[U-Boot] [PATCH 2/5] MSM 7x27a: Add support for qualcomm msm 7x27a SOC
Signed-off-by: Srikanth Reddy Vintha srikanth.reddy@lntinfotech.com --- arch/arm/cpu/armv7/msm7x27a/Makefile | 53 ++++ arch/arm/cpu/armv7/msm7x27a/acpuclock.c | 252 +++++++++++++++ arch/arm/cpu/armv7/msm7x27a/board.c | 66 ++++ arch/arm/cpu/armv7/msm7x27a/config.mk | 21 ++ arch/arm/cpu/armv7/msm7x27a/gpio.c | 287 +++++++++++++++++ arch/arm/cpu/armv7/msm7x27a/lowlevel_init.S | 118 +++++++ arch/arm/cpu/armv7/msm7x27a/timer.c | 127 ++++++++ arch/arm/include/asm/arch-msm7x27a/gpio.h | 47 +++ arch/arm/include/asm/arch-msm7x27a/iomap.h | 105 +++++++ arch/arm/include/asm/arch-msm7x27a/mmc.h | 399 ++++++++++++++++++++++++ arch/arm/include/asm/arch-msm7x27a/proc_comm.h | 42 +++ arch/arm/include/asm/arch-msm7x27a/sys_proto.h | 27 ++ 12 files changed, 1544 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/msm7x27a/Makefile create mode 100644 arch/arm/cpu/armv7/msm7x27a/acpuclock.c create mode 100644 arch/arm/cpu/armv7/msm7x27a/board.c create mode 100644 arch/arm/cpu/armv7/msm7x27a/config.mk create mode 100644 arch/arm/cpu/armv7/msm7x27a/gpio.c create mode 100644 arch/arm/cpu/armv7/msm7x27a/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/msm7x27a/timer.c create mode 100644 arch/arm/include/asm/arch-msm7x27a/gpio.h create mode 100644 arch/arm/include/asm/arch-msm7x27a/iomap.h create mode 100644 arch/arm/include/asm/arch-msm7x27a/mmc.h create mode 100644 arch/arm/include/asm/arch-msm7x27a/proc_comm.h create mode 100644 arch/arm/include/asm/arch-msm7x27a/sys_proto.h
diff --git a/arch/arm/cpu/armv7/msm7x27a/Makefile b/arch/arm/cpu/armv7/msm7x27a/Makefile new file mode 100644 index 0000000..5f493d7 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2012 +# Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> +# +# (C) Copyright 2010,2011 Nvidia Corporation. +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS-y := lowlevel_init.o +COBJS-y := board.o +COBJS-y += timer.o +COBJS-y += acpuclock.o +COBJS-y += gpio.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/msm7x27a/acpuclock.c b/arch/arm/cpu/armv7/msm7x27a/acpuclock.c new file mode 100644 index 0000000..c144233 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/acpuclock.c @@ -0,0 +1,252 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. + * + * Copyright (c) 2008, Google Inc. + * All rights reserved. + * Copyright (c) 2009-2011, Code Aurora Forum. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS + * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS + * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE + * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS + * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED + * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + */ + +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <common.h> +#include <asm/arch/mmc.h> +#include <asm/arch/proc_comm.h> + +#define BIT(x) (1 << (x)) + +#define A11S_CLK_CNTL_ADDR (MSM_CSR_BASE + 0x100) +#define A11S_CLK_SEL_ADDR (MSM_CSR_BASE + 0x104) +#define VDD_SVS_PLEVEL_ADDR (MSM_CSR_BASE + 0x124) + +#define PLL2_MODE_ADDR (MSM_CLK_CTL_BASE + 0x338) +#define PLL4_MODE_ADDR (MSM_CLK_CTL_BASE + 0x374) + +#define PLL_RESET_N BIT(2) +#define PLL_BYPASSNL BIT(1) +#define PLL_OUTCTRL BIT(0) + +#define SRC_SEL_TCX0 0 /* TCXO */ +#define SRC_SEL_PLL1 1 /* PLL1: modem_pll */ +#define SRC_SEL_PLL2 2 /* PLL2: backup_pll_0 */ +#define SRC_SEL_PLL3 3 /* PLL3: backup_pll_1 */ +#define SRC_SEL_PLL4 6 /* PLL4: sparrow_pll */ + +#define DIV_1 0 +#define DIV_2 1 +#define DIV_3 2 +#define DIV_4 3 +#define DIV_5 4 +#define DIV_6 5 +#define DIV_7 6 +#define DIV_8 7 +#define DIV_9 8 +#define DIV_10 9 +#define DIV_11 10 +#define DIV_12 11 +#define DIV_13 12 +#define DIV_14 13 +#define DIV_15 14 +#define DIV_16 15 + +#define WAIT_CNT 100 +#define VDD_LEVEL 7 +#define MIN_AXI_HZ 120000000 +#define ACPU_800MHZ 41 + +#define A11S_CLK_SEL_MASK 0x7 /* bits 2:0 */ + +/* The stepping frequencies have been choosen to make sure the step + * is <= 256 MHz for both 7x27a and 7x25a targets. The + * table also assumes the ACPU is running at TCXO freq and AHB div is + * set to DIV_1. + * + * To use the tables: + * - Start at location 0/1 depending on clock source sel bit. + * - Set values till end of table skipping every other entry. + * - When you reach the end of the table, you are done scaling. + */ + +uint32_t const clk_cntl_reg_val_7627A[] = { + (WAIT_CNT << 16) | (SRC_SEL_PLL2 << 4) | DIV_16, + (WAIT_CNT << 16) | (SRC_SEL_PLL2 << 12) | (DIV_8 << 8), + (WAIT_CNT << 16) | (SRC_SEL_PLL2 << 4) | DIV_4, + (WAIT_CNT << 16) | (SRC_SEL_PLL2 << 12) | (DIV_2 << 8), + + /* TODO: Fix it for 800MHz */ +#if 0 + (WAIT_CNT << 16) | (SRC_SEL_PLL4 << 4) | DIV_1, +#endif +}; + + +/* Using DIV_1 for all cases to avoid worrying about turbo vs. normal + * mode. Able to use DIV_1 for all steps because it's the largest AND + * the final value. */ +uint32_t const clk_sel_reg_val[] = { + DIV_1 << 1 | 1, /* Switch to src1 */ + DIV_1 << 1 | 0, /* Switch to src0 */ +}; + +/* + * Mask to make sure current selected src frequency doesn't change. + */ +uint32_t const clk_cntl_mask[] = { + 0x0000FF00, /* Mask to read src0 */ + 0x000000FF /* Mask to read src1 */ +}; + +/* enum for SDC CLK IDs */ +enum { + SDC1_CLK = 19, + SDC1_PCLK = 20, + SDC2_CLK = 21, + SDC2_PCLK = 22, + SDC3_CLK = 23, + SDC3_PCLK = 24, + SDC4_CLK = 25, + SDC4_PCLK = 26 +}; +static uint8_t sdc_clk[] = {0, SDC1_CLK, SDC2_CLK, SDC3_CLK, SDC4_CLK}; +static uint8_t sdc_pclk[] = {0, SDC1_PCLK, SDC2_PCLK, SDC3_PCLK, SDC4_PCLK}; + + +void pll_enable(void *pll_mode_addr) +{ + uint32_t nVal; + /* Check status */ + nVal = readl(pll_mode_addr); + if (nVal & PLL_OUTCTRL) + return; + + /* Put the PLL in reset mode */ + nVal = 0; + nVal &= ~PLL_RESET_N; + nVal &= ~PLL_BYPASSNL; + nVal &= ~PLL_OUTCTRL; + writel(nVal, pll_mode_addr); + + /* Put the PLL in warm-up mode */ + nVal |= PLL_RESET_N; + nVal |= PLL_BYPASSNL; + writel(nVal, pll_mode_addr); + + /* Wait for the PLL warm-up time */ + udelay(50); + + /* Put the PLL in active mode */ + nVal |= PLL_RESET_N; + nVal |= PLL_BYPASSNL; + nVal |= PLL_OUTCTRL; + writel(nVal, pll_mode_addr); +} + +void pll_request(unsigned pll, unsigned enable) +{ + if (!enable) { + /* Disable not supported */ + return; + } + switch (pll) { + case 2: + pll_enable((void *)PLL2_MODE_ADDR); + return; + case 4: + pll_enable((void *)PLL4_MODE_ADDR); + return; + default: + return; + }; +} + +void acpu_clock_init(void) +{ + uint32_t i; + uint32_t val; + uint32_t size; + + /* Increase VDD level to the final value. */ + writel((1 << 7) | (VDD_LEVEL << 3), VDD_SVS_PLEVEL_ADDR); + + udelay(1000); + const uint32_t *clk_cntl_reg_val = clk_cntl_reg_val_7627A; + size = ARRAY_SIZE(clk_cntl_reg_val_7627A); + pll_request(2, 1); + /* Read clock source select bit. */ + val = readl(A11S_CLK_SEL_ADDR); + i = val & 1; + + /* Jump into table and set every entry. */ + for (; i < size; i++) { + + val = readl(A11S_CLK_CNTL_ADDR); + + /* Make sure not to disturb already used src */ + val &= clk_cntl_mask[i%2]; + val += clk_cntl_reg_val[i]; + writel(val, A11S_CLK_CNTL_ADDR); + + /* Would need a dmb() here but the whole address space is + * strongly ordered, so it should be fine. + */ + val = readl(A11S_CLK_SEL_ADDR); + val &= ~(A11S_CLK_SEL_MASK); + val |= (A11S_CLK_SEL_MASK & clk_sel_reg_val[i%2]); + writel(val, A11S_CLK_SEL_ADDR); + udelay(1000); + } +} + +#ifdef CONFIG_QC_MMC +/* Configure MMC clock */ +void clock_config_mmc(uint32_t interface, uint32_t freq) +{ + uint32_t reg = 0; + if (mmc_clock_set_rate(sdc_clk[interface], freq) < 0) + printf("Failure setting clock rate for MCLK-" + "clk_rate : %d\n", freq); + + /* enable clock */ + if (mmc_clock_enable_disable(sdc_clk[interface], MMC_CLK_ENABLE) < 0) + printf("Failure enabling MMC Clock!\n"); + + reg |= MMC_BOOT_MCI_CLK_ENABLE; + reg |= MMC_BOOT_MCI_CLK_ENA_FLOW; + reg |= MMC_BOOT_MCI_CLK_IN_FEEDBACK; + writel(reg, MMC_BOOT_MCI_CLK); +} + +/* Intialize MMC clock */ +void clock_init_mmc(uint32_t interface) +{ + if (mmc_clock_enable_disable(sdc_pclk[interface], MMC_CLK_ENABLE) < 0) + printf("Failure enabling PCLK!\n"); +} +#endif + diff --git a/arch/arm/cpu/armv7/msm7x27a/board.c b/arch/arm/cpu/armv7/msm7x27a/board.c new file mode 100644 index 0000000..46fc2ea --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/board.c @@ -0,0 +1,66 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/arch/iomap.h> +#include <asm/arch/sys_proto.h> + + +DECLARE_GLOBAL_DATA_PTR; + + +void set_vector_base(unsigned long addr) +{ + __asm__ volatile ("mcr p15, 0, %0, c12, c0, 0" : : "r" (addr)); +} + +int dram_init(void) +{ + /*TODO: Memory size will change for booting kernel*/ + gd->ram_size = 0x00100000; + return 0; +} + +void dram_init_banksize(void) +{ + /* TODO: Memory layout will change for booting kernel + * This is intial bring up setup + */ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + +} +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + printf("Board: %s\n", sysinfo.board_string); + return 0; +} +#endif /* CONFIG_DISPLAY_BOARDINFO */ + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init() +{ + __cpu_early_init(); + return 0; +} +#endif diff --git a/arch/arm/cpu/armv7/msm7x27a/config.mk b/arch/arm/cpu/armv7/msm7x27a/config.mk new file mode 100644 index 0000000..f350c2b --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/config.mk @@ -0,0 +1,21 @@ +# +# (C) Copyright 2012 +# Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA +# +# + +PLATFORM_CPPFLAGS += -march=armv7-a diff --git a/arch/arm/cpu/armv7/msm7x27a/gpio.c b/arch/arm/cpu/armv7/msm7x27a/gpio.c new file mode 100644 index 0000000..f5975e3 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/gpio.c @@ -0,0 +1,287 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. + * + * Copyright (c) 2008, Google Inc. