[PATCH v2] arm: dts: k3-j7200: Move to OF_UPSTREAM
Move to using OF_UPSTREAM config and thus using the devicetree-rebasing subtree.
Signed-off-by: Aniket Limaye a-limaye@ti.com ---
Boot logs: https://gist.github.com/aniket-l/aab91bb12d2495c54da094fca49c369f
Changes in v2: - Rebased to next - Removed dependency on binman templating series [1] as per [2]
[1]: https://lore.kernel.org/all/20240322131011.1029620-1-n-francis@ti.com/ [2]: https://lore.kernel.org/u-boot/20240520095916.1809962-1-n-francis@ti.com/
--- arch/arm/dts/Makefile | 1 - arch/arm/dts/k3-j7200-binman.dtsi | 2 +- .../k3-j7200-common-proc-board-u-boot.dtsi | 14 +- arch/arm/dts/k3-j7200-common-proc-board.dts | 396 ----- arch/arm/dts/k3-j7200-main.dtsi | 1284 ----------------- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 647 --------- arch/arm/dts/k3-j7200-som-p0.dtsi | 327 ----- arch/arm/dts/k3-j7200-thermal.dtsi | 47 - arch/arm/dts/k3-j7200.dtsi | 164 --- configs/j7200_evm_a72_defconfig | 3 +- 10 files changed, 8 insertions(+), 2877 deletions(-) delete mode 100644 arch/arm/dts/k3-j7200-common-proc-board.dts delete mode 100644 arch/arm/dts/k3-j7200-main.dtsi delete mode 100644 arch/arm/dts/k3-j7200-mcu-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-j7200-som-p0.dtsi delete mode 100644 arch/arm/dts/k3-j7200-thermal.dtsi delete mode 100644 arch/arm/dts/k3-j7200.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f7032f1e175..ea8fee8e25c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1194,7 +1194,6 @@ dtb-$(CONFIG_SOC_K3_AM654) += \
dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-r5-common-proc-board.dtb \ - k3-j7200-common-proc-board.dtb \ k3-j7200-r5-common-proc-board.dtb \ k3-j721e-sk.dtb \ k3-j721e-r5-sk.dtb \ diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi index 06db8659876..b6e0aa37971 100644 --- a/arch/arm/dts/k3-j7200-binman.dtsi +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -180,7 +180,7 @@
#ifdef CONFIG_TARGET_J7200_A72_EVM
-#define SPL_J7200_EVM_DTB "spl/dts/k3-j7200-common-proc-board.dtb" +#define SPL_J7200_EVM_DTB "spl/dts/ti/k3-j7200-common-proc-board.dtb" #define J7200_EVM_DTB "u-boot.dtb"
&binman { diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 485f17c5f06..045ef170e17 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -26,8 +26,12 @@ &cbass_mcu_wakeup { bootph-all;
- chipid@43000014 { + wkup_conf: bus@43000000 { bootph-all; + + chipid: chipid@14 { + bootph-all; + }; }; };
@@ -40,14 +44,6 @@ };
&mcu_udmap { - reg = <0x0 0x285c0000 0x0 0x100>, - <0x0 0x284c0000 0x0 0x4000>, - <0x0 0x2a800000 0x0 0x40000>, - <0x0 0x284a0000 0x0 0x4000>, - <0x0 0x2aa00000 0x0 0x40000>, - <0x0 0x28400000 0x0 0x2000>; - reg-names = "gcfg", "rchan", "rchanrt", "tchan", - "tchanrt", "rflow"; bootph-all; };
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts deleted file mode 100644 index cee2b4b0eb8..00000000000 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ /dev/null @@ -1,396 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/dts-v1/; - -#include "k3-j7200-som-p0.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/net/ti-dp83867.h> -#include <dt-bindings/phy/phy.h> - -#include "k3-serdes.h" - -/ { - compatible = "ti,j7200-evm", "ti,j7200"; - model = "Texas Instruments J7200 EVM"; - - aliases { - serial0 = &wkup_uart0; - serial1 = &mcu_uart0; - serial2 = &main_uart0; - serial3 = &main_uart1; - serial5 = &main_uart3; - mmc0 = &main_sdhci0; - mmc1 = &main_sdhci1; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - evm_12v0: fixedregulator-evm12v0 { - /* main supply */ - compatible = "regulator-fixed"; - regulator-name = "evm_12v0"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - regulator-boot-on; - }; - - vsys_3v3: fixedregulator-vsys3v3 { - /* Output of LM5140 */ - compatible = "regulator-fixed"; - regulator-name = "vsys_3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&evm_12v0>; - regulator-always-on; - regulator-boot-on; - }; - - vsys_5v0: fixedregulator-vsys5v0 { - /* Output of LM5140 */ - compatible = "regulator-fixed"; - regulator-name = "vsys_5v0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&evm_12v0>; - regulator-always-on; - regulator-boot-on; - }; - - vdd_mmc1: fixedregulator-sd { - /* Output of TPS22918 */ - compatible = "regulator-fixed"; - regulator-name = "vdd_mmc1"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - enable-active-high; - vin-supply = <&vsys_3v3>; - gpio = <&exp2 2 GPIO_ACTIVE_HIGH>; - }; - - vdd_sd_dv: gpio-regulator-TLV71033 { - /* Output of TLV71033 */ - compatible = "regulator-gpio"; - regulator-name = "tlv71033"; - pinctrl-names = "default"; - pinctrl-0 = <&vdd_sd_dv_pins_default>; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - vin-supply = <&vsys_5v0>; - gpios = <&main_gpio0 55 GPIO_ACTIVE_HIGH>; - states = <1800000 0x0>, - <3300000 0x1>; - }; -}; - -&wkup_pmx0 { - mcu_uart0_pins_default: mcu-uart0-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) MCU_UART0_RXD */ - J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) MCU_UART0_TXD */ - J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) MCU_UART0_CTSn */ - J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) MCU_UART0_RTSn */ - >; - }; - - wkup_uart0_pins_default: wkup-uart0-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ - J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ - >; - }; -}; - -&wkup_pmx2 { - mcu_cpsw_pins_default: mcu-cpsw-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ - J721E_WKUP_IOPAD(0x0004, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ - J721E_WKUP_IOPAD(0x0008, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ - J721E_WKUP_IOPAD(0x000c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ - J721E_WKUP_IOPAD(0x0010, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ - J721E_WKUP_IOPAD(0x0014, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ - J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ - J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ - J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ - J721E_WKUP_IOPAD(0x002c, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ - J721E_WKUP_IOPAD(0x0018, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ - J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ - >; - }; - - wkup_gpio_pins_default: wkup-gpio-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x70, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */ - >; - }; - - mcu_mdio_pins_default: mcu-mdio1-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0034, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ - J721E_WKUP_IOPAD(0x0030, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ - >; - }; -}; - -&main_pmx0 { - main_uart0_pins_default: main-uart0-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ - J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ - J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ - J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ - >; - }; - - main_uart1_pins_default: main-uart1-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0xb8, PIN_INPUT, 0) /* (T18) UART1_RXD */ - J721E_IOPAD(0xbc, PIN_INPUT, 0) /* (T20) UART1_TXD */ - >; - }; - - main_uart3_pins_default: main-uart3-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0x60, PIN_INPUT, 11) /* (T15) MCAN8_TX.UART3_CTSn */ - J721E_IOPAD(0x30, PIN_INPUT, 11) /* (Y18) MCAN2_TX.UART3_RXD */ - >; - }; - - main_i2c1_pins_default: main-i2c1-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0xdc, PIN_INPUT_PULLUP, 3) /* (U3) ECAP0_IN_APWM_OUT.I2C1_SCL */ - J721E_IOPAD(0xe0, PIN_INPUT_PULLUP, 3) /* (T3) EXT_REFCLK1.I2C1_SDA */ - >; - }; - - main_mmc1_pins_default: main-mmc1-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ - J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ - J721E_IOPAD(0xfc, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ - J721E_IOPAD(0xf8, PIN_INPUT, 0) /* (M19) MMC1_DAT0 */ - J721E_IOPAD(0xf4, PIN_INPUT, 0) /* (N21) MMC1_DAT1 */ - J721E_IOPAD(0xf0, PIN_INPUT, 0) /* (N20) MMC1_DAT2 */ - J721E_IOPAD(0xec, PIN_INPUT, 0) /* (N19) MMC1_DAT3 */ - J721E_IOPAD(0xe4, PIN_INPUT, 8) /* (V1) TIMER_IO0.MMC1_SDCD */ - >; - }; - - vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ - >; - }; -}; - -&main_pmx1 { - main_usbss0_pins_default: main-usbss0-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ - >; - }; -}; - -&wkup_uart0 { - /* Wakeup UART is used by System firmware */ - status = "reserved"; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; -}; - -&mcu_uart0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_uart0_pins_default>; - clock-frequency = <96000000>; -}; - -&main_uart0 { - status = "okay"; - /* Shared with ATF on this platform */ - power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; -}; - -&main_uart1 { - status = "okay"; - /* Default pinmux */ - pinctrl-names = "default"; - pinctrl-0 = <&main_uart1_pins_default>; -}; - -&main_uart2 { - /* MAIN UART 2 is used by R5F firmware */ - status = "reserved"; -}; - -&main_uart3 { - /* Shared with MCAN Interface */ - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart3_pins_default>; -}; - -&main_gpio0 { - status = "okay"; -}; - -&wkup_gpio0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_gpio_pins_default>; -}; - -&mcu_cpsw { - pinctrl-names = "default"; - pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>; -}; - -&davinci_mdio { - phy0: ethernet-phy@0 { - reg = <0>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; - }; -}; - -&cpsw_port1 { - phy-mode = "rgmii-rxid"; - phy-handle = <&phy0>; -}; - -&main_i2c0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - exp1: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; - - exp2: gpio@22 { - compatible = "ti,tca6424"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -/* - * The j7200 CPB board is identical to the CPB used for J721E, the SOMs can be - * swapped on the CPB. - * - * main_i2c1 of J7200 is connected to the CPB i2c bus labeled as i2c3. - * The i2c1 of the CPB (as it is labeled) is not connected to j7200. - */ -&main_i2c1 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c1_pins_default>; - clock-frequency = <400000>; - - exp3: gpio@20 { - compatible = "ti,tca6408"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = "CODEC_RSTz", "CODEC_SPARE1", "UB926_RESETn", - "UB926_LOCK", "UB926_PWR_SW_CNTRL", - "UB926_TUNER_RESET", "UB926_GPIO_SPARE", ""; - }; -}; - -&main_sdhci0 { - /* eMMC */ - status = "okay"; - non-removable; - ti,driver-strength-ohm = <50>; - disable-wp; -}; - -&main_sdhci1 { - /* SD card */ - status = "okay"; - pinctrl-0 = <&main_mmc1_pins_default>; - pinctrl-names = "default"; - vmmc-supply = <&vdd_mmc1>; - vqmmc-supply = <&vdd_sd_dv>; - ti,driver-strength-ohm = <50>; - disable-wp; -}; - -&serdes_ln_ctrl { - idle-states = <J7200_SERDES0_LANE0_PCIE1_LANE0>, <J7200_SERDES0_LANE1_PCIE1_LANE1>, - <J7200_SERDES0_LANE2_QSGMII_LANE1>, <J7200_SERDES0_LANE3_IP4_UNUSED>; -}; - -&usb_serdes_mux { - idle-states = <1>; /* USB0 to SERDES lane 3 */ -}; - -&usbss0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_usbss0_pins_default>; - ti,vbus-divider; - ti,usb2-only; -}; - -&usb0 { - dr_mode = "otg"; - maximum-speed = "high-speed"; -}; - -&tscadc0 { - adc { - ti,adc-channels = <0 1 2 3 4 5 6 7>; - }; -}; - -&serdes_refclk { - clock-frequency = <100000000>; -}; - -&serdes0 { - serdes0_pcie_link: phy@0 { - reg = <0>; - cdns,num-lanes = <2>; - #phy-cells = <0>; - cdns,phy-type = <PHY_TYPE_PCIE>; - resets = <&serdes_wiz0 1>, <&serdes_wiz0 2>; - }; - - serdes0_qsgmii_link: phy@1 { - reg = <2>; - cdns,num-lanes = <1>; - #phy-cells = <0>; - cdns,phy-type = <PHY_TYPE_QSGMII>; - resets = <&serdes_wiz0 3>; - }; -}; - -&pcie1_rc { - reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>; - phys = <&serdes0_pcie_link>; - phy-names = "pcie-phy"; - num-lanes = <2>; -}; - -&pcie1_ep { - phys = <&serdes0_pcie_link>; - phy-names = "pcie-phy"; - num-lanes = <2>; - status = "disabled"; -}; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi deleted file mode 100644 index 264913f8328..00000000000 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ /dev/null @@ -1,1284 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for J7200 SoC Family Main Domain peripherals - * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/ { - serdes_refclk: serdes-refclk { - #clock-cells = <0>; - compatible = "fixed-clock"; - }; -}; - -&cbass_main { - msmc_ram: sram@70000000 { - compatible = "mmio-sram"; - reg = <0x00 0x70000000 0x00 0x100000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0x70000000 0x100000>; - - atf-sram@0 { - reg = <0x00 0x20000>; - }; - }; - - scm_conf: scm-conf@100000 { - compatible = "ti,j721e-system-controller", "syscon", "simple-mfd"; - reg = <0x00 0x00100000 0x00 0x1c000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0x00100000 0x1c000>; - - serdes_ln_ctrl: mux-controller@4080 { - compatible = "mmio-mux"; - #mux-control-cells = <1>; - mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */ - <0x4088 0x3>, <0x408c 0x3>; /* SERDES0 lane2/3 select */ - }; - - cpsw0_phy_gmii_sel: phy@4044 { - compatible = "ti,j7200-cpsw5g-phy-gmii-sel"; - ti,qsgmii-main-ports = <1>; - reg = <0x4044 0x10>; - #phy-cells = <1>; - }; - - usb_serdes_mux: mux-controller@4000 { - compatible = "mmio-mux"; - #mux-control-cells = <1>; - mux-reg-masks = <0x4000 0x8000000>; /* USB0 to SERDES0 lane 1/3 mux */ - }; - }; - - gic500: interrupt-controller@1800000 { - compatible = "arm,gic-v3"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ - <0x00 0x01900000 0x00 0x100000>, /* GICR */ - <0x00 0x6f000000 0x00 0x2000>, /* GICC */ - <0x00 0x6f010000 0x00 0x1000>, /* GICH */ - <0x00 0x6f020000 0x00 0x2000>; /* GICV */ - - /* vcpumntirq: virtual CPU interface maintenance interrupt */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - - gic_its: msi-controller@1820000 { - compatible = "arm,gic-v3-its"; - reg = <0x00 0x01820000 0x00 0x10000>; - socionext,synquacer-pre-its = <0x1000000 0x400000>; - msi-controller; - #msi-cells = <1>; - }; - }; - - main_gpio_intr: interrupt-controller@a00000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x00a00000 0x00 0x800>; - ti,intr-trigger-type = <1>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <131>; - ti,interrupt-ranges = <8 392 56>; - }; - - main_navss: bus@30000000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>; - ti,sci-dev-id = <199>; - dma-coherent; - dma-ranges; - - main_navss_intr: interrupt-controller@310e0000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x310e0000 0x00 0x4000>; - ti,intr-trigger-type = <4>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <213>; - ti,interrupt-ranges = <0 64 64>, - <64 448 64>, - <128 672 64>; - }; - - main_udmass_inta: msi-controller@33d00000 { - compatible = "ti,sci-inta"; - reg = <0x00 0x33d00000 0x00 0x100000>; - interrupt-controller; - #interrupt-cells = <0>; - interrupt-parent = <&main_navss_intr>; - msi-controller; - ti,sci = <&dmsc>; - ti,sci-dev-id = <209>; - ti,interrupt-ranges = <0 0 256>; - }; - - secure_proxy_main: mailbox@32c00000 { - compatible = "ti,am654-secure-proxy"; - #mbox-cells = <1>; - reg-names = "target_data", "rt", "scfg"; - reg = <0x00 0x32c00000 0x00 0x100000>, - <0x00 0x32400000 0x00 0x100000>, - <0x00 0x32800000 0x00 0x100000>; - interrupt-names = "rx_011"; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - }; - - hwspinlock: spinlock@30e00000 { - compatible = "ti,am654-hwspinlock"; - reg = <0x00 0x30e00000 0x00 0x1000>; - #hwlock-cells = <1>; - }; - - mailbox0_cluster0: mailbox@31f80000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f80000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster1: mailbox@31f81000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f81000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster2: mailbox@31f82000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f82000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster3: mailbox@31f83000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f83000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster4: mailbox@31f84000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f84000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster5: mailbox@31f85000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f85000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster6: mailbox@31f86000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f86000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster7: mailbox@31f87000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f87000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster8: mailbox@31f88000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f88000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster9: mailbox@31f89000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f89000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster10: mailbox@31f8a000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f8a000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - mailbox0_cluster11: mailbox@31f8b000 { - compatible = "ti,am654-mailbox"; - reg = <0x00 0x31f8b000 0x00 0x200>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - interrupt-parent = <&main_navss_intr>; - status = "disabled"; - }; - - main_ringacc: ringacc@3c000000 { - compatible = "ti,am654-navss-ringacc"; - reg = <0x00 0x3c000000 0x00 0x400000>, - <0x00 0x38000000 0x00 0x400000>, - <0x00 0x31120000 0x00 0x100>, - <0x00 0x33000000 0x00 0x40000>, - <0x00 0x31080000 0x00 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; - ti,num-rings = <1024>; - ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ - ti,sci = <&dmsc>; - ti,sci-dev-id = <211>; - msi-parent = <&main_udmass_inta>; - }; - - main_udmap: dma-controller@31150000 { - compatible = "ti,j721e-navss-main-udmap"; - reg = <0x00 0x31150000 0x00 0x100>, - <0x00 0x34000000 0x00 0x100000>, - <0x00 0x35000000 0x00 0x100000>; - reg-names = "gcfg", "rchanrt", "tchanrt"; - msi-parent = <&main_udmass_inta>; - #dma-cells = <1>; - - ti,sci = <&dmsc>; - ti,sci-dev-id = <212>; - ti,ringacc = <&main_ringacc>; - - ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */ - <0x0f>, /* TX_HCHAN */ - <0x10>; /* TX_UHCHAN */ - ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */ - <0x0b>, /* RX_HCHAN */ - <0x0c>; /* RX_UHCHAN */ - ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */ - }; - - cpts@310d0000 { - compatible = "ti,j721e-cpts"; - reg = <0x00 0x310d0000 0x00 0x400>; - reg-names = "cpts"; - clocks = <&k3_clks 201 1>; - clock-names = "cpts"; - interrupts-extended = <&main_navss_intr 391>; - interrupt-names = "cpts"; - ti,cpts-periodic-outputs = <6>; - ti,cpts-ext-ts-inputs = <8>; - }; - }; - - cpsw0: ethernet@c000000 { - compatible = "ti,j7200-cpswxg-nuss"; - #address-cells = <2>; - #size-cells = <2>; - reg = <0x00 0xc000000 0x00 0x200000>; - reg-names = "cpsw_nuss"; - ranges = <0x00 0x00 0x00 0xc000000 0x00 0x200000>; - clocks = <&k3_clks 19 33>; - clock-names = "fck"; - power-domains = <&k3_pds 19 TI_SCI_PD_EXCLUSIVE>; - - dmas = <&main_udmap 0xca00>, - <&main_udmap 0xca01>, - <&main_udmap 0xca02>, - <&main_udmap 0xca03>, - <&main_udmap 0xca04>, - <&main_udmap 0xca05>, - <&main_udmap 0xca06>, - <&main_udmap 0xca07>, - <&main_udmap 0x4a00>; - dma-names = "tx0", "tx1", "tx2", "tx3", - "tx4", "tx5", "tx6", "tx7", - "rx"; - - status = "disabled"; - - ethernet-ports { - #address-cells = <1>; - #size-cells = <0>; - cpsw0_port1: port@1 { - reg = <1>; - ti,mac-only; - label = "port1"; - status = "disabled"; - }; - - cpsw0_port2: port@2 { - reg = <2>; - ti,mac-only; - label = "port2"; - status = "disabled"; - }; - - cpsw0_port3: port@3 { - reg = <3>; - ti,mac-only; - label = "port3"; - status = "disabled"; - }; - - cpsw0_port4: port@4 { - reg = <4>; - ti,mac-only; - label = "port4"; - status = "disabled"; - }; - }; - - cpsw5g_mdio: mdio@f00 { - compatible = "ti,cpsw-mdio","ti,davinci_mdio"; - reg = <0x00 0xf00 0x00 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&k3_clks 19 33>; - clock-names = "fck"; - bus_freq = <1000000>; - status = "disabled"; - }; - - cpts@3d000 { - compatible = "ti,j721e-cpts"; - reg = <0x00 0x3d000 0x00 0x400>; - clocks = <&k3_clks 19 16>; - clock-names = "cpts"; - interrupts-extended = <&gic500 GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "cpts"; - ti,cpts-ext-ts-inputs = <4>; - ti,cpts-periodic-outputs = <2>; - }; - }; - - /* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */ - main_timerio_input: pinctrl@104200 { - compatible = "pinctrl-single"; - reg = <0x0 0x104200 0x0 0x50>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0x000001ff>; - }; - - /* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */ - main_timerio_output: pinctrl@104280 { - compatible = "pinctrl-single"; - reg = <0x0 0x104280 0x0 0x20>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0x0000001f>; - }; - - main_pmx0: pinctrl@11c000 { - compatible = "pinctrl-single"; - /* Proxy 0 addressing */ - reg = <0x00 0x11c000 0x00 0x10c>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - main_pmx1: pinctrl@11c11c { - compatible = "pinctrl-single"; - /* Proxy 0 addressing */ - reg = <0x00 0x11c11c 0x00 0xc>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - main_uart0: serial@2800000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02800000 0x00 0x100>; - interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 146 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart1: serial@2810000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02810000 0x00 0x100>; - interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 278 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart2: serial@2820000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02820000 0x00 0x100>; - interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 279 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart3: serial@2830000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02830000 0x00 0x100>; - interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 280 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart4: serial@2840000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02840000 0x00 0x100>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 281 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart5: serial@2850000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02850000 0x00 0x100>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 282 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart6: serial@2860000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02860000 0x00 0x100>; - interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 283 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart7: serial@2870000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02870000 0x00 0x100>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 284 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart8: serial@2880000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02880000 0x00 0x100>; - interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 285 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart9: serial@2890000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x02890000 