[U-Boot-Users] booting linux from u-boot - help!
I've finally resolved my ethernet reset problem - we just happened to be moving things arount on our development area, and found that upon removal of the mpcbdm cable, our board no longer sporadically reset and our ethernet worked just fine. Can anyone shed some light on this? I'm open to suggestions and I'm sure users developing for custom boards would also find this information useful.
Anyway, I'm now up to the stage of booting linux. i've tftp'd a pImage, loaded it into flash and have tried to boot it using:
setenv bootargs root=/dev/hda1 bootm 04880000 ## Booting image at 04880000 ... Image Name: Linux-2.4.19-pre7 Created: 2002-12-16 8:04:21 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 599083 Bytes = 585 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
At this point, it hangs. I've double-checked
linux/include/asm-ppc/ppcboot.h with u-boot/include/asm-ppc/ppcboot.h
and the only difference is the following line:
mon_fnc_t *bi_mon_fnc; /* Pointer to monitor functions */
which is required(?)
I've also tried it with the clocks_in_mhz turned on and off with no avail. I modified linux/arch/ppc/kernel/head_8xx.S to flash some LEDs on the board at _start and that works, suggesting to me that at least the memory map parsed to linux is ok. however, trying to flash our leds to try and find out where our system hangs, it fails when i get to start_here. it appears that the system crashes after the "rfi", which enables our mmu. to "prove" this, we replaced the turn_on_mmu block with a simple "b start_here". what could possibly be the problem here??
in desperate need of help... and thanks in advance, My Hong Vuong
My-Hong Vuong
