[PATCH 1/1] lmb: description lmb_is_reserved, lmb_is_reserved_flags
* provide a description for function lmb_is_reserved() * improve the description of funciton lmb_is_reserved_flags()
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/lmb.h | 22 +++++++++++++++++++--- 1 file changed, 19 insertions(+), 3 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 07bf22144e..0365c9ef1f 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -116,16 +116,32 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr); phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size); phys_size_t lmb_get_free_size(struct lmb *lmb, phys_addr_t addr); + +/** + * lmb_is_reserved_flags() - test if address is in reserved region + * + * The function checks if a reserved region comprising @addr exists. + * flag bits set that are set in @flags. + * + * @lmb: the logical memory block struct + * @addr: address to be tested + * Return: 1 if reservation exists, 0 otherwise + */ int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr); + /** - * lmb_is_reserved_flags - test if tha address is in reserved region with a bitfield flag + * lmb_is_reserved_flags() - test if address is in reserved region with flag bits set + * + * The function checks if a reserved region comprising @addr exists which has + * all flag bits set which are set in @flags. * * @lmb: the logical memory block struct * @addr: address to be tested - * @flags: flags bitfied to be tested - * Return: if not reserved or reserved without the requested flag else 1 + * @flags: bitmap with bits to be tested + * Return: 1 if matching reservation exists, 0 otherwise */ int lmb_is_reserved_flags(struct lmb *lmb, phys_addr_t addr, int flags); + long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size);
void lmb_dump_all(struct lmb *lmb);
Il giorno sab 12 ago 2023 alle ore 19:49 Heinrich Schuchardt < heinrich.schuchardt@canonical.com> ha scritto:
- provide a description for function lmb_is_reserved()
- improve the description of funciton lmb_is_reserved_flags()
- lmb_is_reserved_flags() - test if address is in reserved region
lmb_is_reserved()
- The function checks if a reserved region comprising @addr exists.
- flag bits set that are set in @flags.
line to be removed (cut and paste from lmb_is_reserved_flags() description)
- @lmb: the logical memory block struct
- @addr: address to be tested
- Return: 1 if reservation exists, 0 otherwise
- lmb_is_reserved_flags - test if tha address is in reserved region with
a bitfield flag
- lmb_is_reserved_flags() - test if address is in reserved region with
flag bits set
- The function checks if a reserved region comprising @addr exists which
has
- all flag bits set which are set in @flags.
- @flags: flags bitfied to be tested
- Return: if not reserved or reserved without the requested flag
else 1
- @flags: bitmap with bits to be tested
- Return: 1 if matching reservation exists, 0 otherwise
2.40.1
Massimo Pegorer
