[U-Boot-Users] PATCH: Update U-Boot EXT2 Filesystem to support dynamic inode size and optimize ext2 read function to fasten read speed!
Description: The patch updates /fs/ext2/ext2fs.c file. There are two aims: 1. Make U-Boot could support the EXT2 dynamic version that ext2_inode_size beyond 128bytes. One new feature be involved: CFG_EXT2_SUPPORT_DYNAMIC_REV Refer to: linux-2.6.24.3 source code. 2. Make EXT2 read more fast. One new feature be involved: CFG_OPTIMIZE_EXT2_READ
commit f4120b0f4f06cd1a382bb562d7fe33ea554a1982 Parent: 699f05125509249072a0b865c8d35520d97cd501 Author: Ryan Chen ryan.chen@st.com Date: Tue Jul 29 11:57:11 2008 -0400
Signed-off-by: Ryan Chen ryan.chen@st.com
modified: fs/ext2/ext2fs.c
diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c old mode 100644 new mode 100755 index 7833551..3946978 --- a/fs/ext2/ext2fs.c +++ b/fs/ext2/ext2fs.c @@ -29,6 +29,7 @@ #include <ext2fs.h> #include <malloc.h> #include <asm/byteorder.h> +#define CFG_EXT2_SUPPORT_DYNAMIC_REV
extern int ext2fs_devread (int sector, int byte_offset, int byte_len, char *buf); @@ -66,6 +67,17 @@ extern int ext2fs_devread (int sector, int byte_offset, int byte_len, /* The size of an ext2 block in bytes. */ #define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data))
+#ifdef CFG_EXT2_SUPPORT_DYNAMIC_REV +/* + * Revision levels + */ +#define EXT2_GOOD_OLD_REV 0 /* The good old (original) format */ +#define EXT2_DYNAMIC_REV 1 /* V2 format w/ dynamic inode sizes */ + +#define EXT2_GOOD_OLD_INODE_SIZE 128 +uint32_t ext2_inode_size = EXT2_GOOD_OLD_INODE_SIZE; +#endif + /* The ext2 superblock. */ struct ext2_sblock { uint32_t total_inodes; @@ -217,7 +229,11 @@ static int ext2fs_read_inode if (status == 0) { return (0); } +#ifdef CFG_EXT2_SUPPORT_DYNAMIC_REV + inodes_per_block = EXT2_BLOCK_SIZE (data) / ext2_inode_size; +#else inodes_per_block = EXT2_BLOCK_SIZE (data) / 128; +#endif blkno = (ino % __le32_to_cpu (sblock->inodes_per_group)) / inodes_per_block; blkoff = (ino % __le32_to_cpu (sblock->inodes_per_group)) % @@ -226,10 +242,17 @@ static int ext2fs_read_inode printf ("ext2fs read inode blkno %d blkoff %d\n", blkno, blkoff); #endif /* Read the inode. */ +#ifdef CFG_EXT2_SUPPORT_DYNAMIC_REV + status = ext2fs_devread (((__le32_to_cpu (blkgrp.inode_table_id) + + blkno) << LOG2_EXT2_BLOCK_SIZE (data)), + ext2_inode_size * blkoff, + sizeof (struct ext2_inode), (char *) inode); +#else status = ext2fs_devread (((__le32_to_cpu (blkgrp.inode_table_id) + blkno) << LOG2_EXT2_BLOCK_SIZE (data)), sizeof (struct ext2_inode) * blkoff, sizeof (struct ext2_inode), (char *) inode); +#endif if (status == 0) { return (0); } @@ -243,8 +266,13 @@ void ext2fs_free_node (ext2fs_node_t node, ext2fs_node_t currroot) { } }
+#define CFG_OPTIMIZE_EXT2_READ
+#ifdef CFG_OPTIMIZE_EXT2_READ +static int ext2fs_read_block (ext2fs_node_t node, int fileblock, int *stream) { +#else static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { +#endif struct ext2_data *data = node->data; struct ext2_inode *inode = &node->inode; int blknr; @@ -252,9 +280,20 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { int log2_blksz = LOG2_EXT2_BLOCK_SIZE (data); int status;
+#ifdef CFG_OPTIMIZE_EXT2_READ + *stream = 1;/* itself */ +#endif + /* Direct blocks. */ if (fileblock < INDIRECT_BLOCKS) { blknr = __le32_to_cpu (inode->b.blocks.dir_blocks[fileblock]); +#ifdef CFG_OPTIMIZE_EXT2_READ + while(((inode->b.blocks.dir_blocks[fileblock + 1] - + inode->b.blocks.dir_blocks[fileblock]) == 1) && (fileblock < INDIRECT_BLOCKS - 1)) { + fileblock++; + *stream += 1; + } +#endif } /* Indirect. */ else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { @@ -294,6 +333,13 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { } blknr = __le32_to_cpu (indir1_block [fileblock - INDIRECT_BLOCKS]); +#ifdef CFG_OPTIMIZE_EXT2_READ + while(((__le32_to_cpu (indir1_block[fileblock - INDIRECT_BLOCKS + 1]) - \ + __le32_to_cpu (indir1_block[fileblock - INDIRECT_BLOCKS])) == 1) && (fileblock < (blksz - 1))) { + fileblock++; + *stream += 1; + } +#endif } /* Double indirect. */ else if (fileblock < @@ -301,6 +347,9 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { unsigned int perblock = blksz / 4; unsigned int rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4); +#ifdef CFG_OPTIMIZE_EXT2_READ + int rbcnt = 0; +#endif
