[U-Boot] Build breakage due to "Standalone Apps: Standalone apps should only need exports.h"
I was just rebasing and tweaking my board-support patch to send out again and I noticed that the latest U-Boot master branch does not build when the config option "CONFIG_CMD_SPI" is enabled: In file included from exports.c:41 [...]/include/_exports.h: In function 'jumptable_init': [...]/include/_exports.h:27: error: 'spi_init' undeclared (first use in this function) [...]/include/_exports.h:27: error: (Each undeclared identifier is reported only once [...]/include/_exports.h:27: error: for each function it appears in.) [...]/include/_exports.h:28: error: 'spi_setup_slave' undeclared (first use in this function) [...]/include/_exports.h:29: error: 'spi_free_slave' undeclared (first use in this function) [...]/include/_exports.h:30: error: 'spi_claim_bus' undeclared (first use in this function) [...]/include/_exports.h:31: error: 'spi_release_bus' undeclared (first use in this function) [...]/include/_exports.h:32: error: 'spi_xfer' undeclared (first use in this function)
From what I can tell, the only way to "fix" the exports.h header would
be to copy-paste much of "include/spi.h" (including the structure and most of the constants) into "include/exports.h".
Basically, if those SPI functions should be usable from outside code then the structure definition and the flags to be passed in all need to be available to the outside code as well.
Locally I just reverted the patch, but I'm not sure what the desired long-term fix should be, since it seems silly to have to duplicate spi.h in exports.h
Cheers, Kyle Moffett
-- Kyle Moffett eXMeritus Software Integrated Intelligence The Boeing Company
(703) 764-0925 (703) 812-1146 [FAX] Kyle.D.Moffett@boeing.com
As I understand it, one of the main purposes of standalone applications is to enable proprietary code to be run with U-Boot. In order to realize this objective, however, the code cannot be forced to include anything that is GPL-encumbered. Note that spi.h does not meet this criteria. So, either spi.h needs to be changed, or the spi interfaces need to be added to exports.h in a way that does not require any additional typedefs or structures from other files. I'm not sure which path is best, but my preference would be to keep the interface between standalone applications and U-Boot as clean and well-defined as possible. To me this means as few files as possible.
Regards, Mike Partington
On Wed, Dec 7, 2011 at 2:31 PM, Moffett, Kyle D Kyle.D.Moffett@boeing.comwrote:
From what I can tell, the only way to "fix" the exports.h header would be to copy-paste much of "include/spi.h" (including the structure and most of the constants) into "include/exports.h".
in general, i don't think your statement here is correct. the U-Boot license explicitly provides an exception for using the exported API.
also, please don't top post -mike
Mike Frysinger
Mike Partington
Moffett, Kyle D
