[U-Boot] [Patch V7 01/18] armv7/ls1021a: move ns_access to common file
Config Security Level Register is different between different SoCs, so put the CSL register definition into the arch specific directory.
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V7: - Fix the macro for ls1021atwr. V6: - No change. V5: - No change. V4: - No change. V3: - No change. V2: - Create include/fsl_csu.h instead of board/freescale/common/ns_access.h
arch/arm/include/asm/arch-ls102xa/ns_access.h | 103 ++++++++++++++++++++------ board/freescale/common/Makefile | 2 +- board/freescale/common/ns_access.c | 8 +- board/freescale/ls1021aqds/ls1021aqds.c | 101 ++----------------------- board/freescale/ls1021atwr/ls1021atwr.c | 102 ++----------------------- include/configs/ls1021aqds.h | 2 +- include/configs/ls1021atwr.h | 2 +- include/fsl_csu.h | 34 +++++++++ 8 files changed, 141 insertions(+), 213 deletions(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/ns_access.h b/arch/arm/include/asm/arch-ls102xa/ns_access.h index b53f699..a921fb6 100644 --- a/arch/arm/include/asm/arch-ls102xa/ns_access.h +++ b/arch/arm/include/asm/arch-ls102xa/ns_access.h @@ -7,22 +7,6 @@ #ifndef __FSL_NS_ACCESS_H_ #define __FSL_NS_ACCESS_H_
-enum csu_cslx_access { - CSU_NS_SUP_R = 0x08, - CSU_NS_SUP_W = 0x80, - CSU_NS_SUP_RW = 0x88, - CSU_NS_USER_R = 0x04, - CSU_NS_USER_W = 0x40, - CSU_NS_USER_RW = 0x44, - CSU_S_SUP_R = 0x02, - CSU_S_SUP_W = 0x20, - CSU_S_SUP_RW = 0x22, - CSU_S_USER_R = 0x01, - CSU_S_USER_W = 0x10, - CSU_S_USER_RW = 0x11, - CSU_ALL_RW = 0xff, -}; - enum csu_cslx_ind { CSU_CSLX_PCIE2_IO = 0, CSU_CSLX_PCIE1_IO, @@ -108,11 +92,88 @@ enum csu_cslx_ind { CSU_CSLX_MAX, };
-struct csu_ns_dev { - unsigned long ind; - uint32_t val; +static struct csu_ns_dev ns_dev[] = { + { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, + { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, + { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, + { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, + { CSU_CSLX_OCRAM, CSU_ALL_RW }, + { CSU_CSLX_GIC, CSU_ALL_RW }, + { CSU_CSLX_PCIE1, CSU_ALL_RW }, + { CSU_CSLX_OCRAM2, CSU_ALL_RW }, + { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, + { CSU_CSLX_PCIE2, CSU_ALL_RW }, + { CSU_CSLX_SATA, CSU_ALL_RW }, + { CSU_CSLX_USB3, CSU_ALL_RW }, + { CSU_CSLX_SERDES, CSU_ALL_RW }, + { CSU_CSLX_QDMA, CSU_ALL_RW }, + { CSU_CSLX_LPUART2, CSU_ALL_RW }, + { CSU_CSLX_LPUART1, CSU_ALL_RW }, + { CSU_CSLX_LPUART4, CSU_ALL_RW }, + { CSU_CSLX_LPUART3, CSU_ALL_RW }, + { CSU_CSLX_LPUART6, CSU_ALL_RW }, + { CSU_CSLX_LPUART5, CSU_ALL_RW }, + { CSU_CSLX_DSPI2, CSU_ALL_RW }, + { CSU_CSLX_DSPI1, CSU_ALL_RW }, + { CSU_CSLX_QSPI, CSU_ALL_RW }, + { CSU_CSLX_ESDHC, CSU_ALL_RW }, + { CSU_CSLX_2D_ACE, CSU_ALL_RW }, + { CSU_CSLX_IFC, CSU_ALL_RW }, + { CSU_CSLX_I2C1, CSU_ALL_RW }, + { CSU_CSLX_USB2, CSU_ALL_RW }, + { CSU_CSLX_I2C3, CSU_ALL_RW }, + { CSU_CSLX_I2C2, CSU_ALL_RW }, + { CSU_CSLX_DUART2, CSU_ALL_RW }, + { CSU_CSLX_DUART1, CSU_ALL_RW }, + { CSU_CSLX_WDT2, CSU_ALL_RW }, + { CSU_CSLX_WDT1, CSU_ALL_RW }, + { CSU_CSLX_EDMA, CSU_ALL_RW }, + { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, + { CSU_CSLX_DDR, CSU_ALL_RW }, + { CSU_CSLX_QUICC, CSU_ALL_RW }, + { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, + { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, + { CSU_CSLX_SFP, CSU_ALL_RW }, + { CSU_CSLX_TMU, CSU_ALL_RW }, + { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, + { CSU_CSLX_RESERVED0, CSU_ALL_RW }, + { CSU_CSLX_ETSEC1, CSU_ALL_RW }, + { CSU_CSLX_SEC5_5, CSU_ALL_RW }, + { CSU_CSLX_ETSEC3, CSU_ALL_RW }, + { CSU_CSLX_ETSEC2, CSU_ALL_RW }, + { CSU_CSLX_GPIO2, CSU_ALL_RW }, + { CSU_CSLX_GPIO1, CSU_ALL_RW }, + { CSU_CSLX_GPIO4, CSU_ALL_RW }, + { CSU_CSLX_GPIO3, CSU_ALL_RW }, + { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, + { CSU_CSLX_CSU, CSU_ALL_RW }, + { CSU_CSLX_ASRC, CSU_ALL_RW }, + { CSU_CSLX_SPDIF, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, + { CSU_CSLX_SAI2, CSU_ALL_RW }, + { CSU_CSLX_SAI1, CSU_ALL_RW }, + { CSU_CSLX_SAI4, CSU_ALL_RW }, + { CSU_CSLX_SAI3, CSU_ALL_RW }, + { CSU_CSLX_FTM2, CSU_ALL_RW }, + { CSU_CSLX_FTM1, CSU_ALL_RW }, + { CSU_CSLX_FTM4, CSU_ALL_RW }, + { CSU_CSLX_FTM3, CSU_ALL_RW }, + { CSU_CSLX_FTM6, CSU_ALL_RW }, + { CSU_CSLX_FTM5, CSU_ALL_RW }, + { CSU_CSLX_FTM8, CSU_ALL_RW }, + { CSU_CSLX_FTM7, CSU_ALL_RW }, + { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, + { CSU_CSLX_EPU, CSU_ALL_RW }, + { CSU_CSLX_GDI, CSU_ALL_RW }, + { CSU_CSLX_DDI, CSU_ALL_RW }, + { CSU_CSLX_RESERVED1, CSU_ALL_RW }, + { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, + { CSU_CSLX_RESERVED2, CSU_ALL_RW }, };
-void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num); - #endif diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 87d0578..51d2814 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -71,7 +71,7 @@ obj-$(CONFIG_P4080DS) += p_corenet/ obj-$(CONFIG_P5020DS) += p_corenet/ obj-$(CONFIG_P5040DS) += p_corenet/
-obj-$(CONFIG_LS102XA_NS_ACCESS) += ns_access.o +obj-$(CONFIG_LAYERSCAPE_NS_ACCESS) += ns_access.o
ifdef CONFIG_SECURE_BOOT obj-$(CONFIG_CMD_ESBC_VALIDATE) += fsl_validate.o cmd_esbc_validate.o diff --git a/board/freescale/common/ns_access.c b/board/freescale/common/ns_access.c index d7de982..d8d16c5 100644 --- a/board/freescale/common/ns_access.c +++ b/board/freescale/common/ns_access.c @@ -6,9 +6,10 @@
#include <common.h> #include <asm/io.h> +#include <fsl_csu.h> #include <asm/arch/ns_access.h>
-void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) +static void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) { u32 *base = (u32 *)CONFIG_SYS_FSL_CSU_ADDR; u32 *reg; @@ -28,3 +29,8 @@ void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) out_be32(reg, val); } } + +void enable_layerscape_ns_access(void) +{ + enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +} diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 655fc64..612f17e 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -8,13 +8,13 @@ #include <i2c.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> -#include <asm/arch/ns_access.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> #include <asm/arch/ls102xa_devdis.h> #include <hwconfig.h> #include <mmc.h> +#include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> #include <fsl_sec.h> @@ -56,92 +56,6 @@ enum { GE1_CLK125, };
