[U-Boot-Users] [Ticket#2007011742000331] [PATCH] Add support for the MPC8349E-mITX-GP
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2007011742000331] was created:
<snip>
Add support for the MPC8349E-mITX-GP, a stripped-down version of the MPC8349E-mITX.
Signed-off-by: Timur Tabi timur@freescale.com
MAINTAINERS | 1 + Makefile | 16 ++- board/mpc8349itx/config.mk | 6 +- board/mpc8349itx/mpc8349itx.c | 105 ++-------- include/configs/MPC8349ITX.h | 463 ++++++++++++++++------------------------- include/mpc83xx.h | 41 ++++ 6 files changed, 264 insertions(+), 368 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index ce20def..e65699f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -347,6 +347,7 @@ John Zhan zhanz@sinovee.com Timur Tabi timur@freescale.com
MPC8349E-mITX MPC8349
- MPC8349E-mITX-GP MPC8349
Kim Phillips kim.phillips@freescale.com
diff --git a/Makefile b/Makefile index 1dbdf4d..10d961f 100644 --- a/Makefile +++ b/Makefile @@ -1624,8 +1624,20 @@ MPC8360EMDS_SLAVE_config: unconfig fi ; @$(MKCONFIG) -a MPC8360EMDS ppc mpc83xx mpc8360emds
-MPC8349ITX_config: unconfig
- @$(MKCONFIG) $(@:_config=) ppc mpc83xx mpc8349itx
+MPC8349ITX_config \ +MPC8349ITX_LOWBOOT_config \ +MPC8349ITXGP_config: unconfig
- @mkdir -p $(obj)include
- @mkdir -p $(obj)board/mpc8349itx
- @CTYPE=$(subst MPC,,$(@:_config=)); \
- echo "#define CONFIG_MPC$${CTYPE}" >> $(obj)include/config.h
- @if [ "$(findstring GP,$@)" ] ; then \
echo "TEXT_BASE = 0xFE000000" >$(obj)board/mpc8349itx/config.tmp ; \
- fi
- @if [ "$(findstring LOWBOOT,$@)" ] ; then \
- fi
- @$(MKCONFIG) -a MPC8349ITX ppc mpc83xx mpc8349itx
######################################################################### ## MPC85xx Systems diff --git a/board/mpc8349itx/config.mk b/board/mpc8349itx/config.mk index 2e11311..1901fdc 100644 --- a/board/mpc8349itx/config.mk +++ b/board/mpc8349itx/config.mk @@ -21,10 +21,14 @@ #
# -# MPC8349ITX +# MPC8349E-mITX and MPC8349E-mITX-GP #
+sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp
+ifndef TEXT_BASE TEXT_BASE = 0xFEF00000 +endif
ifneq ($(OBJTREE),$(SRCTREE)) # We are building u-boot in a separate directory, use generated diff --git a/board/mpc8349itx/mpc8349itx.c b/board/mpc8349itx/mpc8349itx.c index 4838e70..aefdaf7 100644 --- a/board/mpc8349itx/mpc8349itx.c +++ b/board/mpc8349itx/mpc8349itx.c @@ -134,88 +134,6 @@ volatile static struct pci_controller ho }; #endif /* CONFIG_PCI */
-/* If MPC8349E-mITX is soldered with SDRAM, then initialize it. */
-void sdram_init(void) -{
- volatile immap_t *immap = (immap_t *) CFG_IMMR;
- volatile lbus83xx_t *lbc = &immap->lbus;
-#if defined(CFG_BR2_PRELIM) \
- && defined(CFG_OR2_PRELIM) \
- && defined(CFG_LBLAWBAR2_PRELIM) \
- && defined(CFG_LBLAWAR2_PRELIM) \
- && !defined(CONFIG_COMPACT_FLASH)
- uint *sdram_addr = (uint *) CFG_LBC_SDRAM_BASE;
- puts("\n SDRAM on Local Bus: ");
</snip>
Your U-Boot support team
OTRS Notification Master wrote:
Hello list,
<snip> > From: Timur Tabi <timur@freescale.com> > > Add support for the MPC8349E-mITX-GP, a stripped-down version of the > MPC8349E-mITX.
FYI, this patch was created on top of my other patch titled, " Add support for generating assembly listing files", so you may need to apply that patch before this one applies cleanly.
Timur Tabi
