \ + "update_dtbkernel_from_sd=if fatload mmc 0:2 ${dtbkernel_addr} " \ + "${dtbkernel_file}; " \ + "then sf probe; " \ + "ubi part dtbkernel; " \ + "ubi write ${dtbkernel_addr} dtbkernel${active_workset} " \ + "${filesize}; " \ + "ubi detach; fi\0" \ + "update_dtbkernel_from_tftp=if tftp ${dtbkernel_addr} " \ + "${tftpdir}${dtbkernel_file}; " \ + "then sf probe; " \ + "ubi part dtbkernel; " \ + "ubi write ${dtbkernel_addr} dtbkernel${active_workset} " \ + "${filesize}; " \ + "ubi detach; fi\0" \ + "update_ramdisk_from_sd=if fatload mmc 0:2 ${ram_addr} " \ + "${ram_file}; " \ + "then sf probe; " \ + "mtdparts default; " \ + "nand erase.part initrd; " \ + "nand write ${ram_addr} initrd ${filesize}; fi\0" \ + "update_ramdisk_from_tftp=if tftp ${ram_addr} ${tftpdir}${ram_file}; " \ + "then sf probe; " \ + "nand erase.part initrd; " \ + "nand write ${ram_addr} initrd ${filesize}; fi\0" \ + "update_rootfs_from_sd=if fatload mmc 0:2 ${sys_addr} " \ + "${filesys}; " \ + "then sf probe; " \ + "ubi part system; " \ + "ubi write ${sys_addr} rootfs${active_workset} ${filesize}; " \ + "ubi detach; fi\0" \ + "update_rootfs_from_tftp=if tftp ${sys_addr} ${tftpdir}${filesys}; " \ + "then sf probe; " \ + "ubi part system; " \ + "ubi write ${sys_addr} rootfs${active_workset} ${filesize}; " \ + "ubi detach; fi\0" \ + "active_workset=1\0" + +/* Miscellaneous configurable options */ + +#define CONFIG_SYS_MEMTEST_START 0x80010000 +#define CONFIG_SYS_MEMTEST_END 0x87C00000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* Physical memory map */ +#define PHYS_SDRAM (0x80000000) +#define PHYS_SDRAM_SIZE (SZ_512M) + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE
-/* add NOR to MTD env */ +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-/* now include standard PCM052 config */ +#ifdef CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SECT_SIZE (SZ_128K) +#define CONFIG_ENV_SIZE (SZ_8K) +#define CONFIG_ENV_OFFSET 0x200000 +#define CONFIG_ENV_SIZE_REDUND (SZ_8K) +#define CONFIG_ENV_OFFSET_REDUND 0x220000 +#endif
-#include "configs/pcm052.h" +#endif /* __CONFIG_H */
This commit cleans up the pcm052.c file to remove dead code after moving to DTS and DM.
