[U-Boot] [PATCH v4 0/6] DM: Convert i.MX28 gpio, pinmux, spi and eth drivers to DM/DTS
This patch series converts some i.MX28 drivers to use DM/DTS.
Converted drivers: - mxs_gpio.c - gpio driver - pinctrl-mxs.c - pinmux driver - Adjust fec_eth.c to support also i.MX28 SoC. - mxs_spi.c - SPI driver
After applying this series it is possible to use ETH on i.MX28 board with following DTS description:
&mac0 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac0_pins_a>; phy-supply = <®_fec_3v3>; phy-reset-gpios = <&gpio2 13 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; phy-reset-post-delay = <1>; status = "okay";
fixed-link { speed = <100>; full-duplex; }; };
And store the received binaries on SPI-NOR memory.
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/547299325
Applied on top of u-boot/master branch SHA1: c2ea87883ef309570c8903e6de4b8b78685d73d0
Changes in v4: - Add 12 digit SHA1 ID for tag v5.1.9 - Sort the entries for compatibles and Kconfig - New file - imx28-u-boot.dtsi - Use BIT() macro instead of 1 << offset - Use devfdt_get_addr to get gpio number - Use gpio-ranges property to setup gpios - Use Linux kernel code to setup pins instead of Barebox - Add soc specific data and compatible for i.MX23 and i.MX28 - Use devm_kfree() to release temporary memory - Adjust the driver to support i.MX23 (add compatible, adjust clk code) - Use BIT() macro where applicable
Changes in v3: - Update tag to 5.1.9 - Set more apropriate tags - Set more apropriate tags - Set more apropriate tags - Set more apropriate tags - Set more appropriate tags
Changes in v2: - Use #if !CONFIG_IS_ENABLED(DM_GPIO) instead of plain #ifdef CONFIG_DM_GPIO - New patch (conversion of mxs_spi.c to DM_SPI)
Lukasz Majewski (6): ARM: dts: imx: Copy imx28 device tree related files from Linux kernel (v5.1.9) ARM: imx: net: Enable support for i.MX28 DM_ETH in the fec_mxc.c driver DTS: dm: mxs: gpio: Provide 'gpio-ranges' for mxs_gpio driver ARM: dm: mxs: gpio: Add support for DM/DTS in the mxs_gpio.c driver (DM_GPIO) ARM: imx: pinctrl: Add support for i.MX2[38] mxs pinctrl driver ARM: dm: spi: Add support DM/DTS for i.MX28 mxs SPI driver (DM_SPI conversion)
arch/arm/dts/imx28-pinfunc.h | 506 ++++++++++++++ arch/arm/dts/imx28-u-boot.dtsi | 28 + arch/arm/dts/imx28.dtsi | 1330 +++++++++++++++++++++++++++++++++++++ arch/arm/dts/mxs-pinfunc.h | 31 + drivers/gpio/mxs_gpio.c | 148 +++++ drivers/net/Kconfig | 2 +- drivers/net/fec_mxc.c | 1 + drivers/pinctrl/nxp/Kconfig | 10 + drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-mxs.c | 200 ++++++ drivers/pinctrl/nxp/pinctrl-mxs.h | 55 ++ drivers/spi/mxs_spi.c | 400 ++++++++--- 12 files changed, 2628 insertions(+), 84 deletions(-) create mode 100644 arch/arm/dts/imx28-pinfunc.h create mode 100644 arch/arm/dts/imx28-u-boot.dtsi create mode 100644 arch/arm/dts/imx28.dtsi create mode 100644 arch/arm/dts/mxs-pinfunc.h create mode 100644 drivers/pinctrl/nxp/pinctrl-mxs.c create mode 100644 drivers/pinctrl/nxp/pinctrl-mxs.h
This patch copies from the Linux kernel (tag v5.1.9) SHA1: 2df16141a2c4 i.MX28 related device tree files.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
Changes in v2: None
arch/arm/dts/imx28-pinfunc.h | 506 ++++++++++++++++ arch/arm/dts/imx28.dtsi | 1330 ++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/mxs-pinfunc.h | 31 + 3 files changed, 1867 insertions(+) create mode 100644 arch/arm/dts/imx28-pinfunc.h create mode 100644 arch/arm/dts/imx28.dtsi create mode 100644 arch/arm/dts/mxs-pinfunc.h
diff --git a/arch/arm/dts/imx28-pinfunc.h b/arch/arm/dts/imx28-pinfunc.h new file mode 100644 index 0000000000..e11f69ba0f --- /dev/null +++ b/arch/arm/dts/imx28-pinfunc.h @@ -0,0 +1,506 @@ +/* + * Header providing constants for i.MX28 pinctrl bindings. + * + * Copyright (C) 2013 Lothar Waßmann LW@KARO-electronics.de + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#ifndef __DT_BINDINGS_MX28_PINCTRL_H__ +#define __DT_BINDINGS_MX28_PINCTRL_H__ + +#include "mxs-pinfunc.h" + +#define MX28_PAD_GPMI_D00__GPMI_D0 0x0000 +#define MX28_PAD_GPMI_D01__GPMI_D1 0x0010 +#define MX28_PAD_GPMI_D02__GPMI_D2 0x0020 +#define MX28_PAD_GPMI_D03__GPMI_D3 0x0030 +#define MX28_PAD_GPMI_D04__GPMI_D4 0x0040 +#define MX28_PAD_GPMI_D05__GPMI_D5 0x0050 +#define MX28_PAD_GPMI_D06__GPMI_D6 0x0060 +#define MX28_PAD_GPMI_D07__GPMI_D7 0x0070 +#define MX28_PAD_GPMI_CE0N__GPMI_CE0N 0x0100 +#define MX28_PAD_GPMI_CE1N__GPMI_CE1N 0x0110 +#define MX28_PAD_GPMI_CE2N__GPMI_CE2N 0x0120 +#define MX28_PAD_GPMI_CE3N__GPMI_CE3N 0x0130 +#define MX28_PAD_GPMI_RDY0__GPMI_READY0 0x0140 +#define MX28_PAD_GPMI_RDY1__GPMI_READY1 0x0150 +#define MX28_PAD_GPMI_RDY2__GPMI_READY2 0x0160 +#define MX28_PAD_GPMI_RDY3__GPMI_READY3 0x0170 +#define MX28_PAD_GPMI_RDN__GPMI_RDN 0x0180 +#define MX28_PAD_GPMI_WRN__GPMI_WRN 0x0190 +#define MX28_PAD_GPMI_ALE__GPMI_ALE 0x01a0 +#define MX28_PAD_GPMI_CLE__GPMI_CLE 0x01b0 +#define MX28_PAD_GPMI_RESETN__GPMI_RESETN 0x01c0 +#define MX28_PAD_LCD_D00__LCD_D0 0x1000 +#define MX28_PAD_LCD_D01__LCD_D1 0x1010 +#define MX28_PAD_LCD_D02__LCD_D2 0x1020 +#define MX28_PAD_LCD_D03__LCD_D3 0x1030 +#define MX28_PAD_LCD_D04__LCD_D4 0x1040 +#define MX28_PAD_LCD_D05__LCD_D5 0x1050 +#define MX28_PAD_LCD_D06__LCD_D6 0x1060 +#define MX28_PAD_LCD_D07__LCD_D7 0x1070 +#define MX28_PAD_LCD_D08__LCD_D8 0x1080 +#define MX28_PAD_LCD_D09__LCD_D9 0x1090 +#define MX28_PAD_LCD_D10__LCD_D10 0x10a0 +#define MX28_PAD_LCD_D11__LCD_D11 0x10b0 +#define MX28_PAD_LCD_D12__LCD_D12 0x10c0 +#define MX28_PAD_LCD_D13__LCD_D13 0x10d0 +#define MX28_PAD_LCD_D14__LCD_D14 0x10e0 +#define MX28_PAD_LCD_D15__LCD_D15 0x10f0 +#define MX28_PAD_LCD_D16__LCD_D16 0x1100 +#define MX28_PAD_LCD_D17__LCD_D17 0x1110 +#define MX28_PAD_LCD_D18__LCD_D18 0x1120 +#define MX28_PAD_LCD_D19__LCD_D19 0x1130 +#define MX28_PAD_LCD_D20__LCD_D20 0x1140 +#define MX28_PAD_LCD_D21__LCD_D21 0x1150 +#define MX28_PAD_LCD_D22__LCD_D22 0x1160 +#define MX28_PAD_LCD_D23__LCD_D23 0x1170 +#define MX28_PAD_LCD_RD_E__LCD_RD_E 0x1180 +#define MX28_PAD_LCD_WR_RWN__LCD_WR_RWN 0x1190 +#define MX28_PAD_LCD_RS__LCD_RS 0x11a0 +#define MX28_PAD_LCD_CS__LCD_CS 0x11b0 +#define MX28_PAD_LCD_VSYNC__LCD_VSYNC 0x11c0 +#define MX28_PAD_LCD_HSYNC__LCD_HSYNC 0x11d0 +#define MX28_PAD_LCD_DOTCLK__LCD_DOTCLK 0x11e0 +#define MX28_PAD_LCD_ENABLE__LCD_ENABLE 0x11f0 +#define MX28_PAD_SSP0_DATA0__SSP0_D0 0x2000 +#define MX28_PAD_SSP0_DATA1__SSP0_D1 0x2010 +#define MX28_PAD_SSP0_DATA2__SSP0_D2 0x2020 +#define MX28_PAD_SSP0_DATA3__SSP0_D3 0x2030 +#define MX28_PAD_SSP0_DATA4__SSP0_D4 0x2040 +#define MX28_PAD_SSP0_DATA5__SSP0_D5 0x2050 +#define MX28_PAD_SSP0_DATA6__SSP0_D6 0x2060 +#define MX28_PAD_SSP0_DATA7__SSP0_D7 0x2070 +#define MX28_PAD_SSP0_CMD__SSP0_CMD 0x2080 +#define MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT 0x2090 +#define MX28_PAD_SSP0_SCK__SSP0_SCK 0x20a0 +#define MX28_PAD_SSP1_SCK__SSP1_SCK 0x20c0 +#define MX28_PAD_SSP1_CMD__SSP1_CMD 0x20d0 +#define MX28_PAD_SSP1_DATA0__SSP1_D0 0x20e0 +#define MX28_PAD_SSP1_DATA3__SSP1_D3 0x20f0 +#define MX28_PAD_SSP2_SCK__SSP2_SCK 0x2100 +#define MX28_PAD_SSP2_MOSI__SSP2_CMD 0x2110 +#define MX28_PAD_SSP2_MISO__SSP2_D0 0x2120 +#define MX28_PAD_SSP2_SS0__SSP2_D3 0x2130 +#define MX28_PAD_SSP2_SS1__SSP2_D4 0x2140 +#define MX28_PAD_SSP2_SS2__SSP2_D5 0x2150 +#define MX28_PAD_SSP3_SCK__SSP3_SCK 0x2180 +#define MX28_PAD_SSP3_MOSI__SSP3_CMD 0x2190 +#define MX28_PAD_SSP3_MISO__SSP3_D0 0x21a0 +#define MX28_PAD_SSP3_SS0__SSP3_D3 0x21b0 +#define MX28_PAD_AUART0_RX__AUART0_RX 0x3000 +#define MX28_PAD_AUART0_TX__AUART0_TX 0x3010 +#define MX28_PAD_AUART0_CTS__AUART0_CTS 0x3020 +#define MX28_PAD_AUART0_RTS__AUART0_RTS 0x3030 +#define MX28_PAD_AUART1_RX__AUART1_RX 0x3040 +#define MX28_PAD_AUART1_TX__AUART1_TX 0x3050 +#define MX28_PAD_AUART1_CTS__AUART1_CTS 0x3060 +#define MX28_PAD_AUART1_RTS__AUART1_RTS 0x3070 +#define MX28_PAD_AUART2_RX__AUART2_RX 0x3080 +#define MX28_PAD_AUART2_TX__AUART2_TX 0x3090 +#define MX28_PAD_AUART2_CTS__AUART2_CTS 0x30a0 +#define MX28_PAD_AUART2_RTS__AUART2_RTS 0x30b0 +#define MX28_PAD_AUART3_RX__AUART3_RX 0x30c0 +#define MX28_PAD_AUART3_TX__AUART3_TX 0x30d0 +#define MX28_PAD_AUART3_CTS__AUART3_CTS 0x30e0 +#define MX28_PAD_AUART3_RTS__AUART3_RTS 0x30f0 +#define MX28_PAD_PWM0__PWM_0 0x3100 +#define MX28_PAD_PWM1__PWM_1 0x3110 +#define MX28_PAD_PWM2__PWM_2 0x3120 +#define MX28_PAD_SAIF0_MCLK__SAIF0_MCLK 0x3140 +#define MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK 0x3150 +#define MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK 0x3160 +#define MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0 0x3170 +#define MX28_PAD_I2C0_SCL__I2C0_SCL 0x3180 +#define MX28_PAD_I2C0_SDA__I2C0_SDA 0x3190 +#define MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0 0x31a0 +#define MX28_PAD_SPDIF__SPDIF_TX 0x31b0 +#define MX28_PAD_PWM3__PWM_3 0x31c0 +#define MX28_PAD_PWM4__PWM_4 0x31d0 +#define MX28_PAD_LCD_RESET__LCD_RESET 0x31e0 +#define MX28_PAD_ENET0_MDC__ENET0_MDC 0x4000 +#define MX28_PAD_ENET0_MDIO__ENET0_MDIO 0x4010 +#define MX28_PAD_ENET0_RX_EN__ENET0_RX_EN 0x4020 +#define MX28_PAD_ENET0_RXD0__ENET0_RXD0 0x4030 +#define MX28_PAD_ENET0_RXD1__ENET0_RXD1 0x4040 +#define MX28_PAD_ENET0_TX_CLK__ENET0_TX_CLK 0x4050 +#define MX28_PAD_ENET0_TX_EN__ENET0_TX_EN 0x4060 +#define MX28_PAD_ENET0_TXD0__ENET0_TXD0 0x4070 +#define MX28_PAD_ENET0_TXD1__ENET0_TXD1 0x4080 +#define MX28_PAD_ENET0_RXD2__ENET0_RXD2 0x4090 +#define MX28_PAD_ENET0_RXD3__ENET0_RXD3 0x40a0 +#define MX28_PAD_ENET0_TXD2__ENET0_TXD2 0x40b0 +#define MX28_PAD_ENET0_TXD3__ENET0_TXD3 0x40c0 +#define MX28_PAD_ENET0_RX_CLK__ENET0_RX_CLK 0x40d0 +#define MX28_PAD_ENET0_COL__ENET0_COL 0x40e0 +#define MX28_PAD_ENET0_CRS__ENET0_CRS 0x40f0 +#define MX28_PAD_ENET_CLK__CLKCTRL_ENET 0x4100 +#define MX28_PAD_JTAG_RTCK__JTAG_RTCK 0x4140 +#define MX28_PAD_EMI_D00__EMI_DATA0 0x5000 +#define MX28_PAD_EMI_D01__EMI_DATA1 0x5010 +#define MX28_PAD_EMI_D02__EMI_DATA2 0x5020 +#define MX28_PAD_EMI_D03__EMI_DATA3 0x5030 +#define MX28_PAD_EMI_D04__EMI_DATA4 0x5040 +#define