0x00 0x100>; - interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 286 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_i2c0: i2c@2000000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2000000 0x00 0x100>; - interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 187 1>; - power-domains = <&k3_pds 187 TI_SCI_PD_SHARED>; - status = "disabled"; - }; - - main_i2c1: i2c@2010000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2010000 0x00 0x100>; - interrupts = <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 188 1>; - power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - main_i2c2: i2c@2020000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2020000 0x00 0x100>; - interrupts = <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 189 1>; - power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - main_i2c3: i2c@2030000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2030000 0x00 0x100>; - interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 190 1>; - power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - main_i2c4: i2c@2040000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2040000 0x00 0x100>; - interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 191 1>; - power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - main_i2c5: i2c@2050000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2050000 0x00 0x100>; - interrupts = <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 192 1>; - power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - main_i2c6: i2c@2060000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2060000 0x00 0x100>; - interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 193 1>; - power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - main_sdhci0: mmc@4f80000 { - compatible = "ti,j7200-sdhci-8bit", "ti,j721e-sdhci-8bit"; - reg = <0x00 0x04f80000 0x00 0x260>, <0x00 0x4f88000 0x00 0x134>; - interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>; - clock-names = "clk_ahb", "clk_xin"; - clocks = <&k3_clks 91 0>, <&k3_clks 91 3>; - ti,otap-del-sel-legacy = <0x0>; - ti,otap-del-sel-mmc-hs = <0x0>; - ti,otap-del-sel-ddr52 = <0x6>; - ti,otap-del-sel-hs200 = <0x8>; - ti,otap-del-sel-hs400 = <0x5>; - ti,itap-del-sel-legacy = <0x10>; - ti,itap-del-sel-mmc-hs = <0xa>; - ti,strobe-sel = <0x77>; - ti,clkbuf-sel = <0x7>; - ti,trm-icp = <0x8>; - bus-width = <8>; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - mmc-hs400-1_8v; - dma-coherent; - status = "disabled"; - }; - - main_sdhci1: mmc@4fb0000 { - compatible = "ti,j7200-sdhci-4bit", "ti,j721e-sdhci-4bit"; - reg = <0x00 0x04fb0000 0x00 0x260>, <0x00 0x4fb8000 0x00 0x134>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 92 TI_SCI_PD_EXCLUSIVE>; - clock-names = "clk_ahb", "clk_xin"; - clocks = <&k3_clks 92 1>, <&k3_clks 92 2>; - ti,otap-del-sel-legacy = <0x0>; - ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x5>; - ti,otap-del-sel-ddr50 = <0xc>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; - ti,clkbuf-sel = <0x7>; - ti,trm-icp = <0x8>; - dma-coherent; - status = "disabled"; - }; - - serdes_wiz0: wiz@5060000 { - compatible = "ti,j721e-wiz-10g"; - #address-cells = <1>; - #size-cells = <1>; - power-domains = <&k3_pds 292 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 292 11>, <&k3_clks 292 85>, <&serdes_refclk>; - clock-names = "fck", "core_ref_clk", "ext_ref_clk"; - num-lanes = <4>; - #reset-cells = <1>; - ranges = <0x5060000 0x0 0x5060000 0x10000>; - - assigned-clocks = <&k3_clks 292 85>; - assigned-clock-parents = <&k3_clks 292 89>; - - wiz0_pll0_refclk: pll0-refclk { - clocks = <&k3_clks 292 85>, <&serdes_refclk>; - clock-output-names = "wiz0_pll0_refclk"; - #clock-cells = <0>; - assigned-clocks = <&wiz0_pll0_refclk>; - assigned-clock-parents = <&k3_clks 292 85>; - }; - - wiz0_pll1_refclk: pll1-refclk { - clocks = <&k3_clks 292 85>, <&serdes_refclk>; - clock-output-names = "wiz0_pll1_refclk"; - #clock-cells = <0>; - assigned-clocks = <&wiz0_pll1_refclk>; - assigned-clock-parents = <&k3_clks 292 85>; - }; - - wiz0_refclk_dig: refclk-dig { - clocks = <&k3_clks 292 85>, <&serdes_refclk>; - clock-output-names = "wiz0_refclk_dig"; - #clock-cells = <0>; - assigned-clocks = <&wiz0_refclk_dig>; - assigned-clock-parents = <&k3_clks 292 85>; - }; - - wiz0_cmn_refclk_dig_div: cmn-refclk-dig-div { - clocks = <&wiz0_refclk_dig>; - #clock-cells = <0>; - }; - - serdes0: serdes@5060000 { - compatible = "ti,j721e-serdes-10g"; - reg = <0x05060000 0x00010000>; - reg-names = "torrent_phy"; - resets = <&serdes_wiz0 0>; - reset-names = "torrent_reset"; - clocks = <&wiz0_pll0_refclk>; - clock-names = "refclk"; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - pcie1_rc: pcie@2910000 { - compatible = "ti,j7200-pcie-host", "ti,j721e-pcie-host"; - reg = <0x00 0x02910000 0x00 0x1000>, - <0x00 0x02917000 0x00 0x400>, - <0x00 0x0d800000 0x00 0x00800000>, - <0x00 0x18000000 0x00 0x00001000>; - reg-names = "intd_cfg", "user_cfg", "reg", "cfg"; - interrupt-names = "link_state"; - interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>; - device_type = "pci"; - ti,syscon-pcie-ctrl = <&scm_conf 0x4074>; - max-link-speed = <3>; - num-lanes = <4>; - power-domains = <&k3_pds 240 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 240 6>; - clock-names = "fck"; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x0 0xff>; - cdns,no-bar-match-nbits = <64>; - vendor-id = <0x104c>; - device-id = <0xb00f>; - msi-map = <0x0 &gic_its 0x0 0x10000>; - dma-coherent; - ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>, - <0x02000000 0x0 0x18011000 0x00 0x18011000 0x0 0x7fef000>; - dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>; - }; - - pcie1_ep: pcie-ep@2910000 { - compatible = "ti,j7200-pcie-ep", "ti,j721e-pcie-ep"; - reg = <0x00 0x02910000 0x00 0x1000>, - <0x00 0x02917000 0x00 0x400>, - <0x00 0x0d800000 0x00 0x00800000>, - <0x00 0x18000000 0x00 0x08000000>; - reg-names = "intd_cfg", "user_cfg", "reg", "mem"; - interrupt-names = "link_state"; - interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>; - ti,syscon-pcie-ctrl = <&scm_conf 0x4074>; - max-link-speed = <3>; - num-lanes = <4>; - power-domains = <&k3_pds 240 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 240 6>; - clock-names = "fck"; - max-functions = /bits/ 8 <6>; - max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>; - dma-coherent; - }; - - usbss0: cdns-usb@4104000 { - compatible = "ti,j721e-usb"; - reg = <0x00 0x4104000 0x00 0x100>; - dma-coherent; - power-domains = <&k3_pds 288 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 288 12>, <&k3_clks 288 3>; - clock-names = "ref", "lpm"; - assigned-clocks = <&k3_clks 288 12>; /* USB2_REFCLK */ - assigned-clock-parents = <&k3_clks 288 13>; /* HFOSC0 */ - #address-cells = <2>; - #size-cells = <2>; - ranges; - - usb0: usb@6000000 { - compatible = "cdns,usb3"; - reg = <0x00 0x6000000 0x00 0x10000>, - <0x00 0x6010000 0x00 0x10000>, - <0x00 0x6020000 0x00 0x10000>; - reg-names = "otg", "xhci", "dev"; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ - <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */ - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; /* otgirq.0 */ - interrupt-names = "host", - "peripheral", - "otg"; - maximum-speed = "super-speed"; - dr_mode = "otg"; - cdns,phyrst-a-enable; - }; - }; - - main_gpio0: gpio@600000 { - compatible = "ti,j721e-gpio", "ti,keystone-gpio"; - reg = <0x00 0x00600000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <145>, <146>, <147>, <148>, - <149>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <69>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 105 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - main_gpio2: gpio@610000 { - compatible = "ti,j721e-gpio", "ti,keystone-gpio"; - reg = <0x00 0x00610000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <154>, <155>, <156>, <157>, - <158>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <69>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 107 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - main_gpio4: gpio@620000 { - compatible = "ti,j721e-gpio", "ti,keystone-gpio"; - reg = <0x00 0x00620000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <163>, <164>, <165>, <166>, - <167>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <69>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 109 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 109 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - main_gpio6: gpio@630000 { - compatible = "ti,j721e-gpio", "ti,keystone-gpio"; - reg = <0x00 0x00630000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <172>, <173>, <174>, <175>, - <176>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <69>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 111 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 111 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - main_spi0: spi@2100000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02100000 0x00 0x400>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 266 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 266 1>; - status = "disabled"; - }; - - main_spi1: spi@2110000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02110000 0x00 0x400>; - interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 267 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 267 1>; - status = "disabled"; - }; - - main_spi2: spi@2120000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02120000 0x00 0x400>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 268 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 268 1>; - status = "disabled"; - }; - - main_spi3: spi@2130000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02130000 0x00 0x400>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 269 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 269 1>; - status = "disabled"; - }; - - main_spi4: spi@2140000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02140000 0x00 0x400>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 270 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 270 1>; - status = "disabled"; - }; - - main_spi5: spi@2150000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02150000 0x00 0x400>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 271 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 271 1>; - status = "disabled"; - }; - - main_spi6: spi@2160000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02160000 0x00 0x400>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 272 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 272 1>; - status = "disabled"; - }; - - main_spi7: spi@2170000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x02170000 0x00 0x400>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 273 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 273 1>; - status = "disabled"; - }; - - watchdog0: watchdog@2200000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x0 0x2200000 0x0 0x100>; - clocks = <&k3_clks 252 1>; - power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 252 1>; - assigned-clock-parents = <&k3_clks 252 5>; - }; - - watchdog1: watchdog@2210000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x0 0x2210000 0x0 0x100>; - clocks = <&k3_clks 253 1>; - power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 253 1>; - assigned-clock-parents = <&k3_clks 253 5>; - }; - - main_timer0: timer@2400000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2400000 0x00 0x400>; - interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 49 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 49 1>; - assigned-clock-parents = <&k3_clks 49 2>; - power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer1: timer@2410000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2410000 0x00 0x400>; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 50 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 50 1>, <&k3_clks 313 0>; - assigned-clock-parents = <&k3_clks 50 2>, <&k3_clks 313 1>; - power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer2: timer@2420000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2420000 0x00 0x400>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 51 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 51 1>; - assigned-clock-parents = <&k3_clks 51 2>; - power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer3: timer@2430000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2430000 0x00 0x400>; - interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 52 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 52 1>, <&k3_clks 314 0>; - assigned-clock-parents = <&k3_clks 52 2>, <&k3_clks 314 1>; - power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer4: timer@2440000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2440000 0x00 0x400>; - interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 53 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 53 1>; - assigned-clock-parents = <&k3_clks 53 2>; - power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer5: timer@2450000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2450000 0x00 0x400>; - interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 54 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 54 1>, <&k3_clks 315 0>; - assigned-clock-parents = <&k3_clks 54 2>, <&k3_clks 315 1>; - power-domains = <&k3_pds 54 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer6: timer@2460000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2460000 0x00 0x400>; - interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 55 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 55 1>; - assigned-clock-parents = <&k3_clks 55 2>; - power-domains = <&k3_pds 55 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer7: timer@2470000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2470000 0x00 0x400>; - interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 57 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 57 1>, <&k3_clks 316 0>; - assigned-clock-parents = <&k3_clks 57 2>, <&k3_clks 316 1>; - power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer8: timer@2480000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2480000 0x00 0x400>; - interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 58 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 58 1>; - assigned-clock-parents = <&k3_clks 58 2>; - power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer9: timer@2490000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2490000 0x00 0x400>; - interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 59 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 59 1>, <&k3_clks 317 0>; - assigned-clock-parents = <&k3_clks 59 2>, <&k3_clks 317 1>; - power-domains = <&k3_pds 59 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer10: timer@24a0000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x24a0000 0x00 0x400>; - interrupts = <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 60 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 60 1>; - assigned-clock-parents = <&k3_clks 60 2>; - power-domains = <&k3_pds 60 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer11: timer@24b0000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x24b0000 0x00 0x400>; - interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 62 