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS + * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS + * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE + * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS + * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED + * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/iomap.h> +#include <asm/arch/gpio.h> +#include <asm/arch/proc_comm.h> + +#define GPIO1_REG(off) (MSM_GPIO1_BASE + 0x800 + (off)) +#define GPIO2_REG(off) (MSM_GPIO2_BASE + 0xC00 + (off)) + +/* output value */ +#define GPIO_OUT_0 GPIO1_REG(0x00) /* gpio 15-0 */ +#define GPIO_OUT_1 GPIO2_REG(0x00) /* gpio 42-16 */ +#define GPIO_OUT_2 GPIO1_REG(0x04) /* gpio 67-43 */ +#define GPIO_OUT_3 GPIO1_REG(0x08) /* gpio 94-68 */ +#define GPIO_OUT_4 GPIO1_REG(0x0C) /* gpio 106-95 */ +#define GPIO_OUT_5 GPIO1_REG(0x50) /* gpio 132-107 */ + +/* same pin map as above, output enable */ +#define GPIO_OE_0 GPIO1_REG(0x10) +#define GPIO_OE_1 GPIO2_REG(0x08) +#define GPIO_OE_2 GPIO1_REG(0x14) +#define GPIO_OE_3 GPIO1_REG(0x18) +#define GPIO_OE_4 GPIO1_REG(0x1C) +#define GPIO_OE_5 GPIO1_REG(0x54) + +/* same pin map as above, input read */ +#define GPIO_IN_0 GPIO1_REG(0x34) +#define GPIO_IN_1 GPIO2_REG(0x20) +#define GPIO_IN_2 GPIO1_REG(0x38) +#define GPIO_IN_3 GPIO1_REG(0x3C) +#define GPIO_IN_4 GPIO1_REG(0x40) +#define GPIO_IN_5 GPIO1_REG(0x44) + +/* same pin map as above, 1=edge 0=level interrup */ +#define GPIO_INT_EDGE_0 GPIO1_REG(0x60) +#define GPIO_INT_EDGE_1 GPIO2_REG(0x50) +#define GPIO_INT_EDGE_2 GPIO1_REG(0x64) +#define GPIO_INT_EDGE_3 GPIO1_REG(0x68) +#define GPIO_INT_EDGE_4 GPIO1_REG(0x6C) +#define GPIO_INT_EDGE_5 GPIO1_REG(0xC0) + +/* same pin map as above, 1=positive 0=negative */ +#define GPIO_INT_POS_0 GPIO1_REG(0x70) +#define GPIO_INT_POS_1 GPIO2_REG(0x58) +#define GPIO_INT_POS_2 GPIO1_REG(0x74) +#define GPIO_INT_POS_3 GPIO1_REG(0x78) +#define GPIO_INT_POS_4 GPIO1_REG(0x7C) +#define GPIO_INT_POS_5 GPIO1_REG(0xBC) + +/* same pin map as above, interrupt enable */ +#define GPIO_INT_EN_0 GPIO1_REG(0x80) +#define GPIO_INT_EN_1 GPIO2_REG(0x60) +#define GPIO_INT_EN_2 GPIO1_REG(0x84) +#define GPIO_INT_EN_3 GPIO1_REG(0x88) +#define GPIO_INT_EN_4 GPIO1_REG(0x8C) +#define GPIO_INT_EN_5 GPIO1_REG(0xB8) + +/* same pin map as above, write 1 to clear interrupt */ +#define GPIO_INT_CLEAR_0 GPIO1_REG(0x90) +#define GPIO_INT_CLEAR_1 GPIO2_REG(0x68) +#define GPIO_INT_CLEAR_2 GPIO1_REG(0x94) +#define GPIO_INT_CLEAR_3 GPIO1_REG(0x98) +#define GPIO_INT_CLEAR_4 GPIO1_REG(0x9C) +#define GPIO_INT_CLEAR_5 GPIO1_REG(0xB4) + +/* same pin map as above, 1=interrupt pending */ +#define GPIO_INT_STATUS_0 GPIO1_REG(0xA0) +#define GPIO_INT_STATUS_1 GPIO2_REG(0x70) +#define GPIO_INT_STATUS_2 GPIO1_REG(0xA4) +#define GPIO_INT_STATUS_3 GPIO1_REG(0xA8) +#define GPIO_INT_STATUS_4 GPIO1_REG(0xAC) +#define GPIO_INT_STATUS_5 GPIO1_REG(0xB0) + +typedef struct gpioregs gpioregs; + +struct gpioregs { + unsigned out; + unsigned in; + unsigned int_status; + unsigned int_clear; + unsigned int_en; + unsigned int_edge; + unsigned int_pos; + unsigned oe; +}; + +static gpioregs GPIO_REGS[] = { + { + .out = GPIO_OUT_0, + .in = GPIO_IN_0, + .int_status = GPIO_INT_STATUS_0, + .int_clear = GPIO_INT_CLEAR_0, + .int_en = GPIO_INT_EN_0, + .int_edge = GPIO_INT_EDGE_0, + .int_pos = GPIO_INT_POS_0, + .oe = GPIO_OE_0, + }, + { + .out = GPIO_OUT_1, + .in = GPIO_IN_1, + .int_status = GPIO_INT_STATUS_1, + .int_clear = GPIO_INT_CLEAR_1, + .int_en = GPIO_INT_EN_1, + .int_edge = GPIO_INT_EDGE_1, + .int_pos = GPIO_INT_POS_1, + .oe = GPIO_OE_1, + }, + { + .out = GPIO_OUT_2, + .in = GPIO_IN_2, + .int_status = GPIO_INT_STATUS_2, + .int_clear = GPIO_INT_CLEAR_2, + .int_en = GPIO_INT_EN_2, + .int_edge = GPIO_INT_EDGE_2, + .int_pos = GPIO_INT_POS_2, + .oe = GPIO_OE_2, + }, + { + .out = GPIO_OUT_3, + .in = GPIO_IN_3, + .int_status = GPIO_INT_STATUS_3, + .int_clear = GPIO_INT_CLEAR_3, + .int_en = GPIO_INT_EN_3, + .int_edge = GPIO_INT_EDGE_3, + .int_pos = GPIO_INT_POS_3, + .oe = GPIO_OE_3, + }, + { + .out = GPIO_OUT_4, + .in = GPIO_IN_4, + .int_status = GPIO_INT_STATUS_4, + .int_clear = GPIO_INT_CLEAR_4, + .int_en = GPIO_INT_EN_4, + .int_edge = GPIO_INT_EDGE_4, + .int_pos = GPIO_INT_POS_4, + .oe = GPIO_OE_4, + }, + { + .out = GPIO_OUT_5, + .in = GPIO_IN_5, + .int_status = GPIO_INT_STATUS_5, + .int_clear = GPIO_INT_CLEAR_5, + .int_en = GPIO_INT_EN_5, + .int_edge = GPIO_INT_EDGE_5, + .int_pos = GPIO_INT_POS_5, + .oe = GPIO_OE_5, + }, +}; + +static gpioregs *find_gpio(unsigned n, unsigned *bit) +{ + if (n > 132) + return 0; + if (n > 106) { + *bit = 1 << (n - 107); + return GPIO_REGS + 5; + } + if (n > 94) { + *bit = 1 << (n - 95); + return GPIO_REGS + 4; + } + if (n > 67) { + *bit = 1 << (n - 68); + return GPIO_REGS + 3; + } + if (n > 42) { + *bit = 1 << (n - 43); + return GPIO_REGS + 2; + } + if (n > 15) { + *bit = 1 << (n - 16); + return GPIO_REGS + 1; + } + *bit = 1 << n; + return GPIO_REGS + 0; +} + +int gpio_config(unsigned n, unsigned flags) +{ + gpioregs *r; + unsigned b; + unsigned v; + r = find_gpio(n, &b); + if (!r) + return -1; + + v = readl(r->oe); + if (flags & GPIO_OUTPUT) + writel(v | b, r->oe); + else + writel(v & (~b), r->oe); + return 0; +} + +void gpio_set(unsigned n, unsigned on) +{ + gpioregs *r; + unsigned b; + unsigned v; + + r = find_gpio(n, &b); + if (r == 0) + return; + + v = readl(r->out); + if (on) + writel(v | b, r->out); + else + writel(v & (~b), r->out); + +} + +int gpio_get(unsigned n) +{ + gpioregs *r; + unsigned b; + r = find_gpio(n, &b); + if (r == 0) + return 0; + return (readl(r->in) & b) ? 