if (indir1_block == NULL) { indir1_block = (uint32_t *) malloc (blksz); @@ -370,6 +419,14 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { __le32_to_cpu (indir1_block[rblock / perblock]) << log2_blksz; } blknr = __le32_to_cpu (indir2_block[rblock % perblock]); +#ifdef CFG_OPTIMIZE_EXT2_READ + rbcnt = rblock % perblock; + while(((__le32_to_cpu (indir2_block[rbcnt + 1]) - \ + __le32_to_cpu (indir2_block[rbcnt])) == 1) && (rbcnt < (blksz - 1))) { + rbcnt++; + *stream += 1; + } +#endif } /* Tripple indirect. */ else { @@ -382,7 +439,57 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { return (blknr); }
+#ifdef CFG_OPTIMIZE_EXT2_READ +int ext2fs_read_file + (ext2fs_node_t node, int pos, unsigned int len, char *buf) { + int log2blocksize = LOG2_EXT2_BLOCK_SIZE (node->data); + int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); + unsigned int filesize = __le32_to_cpu(node->inode.size); + int blknr; + int blockend; + int status; + int remain = len; + char *buffer = buf; + int stream = 0; + int cur = pos / blocksize; + int blockoff = pos % blocksize; + + /* Adjust len so it we can't read past the end of the file. */ + if (len > filesize) { + len = filesize; + }
+ while (remain > 0) { + blknr = ext2fs_read_block (node, cur, &stream); + if (blknr < 0) { + return (-1); + } + blknr = blknr << log2blocksize; + + if(remain < blocksize * stream) { + blockend = remain; + } else { + blockend = blocksize * stream; + } + + status = ext2fs_devread (blknr, blockoff, blockend, buffer); + if (status == 0) { + return (-1); + } + + remain -= blockend; + buffer += blockend; + cur += stream; + blockoff = 0; + + if(remain == 0) + return (len); + else if(remain < 0) + return (-1); + } + return (len); +} +#else int ext2fs_read_file (ext2fs_node_t node, int pos, unsigned int len, char *buf) { int i; @@ -390,7 +497,7 @@ int ext2fs_read_file int log2blocksize = LOG2_EXT2_BLOCK_SIZE (node->data); int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); unsigned int filesize = __le32_to_cpu(node->inode.size); - + /* Adjust len so it we can't read past the end of the file. */ if (len > filesize) { len = filesize; @@ -409,7 +516,7 @@ int ext2fs_read_file return (-1); } blknr = blknr << log2blocksize; - + /* Last block. */ if (i == blockcnt - 1) { blockend = (len + pos) % blocksize; @@ -442,6 +549,7 @@ int ext2fs_read_file } return (len); } +#endif
static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fnode, int *ftype) @@ -854,6 +962,17 @@ int ext2fs_mount (unsigned part_length) { if (__le16_to_cpu (data->sblock.magic) != EXT2_MAGIC) { goto fail; } +#ifdef CFG_EXT2_SUPPORT_DYNAMIC_REV +#ifdef DEBUG + printf("revision_level = 0x%x, inode_size = 0x%x\n", data->sblock.revision_level, data->sblock.inode_size); +#endif + if (__le32_to_cpu (data->sblock.revision_level) == EXT2_GOOD_OLD_REV) { + ext2_inode_size = EXT2_GOOD_OLD_INODE_SIZE; + } else { + ext2_inode_size = __le16_to_cpu (data->sblock.inode_size); + } +#endif + data->diropen.data = data; data->diropen.ino = 2; data->diropen.inode_read = 1;
Best Regards, Ryan Chen
- Make U-Boot could support the EXT2 dynamic version that ext2_inode_size beyond 128bytes. One new feature be involved: CFG_EXT2_SUPPORT_DYNAMIC_REV Refer to: linux-2.6.24.3 source code.