board/phytec/pcm052/pcm052.c | 267 ------------------------------------------- 1 file changed, 267 deletions(-)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index 95df0be6c1..4a18b0e0f4 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -13,79 +13,9 @@ #include <asm/arch/ddrmc-vf610.h> #include <asm/arch/crm_regs.h> #include <asm/arch/clock.h> -#include <mmc.h> -#include <fsl_esdhc.h> -#include <miiphy.h> -#include <netdev.h> -#include <i2c.h>
DECLARE_GLOBAL_DATA_PTR;
-/* - * Default DDR pad settings in arch/arm/include/asm/arch-vf610/iomux-vf610.h - * do not match our settings. Let us (re)define our own settings here. - */ - -#define PCM052_VF610_DDR_PAD_CTRL PAD_CTL_DSE_20ohm -#define PCM052_VF610_DDR_PAD_CTRL_1 (PAD_CTL_DSE_20ohm | \ - PAD_CTL_INPUT_DIFFERENTIAL) -#define PCM052_VF610_DDR_RESET_PAD_CTL (PAD_CTL_DSE_150ohm | \ - PAD_CTL_PUS_100K_UP | \ - PAD_CTL_INPUT_DIFFERENTIAL) - -enum { - PCM052_VF610_PAD_DDR_RESETB = IOMUX_PAD(0x021c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_RESET_PAD_CTL), - PCM052_VF610_PAD_DDR_A15__DDR_A_15 = IOMUX_PAD(0x0220, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A14__DDR_A_14 = IOMUX_PAD(0x0224, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A13__DDR_A_13 = IOMUX_PAD(0x0228, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A12__DDR_A_12 = IOMUX_PAD(0x022c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A11__DDR_A_11 = IOMUX_PAD(0x0230, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A10__DDR_A_10 = IOMUX_PAD(0x0234, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A9__DDR_A_9 = IOMUX_PAD(0x0238, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A8__DDR_A_8 = IOMUX_PAD(0x023c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A7__DDR_A_7 = IOMUX_PAD(0x0240, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A6__DDR_A_6 = IOMUX_PAD(0x0244, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A5__DDR_A_5 = IOMUX_PAD(0x0248, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A4__DDR_A_4 = IOMUX_PAD(0x024c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A3__DDR_A_3 = IOMUX_PAD(0x0250, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A2__DDR_A_2 = IOMUX_PAD(0x0254, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A1__DDR_A_1 = IOMUX_PAD(0x0258, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_A0__DDR_A_0 = IOMUX_PAD(0x025c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_BA2__DDR_BA_2 = IOMUX_PAD(0x0260, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_BA1__DDR_BA_1 = IOMUX_PAD(0x0264, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_BA0__DDR_BA_0 = IOMUX_PAD(0x0268, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_CAS__DDR_CAS_B = IOMUX_PAD(0x026c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_CKE__DDR_CKE_0 = IOMUX_PAD(0x0270, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_CLK__DDR_CLK_0 = IOMUX_PAD(0x0274, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), - PCM052_VF610_PAD_DDR_CS__DDR_CS_B_0 = IOMUX_PAD(0x0278, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D15__DDR_D_15 = IOMUX_PAD(0x027c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D14__DDR_D_14 = IOMUX_PAD(0x0280, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D13__DDR_D_13 = IOMUX_PAD(0x0284, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D12__DDR_D_12 = IOMUX_PAD(0x0288, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D11__DDR_D_11 = IOMUX_PAD(0x028c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D10__DDR_D_10 = IOMUX_PAD(0x0290, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D9__DDR_D_9 = IOMUX_PAD(0x0294, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D8__DDR_D_8 = IOMUX_PAD(0x0298, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D7__DDR_D_7 = IOMUX_PAD(0x029c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D6__DDR_D_6 = IOMUX_PAD(0x02a0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D5__DDR_D_5 = IOMUX_PAD(0x02a4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D4__DDR_D_4 = IOMUX_PAD(0x02a8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D3__DDR_D_3 = IOMUX_PAD(0x02ac, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D2__DDR_D_2 = IOMUX_PAD(0x02b0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D1__DDR_D_1 = IOMUX_PAD(0x02b4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_D0__DDR_D_0 = IOMUX_PAD(0x02b8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_DQM1__DDR_DQM_1 = IOMUX_PAD(0x02bc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_DQM0__DDR_DQM_0 = IOMUX_PAD(0x02c0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_DQS1__DDR_DQS_1 = IOMUX_PAD(0x02c4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), - PCM052_VF610_PAD_DDR_DQS0__DDR_DQS_0 = IOMUX_PAD(0x02c8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), - PCM052_VF610_PAD_DDR_RAS__DDR_RAS_B = IOMUX_PAD(0x02cc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_WE__DDR_WE_B = IOMUX_PAD(0x02d0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_ODT1__DDR_ODT_0 = IOMUX_PAD(0x02d4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_ODT0__DDR_ODT_1 = IOMUX_PAD(0x02d8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 = IOMUX_PAD(0x02dc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), - PCM052_VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0 = IOMUX_PAD(0x02e0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), -}; - static struct ddrmc_cr_setting pcm052_cr_settings[] = { /* not in the datasheets, but in the original code */ { 0x00002000, 105 }, @@ -154,59 +84,6 @@ static struct ddrmc_phy_setting pcm052_phy_settings[] = {
int dram_init(void) { - static const iomux_v3_cfg_t pcm052_pads[] = { - PCM052_VF610_PAD_DDR_A15__DDR_A_15, - PCM052_VF610_PAD_DDR_A14__DDR_A_14, - PCM052_VF610_PAD_DDR_A13__DDR_A_13, - PCM052_VF610_PAD_DDR_A12__DDR_A_12, - PCM052_VF610_PAD_DDR_A11__DDR_A_11, - PCM052_VF610_PAD_DDR_A10__DDR_A_10, - PCM052_VF610_PAD_DDR_A9__DDR_A_9, - PCM052_VF610_PAD_DDR_A8__DDR_A_8, - PCM052_VF610_PAD_DDR_A7__DDR_A_7, - PCM052_VF610_PAD_DDR_A6__DDR_A_6, - PCM052_VF610_PAD_DDR_A5__DDR_A_5, - PCM052_VF610_PAD_DDR_A4__DDR_A_4, - PCM052_VF610_PAD_DDR_A3__DDR_A_3, - PCM052_VF610_PAD_DDR_A2__DDR_A_2, - PCM052_VF610_PAD_DDR_A1__DDR_A_1, - PCM052_VF610_PAD_DDR_A0__DDR_A_0, - PCM052_VF610_PAD_DDR_BA2__DDR_BA_2, - PCM052_VF610_PAD_DDR_BA1__DDR_BA_1, - PCM052_VF610_PAD_DDR_BA0__DDR_BA_0, - PCM052_VF610_PAD_DDR_CAS__DDR_CAS_B, - PCM052_VF610_PAD_DDR_CKE__DDR_CKE_0, - PCM052_VF610_PAD_DDR_CLK__DDR_CLK_0, - PCM052_VF610_PAD_DDR_CS__DDR_CS_B_0, - PCM052_VF610_PAD_DDR_D15__DDR_D_15, - PCM052_VF610_PAD_DDR_D14__DDR_D_14, - PCM052_VF610_PAD_DDR_D13__DDR_D_13, - PCM052_VF610_PAD_DDR_D12__DDR_D_12, - PCM052_VF610_PAD_DDR_D11__DDR_D_11, - PCM052_VF610_PAD_DDR_D10__DDR_D_10, - PCM052_VF610_PAD_DDR_D9__DDR_D_9, - PCM052_VF610_PAD_DDR_D8__DDR_D_8, - PCM052_VF610_PAD_DDR_D7__DDR_D_7, - PCM052_VF610_PAD_DDR_D6__DDR_D_6, - PCM052_VF610_PAD_DDR_D5__DDR_D_5, - PCM052_VF610_PAD_DDR_D4__DDR_D_4, - PCM052_VF610_PAD_DDR_D3__DDR_D_3, - PCM052_VF610_PAD_DDR_D2__DDR_D_2, - PCM052_VF610_PAD_DDR_D1__DDR_D_1, - PCM052_VF610_PAD_DDR_D0__DDR_D_0, - PCM052_VF610_PAD_DDR_DQM1__DDR_DQM_1, - PCM052_VF610_PAD_DDR_DQM0__DDR_DQM_0, - PCM052_VF610_PAD_DDR_DQS1__DDR_DQS_1, - PCM052_VF610_PAD_DDR_DQS0__DDR_DQS_0, - PCM052_VF610_PAD_DDR_RAS__DDR_RAS_B, - PCM052_VF610_PAD_DDR_WE__DDR_WE_B, - PCM052_VF610_PAD_DDR_ODT1__DDR_ODT_0, - PCM052_VF610_PAD_DDR_ODT0__DDR_ODT_1, - PCM052_VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1, - PCM052_VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0, - PCM052_VF610_PAD_DDR_RESETB, - }; - #if defined(CONFIG_TARGET_PCM052)
static const struct ddr3_jedec_timings pcm052_ddr_timings = { @@ -323,8 +200,6 @@ int dram_init(void)
#endif
- imx_iomux_v3_setup_multiple_pads(pcm052_pads, ARRAY_SIZE(pcm052_pads)); - ddrmc_ctrl_init_ddr3(&pcm052_ddr_timings, pcm052_cr_settings, pcm052_phy_settings, 1, row_diff);
@@ -333,135 +208,6 @@ int dram_init(void) return 0; }
-static void setup_iomux_uart(void) -{ - static const iomux_v3_cfg_t uart1_pads[] = { - NEW_PAD_CTRL(VF610_PAD_PTB4__UART1_TX, VF610_UART_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTB5__UART1_RX, VF610_UART_PAD_CTRL), - }; - - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); -} - -#define ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_HIGH | \ - PAD_CTL_DSE_50ohm | PAD_CTL_OBE_IBE_ENABLE) - -static void setup_iomux_enet(void) -{ - static const iomux_v3_cfg_t enet0_pads[] = { - NEW_PAD_CTRL(VF610_PAD_PTA6__RMII0_CLKIN, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC1__RMII0_MDIO, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC0__RMII0_MDC, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC2__RMII0_CRS_DV, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC3__RMII0_RD1, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC4__RMII0_RD0, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC5__RMII0_RXER, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC6__RMII0_TD1, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC7__RMII0_TD0, ENET_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTC8__RMII0_TXEN, ENET_PAD_CTRL), - }; - - imx_iomux_v3_setup_multiple_pads(enet0_pads, ARRAY_SIZE(enet0_pads)); -} - -/* - * I2C2 is the only I2C used, on pads PTA22/PTA23. - */ - -static void setup_iomux_i2c(void) -{ - static const iomux_v3_cfg_t i2c_pads[] = { - VF610_PAD_PTA22__I2C2_SCL, - VF610_PAD_PTA23__I2C2_SDA, - }; - - imx_iomux_v3_setup_multiple_pads(i2c_pads, ARRAY_SIZE(i2c_pads)); -} - -#ifdef CONFIG_NAND_VF610_NFC -static void setup_iomux_nfc(void) -{ - static const iomux_v3_cfg_t nfc_pads[] = { - VF610_PAD_PTD31__NF_IO15, - VF610_PAD_PTD30__NF_IO14, - VF610_PAD_PTD29__NF_IO13, - VF610_PAD_PTD28__NF_IO12, - VF610_PAD_PTD27__NF_IO11, - VF610_PAD_PTD26__NF_IO10, - VF610_PAD_PTD25__NF_IO9, - VF610_PAD_PTD24__NF_IO8, - VF610_PAD_PTD23__NF_IO7, - VF610_PAD_PTD22__NF_IO6, - VF610_PAD_PTD21__NF_IO5, - VF610_PAD_PTD20__NF_IO4, - VF610_PAD_PTD19__NF_IO3, - VF610_PAD_PTD18__NF_IO2, - VF610_PAD_PTD17__NF_IO1, - VF610_PAD_PTD16__NF_IO0, - VF610_PAD_PTB24__NF_WE_B, - VF610_PAD_PTB25__NF_CE0_B, - VF610_PAD_PTB27__NF_RE_B, - VF610_PAD_PTC26__NF_RB_B, - VF610_PAD_PTC27__NF_ALE, - VF610_PAD_PTC28__NF_CLE - }; - - imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads)); -} -#endif - -static void setup_iomux_qspi(void) -{ - static const iomux_v3_cfg_t qspi0_pads[] = { - VF610_PAD_PTD0__QSPI0_A_QSCK, - VF610_PAD_PTD1__QSPI0_A_CS0, - VF610_PAD_PTD2__QSPI0_A_DATA3, - VF610_PAD_PTD3__QSPI0_A_DATA2, - VF610_PAD_PTD4__QSPI0_A_DATA1, - VF610_PAD_PTD5__QSPI0_A_DATA0, - VF610_PAD_PTD7__QSPI0_B_QSCK, - VF610_PAD_PTD8__QSPI0_B_CS0, - VF610_PAD_PTD9__QSPI0_B_DATA3, - VF610_PAD_PTD10__QSPI0_B_DATA2, - VF610_PAD_PTD11__QSPI0_B_DATA1, - VF610_PAD_PTD12__QSPI0_B_DATA0, - }; - - imx_iomux_v3_setup_multiple_pads(qspi0_pads, ARRAY_SIZE(qspi0_pads)); -} - -#define ESDHC_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_HIGH | \ - PAD_CTL_DSE_20ohm | PAD_CTL_OBE_IBE_ENABLE) - -struct fsl_esdhc_cfg esdhc_cfg[1] = { - {ESDHC1_BASE_ADDR}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - /* eSDHC1 is always present */ - return 1; -} - -int board_mmc_init(bd_t *bis) -{ - static const iomux_v3_cfg_t esdhc1_pads[] = { - NEW_PAD_CTRL(VF610_PAD_PTA24__ESDHC1_CLK, ESDHC_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTA25__ESDHC1_CMD, ESDHC_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTA26__ESDHC1_DAT0, ESDHC_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTA27__ESDHC1_DAT1, ESDHC_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTA28__ESDHC1_DAT2, ESDHC_PAD_CTRL), - NEW_PAD_CTRL(VF610_PAD_PTA29__ESDHC1_DAT3, ESDHC_PAD_CTRL), - }; - - esdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - - imx_iomux_v3_setup_multiple_pads( - esdhc1_pads, ARRAY_SIZE(esdhc1_pads)); - - return fsl_esdhc_initialize(bis, &esdhc_cfg[0]); -} - static void clock_init(void) { struct ccm_reg *ccm = (struct ccm_reg *)CCM_BASE_ADDR; @@ -534,23 +280,10 @@ static void mscm_init(void) writew(MSCM_IRSPRC_CP0_EN, &mscmir->irsprc[i]); }
-int board_phy_config(struct phy_device *phydev) -{ - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - int board_early_init_f(void) { clock_init(); mscm_init(); - setup_iomux_uart(); - setup_iomux_enet(); - setup_iomux_i2c(); - setup_iomux_qspi(); - setup_iomux_nfc();
return 0; }
include/configs/bk4r1.h | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index bbd3e4e636..7bd3411ff2 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -189,6 +189,37 @@ "ubi part system; " \ "ubi write ${sys_addr} rootfs${active_workset} ${filesize}; " \ "ubi detach; fi\0" \ + "setup_dtbkernel=nand erase.part dtbkernel; " \ + "ubi part dtbkernel; " \ + "ubi create dtbkernel1 972000 s; " \ + "ubi create dtbkernel2 972000 s; " \ + "ubi detach\0" \ + "setup_system=nand erase.part system; " \ + "ubi part system; " \ + "ubi create rootfs1 15E15000 d; " \ + "ubi create rootfs2 15E15000 d; " \ + "ubi create userdata; " \ + "ubi detach\0" \ + "prepare_install_bk4r1_envs=" \ + "echo 'Preparing envs for SD card recovery!';" \ + "setenv ipaddr 192.168.0.99;" \ + "setenv serverip 192.168.0.50;" \ + "\0" \ + "install_bk4r1rs="\ + "led 0 on; " \ + "nand erase.chip; mtdparts default; "\ + "led 1 on; "\ + "run setup_dtbkernel; " \ + "run setup_system; " \ + "led 2 on;" \ + "run update_bootloader_from_sd; "\ + "run update_dtbkernel_from_sd; "\ + "run update_rootfs_from_sd; "\ + "setenv bootcmd 'run bootcmd_nand'; "\ + "saveenv; " \ + "led 3 on; " \ + "echo Finished - Please Power off, REMOVE SDCARD and set boot" \ + "source to NAND\0" \ "active_workset=1\0"