1 : 0; +} + +#if 0 +void platform_config_interleaved_mode_gpios(void) +{ + /* configure EB2_CS1 through GPIO86 */ + writel(GPIO_ALT_FUNC_PAGE_REG, 0x56); + writel(GPIO_ALT_FUNC_CFG_REG, 0x04); + /* configure the EBI2_BUSY1_N through GPIO115 */ + writel(GPIO_ALT_FUNC_PAGE_REG, 0x73); + writel(GPIO_ALT_FUNC_CFG_REG, 0x08); +} + +/* Enables all gpios passed in table*/ +int platform_gpios_enable(const struct msm_gpio *table, int size) +{ + int rc; + int i; + const struct msm_gpio *g; + for (i = 0; i < size; i++) { + g = table + i; + /* Enable gpio */ + rc = gpio_tlmm_config(g->gpio_cfg, GPIO_ENABLE); + if (rc) + goto err; + } + return 0; +err: + return rc; +} +#endif + + diff --git a/arch/arm/cpu/armv7/msm7x27a/lowlevel_init.S b/arch/arm/cpu/armv7/msm7x27a/lowlevel_init.S new file mode 100644 index 0000000..e6c4ac1 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/lowlevel_init.S @@ -0,0 +1,118 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <config.h> +#include <version.h> + +.text +.code 32 + +#define DSB .byte 0x4f, 0xf0, 0x7f, 0xf5 +#define ISB .byte 0x6f, 0xf0, 0x7f, 0xf5 + + + + +_TEXT_BASE: + .word CONFIG_SYS_TEXT_BASE @ sdram load addr from config file + +.global invalidate_dcache +invalidate_dcache: + mov pc, lr + + .align 5 +.globl lowlevel_init +lowlevel_init: + mov pc, lr @ back to arch calling code + +.global reset_cpu +reset_cpu: +_loop_forever: + b _loop_forever + + + +.globl __cpu_early_init +__cpu_early_init: + + //; Zero out r0 for use throughout this code. All other GPRs + //; (r1-r3) are set throughout this code to help establish + //; a consistent startup state for any code that follows. + //; Users should add code at the end of this routine to establish + //; their own stack address (r13), add translation page tables, enable + //; the caches, etc. + push {r5-r12,r14} + mov r0, #0x0 + //; Initialize ASID to zero + mcr p15, 0, r0, c13, c0, 1 //; WCP15_CONTEXTIDR r0 + + //; ICIALL to invalidate entire I-Cache + mcr p15, 0, r0, c7, c5, 0 //; ICIALLU + + //; Initialize ADFSR to zero + mcr p15, 0, r0, c5, c1, 0 //; ADFSR r0 + + //; Ensure the MCR's above have completed their operation before + //; continuing + DSB + ISB + + //;------------------------------------------------------------------- + //; There are a number of registers that must be set prior to enabling + //; the MMU. The DCAR is one of these registers. We are setting + //; it to zero (no access) to easily detect improper setup in subsequent + //; code sequences + //;------------------------------------------------------------------- + //; Setup DACR (Domain Access Control Register) to zero + mcr p15, 0, r0, c3, c0, 0 //; WCP15_DACR r0 + + //;Make sure TLBLKCR is complete before continuing + ISB + + //; Invalidate the UTLB + mcr p15, 0, r0, c8, c7, 0 //; UTLBIALL + + //; Make sure UTLB request has been presented to macro before continuing + ISB + +SYSI2: + //; Enable Z bit to enable branch prediction (default is off) + mrc p15, 0, r2, c1, c0, 0 //; RCP15_SCTLR r2 + orr r2, r2, #0x00000800 + mcr p15, 0, r2, c1, c0, 0 //; WCP15_SCTLR r2 + + //; Make sure Link stack is initialized with branch and links to + //; sequential addresses + //; This aids in creating a predictable startup environment + bl SEQ1 +SEQ1: bl SEQ2 +SEQ2: bl SEQ3 +SEQ3: bl SEQ4 +SEQ4: bl SEQ5 +SEQ5: bl SEQ6 +SEQ6: bl SEQ7 +SEQ7: bl SEQ8 +SEQ8: + + ISB + pop {r5-r12,pc} + + +.ltorg diff --git a/arch/arm/cpu/armv7/msm7x27a/timer.c b/arch/arm/cpu/armv7/msm7x27a/timer.c new file mode 100644 index 0000000..0eb4ece --- /dev/null +++ b/arch/arm/cpu/armv7/msm7x27a/timer.c @@ -0,0 +1,127 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * (C) Copyright 2010,2011 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2008 + * Texas Instruments + * + * Richard Woodruff r-woodruff2@ti.com + * Syed Moahmmed Khasim khasim@ti.com + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <common.h> +#include <asm/types.h> +#define TIMER_LOAD_VAL 0x21 + +#define GPT_ENABLE_CLR_ON_MATCH_EN 2 +#define GPT_ENABLE_EN 1 +#define DGT_ENABLE_CLR_ON_MATCH_EN 2 +#define DGT_ENABLE_EN 1 + +#define SPSS_TIMER_STATUS_DGT_EN (1 << 0) + + +#define READ_TIMER readl(GPT_COUNT_VAL) + +static ulong timestamp; +static ulong lastinc; +#define DGT_HZ 6750000 /* Uses LPXO/4 (27.0 MHz / 4) */ + +/* nothing really to do with interrupts, just starts up a counter. */ +int timer_init(void) +{ + writel(0, DGT_ENABLE); + return 0; +} +/* timer without interrupts */ +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +/* delay x useconds */ +void __udelay(unsigned long usec) +{ + unsigned int