[U-Boot-Users] [PATCH] PPC-44x: Add Open Firmware support to AMCC Yosemite
Hello U-Boot users,
This is my first patch, so any suggestions would be welcome.
I have an AMCC Yosemite board, which I recently updated to use the recent ARCH=powerpc work from mainline Linux. Without this patch, trying to boot from a uImage does not work. The kernel panics while trying to parse the device tree blob. Note that a cuImage works fine previous to this patch.
Also, I noticed that when I started booting with a uImage and dtb, that eth0 had a MAC address of 00:00:00:00:00:00. Adding #define CONFIG_HAS_ETH0 1 fixed this issue, by setting the MAC address via the eth0addr variable in U-Boot.
I tested the following setups: 1) Old ARCH=ppc 2.6.13 kernel 2) New ARCH=powerpc 2.6.26rc0 kernel (cuImage) 3) New ARCH=powerpc 2.6.26rc0 kernel (uImage + dtb)
I ran MAKEALL both with and without the patch. The only changes in output were a ~20kB increase in image size for the yellowstone and yosemite boards.
Thanks for all of the great work. Ira
From d76d560b1f61126c63320cec18d5b436f4bb10c0 Mon Sep 17 00:00:00 2001
From: Ira W. Snyder iws@ovro.caltech.edu Date: Sat, 26 Apr 2008 16:06:26 -0700 Subject: [PATCH] PPC-44x: Add Open Firmware support to AMCC Yosemite
Add support for booting with a device tree blob. This is needed to boot ARCH=powerpc kernels. Also add support for setting the eth0 mac address via the eth0addr variable.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- board/amcc/yosemite/yosemite.c | 11 +++++++++++ include/configs/yosemite.h | 9 +++++++++ 2 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/board/amcc/yosemite/yosemite.c b/board/amcc/yosemite/yosemite.c index 6ec922a..fa610c3 100644 --- a/board/amcc/yosemite/yosemite.c +++ b/board/amcc/yosemite/yosemite.c @@ -26,6 +26,9 @@ #include <asm/processor.h> #include <asm/io.h> #include <spd_sdram.h> +#if defined(CONFIG_OF_LIBFDT) + #include <libfdt.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -554,3 +557,11 @@ void board_reset(void) /* give reset to BCSR */ *(unsigned char *)(CFG_BCSR_BASE | 0x06) = 0x09; } + +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + +} +#endif diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index c9323f6..7dcd4e6 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -141,6 +141,14 @@
/*----------------------------------------------------------------------- + * Open Firmware (Linux-2.6.26+) + *----------------------------------------------------------------------*/ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +/*----------------------------------------------------------------------- * I2C *----------------------------------------------------------------------*/ #define CONFIG_HARD_I2C 1 /* I2C with hardware support */ @@ -227,6 +235,7 @@ #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_NET_MULTI 1 /* required for netconsole */ #define CONFIG_PHY1_ADDR 3 +#define CONFIG_HAS_ETH0 1 /* add support for "eth0addr" */ #define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ #define CONFIG_PHY_ADDR 1 /* PHY address, See schematics */
Hi Ira,
Thanks for your contribution. Its actually quite good for the first time. :)
This should be "ethaddr" instead of "eth0addr".
- Old ARCH=ppc 2.6.13 kernel
- New ARCH=powerpc 2.6.26rc0 kernel (cuImage)
- New ARCH=powerpc 2.6.26rc0 kernel (uImage + dtb)
Thanks. Please find some comments below.
From d76d560b1f61126c63320cec18d5b436f4bb10c0 Mon Sep 17 00:00:00 2001 From: Ira W. Snyder iws@ovro.caltech.edu Date: Sat, 26 Apr 2008 16:06:26 -0700 Subject: [PATCH] PPC-44x: Add Open Firmware support to AMCC Yosemite
I find the subject a little misleading. "Open Firmware" support sounds a little too much. How about:
"ppc4xx: Add device tree support to AMCC Yosemite"
"ethaddr".
- #include <libfdt.h>
Please add this header unconditionally (without indentation).
- ft_cpu_setup(blob, bd);
Why didn't you add the NOR FLASH mapping fixup as done on Sequoia etc? Please add it here.
- Open Firmware (Linux-2.6.26+)
I would prefer "Device tree support" here too.
- I2C
Please address the issues above and resend.
Thanks.
Best regards, Stefan
Hello Stefan, U-Boot users
I have made the changes that Stefan requested: * Include headers unconditionally * Change "eth0addr" to "ethaddr" * Change "Open Firmware support" to "device tree support" * Add NOR flash mapping fixup from Sequoia
I have re-tested the same three setups I tested earlier: 1) Old ARCH=ppc 2.6.13 kernel 2) New ARCH=powerpc 2.6.26rc0 kernel (cuImage) 3) New ARCH=powerpc 2.6.26rc0 kernel (uImage + dtb)
I did not test the NOR flash mapping fixup, as I do not have any NOR flash to test with. It is an exact copy of the Sequoia code, so I hope it is correct.
Thanks for the comments. Ira
From d2775a95e00d5647583763614cdf4c03a53d39c3 Mon Sep 17 00:00:00 2001
From: Ira W. Snyder iws@ovro.caltech.edu Date: Sat, 26 Apr 2008 16:06:26 -0700 Subject: [PATCH] ppc4xx: Add device tree support to AMCC Yosemite
Add support for booting with a device tree blob. This is needed to boot ARCH=powerpc kernels. Also add support for setting the eth0 mac address via the ethaddr variable.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- board/amcc/yosemite/yosemite.c | 23 +++++++++++++++++++++++ include/configs/yosemite.h | 9 +++++++++ 2 files changed, 32 insertions(+), 0 deletions(-)
diff --git a/board/amcc/yosemite/yosemite.c b/board/amcc/yosemite/yosemite.c index 6ec922a..212fab8 100644 --- a/board/amcc/yosemite/yosemite.c +++ b/board/amcc/yosemite/yosemite.c @@ -26,6 +26,8 @@ #include <asm/processor.h> #include <asm/io.h> #include <spd_sdram.h> +#include <libfdt.h> +#include <fdt_support.h>
@@ -554,3 +556,24 @@ void board_reset(void) /* give reset to BCSR */ *(unsigned char *)(CFG_BCSR_BASE | 0x06) = 0x09; } + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + u32 val[4]; + int rc; + + ft_cpu_setup(blob, bd); + + /* Fixup NOR mapping */ + val[0] = 0; /* chip select number */ + val[1] = 0; /* always 0 */ + val[2] = gd->bd->bi_flashstart; + val[3] = gd->bd->bi_flashsize; + rc = fdt_find_and_setprop(blob, "/plb/opb/ebc", "ranges", + val, sizeof(val), 1); + if (rc) + printf("Unable to update property NOR mapping, err=%s\n", + fdt_strerror(rc)); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index c9323f6..3bd115a 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -141,6 +141,14 @@
/*----------------------------------------------------------------------- + * Device tree support (Linux-2.6.26+) + *----------------------------------------------------------------------*/ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +/*----------------------------------------------------------------------- * I2C *----------------------------------------------------------------------*/ #define CONFIG_HARD_I2C 1 /* I2C with hardware support */ @@ -227,6 +235,7 @@ #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_NET_MULTI 1 /* required for netconsole */ #define CONFIG_PHY1_ADDR 3 +#define CONFIG_HAS_ETH0 1 /* add support for "ethaddr" */ #define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ #define CONFIG_PHY_ADDR 1 /* PHY address, See schematics */
Ira Snyder
Stefan Roese
