[U-Boot] [PATCH] arm: omap: Extract OMAP5 boot environment to separate file
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- include/configs/ti_omap5_common.h | 60 ++-------------------------- include/environment/ti/boot.h | 83 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 86 insertions(+), 57 deletions(-) create mode 100644 include/environment/ti/boot.h
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index d45baabf0b..4c3a2766ec 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -50,14 +50,12 @@ /* * Environment setup */ -#ifndef PARTS_DEFAULT -#define PARTS_DEFAULT -#endif
#ifndef DFUARGS #define DFUARGS #endif
+#include <environment/ti/boot.h> #include <environment/ti/mmc.h>
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -65,63 +63,11 @@ DEFAULT_LINUX_BOOT_ENV \ DEFAULT_MMC_TI_ARGS \ DEFAULT_FIT_TI_ARGS \ - "console=" CONSOLEDEV ",115200n8\0" \ - "fdtfile=undefined\0" \ - "bootpart=0:2\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ - "usbtty=cdc_acm\0" \ - "vram=16M\0" \ - "partitions=" PARTS_DEFAULT "\0" \ - "optargs=\0" \ - "dofastboot=0\0" \ - "findfdt="\ - "if test $board_name = omap5_uevm; then " \ - "setenv fdtfile omap5-uevm.dtb; fi; " \ - "if test $board_name = dra7xx; then " \ - "setenv fdtfile dra7-evm.dtb; fi;" \ - "if test $board_name = dra72x-revc; then " \ - "setenv fdtfile dra72-evm-revc.dtb; fi;" \ - "if test $board_name = dra72x; then " \ - "setenv fdtfile dra72-evm.dtb; fi;" \ - "if test $board_name = dra71x; then " \ - "setenv fdtfile dra71-evm.dtb; fi;" \ - "if test $board_name = beagle_x15; then " \ - "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ - "if test $board_name = beagle_x15_revb1; then " \ - "setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;" \ - "if test $board_name = am572x_idk; then " \ - "setenv fdtfile am572x-idk.dtb; fi;" \ - "if test $board_name = am57xx_evm; then " \ - "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ - "if test $board_name = am57xx_evm_reva3; then " \ - "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ - "if test $board_name = am571x_idk; then " \ - "setenv fdtfile am571x-idk.dtb; fi;" \ - "if test $fdtfile = undefined; then " \ - "echo WARNING: Could not determine device tree to use; fi; \0" \ + DEFAULT_COMMON_BOOT_TI_ARGS \ + DEFAULT_FDT_TI_ARGS \ DFUARGS \ NETARGS \
-#define CONFIG_BOOTCOMMAND \ - "if test ${dofastboot} -eq 1; then " \ - "echo Boot fastboot requested, resetting dofastboot ...;" \ - "setenv dofastboot 0; saveenv;" \ - "echo Booting into fastboot ...; " \ - "fastboot " __stringify(CONFIG_FASTBOOT_USB_DEV) "; " \ - "fi;" \ - "if test ${boot_fit} -eq 1; then " \ - "run update_to_fit;" \ - "fi;" \ - "run findfdt; " \ - "run envboot; " \ - "run mmcboot;" \ - "setenv mmcdev 1; " \ - "setenv bootpart 1:2; " \ - "setenv mmcroot /dev/mmcblk0p2 rw; " \ - "run mmcboot;" \ - "" - /* * SPL related defines. The Public RAM memory map the ROM defines the * area between 0x40300000 and 0x4031E000 as a download area for OMAP5. diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h new file mode 100644 index 0000000000..1c3ae40a99 --- /dev/null +++ b/include/environment/ti/boot.h @@ -0,0 +1,83 @@ +/* + * Boot related environment variable definitions on TI boards. + * + * (C) Copyright 2017 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __TI_BOOT_H +#define __TI_BOOT_H + +#ifndef CONSOLEDEV +#define CONSOLEDEV "ttyO2" +#endif + +#ifndef PARTS_DEFAULT +#define PARTS_DEFAULT +#endif + +#define DEFAULT_COMMON_BOOT_TI_ARGS \ + "console=" CONSOLEDEV ",115200n8\0" \ + "fdtfile=undefined\0" \ + "bootpart=0:2\0" \ + "bootdir=/boot\0" \ + "bootfile=zImage\0" \ + "usbtty=cdc_acm\0" \ + "vram=16M\0" \ + "partitions=" PARTS_DEFAULT "\0" \ + "optargs=\0" \ + "dofastboot=0\0" + +#ifdef CONFIG_OMAP54XX + +#define DEFAULT_FDT_TI_ARGS \ + "findfdt="\ + "if test $board_name = omap5_uevm; then " \ + "setenv fdtfile omap5-uevm.dtb; fi; " \ + "if test $board_name = dra7xx; then " \ + "setenv fdtfile dra7-evm.dtb; fi;" \ + "if test $board_name = dra72x-revc; then " \ + "setenv fdtfile dra72-evm-revc.dtb; fi;" \ + "if test $board_name = dra72x; then " \ + "setenv fdtfile dra72-evm.dtb; fi;" \ + "if test $board_name = dra71x; then " \ + "setenv fdtfile dra71-evm.dtb; fi;" \ + "if test $board_name = beagle_x15; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = beagle_x15_revb1; then " \ + "setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;" \ + "if test $board_name = am572x_idk; then " \ + "setenv fdtfile am572x-idk.dtb; fi;" \ + "if test $board_name = am57xx_evm; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = am57xx_evm_reva3; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = am571x_idk; then " \ + "setenv fdtfile am571x-idk.dtb; fi;" \ + "if test $fdtfile = undefined; then " \ + "echo WARNING: Could not determine device tree to use; fi; \0" + +#define CONFIG_BOOTCOMMAND \ + "if test ${dofastboot} -eq 1; then " \ + "echo Boot fastboot requested, resetting dofastboot ...;" \ + "setenv dofastboot 0; saveenv;" \ + "echo Booting into fastboot ...; " \ + "fastboot " __stringify(CONFIG_FASTBOOT_USB_DEV) "; " \ + "fi;" \ + "if test ${boot_fit} -eq 1; then " \ + "run update_to_fit;" \ + "fi;" \ + "run findfdt; " \ + "run envboot; " \ + "run mmcboot;" \ + "setenv mmcdev 1; " \ + "setenv bootpart 1:2; " \ + "setenv mmcroot /dev/mmcblk0p2 rw; " \ + "run mmcboot;" \ + "" + +#endif /* CONFIG_OMAP54XX */ + +#endif /* __TI_BOOT_H */
As an initial move: Reviewed-by: Tom Rini trini@konsulko.com
But this shows that when we start moving other platforms we need to key the findfdt logic off of SoC, but share bootcmd stuff based on features, rather than SoC.
On Wed, Jun 14, 2017 at 09:34:23PM +0300, Semen Protsenko wrote:
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Reviewed-by: Tom Rini trini@konsulko.com
Sam Protsenko