val; + usec = (usec * 33 + 1000 - 33) / 1000; + + writel(0, GPT_CLEAR); + writel(0, GPT_ENABLE); + do { + val = 0; + val = readl(GPT_COUNT_VAL); + } while (val != 0); + + writel(GPT_ENABLE_EN, GPT_ENABLE); + do { + val = 0; + val = readl(GPT_COUNT_VAL); + } while (val < usec) ; + + writel(0, GPT_ENABLE); + writel(0, GPT_CLEAR); +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; /* current tick value */ + + if (lastinc <= now) { /* normal mode (non roll) */ + /* normal mode */ + timestamp += now - lastinc; + /* move stamp forward with absolute diff ticks */ + } else { /* we have overflow of the count down timer */ + timestamp += now + (TIMER_LOAD_VAL - lastinc); + } + lastinc = now; + + return timestamp; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/include/asm/arch-msm7x27a/gpio.h b/arch/arm/include/asm/arch-msm7x27a/gpio.h new file mode 100644 index 0000000..ca8c4af --- /dev/null +++ b/arch/arm/include/asm/arch-msm7x27a/gpio.h @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __GPIO_H +#define __GPIO_H + +#ifndef GPIO_INPUT +#define GPIO_INPUT 0x0000 +#endif +#ifndef GPIO_OUTPUT +#define GPIO_OUTPUT 0x0001 +#endif + +#define GPIO_LEVEL 0x0000 +#define GPIO_EDGE 0x0010 + +#define GPIO_RISING 0x0020 +#define GPIO_FALLING 0x0040 + +#define GPIO_HIGH 0x0020 +#define GPIO_LOW 0x0040 + +#define GPIO_PULLUP 0x0100 +#define GPIO_PULLDOWN 0x0200 + +int gpio_config(unsigned nr, unsigned flags); +void gpio_set(unsigned nr, unsigned on); +int gpio_get(unsigned nr); + +#endif diff --git a/arch/arm/include/asm/arch-msm7x27a/iomap.h b/arch/arm/include/asm/arch-msm7x27a/iomap.h new file mode 100644 index 0000000..4c9d434 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7x27a/iomap.h @@ -0,0 +1,105 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef _PLATFORM_MSM7627A_IOMAP_H_ +#define _PLATFORM_MSM7627A_IOMAP_H_ + +#define MSM_GPIO1_BASE 0xA9200000 +#define MSM_GPIO2_BASE 0xA9300000 + +#define MSM_UART1_BASE 0xA9A00000 +#define MSM_UART2_BASE 0xA9B00000 +#define MSM_UART3_BASE 0xA9C00000 + +#define MSM_VIC_BASE 0xC0000000 +#define MSM_GPT_BASE 0xC0100000 + +#define GPT_REG(off) (MSM_GPT_BASE + (off)) + +#define GPT_MATCH_VAL GPT_REG(0x0000) +#define GPT_COUNT_VAL GPT_REG(0x0004) +#define GPT_ENABLE GPT_REG(0x0008) +#define GPT_CLEAR GPT_REG(0x000C) +#define DGT_MATCH_VAL GPT_REG(0x0010) +#define DGT_COUNT_VAL GPT_REG(0x0014) +#define DGT_ENABLE GPT_REG(0x0018) +#define DGT_CLEAR GPT_REG(0x001C) +#define SPSS_TIMER_STATUS GPT_REG(0x0034) + +#define MSM_CSR_BASE 0xC0100000 +#define MSM_CLK_CTL_BASE 0xA8600000 + +#define MSM_SHARED_BASE 0x00100000 + +#define MSM_SDC1_BASE 0xA0400000 +#define MSM_SDC3_BASE 0xA0600000 + +#define MIPI_DSI_BASE (0xA1100000) +#define DSI_PHY_SW_RESET (0xA1100128) +#define REG_DSI(off) (MIPI_DSI_BASE + (off)) +#define MDP_BASE (0xAA200000) +#define REG_MDP(off) (MDP_BASE + (off)) +#define DSIPHY_REGULATOR_BASE (0x2CC) +#define DSIPHY_TIMING_BASE (0x260) +#define DSIPHY_CTRL_BASE (0x290) +#define DSIPHY_PLL_BASE (0x200) +#define DSIPHY_STRENGTH_BASE (0x2A0) + +/* Range 0 - 4 */ +#define DSIPHY_REGULATOR_CTRL(x) REG_DSI(DSIPHY_REGULATOR_BASE + (x) * 4) +/* Range 0 - 11 */ +#define DSIPHY_TIMING_CTRL(x) REG_DSI(DSIPHY_TIMING_BASE + (x) * 4) +/* Range 0 - 3 */ +#define DSIPHY_CTRL(x) REG_DSI(DSIPHY_CTRL_BASE + (x) * 4) +/* Range 0 - 2 */ +#define DSIPHY_STRENGTH_CTRL(x) REG_DSI(DSIPHY_STRENGTH_BASE + (x) * 4) +/* Range 0 - 19 */ +#define DSIPHY_PLL_CTRL(x) REG_DSI(DSIPHY_PLL_BASE + (x) * 4) + +#define MDP_DMA_P_CONFIG (0xAA290000) +#define MDP_DMA_P_OUT_XY (0xAA290010) +#define MDP_DMA_P_SIZE (0xAA290004) +#define MDP_DMA_P_BUF_ADDR (0xAA290008) +#define MDP_DMA_P_BUF_Y_STRIDE (0xAA29000C) + +#define MDP_DSI_VIDEO_EN (0xAA2F0000) +#define MDP_DSI_VIDEO_HSYNC_CTL (0xAA2F0004) +#define MDP_DSI_VIDEO_VSYNC_PERIOD (0xAA2F0008) +#define MDP_DSI_VIDEO_VSYNC_PULSE_WIDTH (0xAA2F000C) +#define MDP_DSI_VIDEO_DISPLAY_HCTL (0xAA2F0010) +#define MDP_DSI_VIDEO_DISPLAY_V_START (0xAA2F0014) +#define MDP_DSI_VIDEO_DISPLAY_V_END (0xAA2F0018) +#define MDP_DSI_VIDEO_BORDER_CLR (0xAA2F0028) +#define MDP_DSI_VIDEO_HSYNC_SKEW (0xAA2F0030) +#define MDP_DSI_VIDEO_CTL_POLARITY (0xAA2F0038) +#define MDP_DSI_VIDEO_TEST_CTL (0xAA2F0034) + +#define MDP_DMA_P_START REG_MDP(0x0000C) +#define MDP_DMA_S_START REG_MDP(0x00010) +#define MDP_DISP_INTF_SEL REG_MDP(0x00038) +#define MDP_MAX_RD_PENDING_CMD_CONFIG REG_MDP(0x0004C) +#define MDP_INTR_ENABLE REG_MDP(0x00020) +#define MDP_INTR_CLEAR REG_MDP(0x00028) +#define MDP_DSI_CMD_MODE_ID_MAP REG_MDP(0x000A0) +#define MDP_DSI_CMD_MODE_TRIGGER_EN REG_MDP(0x000A4) + +#define MDP_TEST_MODE_CLK REG_MDP(0xF0000) +#define MDP_INTR_STATUS REG_MDP(0x00054) +#endif diff --git a/arch/arm/include/asm/arch-msm7x27a/mmc.h b/arch/arm/include/asm/arch-msm7x27a/mmc.h new file mode 100644 index 0000000..15a8cd4 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7x27a/mmc.h @@ -0,0 +1,399 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MMC_H__ +#define __MMC_H__ + +#ifndef MMC_SLOT +#define MMC_SLOT 0 +#endif + +#include <common.h> +#include <part.h> +#include <mmc.h> + +/* + * Define Macros for SDCC Registers + */ +/* 8 bit */ +#define MMC_BOOT_MCI_POWER 0x000 + +/* MCICMD output control - 6th bit */ +#ifdef PLATFORM_MSM7X30 +#define MMC_BOOT_MCI_OPEN_DRAIN (1 << 6) +#define MMC_BOOT_MCI_PWR_OFF 0x00 +#define MMC_BOOT_MCI_PWR_UP 0x01 +#define MMC_BOOT_MCI_PWR_ON 0x01 +#else +#define MMC_BOOT_MCI_OPEN_DRAIN (1 << 6) +#define MMC_BOOT_MCI_PWR_OFF 0x00 +#define MMC_BOOT_MCI_PWR_UP 0x02 +#define MMC_BOOT_MCI_PWR_ON 0x03 +#endif + +/* 16 bits */ +#define MMC_BOOT_MCI_CLK 0x004 +/* Enable MCI bus clock - 0: clock disabled 1: enabled */ +#define MMC_BOOT_MCI_CLK_ENABLE (1 << 8) +/* Disable clk o/p when bus idle- 0:always enabled 1:enabled when bus active */ +#define MMC_BOOT_MCI_CLK_PWRSAVE (1 << 9) +/* Enable Widebus mode - 00: 1 bit mode 10:4 bit mode 01/11: 8 bit mode */ +#define MMC_BOOT_MCI_CLK_WIDEBUS_MODE (3 << 10) +#define MMC_BOOT_MCI_CLK_WIDEBUS_1_BIT 0 +#define MMC_BOOT_MCI_CLK_WIDEBUS_4_BIT (2 << 10) +#define MMC_BOOT_MCI_CLK_WIDEBUS_8_BIT (1 << 10) +/* Enable flow control- 0: disable 1: enable */ +#define MMC_BOOT_MCI_CLK_ENA_FLOW (1 << 12) +/* Set/clear to select rising/falling edge for data/cmd output */ +#define MMC_BOOT_MCI_CLK_INVERT_OUT (1 << 13) +/* Select to lach data/cmd coming in falling/rising/feedbk/loopbk of MCIclk */ +#define MMC_BOOT_MCI_CLK_IN_FALLING 0x0 +#define MMC_BOOT_MCI_CLK_IN_RISING (1 << 14) +#define MMC_BOOT_MCI_CLK_IN_FEEDBACK (2 << 14) +#define MMC_BOOT_MCI_CLK_IN_LOOPBACK (3 << 14) + +/* Bus Width */ +#define MMC_BOOT_BUS_WIDTH_1_BIT 0 +#define MMC_BOOT_BUS_WIDTH_4_BIT 2 +#define MMC_BOOT_BUS_WIDTH_8_BIT 3 + +/* 32 bits */ +#define MMC_BOOT_MCI_ARGUMENT 0x008 + +/* 16 bits */ +#define MMC_BOOT_MCI_CMD 0x00C +/* Command Index: 0 -5 */ +/* Waits for response if set */ +#define MMC_BOOT_MCI_CMD_RESPONSE (1 << 6) +/* Receives a 136-bit long response if set */ +#define MMC_BOOT_MCI_CMD_LONGRSP (1 << 7) +/* If set, CPSM disables command timer and waits for interrupt */ +#define MMC_BOOT_MCI_CMD_INTERRUPT (1 << 8) +/* If set waits for CmdPend before starting to send a command */ +#define MMC_BOOT_MCI_CMD_PENDING (1 << 9) +/* CPSM is enabled if set */ +#define MMC_BOOT_MCI_CMD_ENABLE (1 << 10) +/* If set PROG_DONE status bit asserted when busy is de-asserted */ +#define MMC_BOOT_MCI_CMD_PROG_ENA (1 << 11) +/* To indicate that this is a Command with Data (for SDIO interrupts) */ +#define MMC_BOOT_MCI_CMD_DAT_CMD (1 << 12) +/* Signals the next command to be an abort (stop) command. Always read 0 */ +#define MMC_BOOT_MCI_CMD_MCIABORT (1 << 13) +/* Waits for Command Completion Signal if set */ +#define MMC_BOOT_MCI_CMD_CCS_ENABLE (1 << 14) +/* If set sends CCS disable sequence */ +#define MMC_BOOT_MCI_CMD_CCS_DISABLE (1 << 15) + +#define MMC_BOOT_MCI_RESP_CMD 0x010 + +#define MMC_BOOT_MCI_RESP_0 0x014 +#define MMC_BOOT_MCI_RESP_1 0x018 +#define MMC_BOOT_MCI_RESP_2 0x01C +#define MMC_BOOT_MCI_RESP_3 0x020 + +#define MMC_BOOT_MCI_DATA_TIMER 0x024 +#define MMC_BOOT_MCI_DATA_LENGTH 0x028 +/* 16 bits */ +#define MMC_BOOT_MCI_DATA_CTL 0x02C +/* Data transfer enabled */ +#define MMC_BOOT_MCI_DATA_ENABLE (1 << 0) +/* Data transfer direction - 0: controller to card 1:card to controller */ +#define MMC_BOOT_MCI_DATA_DIR (1 << 1) +/* Data transfer mode - 0: block data transfer 1: stream data transfer */ +#define MMC_BOOT_MCI_DATA_MODE (1 << 2) +/* Enable DM interface - 0: DM disabled 1: DM enabled */ +#define MMC_BOOT_MCI_DATA_DM_ENABLE (1 << 3) +/* Data block length in bytes (1-4096) */ +#define MMC_BOOT_MCI_BLKSIZE_POS 4 +#define MMC_BOOT_MCI_DATA_COUNT 0x030 +#define MMC_BOOT_MCI_STATUS 0x034 +/* Command response received - CRC check failed */ +#define MMC_BOOT_MCI_STAT_CMD_CRC_FAIL (1 << 0) +/* Data block sent/received - CRC check failed */ +#define MMC_BOOT_MCI_STAT_DATA_CRC_FAIL (1 << 1) +/* Command resonse timeout */ +#define MMC_BOOT_MCI_STAT_CMD_TIMEOUT (1 << 2) +/* Data timeout */ +#define MMC_BOOT_MCI_STAT_DATA_TIMEOUT (1 << 3) +/* Transmit FIFO underrun error */ +#define MMC_BOOT_MCI_STAT_TX_UNDRUN (1 << 4) +/* Receive FIFO overrun error */ +#define MMC_BOOT_MCI_STAT_RX_OVRRUN (1 << 5) +/* Command response received - CRC check passed */ +#define MMC_BOOT_MCI_STAT_CMD_RESP_END (1 << 6) +/* Command sent - no response required */ +#define MMC_BOOT_MCI_STAT_CMD_SENT (1 << 7) +/* Data end - data counter zero */ +#define MMC_BOOT_MCI_STAT_DATA_END (1 << 8) +/* Start bit not detected on all data signals in wide bus mode */ +#define MMC_BOOT_MCI_STAT_START_BIT_ERR (1 << 9) +/* Data block sent/received - CRC check passed */ +#define MMC_BOOT_MCI_STAT_DATA_BLK_END (1 << 10) +/* Command transfer in progress */ +#define MMC_BOOT_MCI_STAT_CMD_ACTIVE (1 << 11) +/* Data transmit in progress */ +#define MMC_BOOT_MCI_STAT_TX_ACTIVE (1 << 12) +/* Data receive in progress */ +#define MMC_BOOT_MCI_STAT_RX_ACTIVE (1 << 13) +/* Transmit FIFO half full */ +#define MMC_BOOT_MCI_STAT_TX_FIFO_HFULL (1 << 14) +/* Receive FIFO half full */ +#define MMC_BOOT_MCI_STAT_RX_FIFO_HFULL (1 << 15) +/* Transmit FIFO full */ +#define MMC_BOOT_MCI_STAT_TX_FIFO_FULL (1 << 16) +/* Receive FIFO full */ +#define MMC_BOOT_MCI_STAT_RX_FIFO_FULL (1 << 17) +/* Transmit FIFO empty */ +#define MMC_BOOT_MCI_STAT_TX_FIFO_EMPTY (1 << 18) +/* Receive FIFO empty */ +#define MMC_BOOT_MCI_STAT_RX_FIFO_EMPTY (1 << 19) +/* Data available in transmit FIFO */ +#define MMC_BOOT_MCI_STAT_TX_DATA_AVLBL (1 << 20) +/* Data available in receive FIFO */ +#define MMC_BOOT_MCI_STAT_RX_DATA_AVLBL (1 << 21) +/* SDIO interrupt indicator for wake-up */ +#define MMC_BOOT_MCI_STAT_SDIO_INTR (1 << 22) +/* Programming done */ +#define MMC_BOOT_MCI_STAT_PROG_DONE (1 << 23) +/* CE-ATA command completion signal detected */ +#define MMC_BOOT_MCI_STAT_ATA_CMD_CMPL (1 << 24) +/* SDIO interrupt indicator for normal operation */ +#define MMC_BOOT_MCI_STAT_SDIO_INTR_OP (1 << 25) +/* Commpand completion signal timeout */ +#define MMC_BOOT_MCI_STAT_CCS_TIMEOUT (1 << 26) + +#define MMC_BOOT_MCI_STATIC_STATUS (MMC_BOOT_MCI_STAT_CMD_CRC_FAIL| \ + MMC_BOOT_MCI_STAT_DATA_CRC_FAIL| \ + MMC_BOOT_MCI_STAT_CMD_TIMEOUT| \ + MMC_BOOT_MCI_STAT_DATA_TIMEOUT| \ + MMC_BOOT_MCI_STAT_TX_UNDRUN| \ + MMC_BOOT_MCI_STAT_RX_OVRRUN| \ + MMC_BOOT_MCI_STAT_CMD_RESP_END| \ + MMC_BOOT_MCI_STAT_CMD_SENT| \ + MMC_BOOT_MCI_STAT_DATA_END| \ + MMC_BOOT_MCI_STAT_START_BIT_ERR| \ + MMC_BOOT_MCI_STAT_DATA_BLK_END| \ + MMC_BOOT_MCI_SDIO_INTR_CLR| \ + MMC_BOOT_MCI_STAT_PROG_DONE| \ + MMC_BOOT_MCI_STAT_ATA_CMD_CMPL |\ + MMC_BOOT_MCI_STAT_CCS_TIMEOUT) + +#define MMC_BOOT_MCI_CLEAR 0x038 +#define MMC_BOOT_MCI_CMD_CRC_FAIL_CLR (1 << 0) +#define MMC_BOOT_MCI_DATA_CRC_FAIL_CLR (1 << 1) +#define MMC_BOOT_MCI_CMD_TIMEOUT_CLR (1 << 2) +#define MMC_BOOT_MCI_DATA_TIMEOUT_CLR (1 << 3) +#define MMC_BOOT_MCI_TX_UNDERRUN_CLR (1 << 4) +#define MMC_BOOT_MCI_RX_OVERRUN_CLR (1 << 5) +#define MMC_BOOT_MCI_CMD_RESP_END_CLR (1 << 6) +#define MMC_BOOT_MCI_CMD_SENT_CLR (1 << 7) +#define MMC_BOOT_MCI_DATA_END_CLR (1 << 8) +#define MMC_BOOT_MCI_START_BIT_ERR_CLR (1 << 9) +#define MMC_BOOT_MCI_DATA_BLK_END_CLR (1 << 10) +#define MMC_BOOT_MCI_SDIO_INTR_CLR (1 << 22) +#define MMC_BOOT_MCI_PROG_DONE_CLR (1 << 23) +#define MMC_BOOT_MCI_ATA_CMD_COMPLR_CLR (1 << 24) +#define MMC_BOOT_MCI_CCS_TIMEOUT_CLR (1 << 25) + +#define MMC_BOOT_MCI_INT_MASK0 0x03C +#define MMC_BOOT_MCI_CMD_CRC_FAIL_MASK (1 << 0) +#define MMC_BOOT_MCI_DATA_CRC_FAIL_MASK (1 << 1) +#define MMC_BOOT_MCI_CMD_TIMEOUT_MASK (1 << 2) +#define MMC_BOOT_MCI_DATA_TIMEOUT_MASK (1 << 3) +#define MMC_BOOT_MCI_TX_OVERRUN_MASK (1 << 4) +#define MMC_BOOT_MCI_RX_OVERRUN_MASK (1 << 5) +#define MMC_BOOT_MCI_CMD_RESP_END_MASK (1 << 6) +#define MMC_BOOT_MCI_CMD_SENT_MASK (1 << 7) +#define MMC_BOOT_MCI_DATA_END_MASK (1 << 8) +#define MMC_BOOT_MCI_START_BIT_ERR_MASK (1 << 9) +#define MMC_BOOT_MCI_DATA_BLK_END_MASK (1 << 10) +#define MMC_BOOT_MCI_CMD_ACTIVE_MASK (1 << 11) +#define MMC_BOOT_MCI_TX_ACTIVE_MASK (1 << 12) +#define MMC_BOOT_MCI_RX_ACTIVE_MASK (1 << 13) +#define MMC_BOOT_MCI_TX_FIFO_HFULL_MASK (1 << 14) +#define MMC_BOOT_MCI_RX_FIFO_HFULL_MASK (1 << 15) +#define MMC_BOOT_MCI_TX_FIFO_FULL_MASK (1 << 16) +#define MMC_BOOT_MCI_RX_FIFO_FULL_MASK (1 << 17) +#define MMC_BOOT_MCI_TX_FIFO_EMPTY_MASK (1 << 18) +#define MMC_BOOT_MCI_RX_FIFO_EMPTY_MASK (1 << 19) +#define MMC_BOOT_MCI_TX_DATA_AVLBL_MASK (1 << 20) +#define MMC_BOOT_MCI_RX_DATA_AVLBL_MASK (1 << 21) +#define MMC_BOOT_MCI_SDIO_INT_MASK (1 << 22) +#define MMC_BOOT_MCI_PROG_DONE_MASK (1 << 23) +#define MMC_BOOT_MCI_ATA_CMD_COMPL_MASK (1 << 24) +#define MMC_BOOT_MCI_SDIO_INT_OPER_MASK (1 << 25) +#define MMC_BOOT_MCI_CCS_TIME_OUT_MASK (1 << 26) + +#define MMC_BOOT_MCI_INT_MASK1 0x040 + +#define MMC_BOOT_MCI_FIFO_COUNT 0x044 + +#define MMC_BOOT_MCI_CCS_TIMER 0x0058 + +#define MMC_BOOT_MCI_FIFO 0x080 + +/* OCR Register */ +#define MMC_BOOT_OCR_17_19 (1 << 7) +#define MMC_BOOT_OCR_27_36 (0x1FF << 15) +#define MMC_BOOT_OCR_SEC_MODE (2 << 29) +#define MMC_BOOT_OCR_BUSY (1 << 31) + +/* Commands type */ +#define MMC_BOOT_CMD_BCAST (1 << 0) +#define MMC_BOOT_CMD_BCAST_W_RESP (1 << 1) +#define MMC_BOOT_CMD_ADDRESS (1 << 2) +#define MMC_BOOT_CMD_ADDR_DATA_XFER (1 << 3) + +/* Card Status bits (R1 register) */ +#define MMC_BOOT_R1_AKE_SEQ_ERROR (1 << 3) +#define MMC_BOOT_R1_APP_CMD (1 << 5) +#define MMC_BOOT_R1_RDY_FOR_DATA (1 << 6) +#define MMC_BOOT_R1_CURR_STATE_IDLE (0 << 9) +#define MMC_BOOT_R1_CURR_STATE_RDY (1 << 9) +#define MMC_BOOT_R1_CURR_STATE_IDENT (2 << 9) +#define MMC_BOOT_R1_CURR_STATE_STBY (3 << 9) +#define MMC_BOOT_R1_CURR_STATE_TRAN (4 << 9) +#define MMC_BOOT_R1_CURR_STATE_DATA (5 << 9) +#define MMC_BOOT_R1_CURR_STATE_RCV (6 << 9) +#define MMC_BOOT_R1_CURR_STATE_PRG (7 << 9) +#define MMC_BOOT_R1_CURR_STATE_DIS (8 << 9) +#define MMC_BOOT_R1_ERASE_RESET (1 << 13) +#define MMC_BOOT_R1_CARD_ECC_DISABLED (1 << 14) +#define MMC_BOOT_R1_WP_ERASE_SKIP (1 << 15) +#define MMC_BOOT_R1_ERROR (1 << 19) +#define