include/configs/bk4r1.h | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index 7bd3411ff2..05ebb7d9c5 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -200,6 +200,24 @@ "ubi create rootfs2 15E15000 d; " \ "ubi create userdata; " \ "ubi detach\0" \ + "setup_nor1=" BK4_NET_INIT \ + "if tftp ${sys_addr} ${tftpdir}ubinor1.img; " \ + "then sf probe 0:0; " \ + "sf erase 0 01000000; " \ + "mtdparts default; " \ + "ubi part nor; " \ + "ubi create nor1fs; " \ + "ubi write ${sys_addr} nor1fs ${filesize}; " \ + "ubi detach; fi\0" \ + "setup_nor2=" BK4_NET_INIT \ + "if tftp ${sys_addr} ${tftpdir}ubinor2.img; " \ + "then sf probe 0:1; " \ + "sf erase 0 01000000; " \ + "mtdparts default; " \ + "ubi part nor; " \ + "ubi create nor2fs; " \ + "ubi write ${sys_addr} nor2fs ${filesize}; " \ + "ubi detach; fi\0" \ "prepare_install_bk4r1_envs=" \ "echo 'Preparing envs for SD card recovery!';" \ "setenv ipaddr 192.168.0.99;" \
This code allows reusing the default u-boot as in the late board init, the default envs are restored and proper recovery scripts executed.
arch/arm/cpu/armv7/vf610/Kconfig | 1 + arch/arm/include/asm/arch-vf610/imx-regs.h | 2 ++ board/phytec/pcm052/pcm052.c | 32 ++++++++++++++++++++++++++++++ 3 files changed, 35 insertions(+)
diff --git a/arch/arm/cpu/armv7/vf610/Kconfig b/arch/arm/cpu/armv7/vf610/Kconfig index 13905b5281..5d485a3ce2 100644 --- a/arch/arm/cpu/armv7/vf610/Kconfig +++ b/arch/arm/cpu/armv7/vf610/Kconfig @@ -23,6 +23,7 @@ config TARGET_BK4R1 bool "BK4r1" select SYS_FSL_ERRATUM_ESDHC135 select SYS_FSL_ERRATUM_ESDHC_A001 + select BOARD_LATE_INIT
endchoice
diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index 5d1f63c98b..ae0a187c4d 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -289,6 +289,8 @@ #define SRC_SRSR_WDOG_M4 (0x1 << 4) #define SRC_SRSR_WDOG_A5 (0x1 << 3) #define SRC_SRSR_POR_RST (0x1 << 0) +#define SRC_SBMR1_BOOTCFG1_SDMMC BIT(6) +#define SRC_SBMR1_BOOTCFG1_MMC BIT(4) #define SRC_SBMR2_BMOD_MASK (0x3 << 24) #define SRC_SBMR2_BMOD_SHIFT 24 #define SRC_SBMR2_BMOD_FUSES 0x0 diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index 4a18b0e0f4..d4f170a503 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -13,6 +13,7 @@ #include <asm/arch/ddrmc-vf610.h> #include <asm/arch/crm_regs.h> #include <asm/arch/clock.h> +#include <environment.h>
@@ -307,6 +308,37 @@ int board_init(void) return 0; }
+#ifdef CONFIG_TARGET_BK4R1 +int board_late_init(void) +{ + struct src *psrc = (struct src *)SRC_BASE_ADDR; + u32 reg; + + /* + * BK4r1 handle emergency/service SD card boot + * Checking the SBMR1 register BOOTCFG1 byte: + * NAND: + * bit [2] - NAND data width - 16 + * bit [5] - NAND fast boot + * bit [7] = 1 - NAND as a source of booting + * SD card (0x64): + * bit [4] = 0 - SD card source + * bit [6] = 1 - SD/MMC source + */ + + reg = readl(&psrc->sbmr1); + if ((reg & SRC_SBMR1_BOOTCFG1_SDMMC) && + !(reg & SRC_SBMR1_BOOTCFG1_MMC)) { + printf("------ SD card boot -------\n"); + set_default_env("!LVFBootloader", 0); + env_set("bootcmd", + "run prepare_install_bk4r1_envs; run install_bk4r1rs"); + } + + return 0; +} +#endif /* CONFIG_TARGET_BK4R1 */ + int checkboard(void) { #ifdef CONFIG_TARGET_BK4R1
As one has moved to DM based LEDs, this code is required to setup the default state.