MX28_PAD_EMI_D05__EMI_DATA5 0x5050 +#define MX28_PAD_EMI_D06__EMI_DATA6 0x5060 +#define MX28_PAD_EMI_D07__EMI_DATA7 0x5070 +#define MX28_PAD_EMI_D08__EMI_DATA8 0x5080 +#define MX28_PAD_EMI_D09__EMI_DATA9 0x5090 +#define MX28_PAD_EMI_D10__EMI_DATA10 0x50a0 +#define MX28_PAD_EMI_D11__EMI_DATA11 0x50b0 +#define MX28_PAD_EMI_D12__EMI_DATA12 0x50c0 +#define MX28_PAD_EMI_D13__EMI_DATA13 0x50d0 +#define MX28_PAD_EMI_D14__EMI_DATA14 0x50e0 +#define MX28_PAD_EMI_D15__EMI_DATA15 0x50f0 +#define MX28_PAD_EMI_ODT0__EMI_ODT0 0x5100 +#define MX28_PAD_EMI_DQM0__EMI_DQM0 0x5110 +#define MX28_PAD_EMI_ODT1__EMI_ODT1 0x5120 +#define MX28_PAD_EMI_DQM1__EMI_DQM1 0x5130 +#define MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK 0x5140 +#define MX28_PAD_EMI_CLK__EMI_CLK 0x5150 +#define MX28_PAD_EMI_DQS0__EMI_DQS0 0x5160 +#define MX28_PAD_EMI_DQS1__EMI_DQS1 0x5170 +#define MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN 0x51a0 +#define MX28_PAD_EMI_A00__EMI_ADDR0 0x6000 +#define MX28_PAD_EMI_A01__EMI_ADDR1 0x6010 +#define MX28_PAD_EMI_A02__EMI_ADDR2 0x6020 +#define MX28_PAD_EMI_A03__EMI_ADDR3 0x6030 +#define MX28_PAD_EMI_A04__EMI_ADDR4 0x6040 +#define MX28_PAD_EMI_A05__EMI_ADDR5 0x6050 +#define MX28_PAD_EMI_A06__EMI_ADDR6 0x6060 +#define MX28_PAD_EMI_A07__EMI_ADDR7 0x6070 +#define MX28_PAD_EMI_A08__EMI_ADDR8 0x6080 +#define MX28_PAD_EMI_A09__EMI_ADDR9 0x6090 +#define MX28_PAD_EMI_A10__EMI_ADDR10 0x60a0 +#define MX28_PAD_EMI_A11__EMI_ADDR11 0x60b0 +#define MX28_PAD_EMI_A12__EMI_ADDR12 0x60c0 +#define MX28_PAD_EMI_A13__EMI_ADDR13 0x60d0 +#define MX28_PAD_EMI_A14__EMI_ADDR14 0x60e0 +#define MX28_PAD_EMI_BA0__EMI_BA0 0x6100 +#define MX28_PAD_EMI_BA1__EMI_BA1 0x6110 +#define MX28_PAD_EMI_BA2__EMI_BA2 0x6120 +#define MX28_PAD_EMI_CASN__EMI_CASN 0x6130 +#define MX28_PAD_EMI_RASN__EMI_RASN 0x6140 +#define MX28_PAD_EMI_WEN__EMI_WEN 0x6150 +#define MX28_PAD_EMI_CE0N__EMI_CE0N 0x6160 +#define MX28_PAD_EMI_CE1N__EMI_CE1N 0x6170 +#define MX28_PAD_EMI_CKE__EMI_CKE 0x6180 +#define MX28_PAD_GPMI_D00__SSP1_D0 0x0001 +#define MX28_PAD_GPMI_D01__SSP1_D1 0x0011 +#define MX28_PAD_GPMI_D02__SSP1_D2 0x0021 +#define MX28_PAD_GPMI_D03__SSP1_D3 0x0031 +#define MX28_PAD_GPMI_D04__SSP1_D4 0x0041 +#define MX28_PAD_GPMI_D05__SSP1_D5 0x0051 +#define MX28_PAD_GPMI_D06__SSP1_D6 0x0061 +#define MX28_PAD_GPMI_D07__SSP1_D7 0x0071 +#define MX28_PAD_GPMI_CE0N__SSP3_D0 0x0101 +#define MX28_PAD_GPMI_CE1N__SSP3_D3 0x0111 +#define MX28_PAD_GPMI_CE2N__CAN1_TX 0x0121 +#define MX28_PAD_GPMI_CE3N__CAN1_RX 0x0131 +#define MX28_PAD_GPMI_RDY0__SSP1_CARD_DETECT 0x0141 +#define MX28_PAD_GPMI_RDY1__SSP1_CMD 0x0151 +#define MX28_PAD_GPMI_RDY2__CAN0_TX 0x0161 +#define MX28_PAD_GPMI_RDY3__CAN0_RX 0x0171 +#define MX28_PAD_GPMI_RDN__SSP3_SCK 0x0181 +#define MX28_PAD_GPMI_WRN__SSP1_SCK 0x0191 +#define MX28_PAD_GPMI_ALE__SSP3_D1 0x01a1 +#define MX28_PAD_GPMI_CLE__SSP3_D2 0x01b1 +#define MX28_PAD_GPMI_RESETN__SSP3_CMD 0x01c1 +#define MX28_PAD_LCD_D03__ETM_DA8 0x1031 +#define MX28_PAD_LCD_D04__ETM_DA9 0x1041 +#define MX28_PAD_LCD_D08__ETM_DA3 0x1081 +#define MX28_PAD_LCD_D09__ETM_DA4 0x1091 +#define MX28_PAD_LCD_D20__ENET1_1588_EVENT2_OUT 0x1141 +#define MX28_PAD_LCD_D21__ENET1_1588_EVENT2_IN 0x1151 +#define MX28_PAD_LCD_D22__ENET1_1588_EVENT3_OUT 0x1161 +#define MX28_PAD_LCD_D23__ENET1_1588_EVENT3_IN 0x1171 +#define MX28_PAD_LCD_RD_E__LCD_VSYNC 0x1181 +#define MX28_PAD_LCD_WR_RWN__LCD_HSYNC 0x1191 +#define MX28_PAD_LCD_RS__LCD_DOTCLK 0x11a1 +#define MX28_PAD_LCD_CS__LCD_ENABLE 0x11b1 +#define MX28_PAD_LCD_VSYNC__SAIF1_SDATA0 0x11c1 +#define MX28_PAD_LCD_HSYNC__SAIF1_SDATA1 0x11d1 +#define MX28_PAD_LCD_DOTCLK__SAIF1_MCLK 0x11e1 +#define MX28_PAD_SSP0_DATA4__SSP2_D0 0x2041 +#define MX28_PAD_SSP0_DATA5__SSP2_D3 0x2051 +#define MX28_PAD_SSP0_DATA6__SSP2_CMD 0x2061 +#define MX28_PAD_SSP0_DATA7__SSP2_SCK 0x2071 +#define MX28_PAD_SSP1_SCK__SSP2_D1 0x20c1 +#define MX28_PAD_SSP1_CMD__SSP2_D2 0x20d1 +#define MX28_PAD_SSP1_DATA0__SSP2_D6 0x20e1 +#define MX28_PAD_SSP1_DATA3__SSP2_D7 0x20f1 +#define MX28_PAD_SSP2_SCK__AUART2_RX 0x2101 +#define MX28_PAD_SSP2_MOSI__AUART2_TX 0x2111 +#define MX28_PAD_SSP2_MISO__AUART3_RX 0x2121 +#define MX28_PAD_SSP2_SS0__AUART3_TX 0x2131 +#define MX28_PAD_SSP2_SS1__SSP2_D1 0x2141 +#define MX28_PAD_SSP2_SS2__SSP2_D2 0x2151 +#define MX28_PAD_SSP3_SCK__AUART4_TX 0x2181 +#define MX28_PAD_SSP3_MOSI__AUART4_RX 0x2191 +#define MX28_PAD_SSP3_MISO__AUART4_RTS 0x21a1 +#define MX28_PAD_SSP3_SS0__AUART4_CTS 0x21b1 +#define MX28_PAD_AUART0_RX__I2C0_SCL 0x3001 +#define MX28_PAD_AUART0_TX__I2C0_SDA 0x3011 +#define MX28_PAD_AUART0_CTS__AUART4_RX 0x3021 +#define MX28_PAD_AUART0_RTS__AUART4_TX 0x3031 +#define MX28_PAD_AUART1_RX__SSP2_CARD_DETECT 0x3041 +#define MX28_PAD_AUART1_TX__SSP3_CARD_DETECT 0x3051 +#define MX28_PAD_AUART1_CTS__USB0_OVERCURRENT 0x3061 +#define MX28_PAD_AUART1_RTS__USB0_ID 0x3071 +#define MX28_PAD_AUART2_RX__SSP3_D1 0x3081 +#define MX28_PAD_AUART2_TX__SSP3_D2 0x3091 +#define MX28_PAD_AUART2_CTS__I2C1_SCL 0x30a1 +#define MX28_PAD_AUART2_RTS__I2C1_SDA 0x30b1 +#define MX28_PAD_AUART3_RX__CAN0_TX 0x30c1 +#define MX28_PAD_AUART3_TX__CAN0_RX 0x30d1 +#define MX28_PAD_AUART3_CTS__CAN1_TX 0x30e1 +#define MX28_PAD_AUART3_RTS__CAN1_RX 0x30f1 +#define MX28_PAD_PWM0__I2C1_SCL 0x3101 +#define MX28_PAD_PWM1__I2C1_SDA 0x3111 +#define MX28_PAD_PWM2__USB0_ID 0x3121 +#define MX28_PAD_SAIF0_MCLK__PWM_3 0x3141 +#define MX28_PAD_SAIF0_LRCLK__PWM_4 0x3151 +#define MX28_PAD_SAIF0_BITCLK__PWM_5 0x3161 +#define MX28_PAD_SAIF0_SDATA0__PWM_6 0x3171 +#define MX28_PAD_I2C0_SCL__TIMROT_ROTARYA 0x3181 +#define MX28_PAD_I2C0_SDA__TIMROT_ROTARYB 0x3191 +#define MX28_PAD_SAIF1_SDATA0__PWM_7 0x31a1 +#define MX28_PAD_LCD_RESET__LCD_VSYNC 0x31e1 +#define MX28_PAD_ENET0_MDC__GPMI_CE4N 0x4001 +#define MX28_PAD_ENET0_MDIO__GPMI_CE5N 0x4011 +#define MX28_PAD_ENET0_RX_EN__GPMI_CE6N 0x4021 +#define MX28_PAD_ENET0_RXD0__GPMI_CE7N 0x4031 +#define MX28_PAD_ENET0_RXD1__GPMI_READY4 0x4041 +#define MX28_PAD_ENET0_TX_CLK__HSADC_TRIGGER 0x4051 +#define MX28_PAD_ENET0_TX_EN__GPMI_READY5 0x4061 +#define MX28_PAD_ENET0_TXD0__GPMI_READY6 0x4071 +#define MX28_PAD_ENET0_TXD1__GPMI_READY7 0x4081 +#define MX28_PAD_ENET0_RXD2__ENET1_RXD0 0x4091 +#define MX28_PAD_ENET0_RXD3__ENET1_RXD1 0x40a1 +#define MX28_PAD_ENET0_TXD2__ENET1_TXD0 0x40b1 +#define MX28_PAD_ENET0_TXD3__ENET1_TXD1 0x40c1 +#define MX28_PAD_ENET0_RX_CLK__ENET0_RX_ER 0x40d1 +#define MX28_PAD_ENET0_COL__ENET1_TX_EN 0x40e1 +#define MX28_PAD_ENET0_CRS__ENET1_RX_EN 0x40f1 +#define MX28_PAD_GPMI_CE2N__ENET0_RX_ER 0x0122 +#define MX28_PAD_GPMI_CE3N__SAIF1_MCLK 0x0132 +#define MX28_PAD_GPMI_RDY0__USB0_ID 0x0142 +#define MX28_PAD_GPMI_RDY2__ENET0_TX_ER 0x0162 +#define MX28_PAD_GPMI_RDY3__HSADC_TRIGGER 0x0172 +#define MX28_PAD_GPMI_ALE__SSP3_D4 0x01a2 +#define MX28_PAD_GPMI_CLE__SSP3_D5 0x01b2 +#define MX28_PAD_LCD_D00__ETM_DA0 0x1002 +#define MX28_PAD_LCD_D01__ETM_DA1 0x1012 +#define MX28_PAD_LCD_D02__ETM_DA2 0x1022 +#define MX28_PAD_LCD_D03__ETM_DA3 0x1032 +#define MX28_PAD_LCD_D04__ETM_DA4 0x1042 +#define MX28_PAD_LCD_D05__ETM_DA5 0x1052 +#define MX28_PAD_LCD_D06__ETM_DA6 0x1062 +#define MX28_PAD_LCD_D07__ETM_DA7 0x1072 +#define MX28_PAD_LCD_D08__ETM_DA8 0x1082 +#define MX28_PAD_LCD_D09__ETM_DA9 0x1092 +#define MX28_PAD_LCD_D10__ETM_DA10 0x10a2 +#define MX28_PAD_LCD_D11__ETM_DA11 0x10b2 +#define MX28_PAD_LCD_D12__ETM_DA12 0x10c2 +#define MX28_PAD_LCD_D13__ETM_DA13 0x10d2 +#define MX28_PAD_LCD_D14__ETM_DA14 0x10e2 +#define MX28_PAD_LCD_D15__ETM_DA15 0x10f2 +#define MX28_PAD_LCD_D16__ETM_DA7 0x1102 +#define MX28_PAD_LCD_D17__ETM_DA6 0x1112 +#define MX28_PAD_LCD_D18__ETM_DA5 0x1122 +#define MX28_PAD_LCD_D19__ETM_DA4 0x1132 +#define MX28_PAD_LCD_D20__ETM_DA3 0x1142 +#define MX28_PAD_LCD_D21__ETM_DA2 0x1152 +#define MX28_PAD_LCD_D22__ETM_DA1 0x1162 +#define MX28_PAD_LCD_D23__ETM_DA0 0x1172 +#define MX28_PAD_LCD_RD_E__ETM_TCTL 0x1182 +#define MX28_PAD_LCD_WR_RWN__ETM_TCLK 0x1192 +#define MX28_PAD_LCD_HSYNC__ETM_TCTL 0x11d2 +#define MX28_PAD_LCD_DOTCLK__ETM_TCLK 0x11e2 +#define MX28_PAD_SSP1_SCK__ENET0_1588_EVENT2_OUT 0x20c2 +#define MX28_PAD_SSP1_CMD__ENET0_1588_EVENT2_IN 0x20d2 +#define MX28_PAD_SSP1_DATA0__ENET0_1588_EVENT3_OUT 0x20e2 +#define MX28_PAD_SSP1_DATA3__ENET0_1588_EVENT3_IN 0x20f2 +#define MX28_PAD_SSP2_SCK__SAIF0_SDATA1 0x2102 +#define MX28_PAD_SSP2_MOSI__SAIF0_SDATA2 0x2112 +#define MX28_PAD_SSP2_MISO__SAIF1_SDATA1 0x2122 +#define MX28_PAD_SSP2_SS0__SAIF1_SDATA2 0x2132 +#define MX28_PAD_SSP2_SS1__USB1_OVERCURRENT 0x2142 +#define MX28_PAD_SSP2_SS2__USB0_OVERCURRENT 0x2152 +#define MX28_PAD_SSP3_SCK__ENET1_1588_EVENT0_OUT 0x2182 +#define MX28_PAD_SSP3_MOSI__ENET1_1588_EVENT0_IN 0x2192 +#define MX28_PAD_SSP3_MISO__ENET1_1588_EVENT1_OUT 0x21a2 +#define MX28_PAD_SSP3_SS0__ENET1_1588_EVENT1_IN 0x21b2 +#define MX28_PAD_AUART0_RX__DUART_CTS 0x3002 +#define MX28_PAD_AUART0_TX__DUART_RTS 0x3012 +#define MX28_PAD_AUART0_CTS__DUART_RX 0x3022 +#define MX28_PAD_AUART0_RTS__DUART_TX 0x3032 +#define MX28_PAD_AUART1_RX__PWM_0 0x3042 +#define MX28_PAD_AUART1_TX__PWM_1 0x3052 +#define MX28_PAD_AUART1_CTS__TIMROT_ROTARYA 0x3062 +#define MX28_PAD_AUART1_RTS__TIMROT_ROTARYB 0x3072 +#define MX28_PAD_AUART2_RX__SSP3_D4 0x3082 +#define MX28_PAD_AUART2_TX__SSP3_D5 0x3092 +#define MX28_PAD_AUART2_CTS__SAIF1_BITCLK 0x30a2 +#define MX28_PAD_AUART2_RTS__SAIF1_LRCLK 0x30b2 +#define MX28_PAD_AUART3_RX__ENET0_1588_EVENT0_OUT 0x30c2 +#define MX28_PAD_AUART3_TX__ENET0_1588_EVENT0_IN 0x30d2 +#define MX28_PAD_AUART3_CTS__ENET0_1588_EVENT1_OUT 0x30e2 +#define MX28_PAD_AUART3_RTS__ENET0_1588_EVENT1_IN 0x30f2 +#define MX28_PAD_PWM0__DUART_RX 0x3102 +#define MX28_PAD_PWM1__DUART_TX 0x3112 +#define MX28_PAD_PWM2__USB1_OVERCURRENT 0x3122 +#define MX28_PAD_SAIF0_MCLK__AUART4_CTS 0x3142 +#define MX28_PAD_SAIF0_LRCLK__AUART4_RTS 0x3152 +#define MX28_PAD_SAIF0_BITCLK__AUART4_RX 0x3162 +#define MX28_PAD_SAIF0_SDATA0__AUART4_TX 0x3172 +#define MX28_PAD_I2C0_SCL__DUART_RX 0x3182 +#define MX28_PAD_I2C0_SDA__DUART_TX 0x3192 +#define MX28_PAD_SAIF1_SDATA0__SAIF0_SDATA1 0x31a2 +#define