- Make EXT2 read more fast. One new feature be involved: CFG_OPTIMIZE_EXT2_READ
Does it significantly increase code size, or is there any other reason why these need to be conditionalized?
-Scott
Hi Scott, For sure, the modification will increase code size, but I think it is reasonable. 1. Make U-Boot could support the EXT2 dynamic version that ext2_inode_size beyond 128bytes. According to Linux kernel source code, now EXT2 filesystem could support two revision: EXT2_GOOD_OLD_REV EXT2_DYNAMIC_REV ext2_inode_size be fixed as 128bytes in the first revision while it could beyond 128bytes in another revision. In the past, the first revision is the default option for mkfs.ext2 command. But now there are some OSes like Mandriva Linux 2008.1 for STLS want to use new revision option to format disk. I have tested it and our current U-Boot couldn't support it. So I think it is time to do it.
2. Make EXT2 read more fast. I have tested our U-Boot to access EXT2 filesystem on USB disk. It's quite slow and it takes about 200 seconds to read a file that its size is 8MB. Our USB host controller is NEC upd720101 OHCI host controller and operation mode is 'bulk'. I think its width is enough. I have analyzed our ext2fs.c file and found it only read 4KB(512B/block * 8blocks, I format EXT2 filesystem with default options) once time. One time is a USB timing slot - 100ms. So it is so slow. Now I mainly modified ext2fs_read_block() function to detect how many seriate blocks and read them in one time. The modification fasten read opertion a lot especially big file.
Best Regards, Ryan Chen -----Original Message----- From: Scott Wood [mailto:scottwood@freescale.com] Sent: Wednesday, July 30, 2008 4:11 AM To: Ryan CHEN Cc: u-boot-users@lists.sourceforge.net; Antonio Maria BORNEO Subject: Re: [U-Boot-Users] PATCH: Update U-Boot EXT2 Filesystem to support dynamic inode size and optimize ext2 read function to fasten read speed!
beyond 128bytes.
-Scott
Do we really need new config options and #ifdeffery for these?
You're adding trailing white space here. Please don't.
+#ifdef DEBUG
- printf("revision_level = 0x%x, inode_size = 0x%x\n", data->sblock.revision_level, data->sblock.inode_size);
Use debug() instead of #ifdef
And mind the maximum line length.
Hi Wolfgang, I have modified my patch according to your suggestion. The only question is that use debug() because I found all debug print msg lines are written as : #ifdef DEBUG printf(......); #endif Are you sure I need change my debug print to debug()?
commit 4e638f2b97cea8b256eca7eb098d4da45015e10d Parent: 699f05125509249072a0b865c8d35520d97cd501 Author: Ryan Chen ryan.chen@st.com Date: Wed Jul 30 05:48:16 2008 -0400
diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c old mode 100644 new mode 100755 index 7833551..4b01463 --- a/fs/ext2/ext2fs.c +++ b/fs/ext2/ext2fs.c @@ -29,6 +29,7 @@ #include <ext2fs.h> #include <malloc.h> #include <asm/byteorder.h> +#define CFG_EXT2_SUPPORT_DYNAMIC_REV
+#ifdef CFG_OPTIMIZE_EXT2_READ +static int ext2fs_read_block (ext2fs_node_t node, int fileblock, int *stream) { +#else static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { +#endif struct ext2_data *data = node->data; struct ext2_inode *inode = &node->inode; int blknr; @@ -252,9 +280,21 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { int log2_blksz = LOG2_EXT2_BLOCK_SIZE (data); int status;