board/phytec/pcm052/pcm052.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index d4f170a503..721e25105a 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -13,6 +13,7 @@ #include <asm/arch/ddrmc-vf610.h> #include <asm/arch/crm_regs.h> #include <asm/arch/clock.h> +#include <led.h> #include <environment.h>
DECLARE_GLOBAL_DATA_PTR; @@ -314,6 +315,9 @@ int board_late_init(void) struct src *psrc = (struct src *)SRC_BASE_ADDR; u32 reg;
+ if (IS_ENABLED(CONFIG_LED)) + led_default_state(); + /* * BK4r1 handle emergency/service SD card boot * Checking the SBMR1 register BOOTCFG1 byte:
This commit introduces the board specific function to read fused mac address.
board/phytec/pcm052/pcm052.c | 41 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index 721e25105a..1e443a5850 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -310,6 +310,47 @@ int board_init(void) }
#ifdef CONFIG_TARGET_BK4R1 +void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[4]; + struct fuse_bank4_regs *fuse = + (struct fuse_bank4_regs *)bank->fuse_regs; + u32 value; + + /* + * BK4 has different layout of stored MAC address + * than one used in imx_get_mac_from_fuse() @ generic.c + */ + + switch (dev_id) { + case 0: + value = readl(&fuse->mac_addr1); + + mac[0] = value >> 8; + mac[1] = value; + + value = readl(&fuse->mac_addr0); + mac[2] = value >> 24; + mac[3] = value >> 16; + mac[4] = value >> 8; + mac[5] = value; + break; + case 1: + value = readl(&fuse->mac_addr2); + + mac[0] = value >> 24; + mac[1] = value >> 16; + mac[2] = value >> 8; + mac[3] = value; + + value = readl(&fuse->mac_addr1); + mac[4] = value >> 24; + mac[5] = value >> 16; + break; + } +} + int board_late_init(void) { struct src *psrc = (struct src *)SRC_BASE_ADDR;
BK4 requires setup of 50MHz reference clock for its KSZ8081 PHY devices.
board/phytec/pcm052/pcm052.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index 1e443a5850..c30df5df9d 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -15,6 +15,7 @@ #include <asm/arch/clock.h> #include <led.h> #include <environment.h> +#include <miiphy.h>
@@ -382,6 +383,21 @@ int board_late_init(void)
return 0; } + +/** + * KSZ8081 + */ +#define MII_KSZ8081_REFERENCE_CLOCK_SELECT 0x1f +#define RMII_50MHz_CLOCK 0x8180 + +int board_phy_config(struct phy_device *phydev) +{ + /* Set 50 MHz reference clock */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_KSZ8081_REFERENCE_CLOCK_SELECT, + RMII_50MHz_CLOCK); + + return genphy_config(phydev); +} #endif /* CONFIG_TARGET_BK4R1 */
Lukasz Majewski
Marcel Ziswiler
Stefan Agner
