[U-Boot] [PATCH] fs: ext4: fix symlink read function
Since last API changes for files >2GB, the read of symlink is broken as ext4fs_read_file now returns 0 instead of the length of the actual read.
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com --- Hi all,
Switching from an old v2014.07 to v2015.07 we've noticed that we couldn't read symlinks any more. This is due to the API changes made to ext4fs_read_file (commit 9f12cd0).
This patch makes the read symlink check both for errors (status < 0) and actual read length.
Regards, Gary --- fs/ext4/ext4_common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index cab5465..e2ab145 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -2040,7 +2040,7 @@ static char *ext4fs_read_symlink(struct ext2fs_node *node) status = ext4fs_read_file(diro, 0, __le32_to_cpu(diro->inode.size), symlink, &actread); - if (status == 0) { + if ((status < 0) || (actread == 0)) { free(symlink); return 0; }
Hi Gary,
On 7 September 2015 at 03:20, Gary Bisson gary.bisson@boundarydevices.com wrote:
Hi all,
Regards, Gary
Thanks for fixing this. Does the filesystem test (test/fs-test.sh) show this error? How could we enhance the test to detect this?
if (status == 0) {
-- 2.5.1
Hi Simon,
On Tue, Sep 8, 2015 at 5:56 AM, Simon Glass sjg@chromium.org wrote:
Hi Gary,
Hi all,
Regards, Gary
I wasn't aware of this testing script, a quick look at it makes me think it doesn't check anything symlink-related. I guess it would require to add SYMLINK_FILE that points to either SMALL_FILE or BIG_FILE, read it and check the md5sum.
Regards, Gary
Hi Gary,
On Tuesday, 8 September 2015, Gary Bisson gary.bisson@boundarydevices.com wrote:
Hi Simon,
Hi Gary,
Hi all,
Regards, Gary
Yes I think that will work. Are you going to take a look?
Gary Bisson
