[PATCH v3] sysreset: add Qualcomm PSHOLD reset driver
Number of Qualcomm ARMv7 SoC-s did not use PSCI but rather used PSHOLD (Qualcomm Power Supply Hold Reset) bit to trigger reset or poweroff.
Qualcomm IPQ40XX is one of them, so provide a simple sysreset driver based on the upstream Linux one, it is DT compatible as well.
Signed-off-by: Robert Marko robert.marko@sartura.hr Reviewed-by: Caleb Connolly caleb.connolly@linaro.org --- Changes in v3: * Drop <common.h>
Changes in v2: * Use QCOM instead of MSM naming
drivers/sysreset/Kconfig | 6 +++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_qcom-pshold.c | 55 +++++++++++++++++++++++++ 3 files changed, 62 insertions(+) create mode 100644 drivers/sysreset/sysreset_qcom-pshold.c
diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index b64bfadb20..121194e441 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -240,6 +240,12 @@ config SYSRESET_RAA215300 help Add support for the system reboot via the Renesas RAA215300 PMIC.
+config SYSRESET_QCOM_PSHOLD + bool "Support sysreset for Qualcomm SoCs via PSHOLD" + depends on ARCH_IPQ40XX + help + Add support for the system reboot on Qualcomm SoCs via PSHOLD. + endif
endmenu diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index d59299aa31..a6a0584585 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -29,4 +29,5 @@ obj-$(CONFIG_SYSRESET_RESETCTL) += sysreset_resetctl.o obj-$(CONFIG_$(SPL_TPL_)SYSRESET_AT91) += sysreset_at91.o obj-$(CONFIG_$(SPL_TPL_)SYSRESET_X86) += sysreset_x86.o obj-$(CONFIG_SYSRESET_RAA215300) += sysreset_raa215300.o +obj-$(CONFIG_SYSRESET_QCOM_PSHOLD) += sysreset_qcom-pshold.o obj-$(CONFIG_TARGET_XTFPGA) += sysreset_xtfpga.o diff --git a/drivers/sysreset/sysreset_qcom-pshold.c b/drivers/sysreset/sysreset_qcom-pshold.c new file mode 100644 index 0000000000..4529047853 --- /dev/null +++ b/drivers/sysreset/sysreset_qcom-pshold.c @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Qualcomm PSHOLD reset driver + * + * Copyright (c) 2024 Sartura Ltd. + * + * Author: Robert Marko robert.marko@sartura.hr + * Based on the Linux msm-poweroff driver. + * + */ + +#include <dm.h> +#include <sysreset.h> +#include <asm/io.h> +#include <linux/delay.h> + +struct qcom_pshold_priv { + phys_addr_t base; +}; + +static int qcom_pshold_request(struct udevice *dev, enum sysreset_t type) +{ + struct qcom_pshold_priv *priv = dev_get_priv(dev); + + writel(0, priv->base); + mdelay(10000); + + return 0; +} + +static struct sysreset_ops qcom_pshold_ops = { + .request = qcom_pshold_request, +}; + +static int qcom_pshold_probe(struct udevice *dev) +{ + struct qcom_pshold_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr(dev); + return priv->base == FDT_ADDR_T_NONE ? -EINVAL : 0; +} + +static const struct udevice_id qcom_pshold_ids[] = { + { .compatible = "qcom,pshold", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(qcom_pshold) = { + .name = "qcom_pshold", + .id = UCLASS_SYSRESET, + .of_match = qcom_pshold_ids, + .probe = qcom_pshold_probe, + .priv_auto = sizeof(struct qcom_pshold_priv), + .ops = &qcom_pshold_ops, +};
Applied, thanks!
[1/1] sysreset: add Qualcomm PSHOLD reset driver https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/93738072...
Caleb Connolly
Robert Marko