MX28_PAD_SPDIF__ENET1_RX_ER 0x31b2 +#define MX28_PAD_ENET0_MDC__SAIF0_SDATA1 0x4002 +#define MX28_PAD_ENET0_MDIO__SAIF0_SDATA2 0x4012 +#define MX28_PAD_ENET0_RX_EN__SAIF1_SDATA1 0x4022 +#define MX28_PAD_ENET0_RXD0__SAIF1_SDATA2 0x4032 +#define MX28_PAD_ENET0_TX_CLK__ENET0_1588_EVENT2_OUT 0x4052 +#define MX28_PAD_ENET0_RXD2__ENET0_1588_EVENT0_OUT 0x4092 +#define MX28_PAD_ENET0_RXD3__ENET0_1588_EVENT0_IN 0x40a2 +#define MX28_PAD_ENET0_TXD2__ENET0_1588_EVENT1_OUT 0x40b2 +#define MX28_PAD_ENET0_TXD3__ENET0_1588_EVENT1_IN 0x40c2 +#define MX28_PAD_ENET0_RX_CLK__ENET0_1588_EVENT2_IN 0x40d2 +#define MX28_PAD_ENET0_COL__ENET0_1588_EVENT3_OUT 0x40e2 +#define MX28_PAD_ENET0_CRS__ENET0_1588_EVENT3_IN 0x40f2 +#define MX28_PAD_GPMI_D00__GPIO_0_0 0x0003 +#define MX28_PAD_GPMI_D01__GPIO_0_1 0x0013 +#define MX28_PAD_GPMI_D02__GPIO_0_2 0x0023 +#define MX28_PAD_GPMI_D03__GPIO_0_3 0x0033 +#define MX28_PAD_GPMI_D04__GPIO_0_4 0x0043 +#define MX28_PAD_GPMI_D05__GPIO_0_5 0x0053 +#define MX28_PAD_GPMI_D06__GPIO_0_6 0x0063 +#define MX28_PAD_GPMI_D07__GPIO_0_7 0x0073 +#define MX28_PAD_GPMI_CE0N__GPIO_0_16 0x0103 +#define MX28_PAD_GPMI_CE1N__GPIO_0_17 0x0113 +#define MX28_PAD_GPMI_CE2N__GPIO_0_18 0x0123 +#define MX28_PAD_GPMI_CE3N__GPIO_0_19 0x0133 +#define MX28_PAD_GPMI_RDY0__GPIO_0_20 0x0143 +#define MX28_PAD_GPMI_RDY1__GPIO_0_21 0x0153 +#define MX28_PAD_GPMI_RDY2__GPIO_0_22 0x0163 +#define MX28_PAD_GPMI_RDY3__GPIO_0_23 0x0173 +#define MX28_PAD_GPMI_RDN__GPIO_0_24 0x0183 +#define MX28_PAD_GPMI_WRN__GPIO_0_25 0x0193 +#define MX28_PAD_GPMI_ALE__GPIO_0_26 0x01a3 +#define MX28_PAD_GPMI_CLE__GPIO_0_27 0x01b3 +#define MX28_PAD_GPMI_RESETN__GPIO_0_28 0x01c3 +#define MX28_PAD_LCD_D00__GPIO_1_0 0x1003 +#define MX28_PAD_LCD_D01__GPIO_1_1 0x1013 +#define MX28_PAD_LCD_D02__GPIO_1_2 0x1023 +#define MX28_PAD_LCD_D03__GPIO_1_3 0x1033 +#define MX28_PAD_LCD_D04__GPIO_1_4 0x1043 +#define MX28_PAD_LCD_D05__GPIO_1_5 0x1053 +#define MX28_PAD_LCD_D06__GPIO_1_6 0x1063 +#define MX28_PAD_LCD_D07__GPIO_1_7 0x1073 +#define MX28_PAD_LCD_D08__GPIO_1_8 0x1083 +#define MX28_PAD_LCD_D09__GPIO_1_9 0x1093 +#define MX28_PAD_LCD_D10__GPIO_1_10 0x10a3 +#define MX28_PAD_LCD_D11__GPIO_1_11 0x10b3 +#define MX28_PAD_LCD_D12__GPIO_1_12 0x10c3 +#define MX28_PAD_LCD_D13__GPIO_1_13 0x10d3 +#define MX28_PAD_LCD_D14__GPIO_1_14 0x10e3 +#define MX28_PAD_LCD_D15__GPIO_1_15 0x10f3 +#define MX28_PAD_LCD_D16__GPIO_1_16 0x1103 +#define MX28_PAD_LCD_D17__GPIO_1_17 0x1113 +#define MX28_PAD_LCD_D18__GPIO_1_18 0x1123 +#define MX28_PAD_LCD_D19__GPIO_1_19 0x1133 +#define MX28_PAD_LCD_D20__GPIO_1_20 0x1143 +#define MX28_PAD_LCD_D21__GPIO_1_21 0x1153 +#define MX28_PAD_LCD_D22__GPIO_1_22 0x1163 +#define MX28_PAD_LCD_D23__GPIO_1_23 0x1173 +#define MX28_PAD_LCD_RD_E__GPIO_1_24 0x1183 +#define MX28_PAD_LCD_WR_RWN__GPIO_1_25 0x1193 +#define MX28_PAD_LCD_RS__GPIO_1_26 0x11a3 +#define MX28_PAD_LCD_CS__GPIO_1_27 0x11b3 +#define MX28_PAD_LCD_VSYNC__GPIO_1_28 0x11c3 +#define MX28_PAD_LCD_HSYNC__GPIO_1_29 0x11d3 +#define MX28_PAD_LCD_DOTCLK__GPIO_1_30 0x11e3 +#define MX28_PAD_LCD_ENABLE__GPIO_1_31 0x11f3 +#define MX28_PAD_SSP0_DATA0__GPIO_2_0 0x2003 +#define MX28_PAD_SSP0_DATA1__GPIO_2_1 0x2013 +#define MX28_PAD_SSP0_DATA2__GPIO_2_2 0x2023 +#define MX28_PAD_SSP0_DATA3__GPIO_2_3 0x2033 +#define MX28_PAD_SSP0_DATA4__GPIO_2_4 0x2043 +#define MX28_PAD_SSP0_DATA5__GPIO_2_5 0x2053 +#define MX28_PAD_SSP0_DATA6__GPIO_2_6 0x2063 +#define MX28_PAD_SSP0_DATA7__GPIO_2_7 0x2073 +#define MX28_PAD_SSP0_CMD__GPIO_2_8 0x2083 +#define MX28_PAD_SSP0_DETECT__GPIO_2_9 0x2093 +#define MX28_PAD_SSP0_SCK__GPIO_2_10 0x20a3 +#define MX28_PAD_SSP1_SCK__GPIO_2_12 0x20c3 +#define MX28_PAD_SSP1_CMD__GPIO_2_13 0x20d3 +#define MX28_PAD_SSP1_DATA0__GPIO_2_14 0x20e3 +#define MX28_PAD_SSP1_DATA3__GPIO_2_15 0x20f3 +#define MX28_PAD_SSP2_SCK__GPIO_2_16 0x2103 +#define MX28_PAD_SSP2_MOSI__GPIO_2_17 0x2113 +#define MX28_PAD_SSP2_MISO__GPIO_2_18 0x2123 +#define MX28_PAD_SSP2_SS0__GPIO_2_19 0x2133 +#define MX28_PAD_SSP2_SS1__GPIO_2_20 0x2143 +#define MX28_PAD_SSP2_SS2__GPIO_2_21 0x2153 +#define MX28_PAD_SSP3_SCK__GPIO_2_24 0x2183 +#define MX28_PAD_SSP3_MOSI__GPIO_2_25 0x2193 +#define MX28_PAD_SSP3_MISO__GPIO_2_26 0x21a3 +#define MX28_PAD_SSP3_SS0__GPIO_2_27 0x21b3 +#define MX28_PAD_AUART0_RX__GPIO_3_0 0x3003 +#define MX28_PAD_AUART0_TX__GPIO_3_1 0x3013 +#define MX28_PAD_AUART0_CTS__GPIO_3_2 0x3023 +#define MX28_PAD_AUART0_RTS__GPIO_3_3 0x3033 +#define MX28_PAD_AUART1_RX__GPIO_3_4 0x3043 +#define MX28_PAD_AUART1_TX__GPIO_3_5 0x3053 +#define MX28_PAD_AUART1_CTS__GPIO_3_6 0x3063 +#define MX28_PAD_AUART1_RTS__GPIO_3_7 0x3073 +#define MX28_PAD_AUART2_RX__GPIO_3_8 0x3083 +#define MX28_PAD_AUART2_TX__GPIO_3_9 0x3093 +#define MX28_PAD_AUART2_CTS__GPIO_3_10 0x30a3 +#define MX28_PAD_AUART2_RTS__GPIO_3_11 0x30b3 +#define MX28_PAD_AUART3_RX__GPIO_3_12 0x30c3 +#define MX28_PAD_AUART3_TX__GPIO_3_13 0x30d3 +#define MX28_PAD_AUART3_CTS__GPIO_3_14 0x30e3 +#define MX28_PAD_AUART3_RTS__GPIO_3_15 0x30f3 +#define MX28_PAD_PWM0__GPIO_3_16 0x3103 +#define MX28_PAD_PWM1__GPIO_3_17 0x3113 +#define MX28_PAD_PWM2__GPIO_3_18 0x3123 +#define MX28_PAD_SAIF0_MCLK__GPIO_3_20 0x3143 +#define MX28_PAD_SAIF0_LRCLK__GPIO_3_21 0x3153 +#define MX28_PAD_SAIF0_BITCLK__GPIO_3_22 0x3163 +#define MX28_PAD_SAIF0_SDATA0__GPIO_3_23 0x3173 +#define MX28_PAD_I2C0_SCL__GPIO_3_24 0x3183 +#define MX28_PAD_I2C0_SDA__GPIO_3_25 0x3193 +#define MX28_PAD_SAIF1_SDATA0__GPIO_3_26 0x31a3 +#define MX28_PAD_SPDIF__GPIO_3_27 0x31b3 +#define MX28_PAD_PWM3__GPIO_3_28 0x31c3 +#define MX28_PAD_PWM4__GPIO_3_29 0x31d3 +#define MX28_PAD_LCD_RESET__GPIO_3_30 0x31e3 +#define MX28_PAD_ENET0_MDC__GPIO_4_0 0x4003 +#define MX28_PAD_ENET0_MDIO__GPIO_4_1 0x4013 +#define MX28_PAD_ENET0_RX_EN__GPIO_4_2 0x4023 +#define MX28_PAD_ENET0_RXD0__GPIO_4_3 0x4033 +#define MX28_PAD_ENET0_RXD1__GPIO_4_4 0x4043 +#define MX28_PAD_ENET0_TX_CLK__GPIO_4_5 0x4053 +#define MX28_PAD_ENET0_TX_EN__GPIO_4_6 0x4063 +#define MX28_PAD_ENET0_TXD0__GPIO_4_7 0x4073 +#define MX28_PAD_ENET0_TXD1__GPIO_4_8 0x4083 +#define MX28_PAD_ENET0_RXD2__GPIO_4_9 0x4093 +#define MX28_PAD_ENET0_RXD3__GPIO_4_10 0x40a3 +#define MX28_PAD_ENET0_TXD2__GPIO_4_11 0x40b3 +#define MX28_PAD_ENET0_TXD3__GPIO_4_12 0x40c3 +#define MX28_PAD_ENET0_RX_CLK__GPIO_4_13 0x40d3 +#define MX28_PAD_ENET0_COL__GPIO_4_14 0x40e3 +#define MX28_PAD_ENET0_CRS__GPIO_4_15 0x40f3 +#define MX28_PAD_ENET_CLK__GPIO_4_16 0x4103 +#define MX28_PAD_JTAG_RTCK__GPIO_4_20 0x4143 + +#endif /* __DT_BINDINGS_MX28_PINCTRL_H__ */ diff --git a/arch/arm/dts/imx28.dtsi b/arch/arm/dts/imx28.dtsi new file mode 100644 index 0000000000..e14d8ef015 --- /dev/null +++ b/arch/arm/dts/imx28.dtsi @@ -0,0 +1,1330 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. + +#include <dt-bindings/gpio/gpio.h> +#include "imx28-pinfunc.h" + +/ { + #address-cells = <1>; + #size-cells = <1>; + + interrupt-parent = <&icoll>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + */ + chosen {}; + + aliases { + ethernet0 = &mac0; + ethernet1 = &mac1; + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + gpio3 = &gpio3; + gpio4 = &gpio4; + saif0 = &saif0; + saif1 = &saif1; + serial0 = &auart0; + serial1 = &auart1; + serial2 = &auart2; + serial3 = &auart3; + serial4 = &auart4; + spi0 = &ssp1; + spi1 = &ssp2; + usbphy0 = &usbphy0; + usbphy1 = &usbphy1; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,arm926ej-s"; + device_type = "cpu"; + reg = <0>; + }; + }; + + apb@80000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80000000 0x80000>; + ranges; + + apbh@80000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80000000 0x3c900>; + ranges; + + icoll: interrupt-controller@80000000 { + compatible = "fsl,imx28-icoll", "fsl,icoll"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0x80000000 0x2000>; + }; + + hsadc: hsadc@80002000 { + reg = <0x80002000 0x2000>; + interrupts = <13>; + dmas = <&dma_apbh 12>; + dma-names = "rx"; + status = "disabled"; + }; + + dma_apbh: dma-apbh@80004000 { + compatible = "fsl,imx28-dma-apbh"; + reg = <0x80004000 0x2000>; + interrupts = <82 83 84 85 + 88 88 88 88 + 88 88 88 88 + 87 86 0 0>; + interrupt-names = "ssp0", "ssp1", "ssp2", "ssp3", + "gpmi0", "gmpi1", "gpmi2", "gmpi3", + "gpmi4", "gmpi5", "gpmi6", "gmpi7", + "hsadc", "lcdif", "empty", "empty"; + #dma-cells = <1>; + dma-channels = <16>; + clocks = <&clks 25>; + }; + + perfmon: perfmon@80006000 { + reg = <0x80006000 0x800>; + interrupts = <27>; + status = "disabled"; + }; + + gpmi: gpmi-nand@8000c000 { + compatible = "fsl,imx28-gpmi-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x8000c000 0x2000>, <0x8000a000 0x2000>; + reg-names = "gpmi-nand", "bch"; + interrupts = <41>; + interrupt-names = "bch"; + clocks = <&clks 50>; + clock-names = "gpmi_io"; + dmas = <&dma_apbh 4>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + ssp0: spi@80010000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x80010000 0x2000>; + interrupts = <96>; + clocks = <&clks 46>; + dmas = <&dma_apbh 0>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + ssp1: spi@80012000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x80012000 0x2000>; + interrupts = <97>; + clocks = <&clks 47>; + dmas = <&dma_apbh 1>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + ssp2: spi@80014000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x80014000 0x2000>; + interrupts = <98>; + clocks = <&clks 48>; + dmas = <&dma_apbh 2>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + ssp3: spi@80016000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x80016000 0x2000>; + interrupts = <99>; + clocks = <&clks 49>; + dmas = <&dma_apbh 3>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + pinctrl: pinctrl@80018000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx28-pinctrl", "simple-bus"; + reg = <0x80018000 0x2000>; + + gpio0: gpio@0 { + compatible = "fsl,imx28-gpio", "fsl,mxs-gpio"; + reg = <0>; + interrupts = <127>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@1 { + compatible = "fsl,imx28-gpio", "fsl,mxs-gpio"; + reg = <1>; + interrupts = <126>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2 { + compatible = "fsl,imx28-gpio", "fsl,mxs-gpio"; + reg = <2>; + interrupts = <125>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@3 { + compatible = "fsl,imx28-gpio", "fsl,mxs-gpio"; + reg = <3>; + interrupts = <124>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@4 { + compatible = "fsl,imx28-gpio", "fsl,mxs-gpio"; + reg = <4>; + interrupts = <123>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + duart_pins_a: duart@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM0__DUART_RX + MX28_PAD_PWM1__DUART_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + duart_pins_b: duart@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART0_CTS__DUART_RX + MX28_PAD_AUART0_RTS__DUART_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + duart_4pins_a: duart-4pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART0_CTS__DUART_RX + MX28_PAD_AUART0_RTS__DUART_TX + MX28_PAD_AUART0_RX__DUART_CTS + MX28_PAD_AUART0_TX__DUART_RTS + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + gpmi_pins_a: gpmi-nand@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_D00__GPMI_D0 + MX28_PAD_GPMI_D01__GPMI_D1 + MX28_PAD_GPMI_D02__GPMI_D2 + MX28_PAD_GPMI_D03__GPMI_D3 + MX28_PAD_GPMI_D04__GPMI_D4 + MX28_PAD_GPMI_D05__GPMI_D5 + MX28_PAD_GPMI_D06__GPMI_D6 + MX28_PAD_GPMI_D07__GPMI_D7 + MX28_PAD_GPMI_CE0N__GPMI_CE0N + MX28_PAD_GPMI_RDY0__GPMI_READY0 + MX28_PAD_GPMI_RDN__GPMI_RDN + MX28_PAD_GPMI_WRN__GPMI_WRN + MX28_PAD_GPMI_ALE__GPMI_ALE + MX28_PAD_GPMI_CLE__GPMI_CLE + MX28_PAD_GPMI_RESETN__GPMI_RESETN + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + gpmi_status_cfg: gpmi-status-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_RDN__GPMI_RDN + MX28_PAD_GPMI_WRN__GPMI_WRN + MX28_PAD_GPMI_RESETN__GPMI_RESETN + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + }; + + auart0_pins_a: auart0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART0_RX__AUART0_RX + MX28_PAD_AUART0_TX__AUART0_TX + MX28_PAD_AUART0_CTS__AUART0_CTS + MX28_PAD_AUART0_RTS__AUART0_RTS + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart0_2pins_a: auart0-2pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART0_RX__AUART0_RX + MX28_PAD_AUART0_TX__AUART0_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart1_pins_a: auart1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART1_RX__AUART1_RX + MX28_PAD_AUART1_TX__AUART1_TX + MX28_PAD_AUART1_CTS__AUART1_CTS + MX28_PAD_AUART1_RTS__AUART1_RTS + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart1_2pins_a: auart1-2pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART1_RX__AUART1_RX + MX28_PAD_AUART1_TX__AUART1_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart2_2pins_a: auart2-2pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_SCK__AUART2_RX + MX28_PAD_SSP2_MOSI__AUART2_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart2_2pins_b: auart2-2pins@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART2_RX__AUART2_RX + MX28_PAD_AUART2_TX__AUART2_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart2_pins_a: auart2-pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART2_RX__AUART2_RX + MX28_PAD_AUART2_TX__AUART2_TX + MX28_PAD_AUART2_CTS__AUART2_CTS + MX28_PAD_AUART2_RTS__AUART2_RTS + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart3_pins_a: auart3@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART3_RX__AUART3_RX + MX28_PAD_AUART3_TX__AUART3_TX + MX28_PAD_AUART3_CTS__AUART3_CTS + MX28_PAD_AUART3_RTS__AUART3_RTS + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart3_2pins_a: auart3-2pins@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_MISO__AUART3_RX + MX28_PAD_SSP2_SS0__AUART3_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart3_2pins_b: auart3-2pins@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART3_RX__AUART3_RX + MX28_PAD_AUART3_TX__AUART3_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart4_2pins_a: auart4@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP3_SCK__AUART4_TX + MX28_PAD_SSP3_MOSI__AUART4_RX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + auart4_2pins_b: auart4@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART0_CTS__AUART4_RX + MX28_PAD_AUART0_RTS__AUART4_TX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mac0_pins_a: mac0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_ENET0_MDC__ENET0_MDC + MX28_PAD_ENET0_MDIO__ENET0_MDIO + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN + MX28_PAD_ENET0_RXD0__ENET0_RXD0 + MX28_PAD_ENET0_RXD1__ENET0_RXD1 + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN + MX28_PAD_ENET0_TXD0__ENET0_TXD0 + MX28_PAD_ENET0_TXD1__ENET0_TXD1 + MX28_PAD_ENET_CLK__CLKCTRL_ENET + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mac0_pins_b: mac0@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_ENET0_MDC__ENET0_MDC + MX28_PAD_ENET0_MDIO__ENET0_MDIO + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN + MX28_PAD_ENET0_RXD0__ENET0_RXD0 + MX28_PAD_ENET0_RXD1__ENET0_RXD1 + MX28_PAD_ENET0_RXD2__ENET0_RXD2 + MX28_PAD_ENET0_RXD3__ENET0_RXD3 + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN + MX28_PAD_ENET0_TXD0__ENET0_TXD0 + MX28_PAD_ENET0_TXD1__ENET0_TXD1 + MX28_PAD_ENET0_TXD2__ENET0_TXD2 + MX28_PAD_ENET0_TXD3__ENET0_TXD3 + MX28_PAD_ENET_CLK__CLKCTRL_ENET + MX28_PAD_ENET0_COL__ENET0_COL + MX28_PAD_ENET0_CRS__ENET0_CRS + MX28_PAD_ENET0_TX_CLK__ENET0_TX_CLK + MX28_PAD_ENET0_RX_CLK__ENET0_RX_CLK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mac1_pins_a: mac1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_ENET0_CRS__ENET1_RX_EN + MX28_PAD_ENET0_RXD2__ENET1_RXD0 + MX28_PAD_ENET0_RXD3__ENET1_RXD1 + MX28_PAD_ENET0_COL__ENET1_TX_EN + MX28_PAD_ENET0_TXD2__ENET1_TXD0 + MX28_PAD_ENET0_TXD3__ENET1_TXD1 + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc0_8bit_pins_a: mmc0-8bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP0_DATA0__SSP0_D0 + MX28_PAD_SSP0_DATA1__SSP0_D1 + MX28_PAD_SSP0_DATA2__SSP0_D2 + MX28_PAD_SSP0_DATA3__SSP0_D3 + MX28_PAD_SSP0_DATA4__SSP0_D4 + MX28_PAD_SSP0_DATA5__SSP0_D5 + MX28_PAD_SSP0_DATA6__SSP0_D6 + MX28_PAD_SSP0_DATA7__SSP0_D7 + MX28_PAD_SSP0_CMD__SSP0_CMD + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT + MX28_PAD_SSP0_SCK__SSP0_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc0_4bit_pins_a: mmc0-4bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP0_DATA0__SSP0_D0 + MX28_PAD_SSP0_DATA1__SSP0_D1 + MX28_PAD_SSP0_DATA2__SSP0_D2 + MX28_PAD_SSP0_DATA3__SSP0_D3 + MX28_PAD_SSP0_CMD__SSP0_CMD + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT + MX28_PAD_SSP0_SCK__SSP0_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc0_cd_cfg: mmc0-cd-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT + >; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc0_sck_cfg: mmc0-sck-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP0_SCK__SSP0_SCK + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc1_4bit_pins_a: mmc1-4bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_D00__SSP1_D0 + MX28_PAD_GPMI_D01__SSP1_D1 + MX28_PAD_GPMI_D02__SSP1_D2 + MX28_PAD_GPMI_D03__SSP1_D3 + MX28_PAD_GPMI_RDY1__SSP1_CMD + MX28_PAD_GPMI_RDY0__SSP1_CARD_DETECT + MX28_PAD_GPMI_WRN__SSP1_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc1_cd_cfg: mmc1-cd-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_RDY0__SSP1_CARD_DETECT + >; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc1_sck_cfg: mmc1-sck-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_WRN__SSP1_SCK + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + + mmc2_4bit_pins_a: mmc2-4bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP0_DATA4__SSP2_D0 + MX28_PAD_SSP1_SCK__SSP2_D1 + MX28_PAD_SSP1_CMD__SSP2_D2 + MX28_PAD_SSP0_DATA5__SSP2_D3 + MX28_PAD_SSP0_DATA6__SSP2_CMD + MX28_PAD_AUART1_RX__SSP2_CARD_DETECT + MX28_PAD_SSP0_DATA7__SSP2_SCK + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc2_4bit_pins_b: mmc2-4bit@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_SCK__SSP2_SCK + MX28_PAD_SSP2_MOSI__SSP2_CMD + MX28_PAD_SSP2_MISO__SSP2_D0 + MX28_PAD_SSP2_SS0__SSP2_D3 + MX28_PAD_SSP2_SS1__SSP2_D1 + MX28_PAD_SSP2_SS2__SSP2_D2 + MX28_PAD_AUART1_RX__SSP2_CARD_DETECT + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + mmc2_cd_cfg: mmc2-cd-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART1_RX__SSP2_CARD_DETECT + >; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc2_sck_cfg_a: mmc2-sck-cfg@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP0_DATA7__SSP2_SCK + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + mmc2_sck_cfg_b: mmc2-sck-cfg@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_SCK__SSP2_SCK + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + i2c0_pins_a: i2c0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_I2C0_SCL__I2C0_SCL + MX28_PAD_I2C0_SDA__I2C0_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + i2c0_pins_b: i2c0@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART0_RX__I2C0_SCL + MX28_PAD_AUART0_TX__I2C0_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + i2c1_pins_a: i2c1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM0__I2C1_SCL + MX28_PAD_PWM1__I2C1_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + i2c1_pins_b: i2c1@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART2_CTS__I2C1_SCL + MX28_PAD_AUART2_RTS__I2C1_SDA + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + saif0_pins_a: saif0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SAIF0_MCLK__SAIF0_MCLK + MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK + MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK + MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0 + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + saif0_pins_b: saif0@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK + MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK + MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0 + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + saif1_pins_a: saif1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0 + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + pwm0_pins_a: pwm0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM0__PWM_0 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + pwm2_pins_a: pwm2@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM2__PWM_2 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + pwm3_pins_a: pwm3@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM3__PWM_3 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + pwm3_pins_b: pwm3@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_SAIF0_MCLK__PWM_3 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + pwm4_pins_a: pwm4@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM4__PWM_4 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + lcdif_24bit_pins_a: lcdif-24bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_LCD_D00__LCD_D0 + MX28_PAD_LCD_D01__LCD_D1 + MX28_PAD_LCD_D02__LCD_D2 + MX28_PAD_LCD_D03__LCD_D3 + MX28_PAD_LCD_D04__LCD_D4 + MX28_PAD_LCD_D05__LCD_D5 + MX28_PAD_LCD_D06__LCD_D6 + MX28_PAD_LCD_D07__LCD_D7 + MX28_PAD_LCD_D08__LCD_D8 + MX28_PAD_LCD_D09__LCD_D9 + MX28_PAD_LCD_D10__LCD_D10 + MX28_PAD_LCD_D11__LCD_D11 + MX28_PAD_LCD_D12__LCD_D12 + MX28_PAD_LCD_D13__LCD_D13 + MX28_PAD_LCD_D14__LCD_D14 + MX28_PAD_LCD_D15__LCD_D15 + MX28_PAD_LCD_D16__LCD_D16 + MX28_PAD_LCD_D17__LCD_D17 + MX28_PAD_LCD_D18__LCD_D18 + MX28_PAD_LCD_D19__LCD_D19 + MX28_PAD_LCD_D20__LCD_D20 + MX28_PAD_LCD_D21__LCD_D21 + MX28_PAD_LCD_D22__LCD_D22 + MX28_PAD_LCD_D23__LCD_D23 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + lcdif_18bit_pins_a: lcdif-18bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_LCD_D00__LCD_D0 + MX28_PAD_LCD_D01__LCD_D1 + MX28_PAD_LCD_D02__LCD_D2 + MX28_PAD_LCD_D03__LCD_D3 + MX28_PAD_LCD_D04__LCD_D4 + MX28_PAD_LCD_D05__LCD_D5 + MX28_PAD_LCD_D06__LCD_D6 + MX28_PAD_LCD_D07__LCD_D7 + MX28_PAD_LCD_D08__LCD_D8 + MX28_PAD_LCD_D09__LCD_D9 + MX28_PAD_LCD_D10__LCD_D10 + MX28_PAD_LCD_D11__LCD_D11 + MX28_PAD_LCD_D12__LCD_D12 + MX28_PAD_LCD_D13__LCD_D13 + MX28_PAD_LCD_D14__LCD_D14 + MX28_PAD_LCD_D15__LCD_D15 + MX28_PAD_LCD_D16__LCD_D16 + MX28_PAD_LCD_D17__LCD_D17 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + lcdif_16bit_pins_a: lcdif-16bit@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_LCD_D00__LCD_D0 + MX28_PAD_LCD_D01__LCD_D1 + MX28_PAD_LCD_D02__LCD_D2 + MX28_PAD_LCD_D03__LCD_D3 + MX28_PAD_LCD_D04__LCD_D4 + MX28_PAD_LCD_D05__LCD_D5 + MX28_PAD_LCD_D06__LCD_D6 + MX28_PAD_LCD_D07__LCD_D7 + MX28_PAD_LCD_D08__LCD_D8 + MX28_PAD_LCD_D09__LCD_D9 + MX28_PAD_LCD_D10__LCD_D10 + MX28_PAD_LCD_D11__LCD_D11 + MX28_PAD_LCD_D12__LCD_D12 + MX28_PAD_LCD_D13__LCD_D13 + MX28_PAD_LCD_D14__LCD_D14 + MX28_PAD_LCD_D15__LCD_D15 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + lcdif_sync_pins_a: lcdif-sync@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_LCD_RS__LCD_DOTCLK + MX28_PAD_LCD_CS__LCD_ENABLE + MX28_PAD_LCD_RD_E__LCD_VSYNC + MX28_PAD_LCD_WR_RWN__LCD_HSYNC + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + can0_pins_a: can0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_RDY2__CAN0_TX + MX28_PAD_GPMI_RDY3__CAN0_RX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + can1_pins_a: can1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_CE2N__CAN1_TX + MX28_PAD_GPMI_CE3N__CAN1_RX + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + spi2_pins_a: spi2@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_SCK__SSP2_SCK + MX28_PAD_SSP2_MOSI__SSP2_CMD + MX28_PAD_SSP2_MISO__SSP2_D0 + MX28_PAD_SSP2_SS0__SSP2_D3 + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + spi3_pins_a: spi3@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART2_RX__SSP3_D4 + MX28_PAD_AUART2_TX__SSP3_D5 + MX28_PAD_SSP3_SCK__SSP3_SCK + MX28_PAD_SSP3_MOSI__SSP3_CMD + MX28_PAD_SSP3_MISO__SSP3_D0 + MX28_PAD_SSP3_SS0__SSP3_D3 + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + spi3_pins_b: spi3@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_SSP3_SCK__SSP3_SCK + MX28_PAD_SSP3_MOSI__SSP3_CMD + MX28_PAD_SSP3_MISO__SSP3_D0 + MX28_PAD_SSP3_SS0__SSP3_D3 + >; + fsl,drive-strength = <MXS_DRIVE_8mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + usb0_pins_a: usb0@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_SS2__USB0_OVERCURRENT + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + usb0_pins_b: usb0@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_AUART1_CTS__USB0_OVERCURRENT + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + usb1_pins_a: usb1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_SSP2_SS1__USB1_OVERCURRENT + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + usb0_id_pins_a: usb0id@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_AUART1_RTS__USB0_ID + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + usb0_id_pins_b: usb0id1@0 { + reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_PWM2__USB0_ID + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_ENABLE>; + }; + + }; + + digctl: digctl@8001c000 { + compatible = "fsl,imx28-digctl", "fsl,imx23-digctl"; + reg = <0x8001c000 0x2000>; + interrupts = <89>; + status = "disabled"; + }; + + etm: etm@80022000 { + reg = <0x80022000 0x2000>; + status = "disabled"; + }; + + dma_apbx: dma-apbx@80024000 { + compatible = "fsl,imx28-dma-apbx"; + reg = <0x80024000 0x2000>; + interrupts = <78 79 66 0 + 80 81 68 69 + 70 71 72 73 + 74 75 76 77>; + interrupt-names = "auart4-rx", "auart4-tx", "spdif-tx", "empty", + "saif0", "saif1", "i2c0", "i2c1", + "auart0-rx", "auart0-tx", "auart1-rx", "auart1-tx", + "auart2-rx", "auart2-tx", "auart3-rx", "auart3-tx"; + #dma-cells = <1>; + dma-channels = <16>; + clocks = <&clks 26>; + }; + + dcp: dcp@80028000 { + compatible = "fsl,imx28-dcp", "fsl,imx23-dcp"; + reg = <0x80028000 0x2000>; + interrupts = <52 53 54>; + status = "okay"; + }; + + pxp: pxp@8002a000 { + reg = <0x8002a000 0x2000>; + interrupts = <39>; + status = "disabled"; + }; + + ocotp: ocotp@8002c000 { + compatible = "fsl,imx28-ocotp", "fsl,ocotp"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x8002c000 0x2000>; + clocks = <&clks 25>; + }; + + axi-ahb@8002e000 { + reg = <0x8002e000 0x2000>; + status = "disabled"; + }; + + lcdif: lcdif@80030000 { + compatible = "fsl,imx28-lcdif"; + reg = <0x80030000 0x2000>; + interrupts = <38>; + clocks = <&clks 55>; + dmas = <&dma_apbh 13>; + dma-names = "rx"; + status = "disabled"; + }; + + can0: can@80032000 { + compatible = "fsl,imx28-flexcan"; + reg = <0x80032000 0x2000>; + interrupts = <8>; + clocks = <&clks 58>, <&clks 58>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + can1: can@80034000 { + compatible = "fsl,imx28-flexcan"; + reg = <0x80034000 0x2000>; + interrupts = <9>; + clocks = <&clks 59>, <&clks 59>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + simdbg: simdbg@8003c000 { + reg = <0x8003c000 0x200>; + status = "disabled"; + }; + + simgpmisel: simgpmisel@8003c200 { + reg = <0x8003c200 0x100>; + status = "disabled"; + }; + + simsspsel: simsspsel@8003c300 { + reg = <0x8003c300 0x100>; + status = "disabled"; + }; + + simmemsel: simmemsel@8003c400 { + reg = <0x8003c400 0x100>; + status = "disabled"; + }; + + gpiomon: gpiomon@8003c500 { + reg = <0x8003c500 0x100>; + status = "disabled"; + }; + + simenet: simenet@8003c700 { + reg = <0x8003c700 0x100>; + status = "disabled"; + }; + + armjtag: armjtag@8003c800 { + reg = <0x8003c800 0x100>; + status = "disabled"; + }; + }; + + apbx@80040000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80040000 0x40000>; + ranges; + + clks: clkctrl@80040000 { + compatible = "fsl,imx28-clkctrl", "fsl,clkctrl"; + reg = <0x80040000 0x2000>; + #clock-cells = <1>; + }; + + saif0: saif@80042000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx28-saif"; + reg = <0x80042000 0x2000>; + interrupts = <59>; + #clock-cells = <0>; + clocks = <&clks 53>; + dmas = <&dma_apbx 4>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + power: power@80044000 { + reg = <0x80044000 0x2000>; + status = "disabled"; + }; + + saif1: saif@80046000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx28-saif"; + reg = <0x80046000 0x2000>; + interrupts = <58>; + clocks = <&clks 54>; + dmas = <&dma_apbx 5>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + lradc: lradc@80050000 { + compatible = "fsl,imx28-lradc"; + reg = <0x80050000 0x2000>; + interrupts = <10 14 15 16 17 18 19 + 20 21 22 23 24 25>; + status = "disabled"; + clocks = <&clks 41>; + #io-channel-cells = <1>; + }; + + spdif: spdif@80054000 { + reg = <0x80054000 0x2000>; + interrupts = <45>; + dmas = <&dma_apbx 2>; + dma-names = "tx"; + status = "disabled"; + }; + + mxs_rtc: rtc@80056000 { + compatible = "fsl,imx28-rtc", "fsl,stmp3xxx-rtc"; + reg = <0x80056000 0x2000>; + interrupts = <29>; + }; + + i2c0: i2c@80058000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx28-i2c"; + reg = <0x80058000 0x2000>; + interrupts = <111>; + clock-frequency = <100000>; + dmas = <&dma_apbx 6>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + i2c1: i2c@8005a000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx28-i2c"; + reg = <0x8005a000 0x2000>; + interrupts = <110>; + clock-frequency = <100000>; + dmas = <&dma_apbx 7>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + pwm: pwm@80064000 { + compatible = "fsl,imx28-pwm", "fsl,imx23-pwm"; + reg = <0x80064000 0x2000>; + clocks = <&clks 44>; + #pwm-cells = <2>; + fsl,pwm-number = <8>; + status = "disabled"; + }; + + timer: timrot@80068000 { + compatible = "fsl,imx28-timrot", "fsl,timrot"; + reg = <0x80068000 0x2000>; + interrupts = <48 49 50 51>; + clocks = <&clks 26>; + }; + + auart0: serial@8006a000 { + compatible = "fsl,imx28-auart", "fsl,imx23-auart"; + reg = <0x8006a000 0x2000>; + interrupts = <112>; + dmas = <&dma_apbx 8>, <&dma_apbx 9>; + dma-names = "rx", "tx"; + clocks = <&clks 45>; + status = "disabled"; + }; + + auart1: serial@8006c000 { + compatible = "fsl,imx28-auart", "fsl,imx23-auart"; + reg = <0x8006c000 0x2000>; + interrupts = <113>; + dmas = <&dma_apbx 10>, <&dma_apbx 11>; + dma-names = "rx", "tx"; + clocks = <&clks 45>; + status = "disabled"; + }; + + auart2: serial@8006e000 { + compatible = "fsl,imx28-auart", "fsl,imx23-auart"; + reg = <0x8006e000 0x2000>; + interrupts = <114>; + dmas = <&dma_apbx 12>, <&dma_apbx 13>; + dma-names = "rx", "tx"; + clocks = <&clks 45>; + status = "disabled"; + }; + + auart3: serial@80070000 { + compatible = "fsl,imx28-auart", "fsl,imx23-auart"; + reg = <0x80070000 0x2000>; + interrupts = <115>; + dmas = <&dma_apbx 14>, <&dma_apbx 15>; + dma-names = "rx", "tx"; + clocks = <&clks 45>; + status = "disabled"; + }; + + auart4: serial@80072000 { + compatible = "fsl,imx28-auart", "fsl,imx23-auart"; + reg = <0x80072000 0x2000>; + interrupts = <116>; + dmas = <&dma_apbx 0>, <&dma_apbx 1>; + dma-names = "rx", "tx"; + clocks = <&clks 45>; + status = "disabled"; + }; + + duart: serial@80074000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x80074000 0x1000>; + interrupts = <47>; + clocks = <&clks 45>, <&clks 26>; + clock-names = "uart", "apb_pclk"; + status = "disabled"; + }; + + usbphy0: usbphy@8007c000 { + compatible = "fsl,imx28-usbphy", "fsl,imx23-usbphy"; + reg = <0x8007c000 0x2000>; + clocks = <&clks 62>; + status = "disabled"; + }; + + usbphy1: usbphy@8007e000 { + compatible = "fsl,imx28-usbphy", "fsl,imx23-usbphy"; + reg = <0x8007e000 0x2000>; + clocks = <&clks 63>; + status = "disabled"; + }; + }; + }; + + ahb@80080000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80080000 0x80000>; + ranges; + + usb0: usb@80080000 { + compatible = "fsl,imx28-usb", "fsl,imx27-usb"; + reg = <0x80080000 0x10000>; + interrupts = <93>; + clocks = <&clks 60>; + fsl,usbphy = <&usbphy0>; + status = "disabled"; + }; + + usb1: usb@80090000 { + compatible = "fsl,imx28-usb", "fsl,imx27-usb"; + reg = <0x80090000 0x10000>; + interrupts = <92>; + clocks = <&clks 61>; + fsl,usbphy = <&usbphy1>; + dr_mode = "host"; + status = "disabled"; + }; + + dflpt: dflpt@800c0000 { + reg = <0x800c0000 0x10000>; + status = "disabled"; + }; + + mac0: ethernet@800f0000 { + compatible = "fsl,imx28-fec"; + reg = <0x800f0000 0x4000>; + interrupts = <101>; + clocks = <&clks 57>, <&clks 57>, <&clks 64>; + clock-names = "ipg", "ahb", "enet_out"; + status = "disabled"; + }; + + mac1: ethernet@800f4000 { + compatible = "fsl,imx28-fec"; + reg = <0x800f4000 0x4000>; + interrupts = <102>; + clocks = <&clks 57>, <&clks 57>; + clock-names = "ipg", "ahb"; + status = "disabled"; + }; + + etn_switch: switch@800f8000 { + reg = <0x800f8000 0x8000>; + status = "disabled"; + }; + }; + + iio-hwmon { + compatible = "iio-hwmon"; + io-channels = <&lradc 8>; + }; +}; diff --git a/arch/arm/dts/mxs-pinfunc.h b/arch/arm/dts/mxs-pinfunc.h new file mode 100644 index 0000000000..c6da987b20 --- /dev/null +++ b/arch/arm/dts/mxs-pinfunc.h @@ -0,0 +1,31 @@ +/* + * Header providing constants for i.MX28 pinctrl bindings. + * + * Copyright (C) 2013 Lothar Waßmann LW@KARO-electronics.de + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#ifndef __DT_BINDINGS_MXS_PINCTRL_H__ +#define __DT_BINDINGS_MXS_PINCTRL_H__ + +/* fsl,drive-strength property */ +#define MXS_DRIVE_4mA 0 +#define MXS_DRIVE_8mA 1 +#define MXS_DRIVE_12mA 2 +#define MXS_DRIVE_16mA 3 + +/* fsl,voltage property */ +#define MXS_VOLTAGE_LOW 0 +#define MXS_VOLTAGE_HIGH 1 + +/* fsl,pull-up property */ +#define MXS_PULL_DISABLE 0 +#define MXS_PULL_ENABLE 1 + +#endif /* __DT_BINDINGS_MXS_PINCTRL_H__ */
The fec_mxc.c driver can be reused by i.MX28 when DM_ETH is enabled. One only needs to add proper compatible and dependency on FEC_MXC in the Kconfig.
Changes in v4: - Sort the entries for compatibles and Kconfig
Changes in v3: - Set more apropriate tags
Changes in v2: None
drivers/net/Kconfig | 2 +- drivers/net/fec_mxc.c | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index e6a4fdf30e..60273dc737 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -190,7 +190,7 @@ config FEC_MXC_MDIO_BASE
config FEC_MXC bool "FEC Ethernet controller" - depends on MX5 || MX6 || MX7 || IMX8 || VF610 + depends on MX28 || MX5 || MX6 || MX7 || IMX8 || VF610 help This driver supports the 10/100 Fast Ethernet controller for NXP i.MX processors. diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index d7c080943a..96e3ad9a1a 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1485,6 +1485,7 @@ static int fecmxc_ofdata_to_platdata(struct udevice *dev) }
static const struct udevice_id fecmxc_ids[] = { + { .compatible = "fsl,imx28-fec" }, { .compatible = "fsl,imx6q-fec" }, { .compatible = "fsl,imx6sl-fec" }, { .compatible = "fsl,imx6sx-fec" },
Tags should be "net: fec:" , see git log --oneline drivers/net/fec . Driver additions should always use "subsystem: driver:" tag, when in doubt, check git log.
Those properties are U-Boot specific as the mxs gpio Linux driver (up to version v5.1.11) is not supporting them.
Changes in v4: - New file - imx28-u-boot.dtsi
arch/arm/dts/imx28-u-boot.dtsi | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+) create mode 100644 arch/arm/dts/imx28-u-boot.dtsi
diff --git a/arch/arm/dts/imx28-u-boot.dtsi b/arch/arm/dts/imx28-u-boot.dtsi new file mode 100644 index 0000000000..a5bf74b1b7 --- /dev/null +++ b/arch/arm/dts/imx28-u-boot.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ +#include "imx28.dtsi" + +&gpio0 { + gpio-ranges = <&pinctrl 0 0 29>; +}; + +&gpio1 { + gpio-ranges = <&pinctrl 29 0 32>; +}; + +&gpio2 { + gpio-ranges = <&pinctrl 61 0 28>; +}; + +&gpio3 { + gpio-ranges = <&pinctrl 89 0 31>; +}; + +&gpio4 { + gpio-ranges = <&pinctrl 120 0 21>; +};
Tags should be "ARM: dts: imx:" , just like 1/6 .
This patch adds support for DM/DTS in the mxs_gpio.c driver. Information regarding per gpio controller pin number is passed via DTS.
Changes in v4: - Use BIT() macro instead of 1 << offset - Use devfdt_get_addr to get gpio number - Use gpio-ranges property to setup gpios
drivers/gpio/mxs_gpio.c | 148 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 148 insertions(+)
diff --git a/drivers/gpio/mxs_gpio.c b/drivers/gpio/mxs_gpio.c index c2c8a25886..b2451fdda8 100644 --- a/drivers/gpio/mxs_gpio.c +++ b/drivers/gpio/mxs_gpio.c @@ -51,6 +51,7 @@ void mxs_gpio_init(void) } }
+#if !CONFIG_IS_ENABLED(DM_GPIO) int gpio_get_value(unsigned gpio) { uint32_t bank = PAD_BANK(gpio); @@ -127,3 +128,150 @@ int name_to_gpio(const char *name)
return (bank << MXS_PAD_BANK_SHIFT) | (pin << MXS_PAD_PIN_SHIFT); } +#else /* CONFIG_DM_GPIO */ +#include <dm.h> +#include <asm/gpio.h> +#include <asm/arch/gpio.h> +#define MXS_MAX_GPIO_PER_BANK 32 + +DECLARE_GLOBAL_DATA_PTR; +/* + * According to i.MX28 Reference Manual: + * 'i.MX28 Applications Processor Reference Manual, Rev. 1, 2010' + * The i.MX28 has following number of GPIOs available: + * Bank 0: 0-28 -> 29 PINS + * Bank 1: 0-31 -> 32 PINS + * Bank 2: 0-27 -> 28 PINS + * Bank 3: 0-30 -> 31 PINS + * Bank 4: 0-20 -> 21 PINS + */ + +struct mxs_gpio_priv { + unsigned int bank; +}; + +static int mxs_gpio_get_value(struct udevice *dev, unsigned offset) +{ + struct mxs_gpio_priv *priv = dev_get_priv(dev); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + + PINCTRL_DIN(priv->bank)); + + return (readl(®->reg) >> offset) & 1; +} + +static int mxs_gpio_set_value(struct udevice *dev, unsigned offset, + int value) +{ + struct mxs_gpio_priv *priv = dev_get_priv(dev); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + + PINCTRL_DOUT(priv->bank)); + if (value) + writel(BIT(offset), ®->reg_set); + else + writel(BIT(offset), ®->reg_clr); + + return 0; +} + +static int mxs_gpio_direction_input(struct udevice *dev, unsigned offset) +{ + struct mxs_gpio_priv *priv = dev_get_priv(dev); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + + PINCTRL_DOE(priv->bank)); + + writel(BIT(offset), ®->reg_clr); + + return 0; +} + +static int mxs_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) +{ + struct mxs_gpio_priv *priv = dev_get_priv(dev); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + + PINCTRL_DOE(priv->bank)); + + mxs_gpio_set_value(dev, offset, value); + + writel(BIT(offset), ®->reg_set); + + return 0; +} + +static int mxs_gpio_get_function(struct udevice *dev, unsigned offset) +{ + struct mxs_gpio_priv *priv = dev_get_priv(dev); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + + PINCTRL_DOE(priv->bank)); + bool is_output = !!(readl(®->reg) >> offset); + + return is_output ? GPIOF_OUTPUT : GPIOF_INPUT; +} + +static const struct dm_gpio_ops gpio_mxs_ops = { + .direction_input = mxs_gpio_direction_input, + .direction_output = mxs_gpio_direction_output, + .get_value = mxs_gpio_get_value, + .set_value = mxs_gpio_set_value, + .get_function = mxs_gpio_get_function, +}; + +static int mxs_gpio_probe(struct udevice *dev) +{ + struct mxs_gpio_priv *priv = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct fdtdec_phandle_args args; + int node = dev_of_offset(dev); + char name[16], *str; + fdt_addr_t addr; + int ret; + + addr = devfdt_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) { + printf("%s: No 'reg' property defined!\n", __func__); + return -EINVAL; + } + + priv->bank = (unsigned int)addr; + + snprintf(name, sizeof(name), "GPIO%d_", priv->bank); + str = strdup(name); + if (!str) + return -ENOMEM; + + uc_priv->bank_name = str; + + ret = fdtdec_parse_phandle_with_args(gd->fdt_blob, node, "gpio-ranges", + NULL, 3, 0, &args); + if (ret) + printf("%s: 'gpio-ranges' not defined - using default!\n", + __func__); + + uc_priv->gpio_count = ret == 0 ? args.args[2] : MXS_MAX_GPIO_PER_BANK; + + debug("%s: %s: %d pins\n", __func__, uc_priv->bank_name, + uc_priv->gpio_count); + + return 0; +} + +static const struct udevice_id mxs_gpio_ids[] = { + { .compatible = "fsl,imx23-gpio" }, + { .compatible = "fsl,imx28-gpio" }, + { } +}; + +U_BOOT_DRIVER(gpio_mxs) = { + .name = "gpio_mxs", + .id = UCLASS_GPIO, + .ops = &gpio_mxs_ops, + .probe = mxs_gpio_probe, + .priv_auto_alloc_size = sizeof(struct mxs_gpio_priv), + .of_match = mxs_gpio_ids, +}; +#endif /* CONFIG_DM_GPIO */
Signed-off-by: Lukasz Majewski lukma@denx.de
Here the tags should be "gpio: mxs:" .