MMC_BOOT_R1_CC_ERROR (1 << 20) +#define MMC_BOOT_R1_CARD_ECC_FAILED (1 << 21) +#define MMC_BOOT_R1_ILLEGAL_CMD (1 << 22) +#define MMC_BOOT_R1_COM_CRC_ERR (1 << 23) +#define MMC_BOOT_R1_LOCK_UNLOCK_FAIL (1 << 24) +#define MMC_BOOT_R1_CARD_IS_LOCKED (1 << 25) +#define MMC_BOOT_R1_WP_VIOLATION (1 << 26) +#define MMC_BOOT_R1_ERASE_PARAM (1 << 27) +#define MMC_BOOT_R1_ERASE_SEQ_ERR (1 << 28) +#define MMC_BOOT_R1_BLOCK_LEN_ERR (1 << 29) +#define MMC_BOOT_R1_ADDR_ERR (1 << 30) +#define MMC_BOOT_R1_OUT_OF_RANGE (1 << 31) + +/* Macros for Common Errors */ +#define MMC_BOOT_E_SUCCESS 0 +#define MMC_BOOT_E_FAILURE 1 +/* Not used..use instead TIMEOUT in include/mmc.h */ +#define MMC_BOOT_E_TIMEOUT 2 +#define MMC_BOOT_E_INVAL 3 +#define MMC_BOOT_E_CRC_FAIL 4 +#define MMC_BOOT_E_INIT_FAIL 5 +#define MMC_BOOT_E_CMD_INDX_MISMATCH 6 +#define MMC_BOOT_E_RESP_VERIFY_FAIL 7 +#define MMC_BOOT_E_NOT_SUPPORTED 8 +#define MMC_BOOT_E_CARD_BUSY 9 +#define MMC_BOOT_E_MEM_ALLOC_FAIL 10 +#define MMC_BOOT_E_CLK_ENABLE_FAIL 11 +#define MMC_BOOT_E_CMMC_DECODE_FAIL 12 +#define MMC_BOOT_E_CID_DECODE_FAIL 13 +#define MMC_BOOT_E_BLOCKLEN_ERR 14 +#define MMC_BOOT_E_ADDRESS_ERR 15 +#define MMC_BOOT_E_DATA_CRC_FAIL 16 +#define MMC_BOOT_E_DATA_TIMEOUT 17 +#define MMC_BOOT_E_RX_OVRRUN 18 +#define MMC_BOOT_E_VREG_SET_FAILED 19 +#define MMC_BOOT_E_GPIO_CFG_FAIL 20 +#define MMC_BOOT_E_DATA_ADM_ERR 21 + +/* EXT_CSD */ +#define MMC_BOOT_ACCESS_WRITE 0x3 +#define MMC_BOOT_EXT_CMMC_HS_TIMING 185 +#define MMC_BOOT_EXT_CMMC_BUS_WIDTH 183 + +#define MMC_BOOT_EXT_USER_WP 171 +#define MMC_BOOT_EXT_ERASE_GROUP_DEF 175 +#define MMC_BOOT_EXT_HC_WP_GRP_SIZE 221 +#define MMC_BOOT_EXT_HC_ERASE_GRP_SIZE 224 + +#define MMC_BOOT_US_PERM_WP_EN 2 +#define MMC_BOOT_US_PWR_WP_DIS 3 + +#define MMC_BOOT_US_PERM_WP_DIS (1<<4) +#define MMC_BOOT_US_PWR_WP_EN 1 + +/* For SD */ +#define MMC_BOOT_SD_HC_VOLT_SUPPLIED 0x000001AA +#define MMC_BOOT_SD_NEG_OCR 0x00FF8000 +#define MMC_BOOT_SD_HC_HCS 0x40000000 +#define MMC_BOOT_SD_DEV_READY 0x80000000 +#define MMC_BOOT_SD_SWITCH_HS 0x80FFFFF1 + +/* Data structure definitions */ + +#define MMC_BOOT_XFER_MODE_BLOCK 0 +#define MMC_BOOT_XFER_MODE_STREAM 1 +#define MMC_BOOT_PROGRAM_ENABLED 2 + + +#define MMC_RCA 2 + +#define MMC_BOOT_MAX_COMMAND_RETRY 1000 +#define MMC_BOOT_RD_BLOCK_LEN 512 +#define MMC_BOOT_WR_BLOCK_LEN 512 + +/* We have 16 32-bits FIFO registers */ +#define MMC_BOOT_MCI_FIFO_DEPTH 16 +#define MMC_BOOT_MCI_HFIFO_COUNT (MMC_BOOT_MCI_FIFO_DEPTH / 2) +#define MMC_BOOT_MCI_FIFO_SIZE (MMC_BOOT_MCI_FIFO_DEPTH * 4) + +#define MAX_PARTITIONS 64 + +#define MMC_BOOT_CHECK_PATTERN 0xAA /* 10101010b */ + +#define MMC_CLK_400KHZ 400000 +#define MMC_CLK_144KHZ 144000 +#define MMC_CLK_20MHZ 20000000 +#define MMC_CLK_24MHZ 24000000 +#define MMC_CLK_25MHZ 25000000 +#define MMC_CLK_26MHZ 26000000 +#define MMC_CLK_48MHZ 48000000 +#define MMC_CLK_50MHZ 49152000 +#define MMC_CLK_52MHZ 52000000 + +#define MMC_CLK_ENABLE 1 +#define MMC_CLK_DISABLE 0 + +#if 0 +#define MSM_SDC1_BASE 0x12400000 +#define MSM_SDC2_BASE 0x12140000 +#define MSM_SDC3_BASE 0x12180000 +#define MSM_SDC4_BASE 0x121C0000 +#endif +struct mmc_priv { + unsigned int instance; + unsigned int base; + unsigned int rd_timeout_ns; /* for read timeout */ +}; + +void mmc_boot_set_ios(struct mmc *mmc); +int mmc_boot_send_command_map(struct mmc *mmc, + struct mmc_cmd *cmd, + struct mmc_data *data); +unsigned long int mmc_boot_mci_reg(unsigned long base, unsigned long offset); +unsigned int mmc_boot_main(struct mmc *mmc); + +extern void clock_config_mmc(uint32_t interface, uint32_t freq); +extern void clock_init_mmc(uint32_t interface); +#endif + diff --git a/arch/arm/include/asm/arch-msm7x27a/proc_comm.h b/arch/arm/include/asm/arch-msm7x27a/proc_comm.h new file mode 100644 index 0000000..e919794 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7x27a/proc_comm.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __PROC_COMM_H_ +#define __PROC_COMM_H_ + +void usb_clock_init(void); +void lcdc_clock_init(unsigned rate); +void mdp_clock_init(unsigned rate); +void uart3_clock_init(void); +void uart2_clock_init(void); +void uart1_clock_init(void); +void mddi_clock_init(unsigned num, unsigned rate); +void reboot(unsigned reboot_reason); +int mmc_clock_enable_disable(unsigned id, unsigned enable); +int mmc_clock_set_rate(unsigned id, unsigned rate); +int mmc_clock_get_rate(unsigned id); +int gpio_tlmm_config(unsigned config, unsigned disable); +int vreg_set_level(unsigned id, unsigned mv); +int vreg_enable(unsigned id); +int vreg_disable(unsigned id); + +#endif + + diff --git a/arch/arm/include/asm/arch-msm7x27a/sys_proto.h b/arch/arm/include/asm/arch-msm7x27a/sys_proto.h new file mode 100644 index 0000000..d5d5125 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7x27a/sys_proto.h @@ -0,0 +1,27 @@ +/* + * (C) Copyright 2012 + * Larsen & Toubro Infotech Ltd. <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ +void pll8_enable(void); +void clock_init(void); +void __cpu_early_init(void); +#endif +
