[U-Boot] [PATCH 1/3] imx8mq_evk: README: Need to copy bl31.bin to U-Boot source tree
After building ATF it is needed to copy the generated bl31.bin file to the U-Boot source tree.
Make this step explicit in the instructions.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/imx8mq_evk/README | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/freescale/imx8mq_evk/README b/board/freescale/imx8mq_evk/README index 2529f7da3d..bd5ee12722 100644 --- a/board/freescale/imx8mq_evk/README +++ b/board/freescale/imx8mq_evk/README @@ -9,13 +9,14 @@ Quick Start
Get and Build the ARM Trusted firmware ==================== +Note: srctree is U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf branch: imx_4.14.62_1.0.0_beta $ make PLAT=imx8mq bl31 +$ cp build/imx8mq/release/bl31.bin $(srctree)
Get the ddr and hdmi firmware ==================== -Note: srctree is U-Boot source directory $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.9.bin $ chmod +x firmware-imx-7.9.bin $ ./firmware-imx-7.9.bin
The DDR firmware binaries should be copied to '$(srctree)', so fix a typo.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/imx8mq_evk/README | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/imx8mq_evk/README b/board/freescale/imx8mq_evk/README index bd5ee12722..aa9fbd8eaf 100644 --- a/board/freescale/imx8mq_evk/README +++ b/board/freescale/imx8mq_evk/README @@ -21,7 +21,7 @@ $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.9.bin $ chmod +x firmware-imx-7.9.bin $ ./firmware-imx-7.9.bin $ cp firmware-imx-7.9/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(srctree) -$ cp firmware-imx-7.9/firmware/ddr/synopsys/lpddr4*.bin $(srctee) +$ cp firmware-imx-7.9/firmware/ddr/synopsys/lpddr4*.bin $(srctree)
Build U-Boot ====================
The DDR firmware binaries should be copied to '$(srctree)', so fix a typo. Signed-off-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Let the underline marker "=" fill the whole sentence for better readability.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/imx8mq_evk/README | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/freescale/imx8mq_evk/README b/board/freescale/imx8mq_evk/README index aa9fbd8eaf..c1d400bcf9 100644 --- a/board/freescale/imx8mq_evk/README +++ b/board/freescale/imx8mq_evk/README @@ -1,14 +1,14 @@ U-Boot for the NXP i.MX8MQ EVK board
Quick Start -==================== +=========== - Build the ARM Trusted firmware binary - Get ddr and hdmi fimware - Build U-Boot - Boot
Get and Build the ARM Trusted firmware -==================== +====================================== Note: srctree is U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf branch: imx_4.14.62_1.0.0_beta @@ -16,7 +16,7 @@ $ make PLAT=imx8mq bl31 $ cp build/imx8mq/release/bl31.bin $(srctree)
Get the ddr and hdmi firmware -==================== +============================= $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.9.bin $ chmod +x firmware-imx-7.9.bin $ ./firmware-imx-7.9.bin @@ -24,7 +24,7 @@ $ cp firmware-imx-7.9/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(srctree) $ cp firmware-imx-7.9/firmware/ddr/synopsys/lpddr4*.bin $(srctree)
Build U-Boot -==================== +============ $ export CROSS_COMPILE=aarch64-poky-linux- $ make imx8mq_evk_defconfig $ make flash.bin @@ -33,5 +33,5 @@ Burn the flash.bin to MicroSD card offset 33KB $sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=33
Boot -==================== +==== Set Boot switch SW801: 1100 and Bmode: 10 to boot from Micro SD.
Let the underline marker "=" fill the whole sentence for better readability. Signed-off-by: Fabio Estevam festevam@gmail.com
After building ATF it is needed to copy the generated bl31.bin file to the U-Boot source tree. Make this step explicit in the instructions. Signed-off-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
sbabic@denx.de