The code responsible for setting proper values in the MUX registers (in the mxs_pinctrl_set_state()) has been ported from Linux kernel - SHA1: 17bb763e7eaf tag v5.1.11 from linux-stable.
As the pinctrl node in the imx28.dtsi file has gpio pins nodes as subnodes, it was necessary to use 'dm_scan_fdt_dev()' (as a .bind method) to also make them 'visible' by the DM's "gpio_mxs" driver.
Changes in v4: - Use Linux kernel code to setup pins instead of Barebox - Add soc specific data and compatible for i.MX23 and i.MX28 - Use devm_kfree() to release temporary memory
Changes in v2: None
drivers/pinctrl/nxp/Kconfig | 10 ++ drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-mxs.c | 200 ++++++++++++++++++++++++++++++++++++++ drivers/pinctrl/nxp/pinctrl-mxs.h | 55 +++++++++++ 4 files changed, 266 insertions(+) create mode 100644 drivers/pinctrl/nxp/pinctrl-mxs.c create mode 100644 drivers/pinctrl/nxp/pinctrl-mxs.h
diff --git a/drivers/pinctrl/nxp/Kconfig b/drivers/pinctrl/nxp/Kconfig index 61f93be42d..f2e67ca231 100644 --- a/drivers/pinctrl/nxp/Kconfig +++ b/drivers/pinctrl/nxp/Kconfig @@ -89,6 +89,16 @@ config PINCTRL_IMX8M only parses the 'fsl,pins' property and configure related registers.
+config PINCTRL_MXS + bool "NXP MXS pinctrl driver" + depends on ARCH_MX28 && PINCTRL_FULL + help + Say Y here to enable the i.MX mxs pinctrl driver + + This option provides a simple pinctrl driver for i.MX mxs SoC + familiy, e.g. i.MX28. This feature depends on device tree + configuration. + config PINCTRL_VYBRID bool "Vybrid (vf610) pinctrl driver" depends on ARCH_VF610 && PINCTRL_FULL diff --git a/drivers/pinctrl/nxp/Makefile b/drivers/pinctrl/nxp/Makefile index b340d9448a..b86448aac9 100644 --- a/drivers/pinctrl/nxp/Makefile +++ b/drivers/pinctrl/nxp/Makefile @@ -6,4 +6,5 @@ obj-$(CONFIG_PINCTRL_IMX7ULP) += pinctrl-imx7ulp.o obj-$(CONFIG_PINCTRL_IMX_SCU) += pinctrl-scu.o obj-$(CONFIG_PINCTRL_IMX8) += pinctrl-imx8.o obj-$(CONFIG_PINCTRL_IMX8M) += pinctrl-imx8m.o +obj-$(CONFIG_PINCTRL_MXS) += pinctrl-mxs.o obj-$(CONFIG_PINCTRL_VYBRID) += pinctrl-vf610.o diff --git a/drivers/pinctrl/nxp/pinctrl-mxs.c b/drivers/pinctrl/nxp/pinctrl-mxs.c new file mode 100644 index 0000000000..d429d6943a --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-mxs.c @@ -0,0 +1,200 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + */ + +#include <common.h> +#include <linux/io.h> +#include <linux/err.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/read.h> +#include "pinctrl-mxs.h" + +DECLARE_GLOBAL_DATA_PTR; + +struct mxs_pinctrl_priv { + void __iomem *base; + const struct mxs_regs *regs; +}; + +static void mxs_pinctrl_rmwl(u32 value, u32 mask, u8 shift, void __iomem *reg) +{ + u32 tmp; + + tmp = readl(reg); + tmp &= ~(mask << shift); + tmp |= value << shift; + writel(tmp, reg); +} + +static unsigned long mxs_dt_node_to_map(struct udevice *conf) +{ + unsigned long config = 0; + int ret; + u32 val; + + ret = dev_read_u32(conf, "fsl,drive-strength", &val); + if (!ret) + config = val | MA_PRESENT; + + ret = dev_read_u32(conf, "fsl,voltage", &val); + if (!ret) + config |= val << VOL_SHIFT | VOL_PRESENT; + + ret = dev_read_u32(conf, "fsl,pull-up", &val); + if (!ret) + config |= val << PULL_SHIFT | PULL_PRESENT; + + return config; +} + +static int mxs_pinctrl_set_mux(struct udevice *dev, u32 val, int bank, int pin) +{ + struct mxs_pinctrl_priv *iomux = dev_get_priv(dev); + int muxsel = MUXID_TO_MUXSEL(val), shift; + void __iomem *reg; + + reg = iomux->base + iomux->regs->muxsel; + reg += bank * 0x20 + pin / 16 * 0x10; + shift = pin % 16 * 2; + + mxs_pinctrl_rmwl(muxsel, 0x3, shift, reg); + debug(" mux %d,", muxsel); + + return 0; +} + +static int mxs_pinctrl_set_state(struct udevice *dev, struct udevice *conf) +{ + struct mxs_pinctrl_priv *iomux = dev_get_priv(dev); + u32 *pin_data, val, ma, vol, pull; + int npins, size, i, ret; + unsigned long config; + + debug("\n%s: set state: %s\n", __func__, conf->name); + + size = dev_read_size(conf, "fsl,pinmux-ids"); + if (size < 0) + return size; + + if (!size || size % sizeof(int)) { + dev_err(dev, "Invalid fsl,pinmux-ids property in %s\n", + conf->name); + return -EINVAL; + } + + npins = size / sizeof(int); + + pin_data = devm_kzalloc(dev, size, 0); + if (!pin_data) + return -ENOMEM; + + ret = dev_read_u32_array(conf, "fsl,pinmux-ids", pin_data, npins); + if (ret) { + dev_err(dev, "Error reading pin data.\n"); + devm_kfree(dev, pin_data); + return -EINVAL; + } + + config = mxs_dt_node_to_map(conf); + + ma = CONFIG_TO_MA(config); + vol = CONFIG_TO_VOL(config); + pull = CONFIG_TO_PULL(config); + + for (i = 0; i < npins; i++) { + int pinid, bank, pin, shift; + void __iomem *reg; + + val = pin_data[i]; + + pinid = MUXID_TO_PINID(val); + bank = PINID_TO_BANK(pinid); + pin = PINID_TO_PIN(pinid); + + debug("(val: 0x%x) pin %d,", val, pinid); + /* Setup pinmux */ + mxs_pinctrl_set_mux(dev, val, bank, pin); + + debug(" ma: %d, vol: %d, pull: %d\n", ma, vol, pull); + + /* drive */ + reg = iomux->base + iomux->regs->drive; + reg += bank * 0x40 + pin / 8 * 0x10; + + /* mA */ + if (config & MA_PRESENT) { + shift = pin % 8 * 4; + mxs_pinctrl_rmwl(ma, 0x3, shift, reg); + } + + /* vol */ + if (config & VOL_PRESENT) { + shift = pin % 8 * 4 + 2; + if (vol) + writel(1 << shift, reg + SET); + else + writel(1 << shift, reg + CLR); + } + + /* pull */ + if (config & PULL_PRESENT) { + reg = iomux->base + iomux->regs->pull; + reg += bank * 0x10; + shift = pin; + if (pull) + writel(1 << shift, reg + SET); + else + writel(1 << shift, reg + CLR); + } + } + + devm_kfree(dev, pin_data); + return 0; +} + +static struct pinctrl_ops mxs_pinctrl_ops = { + .set_state = mxs_pinctrl_set_state, +}; + +static int mxs_pinctrl_probe(struct udevice *dev) +{ + struct mxs_pinctrl_priv *iomux = dev_get_priv(dev); + + iomux->base = dev_read_addr_ptr(dev); + iomux->regs = (struct mxs_regs *)dev_get_driver_data(dev); + + return 0; +} + +static const struct mxs_regs imx23_regs = { + .muxsel = 0x100, + .drive = 0x200, + .pull = 0x400, +}; + +static const struct mxs_regs imx28_regs = { + .muxsel = 0x100, + .drive = 0x300, + .pull = 0x600, +}; + +static const struct udevice_id mxs_pinctrl_match[] = { + { .compatible = "fsl,imx23-pinctrl", .data = (ulong)&imx23_regs }, + { .compatible = "fsl,imx28-pinctrl", .data = (ulong)&imx28_regs }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(mxs_pinctrl) = { + .name = "mxs-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(mxs_pinctrl_match), + .probe = mxs_pinctrl_probe, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .bind = dm_scan_fdt_dev, +#endif + .priv_auto_alloc_size = sizeof(struct mxs_pinctrl_priv), + .ops = &mxs_pinctrl_ops, +}; diff --git a/drivers/pinctrl/nxp/pinctrl-mxs.h b/drivers/pinctrl/nxp/pinctrl-mxs.h new file mode 100644 index 0000000000..a3d54e680c --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-mxs.h @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + */ + +#ifndef __PINCTRL_MXS_H +#define __PINCTRL_MXS_H + +#include <dm/pinctrl.h> + +#define SET 0x4 +#define CLR 0x8 +#define TOG 0xc + +#define MXS_PINCTRL_PIN(pin) PINCTRL_PIN(pin, #pin) +#define PINID(bank, pin) ((bank) * 32 + (pin)) + +/* + * pinmux-id bit field definitions + * + * bank: 15..12 (4) + * pin: 11..4 (8) + * muxsel: 3..0 (4) + */ +#define MUXID_TO_PINID(m) PINID((m) >> 12 & 0xf, (m) >> 4 & 0xff) +#define MUXID_TO_MUXSEL(m) ((m) & 0xf) + +#define PINID_TO_BANK(p) ((p) >> 5) +#define PINID_TO_PIN(p) ((p) % 32) + +/* + * pin config bit field definitions + * + * pull-up: 6..5 (2) + * voltage: 4..3 (2) + * mA: 2..0 (3) + * + * MSB of each field is presence bit for the config. + */ +#define PULL_PRESENT (1 << 6) +#define PULL_SHIFT 5 +#define VOL_PRESENT (1 << 4) +#define VOL_SHIFT 3 +#define MA_PRESENT (1 << 2) +#define MA_SHIFT 0 +#define CONFIG_TO_PULL(c) ((c) >> PULL_SHIFT & 0x1) +#define CONFIG_TO_VOL(c) ((c) >> VOL_SHIFT & 0x1) +#define CONFIG_TO_MA(c) ((c) >> MA_SHIFT & 0x3) + +struct mxs_regs { + u16 muxsel; + u16 drive; + u16 pull; +}; +#endif /* __PINCTRL_MXS_H */
Maybe you want to keep the DTs and this driver based off the same version of Linux kernel.
Tags are "pinctrl: mxs: ".
- u32 tmp;
This is clrsetbits_le32() reimplementation.
- tmp = readl(reg);
- tmp &= ~(mask << shift);
- tmp |= value << shift;
- writel(tmp, reg);
Hi Marek,
I will keep and used the v5.1.11 in both drivers.
I will fix the tags globally.
- u32 tmp;
Ach, right. I will leave the mxs_pinctrl_rmwl wrapper function and replace below code with clrsetbits_le32.
- tmp = readl(reg);
- writel(tmp, reg);
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
This patch converts mxs_spi driver to support DM/DTS.
