[U-Boot] [PATCH 0/2] Gateworks Ventana watchdog fix
This series resovles a couple of issues with the Gateworks Ventana IMX6 watchdog device-tree fixups.
Tim Harvey (2): imx: ventana: fix GW520x external watchdog dt update imx: ventana: update imx wdog external reset dt property
board/gateworks/gw_ventana/gw_ventana.c | 31 +++++++++++++++---------------- 1 file changed, 15 insertions(+), 16 deletions(-)
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index dc8cd88..b6a5221 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -1204,16 +1204,16 @@ int ft_board_setup(void *blob, bd_t *bd) strstr((const char *)info->model, "SP331-B")) gpio_cfg[board_type].usd_vsel = 0;
- /* GW520x-E adds WDOG1_B external reset */ - if (info->model[4] == '0' && rev < 'E') - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); - /* GW522x-B adds WDOG1_B external reset */ - if (info->model[4] == '2' && rev < 'B') - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); + ft_delprop_path(blob, WDOG1_PATH, + "fsl,ext-reset-output"); } + + /* GW520x-E adds WDOG1_B external reset */ + else if (info->model[4] == '0' && rev < 'E') + ft_delprop_path(blob, WDOG1_PATH, + "fsl,ext-reset-output"); + break;
case GW53xx:
Early backports of the imx wdog external reset feature occured before the property was accepted upstream and used 'ext-reset-output' instead of 'fsl,ext-reset-output'. In order to support older kernels remove both properties.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 25 ++++++++++++------------- 1 file changed, 12 insertions(+), 13 deletions(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index b6a5221..c4eab20 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -1091,6 +1091,12 @@ void ft_board_pci_fixup(void *blob, bd_t *bd) } #endif /* if defined(CONFIG_CMD_PCI) */
+void ft_board_wdog_fixup(void *blob, const char *path) +{ + ft_delprop_path(blob, path, "ext-reset-output"); + ft_delprop_path(blob, path, "fsl,ext-reset-output"); +} + /* * called prior to booting kernel or by 'fdt boardsetup' command * @@ -1173,8 +1179,7 @@ int ft_board_setup(void *blob, bd_t *bd)
/* GW51xx-E adds WDOG1_B external reset */ if (rev < 'E') - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); + ft_board_wdog_fixup(blob, WDOG1_PATH); break;
case GW52xx: @@ -1205,22 +1210,18 @@ int ft_board_setup(void *blob, bd_t *bd) gpio_cfg[board_type].usd_vsel = 0;
/* GW522x-B adds WDOG1_B external reset */ - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); + ft_board_wdog_fixup(blob, WDOG1_PATH); }
/* GW520x-E adds WDOG1_B external reset */ else if (info->model[4] == '0' && rev < 'E') - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); - + ft_board_wdog_fixup(blob, WDOG1_PATH); break;
case GW53xx: /* GW53xx-E adds WDOG1_B external reset */ if (rev < 'E') - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); + ft_board_wdog_fixup(blob, WDOG1_PATH); break;
case GW54xx: @@ -1234,8 +1235,7 @@ int ft_board_setup(void *blob, bd_t *bd)
/* GW54xx-E adds WDOG2_B external reset */ if (rev < 'E') - ft_delprop_path(blob, WDOG2_PATH, - "fsl,ext-reset-output"); + ft_board_wdog_fixup(blob, WDOG2_PATH); break;
case GW551x: @@ -1284,8 +1284,7 @@ int ft_board_setup(void *blob, bd_t *bd)
/* GW551x-C adds WDOG1_B external reset */ if (rev < 'C') - ft_delprop_path(blob, WDOG1_PATH, - "fsl,ext-reset-output"); + ft_board_wdog_fixup(blob, WDOG1_PATH); break; }
Best regards, Stefano Babic
Stefano Babic
Tim Harvey