+#ifdef CFG_OPTIMIZE_EXT2_READ + *stream = 1;/* itself */ +#endif + /* Direct blocks. */ if (fileblock < INDIRECT_BLOCKS) { blknr = __le32_to_cpu (inode->b.blocks.dir_blocks[fileblock]); +#ifdef CFG_OPTIMIZE_EXT2_READ + while(((inode->b.blocks.dir_blocks[fileblock + 1] - + inode->b.blocks.dir_blocks[fileblock]) == 1) && \ + (fileblock < INDIRECT_BLOCKS - 1)) { + fileblock++; + *stream += 1; + } +#endif } /* Indirect. */ else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { @@ -294,6 +334,14 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { } blknr = __le32_to_cpu (indir1_block [fileblock - INDIRECT_BLOCKS]); +#ifdef CFG_OPTIMIZE_EXT2_READ + while(((__le32_to_cpu (indir1_block[fileblock - INDIRECT_BLOCKS + 1]) - \ + __le32_to_cpu (indir1_block[fileblock - INDIRECT_BLOCKS])) == 1) && \ + (fileblock < (blksz - 1))) { + fileblock++; + *stream += 1; + } +#endif } /* Double indirect. */ else if (fileblock < @@ -301,6 +349,9 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { unsigned int perblock = blksz / 4; unsigned int rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4); +#ifdef CFG_OPTIMIZE_EXT2_READ + int rbcnt = 0; +#endif
if (indir1_block == NULL) { indir1_block = (uint32_t *) malloc (blksz); @@ -370,6 +421,15 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { __le32_to_cpu (indir1_block[rblock / perblock]) << log2_blksz; } blknr = __le32_to_cpu (indir2_block[rblock % perblock]); +#ifdef CFG_OPTIMIZE_EXT2_READ + rbcnt = rblock % perblock; + while(((__le32_to_cpu (indir2_block[rbcnt + 1]) - \ + __le32_to_cpu (indir2_block[rbcnt])) == 1) \ + && (rbcnt < (blksz - 1))) { + rbcnt++; + *stream += 1; + } +#endif } /* Tripple indirect. */ else { @@ -382,7 +442,57 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { return (blknr); }
+ while (remain > 0) { + blknr = ext2fs_read_block (node, cur, &stream); + if (blknr < 0) { + return (-1); + } + blknr = blknr << log2blocksize; + + if(remain < blocksize * stream) { + blockend = remain; + } else { + blockend = blocksize * stream; + } + + status = ext2fs_devread (blknr, blockoff, blockend, buffer); + if (status == 0) { + return (-1); + } + + remain -= blockend; + buffer += blockend; + cur += stream; + blockoff = 0; + + if(remain == 0) + return (len); + else if(remain < 0) + return (-1); + } + return (len); +} +#else int ext2fs_read_file (ext2fs_node_t node, int pos, unsigned int len, char *buf) { int i; @@ -442,6 +552,7 @@ int ext2fs_read_file } return (len); } +#endif
static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fnode, int *ftype) @@ -854,6 +965,18 @@ int ext2fs_mount (unsigned part_length) { if (__le16_to_cpu (data->sblock.magic) != EXT2_MAGIC) { goto fail; } +#ifdef CFG_EXT2_SUPPORT_DYNAMIC_REV +#ifdef DEBUG + printf("revision_level = 0x%x, inode_size = 0x%x\n", data->sblock.revision_level, \ + data->sblock.inode_size); +#endif + if (__le32_to_cpu (data->sblock.revision_level) == EXT2_GOOD_OLD_REV) { + ext2_inode_size = EXT2_GOOD_OLD_INODE_SIZE; + } else { + ext2_inode_size = __le16_to_cpu (data->sblock.inode_size); + } +#endif + data->diropen.data = data; data->diropen.ino = 2; data->diropen.inode_read = 1;
Best Regards, Ryan Chen -----Original Message----- From: wd@denx.de [mailto:wd@denx.de] Sent: Wednesday, July 30, 2008 7:17 AM To: Ryan CHEN Cc: u-boot-users@lists.sourceforge.net; Antonio Maria BORNEO Subject: Re: [U-Boot-Users] PATCH: Update U-Boot EXT2 Filesystem to support dynamic inode size and optimize ext2 read function to fasten read speed!
beyond 128bytes.
+#ifdef DEBUG
+data->sblock.revision_level, data->sblock.inode_size); #endif
Hi Ryan,
Yes, please. We introduced the macro especially for this to make the code more readable.
If you find other instances of the macro not being used, feel free to send a patch changing it ;)
Cheers Detlev
Dear Ryan CHEN,
Since all the other code is like that I agree to leave it unchanged.
But:
- status = ext2fs_devread (((__le32_to_cpu (blkgrp.inode_table_id) +
inode);
etc.
Your patch is corrupted because your mailer wrapped long lines.
Please fix your mailer and repost (with a nice commit message, please).
Detlev Zundel
Ryan CHEN
Scott Wood