Changes in v4: - Adjust the driver to support i.MX23 (add compatible, adjust clk code) - Use BIT() macro where applicable
Changes in v3: - Set more appropriate tags
Changes in v2: - New patch (conversion of mxs_spi.c to DM_SPI)
drivers/spi/mxs_spi.c | 400 +++++++++++++++++++++++++++++++++++++++----------- 1 file changed, 317 insertions(+), 83 deletions(-)
diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c index 5065e407f8..3a9756fbf1 100644 --- a/drivers/spi/mxs_spi.c +++ b/drivers/spi/mxs_spi.c @@ -2,6 +2,9 @@ /* * Freescale i.MX28 SPI driver * + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com * on behalf of DENX Software Engineering GmbH * @@ -27,6 +30,19 @@
#define MXSSSP_SMALL_TRANSFER 512
+static void mxs_spi_start_xfer(struct mxs_ssp_regs *ssp_regs) +{ + writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_set); + writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_clr); +} + +static void mxs_spi_end_xfer(struct mxs_ssp_regs *ssp_regs) +{ + writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_clr); + writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_set); +} + +#if !CONFIG_IS_ENABLED(DM_SPI) struct mxs_spi_slave { struct spi_slave slave; uint32_t max_khz; @@ -38,94 +54,38 @@ static inline struct mxs_spi_slave *to_mxs_slave(struct spi_slave *slave) { return container_of(slave, struct mxs_spi_slave, slave); } +#else +#include <dm.h> +#include <errno.h> +struct mxs_spi_platdata { + s32 frequency; /* Default clock frequency, -1 for none */ + fdt_addr_t base; /* SPI IP block base address */ + int num_cs; /* Number of CSes supported */ + int dma_id; /* ID of the DMA channel */ + int clk_id; /* ID of the SSP clock */ +};
-int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - /* MXS SPI: 4 ports and 3 chip selects maximum */ - if (!mxs_ssp_bus_id_valid(bus) || cs > 2) - return 0; - else - return 1; -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct mxs_spi_slave *mxs_slave; - - if (!spi_cs_is_valid(bus, cs)) { - printf("mxs_spi: invalid bus %d / chip select %d\n", bus, cs); - return NULL; - } - - mxs_slave = spi_alloc_slave(struct mxs_spi_slave, bus, cs); - if (!mxs_slave) - return NULL; - - if (mxs_dma_init_channel(MXS_DMA_CHANNEL_AHB_APBH_SSP0 + bus)) - goto err_init; - - mxs_slave->max_khz = max_hz / 1000; - mxs_slave->mode = mode; - mxs_slave->regs = mxs_ssp_regs_by_bus(bus); - - return &mxs_slave->slave; - -err_init: - free(mxs_slave); - return NULL; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - free(mxs_slave); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; - uint32_t reg = 0; - - mxs_reset_block(&ssp_regs->hw_ssp_ctrl0_reg); - - writel((slave->cs << MXS_SSP_CHIPSELECT_SHIFT) | - SSP_CTRL0_BUS_WIDTH_ONE_BIT, - &ssp_regs->hw_ssp_ctrl0); - - reg = SSP_CTRL1_SSP_MODE_SPI | SSP_CTRL1_WORD_LENGTH_EIGHT_BITS; - reg |= (mxs_slave->mode & SPI_CPOL) ? SSP_CTRL1_POLARITY : 0; - reg |= (mxs_slave->mode & SPI_CPHA) ? SSP_CTRL1_PHASE : 0; - writel(reg, &ssp_regs->hw_ssp_ctrl1); - - writel(0, &ssp_regs->hw_ssp_cmd0); - - mxs_set_ssp_busclock(slave->bus, mxs_slave->max_khz); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ -} - -static void mxs_spi_start_xfer(struct mxs_ssp_regs *ssp_regs) -{ - writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_set); - writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_clr); -} - -static void mxs_spi_end_xfer(struct mxs_ssp_regs *ssp_regs) -{ - writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_clr); - writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_set); -} +struct mxs_spi_priv { + struct mxs_ssp_regs *regs; + unsigned int dma_channel; + unsigned int max_freq; + unsigned int clk_id; + unsigned int mode; +}; +#endif
+#if !CONFIG_IS_ENABLED(DM_SPI) static int mxs_spi_xfer_pio(struct mxs_spi_slave *slave, char *data, int length, int write, unsigned long flags) { struct mxs_ssp_regs *ssp_regs = slave->regs; +#else +static int mxs_spi_xfer_pio(struct mxs_spi_priv *priv, + char *data, int length, int write, + unsigned long flags) +{ + struct mxs_ssp_regs *ssp_regs = priv->regs; +#endif
if (flags & SPI_XFER_BEGIN) mxs_spi_start_xfer(ssp_regs); @@ -181,12 +141,19 @@ static int mxs_spi_xfer_pio(struct mxs_spi_slave *slave, return 0; }
+#if !CONFIG_IS_ENABLED(DM_SPI) static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, char *data, int length, int write, unsigned long flags) { + struct mxs_ssp_regs *ssp_regs = slave->regs; +#else +static int mxs_spi_xfer_dma(struct mxs_spi_priv *priv, + char *data, int length, int write, + unsigned long flags) +{ struct mxs_ssp_regs *ssp_regs = priv->regs; +#endif const int xfer_max_sz = 0xff00; const int desc_count = DIV_ROUND_UP(length, xfer_max_sz) + 1; - struct mxs_ssp_regs *ssp_regs = slave->regs; struct mxs_dma_desc *dp; uint32_t ctrl0; uint32_t cache_data_count; @@ -225,7 +192,11 @@ static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, /* Invalidate the area, so no writeback into the RAM races with DMA */ invalidate_dcache_range(dstart, dstart + cache_data_count);
+#if !CONFIG_IS_ENABLED(DM_SPI) dmach = MXS_DMA_CHANNEL_AHB_APBH_SSP0 + slave->slave.bus; +#else + dmach = priv->dma_channel; +#endif
dp = desc; while (length) { @@ -302,11 +273,20 @@ static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, return ret; }
+#if !CONFIG_IS_ENABLED(DM_SPI) int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; +#else +int mxs_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev_get_parent(dev); + struct mxs_spi_priv *priv = dev_get_priv(bus); + struct mxs_ssp_regs *ssp_regs = priv->regs; +#endif int len = bitlen / 8; char dummy; int write = 0; @@ -350,9 +330,263 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen,
if (!dma || (len < MXSSSP_SMALL_TRANSFER)) { writel(SSP_CTRL1_DMA_ENABLE, &ssp_regs->hw_ssp_ctrl1_clr); +#if !CONFIG_IS_ENABLED(DM_SPI) return mxs_spi_xfer_pio(mxs_slave, data, len, write, flags); +#else + return mxs_spi_xfer_pio(priv, data, len, write, flags); +#endif } else { writel(SSP_CTRL1_DMA_ENABLE, &ssp_regs->hw_ssp_ctrl1_set); +#if !CONFIG_IS_ENABLED(DM_SPI) return mxs_spi_xfer_dma(mxs_slave, data, len, write, flags); +#else + return mxs_spi_xfer_dma(priv, data, len, write, flags); +#endif } } + +#if !CONFIG_IS_ENABLED(DM_SPI) +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + /* MXS SPI: 4 ports and 3 chip selects maximum */ + if (!mxs_ssp_bus_id_valid(bus) || cs > 2) + return 0; + else + return 1; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct mxs_spi_slave *mxs_slave; + + if (!spi_cs_is_valid(bus, cs)) { + printf("mxs_spi: invalid bus %d / chip select %d\n", bus, cs); + return NULL; + } + + mxs_slave = spi_alloc_slave(struct mxs_spi_slave, bus, cs); + if (!mxs_slave) + return NULL; + + if (mxs_dma_init_channel(MXS_DMA_CHANNEL_AHB_APBH_SSP0 + bus)) + goto err_init; + + mxs_slave->max_khz = max_hz / 1000; + mxs_slave->mode = mode; + mxs_slave->regs = mxs_ssp_regs_by_bus(bus); + + return &mxs_slave->slave; + +err_init: + free(mxs_slave); + return NULL; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); + + free(mxs_slave); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); + struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; + u32 reg = 0; + + mxs_reset_block(&ssp_regs->hw_ssp_ctrl0_reg); + + writel((slave->cs << MXS_SSP_CHIPSELECT_SHIFT) | + SSP_CTRL0_BUS_WIDTH_ONE_BIT, + &ssp_regs->hw_ssp_ctrl0); + + reg = SSP_CTRL1_SSP_MODE_SPI | SSP_CTRL1_WORD_LENGTH_EIGHT_BITS; + reg |= (mxs_slave->mode & SPI_CPOL) ? SSP_CTRL1_POLARITY : 0; + reg |= (mxs_slave->mode & SPI_CPHA) ? SSP_CTRL1_PHASE : 0; + writel(reg, &ssp_regs->hw_ssp_ctrl1); + + writel(0, &ssp_regs->hw_ssp_cmd0); + + mxs_set_ssp_busclock(slave->bus, mxs_slave->max_khz); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +#else /* CONFIG_DM_SPI */ +/* Base numbers of i.MX2[38] clk for ssp0 IP block */ +#define MXS_SSP_IMX23_CLKID_SSP0 33 +#define MXS_SSP_IMX28_CLKID_SSP0 46 + +static int mxs_spi_probe(struct udevice *bus) +{ + struct mxs_spi_platdata *plat = dev_get_platdata(bus); + struct mxs_spi_priv *priv = dev_get_priv(bus); + int ret; + + debug("%s: probe\n", __func__); + priv->regs = (struct mxs_ssp_regs *)plat->base; + priv->max_freq = plat->frequency; + + priv->dma_channel = plat->dma_id; + priv->clk_id = plat->clk_id; + + ret = mxs_dma_init_channel(priv->dma_channel); + if (ret) { + printf("%s: DMA init channel error %d\n", __func__, ret); + return ret; + } + + return 0; +} + +static int mxs_spi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct mxs_spi_priv *priv = dev_get_priv(bus); + struct mxs_ssp_regs *ssp_regs = priv->regs; + int cs = spi_chip_select(dev); + + /* + * i.MX28 supports up to 3 CS (SSn0, SSn1, SSn2) + * To set them it uses following tuple (WAIT_FOR_IRQ,WAIT_FOR_CMD), + * where: + * + * WAIT_FOR_IRQ is bit 21 of HW_SSP_CTRL0 + * WAIT_FOR_CMD is bit 20 (#defined as MXS_SSP_CHIPSELECT_SHIFT here) of + * HW_SSP_CTRL0 + * SSn0 b00 + * SSn1 b01 + * SSn2 b10 (which require setting WAIT_FOR_IRQ) + * + * However, for now i.MX28 SPI driver will support up till 2 CSes + * (SSn0, and SSn1). + */ + + /* Ungate SSP clock and set active CS */ + clrsetbits_le32(&ssp_regs->hw_ssp_ctrl0, + BIT(MXS_SSP_CHIPSELECT_SHIFT) | + SSP_CTRL0_CLKGATE, (cs << MXS_SSP_CHIPSELECT_SHIFT)); + + return 0; +} + +static int mxs_spi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct mxs_spi_priv *priv = dev_get_priv(bus); + struct mxs_ssp_regs *ssp_regs = priv->regs; + + /* Gate SSP clock */ + setbits_le32(&ssp_regs->hw_ssp_ctrl0, SSP_CTRL0_CLKGATE); + + return 0; +} + +static int mxs_spi_set_speed(struct udevice *bus, uint speed) +{ + struct mxs_spi_priv *priv = dev_get_priv(bus); +#ifdef CONFIG_MX28 + int clkid = priv->clk_id - MXS_SSP_IMX28_CLKID_SSP0; +#else /* CONFIG_MX23 */ + int clkid = priv->clk_id - MXS_SSP_IMX23_CLKID_SSP0; +#endif + if (speed > priv->max_freq) + speed = priv->max_freq; + + debug("%s speed: %u [Hz] clkid: %d\n", __func__, speed, clkid); + mxs_set_ssp_busclock(clkid, speed / 1000); + + return 0; +} + +static int mxs_spi_set_mode(struct udevice *bus, uint mode) +{ + struct mxs_spi_priv *priv = dev_get_priv(bus); + struct mxs_ssp_regs *ssp_regs = priv->regs; + u32 reg; + + priv->mode = mode; + debug("%s: mode 0x%x\n", __func__, mode); + + reg = SSP_CTRL1_SSP_MODE_SPI | SSP_CTRL1_WORD_LENGTH_EIGHT_BITS; + reg |= (priv->mode & SPI_CPOL) ? SSP_CTRL1_POLARITY : 0; + reg |= (priv->mode & SPI_CPHA) ? SSP_CTRL1_PHASE : 0; + writel(reg, &ssp_regs->hw_ssp_ctrl1); + + /* Single bit SPI support */ + writel(SSP_CTRL0_BUS_WIDTH_ONE_BIT, &ssp_regs->hw_ssp_ctrl0); + + return 0; +} + +static const struct dm_spi_ops mxs_spi_ops = { + .claim_bus = mxs_spi_claim_bus, + .release_bus = mxs_spi_release_bus, + .xfer = mxs_spi_xfer, + .set_speed = mxs_spi_set_speed, + .set_mode = mxs_spi_set_mode, + /* + * cs_info is not needed, since we require all chip selects to be + * in the device tree explicitly + */ +}; + +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +static int mxs_ofdata_to_platdata(struct udevice *bus) +{ + struct mxs_spi_platdata *plat = bus->platdata; + u32 prop[2]; + int ret; + + plat->base = dev_read_addr(bus); + plat->frequency = + dev_read_u32_default(bus, "spi-max-frequency", 40000000); + plat->num_cs = dev_read_u32_default(bus, "num-cs", 2); + + ret = dev_read_u32_array(bus, "dmas", prop, ARRAY_SIZE(prop)); + if (ret) { + printf("%s: Reading 'dmas' property failed!\n", __func__); + return ret; + } + plat->dma_id = prop[1]; + + ret = dev_read_u32_array(bus, "clocks", prop, ARRAY_SIZE(prop)); + if (ret) { + printf("%s: Reading 'clocks' property failed!\n", __func__); + return ret; + } + plat->clk_id = prop[1]; + + debug("%s: base=0x%x, max-frequency=%d num-cs=%d dma_id=%d clk_id=%d\n", + __func__, (uint)plat->base, plat->frequency, plat->num_cs, + plat->dma_id, plat->clk_id); + + return 0; +} +#endif + +static const struct udevice_id mxs_spi_ids[] = { + { .compatible = "fsl,imx23-spi" }, + { .compatible = "fsl,imx28-spi" }, + { } +}; + +U_BOOT_DRIVER(mxs_spi) = { + .name = "mxs_spi", + .id = UCLASS_SPI, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = mxs_spi_ids, + .ofdata_to_platdata = mxs_ofdata_to_platdata, +#endif + .priv_auto_alloc_size = sizeof(struct mxs_spi_platdata), + .ops = &mxs_spi_ops, + .priv_auto_alloc_size = sizeof(struct mxs_spi_priv), + .probe = mxs_spi_probe, +}; +#endif
Tags should be "spi: mxs:" .
btw can you drop the non-DM part of the driver altogether ?
The rest of the patchset is much better, thanks.
Hi Marek,
I think that we can keep the code until e.g. v2019.10 release and remove it in the next (i.e. after v2019.10) merge window.
That would give people some time to adjust i.MX2[38] boards to it.
Ok. Good :-)
Lukasz Majewski
On 6/19/19 8:52 AM, Lukasz Majewski wrote:
Hi Marek,
Fine
Lukasz Majewski
