[U-Boot] [PATCH] 85xx/p1_p2_rdb: Added RevD board support.
Signed-off-by: Dipen Dudhat dipen.dudhat@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- board/freescale/p1_p2_rdb/p1_p2_rdb.c | 25 ++++++++----------------- 1 files changed, 8 insertions(+), 17 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/p1_p2_rdb.c b/board/freescale/p1_p2_rdb/p1_p2_rdb.c index 31cdf9a..d870a3b 100644 --- a/board/freescale/p1_p2_rdb/p1_p2_rdb.c +++ b/board/freescale/p1_p2_rdb/p1_p2_rdb.c @@ -52,32 +52,23 @@ DECLARE_GLOBAL_DATA_PTR;
#define SYSCLK_MASK 0x00200000 #define BOARDREV_MASK 0x10100000 -#define BOARDREV_B 0x10100000 #define BOARDREV_C 0x00100000 +#define BOARDREV_D 0x00000000
#define SYSCLK_66 66666666 -#define SYSCLK_50 50000000 #define SYSCLK_100 100000000
unsigned long get_board_sys_clk(ulong dummy) { volatile ccsr_gpio_t *pgpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR); - u32 val_gpdat, sysclk_gpio, board_rev_gpio; + u32 val_gpdat, sysclk_gpio;
val_gpdat = pgpio->gpdat; sysclk_gpio = val_gpdat & SYSCLK_MASK; - board_rev_gpio = val_gpdat & BOARDREV_MASK; - if (board_rev_gpio == BOARDREV_C) { - if(sysclk_gpio == 0) - return SYSCLK_66; - else - return SYSCLK_100; - } else if (board_rev_gpio == BOARDREV_B) { - if(sysclk_gpio == 0) - return SYSCLK_66; - else - return SYSCLK_50; - } + if(sysclk_gpio == 0) + return SYSCLK_66; + else + return SYSCLK_100; return 0; }
@@ -104,8 +95,8 @@ int checkboard (void) board_rev_gpio = val_gpdat & BOARDREV_MASK; if (board_rev_gpio == BOARDREV_C) board_rev = 'C'; - else if (board_rev_gpio == BOARDREV_B) - board_rev = 'B'; + else if (board_rev_gpio == BOARDREV_D) + board_rev = 'D'; else panic ("Unexpected Board REV %x detected!!\n", board_rev_gpio);
Dear Poonam Aggrwal,
In message 1277185601-4939-1-git-send-email-poonam.aggrwal@freescale.com you wrote:
Does that mean thea board rev. B and 50 MHz sys clk are not longer supported? Have these configurations been used in the past?Then we should rather keep them?
Please use I/O accessors to read from peripherals!
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Tuesday, June 22, 2010 11:31 AM To: Aggrwal Poonam-B10812 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] 85xx/p1_p2_rdb: Added RevD board
support.
In message <1277185601-4939-1-git-send-email- poonam.aggrwal@freescale.com> you wrote:
should
rather keep them?
Okay, will add them.
I will redo the patch and resend.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
"I
find this a nice feature but it is not according to the documen- tation. Or is it a BUG?" "Let's call it an accidental feature. :-)" - Larry Wall in 6909@jpl-devvax.JPL.NASA.GOV
Poonam Aggrwal