-#ifdef CONFIG_LS102XA_NS_ACCESS -static struct csu_ns_dev ns_dev[] = { - { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, - { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, - { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, - { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, - { CSU_CSLX_OCRAM, CSU_ALL_RW }, - { CSU_CSLX_GIC, CSU_ALL_RW }, - { CSU_CSLX_PCIE1, CSU_ALL_RW }, - { CSU_CSLX_OCRAM2, CSU_ALL_RW }, - { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, - { CSU_CSLX_PCIE2, CSU_ALL_RW }, - { CSU_CSLX_SATA, CSU_ALL_RW }, - { CSU_CSLX_USB3, CSU_ALL_RW }, - { CSU_CSLX_SERDES, CSU_ALL_RW }, - { CSU_CSLX_QDMA, CSU_ALL_RW }, - { CSU_CSLX_LPUART2, CSU_ALL_RW }, - { CSU_CSLX_LPUART1, CSU_ALL_RW }, - { CSU_CSLX_LPUART4, CSU_ALL_RW }, - { CSU_CSLX_LPUART3, CSU_ALL_RW }, - { CSU_CSLX_LPUART6, CSU_ALL_RW }, - { CSU_CSLX_LPUART5, CSU_ALL_RW }, - { CSU_CSLX_DSPI2, CSU_ALL_RW }, - { CSU_CSLX_DSPI1, CSU_ALL_RW }, - { CSU_CSLX_QSPI, CSU_ALL_RW }, - { CSU_CSLX_ESDHC, CSU_ALL_RW }, - { CSU_CSLX_2D_ACE, CSU_ALL_RW }, - { CSU_CSLX_IFC, CSU_ALL_RW }, - { CSU_CSLX_I2C1, CSU_ALL_RW }, - { CSU_CSLX_USB2, CSU_ALL_RW }, - { CSU_CSLX_I2C3, CSU_ALL_RW }, - { CSU_CSLX_I2C2, CSU_ALL_RW }, - { CSU_CSLX_DUART2, CSU_ALL_RW }, - { CSU_CSLX_DUART1, CSU_ALL_RW }, - { CSU_CSLX_WDT2, CSU_ALL_RW }, - { CSU_CSLX_WDT1, CSU_ALL_RW }, - { CSU_CSLX_EDMA, CSU_ALL_RW }, - { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, - { CSU_CSLX_DDR, CSU_ALL_RW }, - { CSU_CSLX_QUICC, CSU_ALL_RW }, - { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, - { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, - { CSU_CSLX_SFP, CSU_ALL_RW }, - { CSU_CSLX_TMU, CSU_ALL_RW }, - { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, - { CSU_CSLX_RESERVED0, CSU_ALL_RW }, - { CSU_CSLX_ETSEC1, CSU_ALL_RW }, - { CSU_CSLX_SEC5_5, CSU_ALL_RW }, - { CSU_CSLX_ETSEC3, CSU_ALL_RW }, - { CSU_CSLX_ETSEC2, CSU_ALL_RW }, - { CSU_CSLX_GPIO2, CSU_ALL_RW }, - { CSU_CSLX_GPIO1, CSU_ALL_RW }, - { CSU_CSLX_GPIO4, CSU_ALL_RW }, - { CSU_CSLX_GPIO3, CSU_ALL_RW }, - { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, - { CSU_CSLX_CSU, CSU_ALL_RW }, - { CSU_CSLX_ASRC, CSU_ALL_RW }, - { CSU_CSLX_SPDIF, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, - { CSU_CSLX_SAI2, CSU_ALL_RW }, - { CSU_CSLX_SAI1, CSU_ALL_RW }, - { CSU_CSLX_SAI4, CSU_ALL_RW }, - { CSU_CSLX_SAI3, CSU_ALL_RW }, - { CSU_CSLX_FTM2, CSU_ALL_RW }, - { CSU_CSLX_FTM1, CSU_ALL_RW }, - { CSU_CSLX_FTM4, CSU_ALL_RW }, - { CSU_CSLX_FTM3, CSU_ALL_RW }, - { CSU_CSLX_FTM6, CSU_ALL_RW }, - { CSU_CSLX_FTM5, CSU_ALL_RW }, - { CSU_CSLX_FTM8, CSU_ALL_RW }, - { CSU_CSLX_FTM7, CSU_ALL_RW }, - { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, - { CSU_CSLX_EPU, CSU_ALL_RW }, - { CSU_CSLX_GDI, CSU_ALL_RW }, - { CSU_CSLX_DDI, CSU_ALL_RW }, - { CSU_CSLX_RESERVED1, CSU_ALL_RW }, - { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, - { CSU_CSLX_RESERVED2, CSU_ALL_RW }, -}; -#endif - int checkboard(void) { #ifndef CONFIG_QSPI_BOOT @@ -382,9 +296,8 @@ void board_init_f(ulong dummy) dram_init();
