[PATCH] mx28evk: Only keep the main target
mx28evk_auart_console_defconfig, mx28evk_nand_defconfig and mx28evk_spi_defconfig have not been converted to DM.
Keep only the main mx28evk_defconfig to ease maintenance.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/mx28evk/MAINTAINERS | 3 -- board/freescale/mx28evk/README | 34 +--------------- configs/mx28evk_auart_console_defconfig | 52 ------------------------ configs/mx28evk_nand_defconfig | 53 ------------------------- configs/mx28evk_spi_defconfig | 49 ----------------------- 5 files changed, 2 insertions(+), 189 deletions(-) delete mode 100644 configs/mx28evk_auart_console_defconfig delete mode 100644 configs/mx28evk_nand_defconfig delete mode 100644 configs/mx28evk_spi_defconfig
diff --git a/board/freescale/mx28evk/MAINTAINERS b/board/freescale/mx28evk/MAINTAINERS index c565010ccf6b..f20baa91c673 100644 --- a/board/freescale/mx28evk/MAINTAINERS +++ b/board/freescale/mx28evk/MAINTAINERS @@ -5,6 +5,3 @@ F: board/freescale/mx28evk/ F: arch/arm/dts/imx28-evk.dts F: include/configs/mx28evk.h F: configs/mx28evk_defconfig -F: configs/mx28evk_auart_console_defconfig -F: configs/mx28evk_nand_defconfig -F: configs/mx28evk_spi_defconfig diff --git a/board/freescale/mx28evk/README b/board/freescale/mx28evk/README index d32f0efb3326..bb07c896219e 100644 --- a/board/freescale/mx28evk/README +++ b/board/freescale/mx28evk/README @@ -23,40 +23,10 @@ To boot MX28EVK from an SD card, set the boot mode DIP switches as: * VDD 5V: To the left (off) * Hold Button: Down (off)
-To boot MX28EVK from SPI NOR flash, set the boot mode DIP switches as: - - * Boot Mode Select: 0 0 1 0 (Boot from SSP2) - * JTAG PSWITCH RESET: To the right (reset disabled) - * Battery Source: Down - * Wall 5V: Up - * VDD 5V: To the left (off) - * Hold Button: Down (off) - Environment Storage -------------------
-There are three targets for mx28evk: - -"make mx28evk_config" - store environment variables into MMC - -or - -"make mx28evk_nand_config" - store environment variables into NAND flash - -or - -"make mx28evk_spi_config" - store environment variables into SPI NOR flash - -Choose the target accordingly. - -Note: The mx28evk board does not come with a NAND flash populated from the -factory. It comes with an empty slot (U23), which allows the insertion of a -48-pin TSOP flash device. - -mx28evk does not come with SPI NOR flash populated from the factory either. -It is possible to solder a SOIC memory on U49 or use a DIP8 on J89. -To get SPI communication to work R320, R321,R322 and C178 need to be populated. -Look in the schematics for the proper component values. +"make mx28evk_defconfig" - store environment variables into MMC
Follow the instructions from doc/imx/common/mxs.txt to generate a bootable -SD card or to generate a binary to be flashed into SPI NOR. +SD card. diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig deleted file mode 100644 index 1f61dda5ed98..000000000000 --- a/configs/mx28evk_auart_console_defconfig +++ /dev/null @@ -1,52 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX28=y -CONFIG_SYS_TEXT_BASE=0x40002000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0x40000 -CONFIG_SPL_TEXT_BASE=0x00001000 -CONFIG_TARGET_MX28EVK=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE" -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_MISC_INIT=y -# CONFIG_SPL_FRAMEWORK is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" -CONFIG_CMD_UBI=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_MXS_GPIO=y -CONFIG_MMC_MXS=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXS=y -CONFIG_MII=y -CONFIG_CONS_INDEX=0 -CONFIG_SPI=y -CONFIG_USB=y -CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig deleted file mode 100644 index e40f83f92e01..000000000000 --- a/configs/mx28evk_nand_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX28=y -CONFIG_SYS_TEXT_BASE=0x40002000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0x300000 -CONFIG_SPL_TEXT_BASE=0x00001000 -CONFIG_TARGET_MX28EVK=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL=y -CONFIG_ENV_OFFSET_REDUND=0x380000 -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_MISC_INIT=y -# CONFIG_SPL_FRAMEWORK is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" -CONFIG_CMD_UBI=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_NAND=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_MXS_GPIO=y -CONFIG_MMC_MXS=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXS=y -CONFIG_MII=y -CONFIG_CONS_INDEX=0 -CONFIG_SPI=y -CONFIG_USB=y -CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig deleted file mode 100644 index 577515e34762..000000000000 --- a/configs/mx28evk_spi_defconfig +++ /dev/null @@ -1,49 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX28=y -CONFIG_SYS_TEXT_BASE=0x40002000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x4000 -CONFIG_SPL_TEXT_BASE=0x00001000 -CONFIG_TARGET_MX28EVK=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL=y -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_MISC_INIT=y -# CONFIG_SPL_FRAMEWORK is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" -CONFIG_CMD_UBI=y -CONFIG_ENV_OVERWRITE=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_MXS_GPIO=y -CONFIG_MMC_MXS=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXS=y -CONFIG_MII=y -CONFIG_CONS_INDEX=0 -CONFIG_SPI=y -CONFIG_USB=y -CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y
Fabio Estevam
