[U-Boot] [PATCH v5] MX31: Introduce get_reset_cause()
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v4: - Make get_reset_cause CPU specific code and no need to add any board specific call.
arch/arm/cpu/arm1136/mx31/generic.c | 29 ++++++++++++++++++++++++++++- 1 files changed, 28 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx31/generic.c b/arch/arm/cpu/arm1136/mx31/generic.c index 9b7a7a2..a92731e 100644 --- a/arch/arm/cpu/arm1136/mx31/generic.c +++ b/arch/arm/cpu/arm1136/mx31/generic.c @@ -132,11 +132,38 @@ char *get_cpu_rev(void) return "unknown"; }
+char *get_reset_cause(void) +{ + /* read RCSR register from CCM module */ + struct clock_control_regs *ccm = + (struct clock_control_regs *)CCM_BASE; + + u32 cause = readl(&ccm->rcsr) & 0x07; + + switch (cause) { + case 0x0000: + return "POR"; + break; + case 0x0001: + return "RST"; + break; + case 0x0002: + return "WDOG"; + break; + case 0x0006: + return "JTAG"; + break; + default: + return "unknown reset"; + } +} + #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo (void) { - printf("CPU: Freescale i.MX31 rev %s at %d MHz\n", + printf("CPU: Freescale i.MX31 rev %s at %d MHz.", get_cpu_rev(), mx31_get_mcu_main_clk() / 1000000); + printf("Reset cause: %s\n", get_reset_cause()); return 0; } #endif
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx31pdk/mx31pdk.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 3f291fc..826fb4a 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -70,7 +70,7 @@ int board_init(void)
int checkboard(void) { - printf("Board: i.MX31 MAX PDK (3DS)\n"); + printf("Board: MX31PDK\n"); return 0; }
Hi Fabio,
Changes since v4:
Thanks, this looks good. Now all i.MX31 boards profit!
Acked-by: Detlev Zundel dzu@denx.de
Le 19/04/2011 17:17, Detlev Zundel a écrit :
Hi Fabio,
Signed-off-by: Fabio Estevamfabio.estevam@freescale.com
Changes since v4:
Acked-by: Detlev Zundeldzu@denx.de
Stefano, does this get in your tree?
Amicalement,
Albert ARIBAUD
Detlev Zundel
Fabio Estevam
