[PATCH] arm64: zynqmp: Print the secure boot status information in EL3
Confirm the secure boot configuration on the console.
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- arch/arm/mach-zynqmp/include/mach/hardware.h | 3 ++- board/xilinx/zynqmp/zynqmp.c | 16 +++++++++++++++- 2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index 3776499070..3d3ffa086e 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -139,7 +139,8 @@ struct apu_regs { #define ZYNQMP_SILICON_VER_SHIFT 0
struct csu_regs { - u32 reserved0[4]; + u32 status; + u32 reserved0[3]; u32 multi_boot; u32 reserved1[11]; u32 idcode; diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 1748fec2e4..b7d11630d1 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -355,6 +355,18 @@ static int multi_boot(void) return 0; }
+static void secure_boot(void) +{ + u32 status; + + status = readl(&csu_base->status); + if (status & (BIT(0) | BIT(1))) { + printf("Secure Boot:\t%s%s\n", + status & BIT(0) ? "authenticated" : "not authenticated", + status & BIT(1) ? ", encrypted" : ", not encrypted"); + } +} + #define PS_SYSMON_ANALOG_BUS_VAL 0x3210 #define PS_SYSMON_ANALOG_BUS_REG 0xFFA50914
@@ -391,8 +403,10 @@ int board_init(void) fpga_add(fpga_xilinx, &zynqmppl); #endif
- if (current_el() == 3) + if (current_el() == 3) { multi_boot(); + secure_boot(); + }
return 0; }
Hi Jorge,
On Thu, Jul 22, 2021 at 2:19 PM Jorge Ramirez-Ortiz jorge@foundries.io wrote:
struct csu_regs {
u32 reserved0[4];
u32 status;
u32 status;
secure_boot();
} return 0;
2.31.1
Reviewed-by: Igor Opaniuk igor.opaniuk@foundries.io
On 22/07/21, Jorge Ramirez-Ortiz wrote:
reminder
struct csu_regs {
- u32 reserved0[4];
- u32 status;
- u32 reserved0[3]; u32 multi_boot; u32 reserved1[11]; u32 idcode;
- u32 status;
- status = readl(&csu_base->status);
- if (status & (BIT(0) | BIT(1))) {
secure_boot();
2.31.1
struct csu_regs {
- u32 reserved0[4];
- u32 status;
- u32 status;
please create macros for these bits.
{} around are not needed.
Isn't this more space efficient? printf("Secure Boot:\t%sauthenticated, %sencrypted\n", status & BIT(0) ? "" : "not ", status & BIT(1) ? "" : "not ");
And as I see it is. aarch64: (for 1/1 boards) all -33.0 rodata -17.0 spl/u-boot-spl:all -33.0 spl/u-boot-spl:rodata -17.0 spl/u-boot-spl:text -16.0 text -16.0 xilinx_zynqmp_virt: all -33 rodata -17 spl/u-boot-spl:all -33 spl/u-boot-spl:rodata -17 spl/u-boot-spl:text -16 text -16 spl-u-boot-spl: add: 0/0, grow: 0/-1 bytes: 0/-16 (-16)
- if (current_el() == 3) { multi_boot();
secure_boot();
Please take a look at https://lists.denx.de/pipermail/u-boot/2021-July/456382.html I have changed multi_boot function a little bit.
Thanks, Michal
struct csu_regs {
- u32 reserved0[4];
- u32 status;
- u32 status;
ok
yep
ok with me
secure_boot();
ok
Thanks, Michal
-- Michal Simek, Ing. (M.Eng), OpenPGP -> KeyID: FE3D1F91 w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel - Xilinx Microblaze Maintainer of Linux kernel - Xilinx Zynq ARM and ZynqMP ARM64 SoCs U-Boot custodian - Xilinx Microblaze/Zynq/ZynqMP/Versal SoCs
Igor Opaniuk
Jorge Ramirez-Ortiz
Jorge Ramirez-Ortiz, Foundries
Michal Simek
