[PATCH] riscv: Split SiFive CLINT support between SPL and U-Boot proper
At present there is only one Kconfig option CONFIG_SIFIVE_CLINT to control the enabling of SiFive CLINT support in both SPL (M-mode) and U-Boot proper (S-mode). So for a typical SPL config that the SiFive CLINT driver is enabled in both SPL and U-Boot proper, that means the S-mode U-Boot tries to access the memory-mapped CLINT registers directly, instead of the normal 'rdtime' instruction.
This was not a problem before, as the hardware does not forbid the access from S-mode. However this becomes an issue now with OpenSBI commit 8b569803475e ("lib: utils/sys: Add CLINT memregion in the root domain") that the SiFive CLINT register space is protected by PMP for M-mode access only. U-Boot proper does not boot any more with the latest OpenSBI, that access exceptions are fired forever from U-Boot when trying to read the timer value via the SiFive CLINT driver in U-Boot.
To solve this, we need to split current SiFive CLINT support between SPL and U-Boot proper, using 2 separate Kconfig options.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/riscv/Kconfig | 9 ++++++++- arch/riscv/cpu/fu540/Kconfig | 2 +- arch/riscv/cpu/generic/Kconfig | 3 ++- arch/riscv/include/asm/global_data.h | 2 +- arch/riscv/lib/Makefile | 2 +- drivers/timer/Makefile | 2 +- 6 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3f221dccdb..82e10da11e 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -158,7 +158,14 @@ config DMA_ADDR_T_64BIT
config SIFIVE_CLINT bool - depends on RISCV_MMODE || SPL_RISCV_MMODE + depends on RISCV_MMODE + help + The SiFive CLINT block holds memory-mapped control and status registers + associated with software and timer interrupts. + +config SPL_SIFIVE_CLINT + bool + depends on SPL_RISCV_MMODE help The SiFive CLINT block holds memory-mapped control and status registers associated with software and timer interrupts. diff --git a/arch/riscv/cpu/fu540/Kconfig b/arch/riscv/cpu/fu540/Kconfig index 616b25650f..dcf099447b 100644 --- a/arch/riscv/cpu/fu540/Kconfig +++ b/arch/riscv/cpu/fu540/Kconfig @@ -11,7 +11,7 @@ config SIFIVE_FU540 imply CPU imply CPU_RISCV imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) - imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply SPL_SIFIVE_CLINT imply CMD_CPU imply SPL_CPU imply SPL_OPENSBI diff --git a/arch/riscv/cpu/generic/Kconfig b/arch/riscv/cpu/generic/Kconfig index a4934bb957..e025134b23 100644 --- a/arch/riscv/cpu/generic/Kconfig +++ b/arch/riscv/cpu/generic/Kconfig @@ -9,7 +9,8 @@ config GENERIC_RISCV imply CPU imply CPU_RISCV imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) - imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply SIFIVE_CLINT if RISCV_MMODE + imply SPL_SIFIVE_CLINT if SPL_RISCV_MMODE imply CMD_CPU imply SPL_CPU imply SPL_OPENSBI diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index d3a0b1d221..095484a635 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -18,7 +18,7 @@ struct arch_global_data { long boot_hart; /* boot hart id */ phys_addr_t firmware_fdt_addr; -#ifdef CONFIG_SIFIVE_CLINT +#if CONFIG_IS_ENABLED(SIFIVE_CLINT) void __iomem *clint; /* clint base address */ #endif #ifdef CONFIG_ANDES_PLIC diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index d08cbe9b79..c4cc41434b 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -11,7 +11,7 @@ obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o obj-$(CONFIG_CMD_GO) += boot.o obj-y += cache.o ifeq ($(CONFIG_$(SPL_)RISCV_MMODE),y) -obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint.o +obj-$(CONFIG_$(SPL_)SIFIVE_CLINT) += sifive_clint.o obj-$(CONFIG_ANDES_PLIC) += andes_plic.o else obj-$(CONFIG_SBI) += sbi.o diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index eb5c48cc6c..2ebdeab0ce 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -19,7 +19,7 @@ obj-$(CONFIG_RENESAS_OSTM_TIMER) += ostm_timer.o obj-$(CONFIG_RISCV_TIMER) += riscv_timer.o obj-$(CONFIG_ROCKCHIP_TIMER) += rockchip_timer.o obj-$(CONFIG_SANDBOX_TIMER) += sandbox_timer.o -obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint_timer.o +obj-$(CONFIG_$(SPL_)SIFIVE_CLINT) += sifive_clint_timer.o obj-$(CONFIG_STI_TIMER) += sti-timer.o obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o
- help
- bool
- depends on SPL_RISCV_MMODE help The SiFive CLINT block holds memory-mapped control and status registers associated with software and timer interrupts.
- imply SPL_SIFIVE_CLINT imply CMD_CPU imply SPL_CPU imply SPL_OPENSBI
- imply SIFIVE_CLINT if RISCV_MMODE
- imply SPL_SIFIVE_CLINT if SPL_RISCV_MMODE imply CMD_CPU imply SPL_CPU imply SPL_OPENSBI
Reviewed-by: Sean Anderson seanga2@gmail.com
Bin Meng
Sean Anderson