/* Allow OCRAM access permission as R/W */ -#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(&ns_dev[4], 1); - enable_devices_ns_access(&ns_dev[7], 1); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif
board_init_r(NULL, 0); @@ -602,8 +515,8 @@ int board_init(void) ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id));
-#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif
#ifdef CONFIG_U_QE @@ -627,8 +540,8 @@ void board_sleep_prepare(void) }
-#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif } #endif diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 228dbf8..236689b 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -8,13 +8,13 @@ #include <i2c.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> -#include <asm/arch/ns_access.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> #include <asm/arch/ls102xa_devdis.h> #include <hwconfig.h> #include <mmc.h> +#include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> #include <fsl_immap.h> @@ -69,92 +69,6 @@ DECLARE_GLOBAL_DATA_PTR; #define PIN_QE_LCD_MUX_LCD 0x0 #define PIN_QE_LCD_MUX_QE 0x1
-#ifdef CONFIG_LS102XA_NS_ACCESS -static struct csu_ns_dev ns_dev[] = { - { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, - { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, - { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, - { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, - { CSU_CSLX_OCRAM, CSU_ALL_RW }, - { CSU_CSLX_GIC, CSU_ALL_RW }, - { CSU_CSLX_PCIE1, CSU_ALL_RW }, - { CSU_CSLX_OCRAM2, CSU_ALL_RW }, - { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, - { CSU_CSLX_PCIE2, CSU_ALL_RW }, - { CSU_CSLX_SATA, CSU_ALL_RW }, - { CSU_CSLX_USB3, CSU_ALL_RW }, - { CSU_CSLX_SERDES, CSU_ALL_RW }, - { CSU_CSLX_QDMA, CSU_ALL_RW }, - { CSU_CSLX_LPUART2, CSU_ALL_RW }, - { CSU_CSLX_LPUART1, CSU_ALL_RW }, - { CSU_CSLX_LPUART4, CSU_ALL_RW }, - { CSU_CSLX_LPUART3, CSU_ALL_RW }, - { CSU_CSLX_LPUART6, CSU_ALL_RW }, - { CSU_CSLX_LPUART5, CSU_ALL_RW }, - { CSU_CSLX_DSPI2, CSU_ALL_RW }, - { CSU_CSLX_DSPI1, CSU_ALL_RW }, - { CSU_CSLX_QSPI, CSU_ALL_RW }, - { CSU_CSLX_ESDHC, CSU_ALL_RW }, - { CSU_CSLX_2D_ACE, CSU_ALL_RW }, - { CSU_CSLX_IFC, CSU_ALL_RW }, - { CSU_CSLX_I2C1, CSU_ALL_RW }, - { CSU_CSLX_USB2, CSU_ALL_RW }, - { CSU_CSLX_I2C3, CSU_ALL_RW }, - { CSU_CSLX_I2C2, CSU_ALL_RW }, - { CSU_CSLX_DUART2, CSU_ALL_RW }, - { CSU_CSLX_DUART1, CSU_ALL_RW }, - { CSU_CSLX_WDT2, CSU_ALL_RW }, - { CSU_CSLX_WDT1, CSU_ALL_RW }, - { CSU_CSLX_EDMA, CSU_ALL_RW }, - { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, - { CSU_CSLX_DDR, CSU_ALL_RW }, - { CSU_CSLX_QUICC, CSU_ALL_RW }, - { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, - { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, - { CSU_CSLX_SFP, CSU_ALL_RW }, - { CSU_CSLX_TMU, CSU_ALL_RW }, - { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, - { CSU_CSLX_RESERVED0, CSU_ALL_RW }, - { CSU_CSLX_ETSEC1, CSU_ALL_RW }, - { CSU_CSLX_SEC5_5, CSU_ALL_RW }, - { CSU_CSLX_ETSEC3, CSU_ALL_RW }, - { CSU_CSLX_ETSEC2, CSU_ALL_RW }, - { CSU_CSLX_GPIO2, CSU_ALL_RW }, - { CSU_CSLX_GPIO1, CSU_ALL_RW }, - { CSU_CSLX_GPIO4, CSU_ALL_RW }, - { CSU_CSLX_GPIO3, CSU_ALL_RW }, - { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, - { CSU_CSLX_CSU, CSU_ALL_RW }, - { CSU_CSLX_ASRC, CSU_ALL_RW }, - { CSU_CSLX_SPDIF, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, - { CSU_CSLX_SAI2, CSU_ALL_RW }, - { CSU_CSLX_SAI1, CSU_ALL_RW }, - { CSU_CSLX_SAI4, CSU_ALL_RW }, - { CSU_CSLX_SAI3, CSU_ALL_RW }, - { CSU_CSLX_FTM2, CSU_ALL_RW }, - { CSU_CSLX_FTM1, CSU_ALL_RW }, - { CSU_CSLX_FTM4, CSU_ALL_RW }, - { CSU_CSLX_FTM3, CSU_ALL_RW }, - { CSU_CSLX_FTM6, CSU_ALL_RW }, - { CSU_CSLX_FTM5, CSU_ALL_RW }, - { CSU_CSLX_FTM8, CSU_ALL_RW }, - { CSU_CSLX_FTM7, CSU_ALL_RW }, - { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, - { CSU_CSLX_EPU, CSU_ALL_RW }, - { CSU_CSLX_GDI, CSU_ALL_RW }, - { CSU_CSLX_DDI, CSU_ALL_RW }, - { CSU_CSLX_RESERVED1, CSU_ALL_RW }, - { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, - { CSU_CSLX_RESERVED2, CSU_ALL_RW }, -}; -#endif - struct cpld_data { u8 cpld_ver; /* cpld revision */ u8 cpld_ver_sub; /* cpld sub revision */ @@ -546,9 +460,9 @@ void board_init_f(ulong dummy) dram_init();
/* Allow OCRAM access permission as R/W */ -#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(&ns_dev[4], 1); - enable_devices_ns_access(&ns_dev[7], 1); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); + enable_layerscape_ns_access(); #endif
board_init_r(NULL, 0); @@ -637,8 +551,8 @@ int board_init(void) ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id));
#ifdef CONFIG_U_QE @@ -670,8 +584,8 @@ int misc_init_r(void) #if defined(CONFIG_DEEP_SLEEP) void board_sleep_prepare(void) { -#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif } #endif diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index f73900f..9b8b001 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -563,7 +563,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN -#define CONFIG_LS102XA_NS_ACCESS +#define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 #define CONFIG_TIMER_CLK_FREQ 12500000
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 02cc09c..676c096 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -415,7 +415,7 @@ #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN -#define CONFIG_LS102XA_NS_ACCESS +#define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 #define CONFIG_TIMER_CLK_FREQ 12500000
diff --git a/include/fsl_csu.h b/include/fsl_csu.h new file mode 100644 index 0000000..f4d97fb --- /dev/null +++ b/include/fsl_csu.h @@ -0,0 +1,34 @@ +/* + * Copyright 2015 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef __FSL_CSU_H__ +#define __FSL_CSU_H__ + +enum csu_cslx_access { + CSU_NS_SUP_R = 0x08, + CSU_NS_SUP_W = 0x80, + CSU_NS_SUP_RW = 0x88, + CSU_NS_USER_R = 0x04, + CSU_NS_USER_W = 0x40, + CSU_NS_USER_RW = 0x44, + CSU_S_SUP_R = 0x02, + CSU_S_SUP_W = 0x20, + CSU_S_SUP_RW = 0x22, + CSU_S_USER_R = 0x01, + CSU_S_USER_W = 0x10, + CSU_S_USER_RW = 0x11, + CSU_ALL_RW = 0xff, +}; + +struct csu_ns_dev { + unsigned long ind; + uint32_t val; +}; + +void enable_layerscape_ns_access(void); + +#endif
Gong Qianyu