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 62 1>, <&k3_clks 318 0>; - assigned-clock-parents = <&k3_clks 62 2>, <&k3_clks 318 1>; - power-domains = <&k3_pds 62 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer12: timer@24c0000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x24c0000 0x00 0x400>; - interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 63 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 63 1>; - assigned-clock-parents = <&k3_clks 63 2>; - power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer13: timer@24d0000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x24d0000 0x00 0x400>; - interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 64 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 64 1>, <&k3_clks 319 0>; - assigned-clock-parents = <&k3_clks 64 2>, <&k3_clks 319 1>; - power-domains = <&k3_pds 64 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer14: timer@24e0000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x24e0000 0x00 0x400>; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 65 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 65 1>; - assigned-clock-parents = <&k3_clks 65 2>; - power-domains = <&k3_pds 65 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer15: timer@24f0000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x24f0000 0x00 0x400>; - interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 66 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 66 1>, <&k3_clks 320 0>; - assigned-clock-parents = <&k3_clks 66 2>, <&k3_clks 320 1>; - power-domains = <&k3_pds 66 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer16: timer@2500000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2500000 0x00 0x400>; - interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 67 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 67 1>; - assigned-clock-parents = <&k3_clks 67 2>; - power-domains = <&k3_pds 67 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer17: timer@2510000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2510000 0x00 0x400>; - interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 68 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 68 1>, <&k3_clks 321 0>; - assigned-clock-parents = <&k3_clks 68 2>, <&k3_clks 321 1>; - power-domains = <&k3_pds 68 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer18: timer@2520000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2520000 0x00 0x400>; - interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 69 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 69 1>; - assigned-clock-parents = <&k3_clks 69 2>; - power-domains = <&k3_pds 69 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer19: timer@2530000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2530000 0x00 0x400>; - interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 70 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 70 1>, <&k3_clks 322 0>; - assigned-clock-parents = <&k3_clks 70 2>, <&k3_clks 322 1>; - power-domains = <&k3_pds 70 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_r5fss0: r5fss@5c00000 { - compatible = "ti,j7200-r5fss"; - ti,cluster-mode = <1>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x5c00000 0x00 0x5c00000 0x20000>, - <0x5d00000 0x00 0x5d00000 0x20000>; - power-domains = <&k3_pds 243 TI_SCI_PD_EXCLUSIVE>; - - main_r5fss0_core0: r5f@5c00000 { - compatible = "ti,j7200-r5f"; - reg = <0x5c00000 0x00010000>, - <0x5c10000 0x00010000>; - reg-names = "atcm", "btcm"; - ti,sci = <&dmsc>; - ti,sci-dev-id = <245>; - ti,sci-proc-ids = <0x06 0xff>; - resets = <&k3_reset 245 1>; - firmware-name = "j7200-main-r5f0_0-fw"; - ti,atcm-enable = <1>; - ti,btcm-enable = <1>; - ti,loczrama = <1>; - }; - - main_r5fss0_core1: r5f@5d00000 { - compatible = "ti,j7200-r5f"; - reg = <0x5d00000 0x00008000>, - <0x5d10000 0x00008000>; - reg-names = "atcm", "btcm"; - ti,sci = <&dmsc>; - ti,sci-dev-id = <246>; - ti,sci-proc-ids = <0x07 0xff>; - resets = <&k3_reset 246 1>; - firmware-name = "j7200-main-r5f0_1-fw"; - ti,atcm-enable = <1>; - ti,btcm-enable = <1>; - ti,loczrama = <1>; - }; - }; - - main_esm: esm@700000 { - compatible = "ti,j721e-esm"; - reg = <0x0 0x700000 0x0 0x1000>; - ti,esm-pins = <656>, <657>; - }; -}; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi deleted file mode 100644 index 3fc588b848c..00000000000 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ /dev/null @@ -1,647 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for J7200 SoC Family MCU/WAKEUP Domain peripherals - * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ - */ - -&cbass_mcu_wakeup { - dmsc: system-controller@44083000 { - compatible = "ti,k2g-sci"; - ti,host-id = <12>; - - mbox-names = "rx", "tx"; - - mboxes = <&secure_proxy_main 11>, - <&secure_proxy_main 13>; - - reg-names = "debug_messages"; - reg = <0x00 0x44083000 0x00 0x1000>; - - k3_pds: power-controller { - compatible = "ti,sci-pm-domain"; - #power-domain-cells = <2>; - }; - - k3_clks: clock-controller { - compatible = "ti,k2g-sci-clk"; - #clock-cells = <2>; - }; - - k3_reset: reset-controller { - compatible = "ti,sci-reset"; - #reset-cells = <2>; - }; - }; - - mcu_timer0: timer@40400000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40400000 0x00 0x400>; - interrupts = <GIC_SPI 816 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 35 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 35 1>; - assigned-clock-parents = <&k3_clks 35 2>; - power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer1: timer@40410000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40410000 0x00 0x400>; - interrupts = <GIC_SPI 817 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 71 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 71 1>, <&k3_clks 308 0>; - assigned-clock-parents = <&k3_clks 71 2>, <&k3_clks 308 1>; - power-domains = <&k3_pds 71 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer2: timer@40420000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40420000 0x00 0x400>; - interrupts = <GIC_SPI 818 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 72 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 72 1>; - assigned-clock-parents = <&k3_clks 72 2>; - power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer3: timer@40430000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40430000 0x00 0x400>; - interrupts = <GIC_SPI 819 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 73 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 73 1>, <&k3_clks 309 0>; - assigned-clock-parents = <&k3_clks 73 2>, <&k3_clks 309 1>; - power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer4: timer@40440000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40440000 0x00 0x400>; - interrupts = <GIC_SPI 820 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 74 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 74 1>; - assigned-clock-parents = <&k3_clks 74 2>; - power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer5: timer@40450000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40450000 0x00 0x400>; - interrupts = <GIC_SPI 821 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 75 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 75 1>, <&k3_clks 310 0>; - assigned-clock-parents = <&k3_clks 75 2>, <&k3_clks 310 1>; - power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer6: timer@40460000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40460000 0x00 0x400>; - interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 76 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 76 1>; - assigned-clock-parents = <&k3_clks 76 2>; - power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer7: timer@40470000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40470000 0x00 0x400>; - interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 77 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 77 1>, <&k3_clks 311 0>; - assigned-clock-parents = <&k3_clks 77 2>, <&k3_clks 311 1>; - power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer8: timer@40480000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40480000 0x00 0x400>; - interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 78 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 78 1>; - assigned-clock-parents = <&k3_clks 78 2>; - power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_timer9: timer@40490000 { - status = "reserved"; - compatible = "ti,am654-timer"; - reg = <0x00 0x40490000 0x00 0x400>; - interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 79 1>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 79 1>, <&k3_clks 312 0>; - assigned-clock-parents = <&k3_clks 79 2>, <&k3_clks 312 1>; - power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - mcu_conf: syscon@40f00000 { - compatible = "syscon", "simple-mfd"; - reg = <0x00 0x40f00000 0x00 0x20000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0x40f00000 0x20000>; - - phy_gmii_sel: phy@4040 { - compatible = "ti,am654-phy-gmii-sel"; - reg = <0x4040 0x4>; - #phy-cells = <1>; - }; - }; - - chipid@43000014 { - compatible = "ti,am654-chipid"; - reg = <0x00 0x43000014 0x00 0x4>; - }; - - /* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */ - mcu_timerio_input: pinctrl@40f04200 { - compatible = "pinctrl-single"; - reg = <0x0 0x40f04200 0x0 0x28>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0x0000000F>; - status = "reserved"; - }; - - /* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */ - mcu_timerio_output: pinctrl@40f04280 { - compatible = "pinctrl-single"; - reg = <0x0 0x40f04280 0x0 0x28>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0x0000000F>; - status = "reserved"; - }; - - wkup_pmx0: pinctrl@4301c000 { - compatible = "pinctrl-single"; - /* Proxy 0 addressing */ - reg = <0x00 0x4301c000 0x00 0x34>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - wkup_pmx1: pinctrl@4301c038 { - compatible = "pinctrl-single"; - /* Proxy 0 addressing */ - reg = <0x00 0x4301c038 0x00 0x8>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - wkup_pmx2: pinctrl@4301c068 { - compatible = "pinctrl-single"; - /* Proxy 0 addressing */ - reg = <0x00 0x4301c068 0x00 0xec>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - wkup_pmx3: pinctrl@4301c174 { - compatible = "pinctrl-single"; - /* Proxy 0 addressing */ - reg = <0x00 0x4301c174 0x00 0x20>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - mcu_ram: sram@41c00000 { - compatible = "mmio-sram"; - reg = <0x00 0x41c00000 0x00 0x100000>; - ranges = <0x00 0x00 0x41c00000 0x100000>; - #address-cells = <1>; - #size-cells = <1>; - }; - - wkup_uart0: serial@42300000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x42300000 0x00 0x100>; - interrupts = <GIC_SPI 897 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <48000000>; - current-speed = <115200>; - power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 287 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - mcu_uart0: serial@40a00000 { - compatible = "ti,j721e-uart", "ti,am654-uart"; - reg = <0x00 0x40a00000 0x00 0x100>; - interrupts = <GIC_SPI 846 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <96000000>; - current-speed = <115200>; - power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 149 2>; - clock-names = "fclk"; - status = "disabled"; - }; - - wkup_gpio_intr: interrupt-controller@42200000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x42200000 0x00 0x400>; - ti,intr-trigger-type = <1>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <137>; - ti,interrupt-ranges = <16 960 16>; - }; - - wkup_gpio0: gpio@42110000 { - compatible = "ti,j721e-gpio", "ti,keystone-gpio"; - reg = <0x00 0x42110000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&wkup_gpio_intr>; - interrupts = <103>, <104>, <105>, <106>, <107>, <108>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <85>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 113 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 113 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - wkup_gpio1: gpio@42100000 { - compatible = "ti,j721e-gpio", "ti,keystone-gpio"; - reg = <0x00 0x42100000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&wkup_gpio_intr>; - interrupts = <112>, <113>, <114>, <115>, <116>, <117>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <85>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 114 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - mcu_navss: bus@28380000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>; - dma-coherent; - dma-ranges; - ti,sci-dev-id = <232>; - - mcu_ringacc: ringacc@2b800000 { - compatible = "ti,am654-navss-ringacc"; - reg = <0x00 0x2b800000 0x00 0x400000>, - <0x00 0x2b000000 0x00 0x400000>, - <0x00 0x28590000 0x00 0x100>, - <0x00 0x2a500000 0x00 0x40000>, - <0x00 0x28440000 0x00 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", - "proxy_target", "cfg"; - ti,num-rings = <286>; - ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ - ti,sci = <&dmsc>; - ti,sci-dev-id = <235>; - msi-parent = <&main_udmass_inta>; - }; - - mcu_udmap: dma-controller@285c0000 { - compatible = "ti,j721e-navss-mcu-udmap"; - reg = <0x00 0x285c0000 0x00 0x100>, - <0x00 0x2a800000 0x00 0x40000>, - <0x00 0x2aa00000 0x00 0x40000>; - reg-names = "gcfg", "rchanrt", "tchanrt"; - msi-parent = <&main_udmass_inta>; - #dma-cells = <1>; - - ti,sci = <&dmsc>; - ti,sci-dev-id = <236>; - ti,ringacc = <&mcu_ringacc>; - - ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */ - <0x0f>; /* TX_HCHAN */ - ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */ - <0x0b>; /* RX_HCHAN */ - ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */ - }; - }; - - secure_proxy_mcu: mailbox@2a480000 { - compatible = "ti,am654-secure-proxy"; - #mbox-cells = <1>; - reg-names = "target_data", "rt", "scfg"; - reg = <0x0 0x2a480000 0x0 0x80000>, - <0x0 0x2a380000 0x0 0x80000>, - <0x0 0x2a400000 0x0 0x80000>; - /* - * Marked Disabled: - * Node is incomplete as it is meant for bootloaders and - * firmware on non-MPU processors - */ - status = "disabled"; - }; - - mcu_cpsw: ethernet@46000000 { - compatible = "ti,j721e-cpsw-nuss"; - #address-cells = <2>; - #size-cells = <2>; - reg = <0x00 0x46000000 0x00 0x200000>; - reg-names = "cpsw_nuss"; - ranges = <0x00 0x00 0x00 0x46000000 0x00 0x200000>; - dma-coherent; - clocks = <&k3_clks 18 21>; - clock-names = "fck"; - power-domains = <&k3_pds 18 TI_SCI_PD_EXCLUSIVE>; - - dmas = <&mcu_udmap 0xf000>, - <&mcu_udmap 0xf001>, - <&mcu_udmap 0xf002>, - <&mcu_udmap 0xf003>, - <&mcu_udmap 0xf004>, - <&mcu_udmap 0xf005>, - <&mcu_udmap 0xf006>, - <&mcu_udmap 0xf007>, - <&mcu_udmap 0x7000>; - dma-names = "tx0", "tx1", "tx2", "tx3", - "tx4", "tx5", "tx6", "tx7", - "rx"; - - ethernet-ports { - #address-cells = <1>; - #size-cells = <0>; - - cpsw_port1: port@1 { - reg = <1>; - ti,mac-only; - label = "port1"; - ti,syscon-efuse = <&mcu_conf 0x200>; - phys = <&phy_gmii_sel 1>; - }; - }; - - davinci_mdio: mdio@f00 { - compatible = "ti,cpsw-mdio","ti,davinci_mdio"; - reg = <0x00 0xf00 0x00 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&k3_clks 18 21>; - clock-names = "fck"; - bus_freq = <1000000>; - }; - - cpts@3d000 { - compatible = "ti,am65-cpts"; - reg = <0x00 0x3d000 0x00 0x400>; - clocks = <&k3_clks 18 2>; - clock-names = "cpts"; - interrupts-extended = <&gic500 GIC_SPI 858 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "cpts"; - ti,cpts-ext-ts-inputs = <4>; - ti,cpts-periodic-outputs = <2>; - }; - }; - - mcu_i2c0: i2c@40b00000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x40b00000 0x00 0x100>; - interrupts = <GIC_SPI 852 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 194 1>; - power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - mcu_i2c1: i2c@40b10000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x40b10000 0x00 0x100>; - interrupts = <GIC_SPI 853 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 195 1>; - power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - wkup_i2c0: i2c@42120000 { - compatible = "ti,j721e-i2c", "ti,omap4-i2c"; - reg = <0x00 0x42120000 0x00 0x100>; - interrupts = <GIC_SPI 896 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "fck"; - clocks = <&k3_clks 197 1>; - power-domains = <&k3_pds 197 TI_SCI_PD_SHARED>; - status = "disabled"; - }; - - mcu_spi0: spi@40300000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x040300000 0x00 0x400>; - interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 274 0>; - status = "disabled"; - }; - - mcu_spi1: spi@40310000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x040310000 0x00 0x400>; - interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 275 0>; - status = "disabled"; - }; - - mcu_spi2: spi@40320000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x040320000 0x00 0x400>; - interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 276 0>; - status = "disabled"; - }; - - fss: syscon@47000000 { - compatible = "syscon", "simple-mfd"; - reg = <0x00 0x47000000 0x00 0x100>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - hbmc_mux: hbmc-mux { - compatible = "mmio-mux"; - #mux-control-cells = <1>; - mux-reg-masks = <0x4 0x2>; /* HBMC select */ - }; - - hbmc: hyperbus@47034000 { - compatible = "ti,am654-hbmc"; - reg = <0x00 0x47034000 0x00 0x100>, - <0x05 0x00000000 0x01 0x0000000>; - power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 102 0>; - assigned-clocks = <&k3_clks 102 5>; - assigned-clock-rates = <333333333>; - #address-cells = <2>; - #size-cells = <1>; - mux-controls = <&hbmc_mux 0>; - }; - - ospi0: spi@47040000 { - compatible = "ti,am654-ospi", "cdns,qspi-nor"; - reg = <0x0 0x47040000 0x0 0x100>, - <0x5 0x00000000 0x1 0x0000000>; - interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>; - cdns,fifo-depth = <256>; - cdns,fifo-width = <4>; - cdns,trigger-address = <0x0>; - clocks = <&k3_clks 103 0>; - assigned-clocks = <&k3_clks 103 0>; - assigned-clock-parents = <&k3_clks 103 2>; - assigned-clock-rates = <166666666>; - power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - }; - - tscadc0: tscadc@40200000 { - compatible = "ti,am3359-tscadc"; - reg = <0x00 0x40200000 0x00 0x1000>; - interrupts = <GIC_SPI 860 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 0 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 0 1>; - assigned-clocks = <&k3_clks 0 3>; - assigned-clock-rates = <60000000>; - clock-names = "fck"; - dmas = <&main_udmap 0x7400>, - <&main_udmap 0x7401>; - dma-names = "fifo0", "fifo1"; - - adc { - #io-channel-cells = <1>; - compatible = "ti,am3359-adc"; - }; - }; - - mcu_r5fss0: r5fss@41000000 { - compatible = "ti,j7200-r5fss"; - ti,cluster-mode = <1>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x41000000 0x00 0x41000000 0x20000>, - <0x41400000 0x00 0x41400000 0x20000>; - power-domains = <&k3_pds 249 TI_SCI_PD_EXCLUSIVE>; - - mcu_r5fss0_core0: r5f@41000000 { - compatible = "ti,j7200-r5f"; - reg = <0x41000000 0x00010000>, - <0x41010000 0x00010000>; - reg-names = "atcm", "btcm"; - ti,sci = <&dmsc>; - ti,sci-dev-id = <250>; - ti,sci-proc-ids = <0x01 0xff>; - resets = <&k3_reset 250 1>; - firmware-name = "j7200-mcu-r5f0_0-fw"; - ti,atcm-enable = <1>; - ti,btcm-enable = <1>; - ti,loczrama = <1>; - }; - - mcu_r5fss0_core1: r5f@41400000 { - compatible = "ti,j7200-r5f"; - reg = <0x41400000 0x00008000>, - <0x41410000 0x00008000>; - reg-names = "atcm", "btcm"; - ti,sci = <&dmsc>; - ti,sci-dev-id = <251>; - ti,sci-proc-ids = <0x02 0xff>; - resets = <&k3_reset 251 1>; - firmware-name = "j7200-mcu-r5f0_1-fw"; - ti,atcm-enable = <1>; - ti,btcm-enable = <1>; - ti,loczrama = <1>; - }; - }; - - mcu_crypto: crypto@40900000 { - compatible = "ti,j721e-sa2ul"; - reg = <0x00 0x40900000 0x00 0x1200>; - power-domains = <&k3_pds 265 TI_SCI_PD_SHARED>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>; - dmas = <&mcu_udmap 0xf501>, <&mcu_udmap 0x7502>, - <&mcu_udmap 0x7503>; - dma-names = "tx", "rx1", "rx2"; - - rng: rng@40910000 { - compatible = "inside-secure,safexcel-eip76"; - reg = <0x00 0x40910000 0x00 0x7d>; - interrupts = <GIC_SPI 945 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; /* Used by OP-TEE */ - }; - }; - - wkup_vtm0: temperature-sensor@42040000 { - compatible = "ti,j7200-vtm"; - reg = <0x00 0x42040000 0x00 0x350>, - <0x00 0x42050000 0x00 0x350>; - power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; - #thermal-sensor-cells = <1>; - }; - - mcu_esm: esm@40800000 { - compatible = "ti,j721e-esm"; - reg = <0x00 0x40800000 0x00 0x1000>; - ti,esm-pins = <95>; - bootph-pre-ram; - }; -}; diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi deleted file mode 100644 index 5a300d4c8ba..00000000000 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ /dev/null @@ -1,327 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/dts-v1/; - -#include "k3-j7200.dtsi" - -/ { - memory@80000000 { - device_type = "memory"; - /* 4G RAM */ - reg = <0x00 0x80000000 0x00 0x80000000>, - <0x08 0x80000000 0x00 0x80000000>; - }; - - reserved_memory: reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; - alignment = <0x1000>; - no-map; - }; - - mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa0000000 0x00 0x100000>; - no-map; - }; - - mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa0100000 0x00 0xf00000>; - no-map; - }; - - mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa1000000 0x00 0x100000>; - no-map; - }; - - mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa1100000 0x00 0xf00000>; - no-map; - }; - - main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa2000000 0x00 0x100000>; - no-map; - }; - - main_r5fss0_core0_memory_region: r5f-memory@a2100000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa2100000 0x00 0xf00000>; - no-map; - }; - - main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa3000000 0x00 0x100000>; - no-map; - }; - - main_r5fss0_core1_memory_region: r5f-memory@a3100000 { - compatible = "shared-dma-pool"; - reg = <0x00 0xa3100000 0x00 0xf00000>; - no-map; - }; - - rtos_ipc_memory_region: ipc-memories@a4000000 { - reg = <0x00 0xa4000000 0x00 0x00800000>; - alignment = <0x1000>; - no-map; - }; - }; -}; - -&wkup_pmx0 { - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (B6) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ - J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C8) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */ - J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 1) /* (D6) MCU_OSPI0_CSn0.MCU_HYPERBUS0_CSn0 */ - J721E_WKUP_IOPAD(0x30, PIN_OUTPUT, 1) /* (D7) MCU_OSPI0_CSn1.MCU_HYPERBUS0_RESETn */ - J721E_WKUP_IOPAD(0x8, PIN_INPUT, 1) /* (B7) MCU_OSPI0_DQS.MCU_HYPERBUS0_RWDS */ - J721E_WKUP_IOPAD(0xc, PIN_INPUT, 1) /* (D8) MCU_OSPI0_D0.MCU_HYPERBUS0_DQ0 */ - J721E_WKUP_IOPAD(0x10, PIN_INPUT, 1) /* (C7) MCU_OSPI0_D1.MCU_HYPERBUS0_DQ1 */ - J721E_WKUP_IOPAD(0x14, PIN_INPUT, 1) /* (C5) MCU_OSPI0_D2.MCU_HYPERBUS0_DQ2 */ - J721E_WKUP_IOPAD(0x18, PIN_INPUT, 1) /* (A5) MCU_OSPI0_D3.MCU_HYPERBUS0_DQ3 */ - J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 1) /* (A6) MCU_OSPI0_D4.MCU_HYPERBUS0_DQ4 */ - J721E_WKUP_IOPAD(0x20, PIN_INPUT, 1) /* (B8) MCU_OSPI0_D5.MCU_HYPERBUS0_DQ5 */ - J721E_WKUP_IOPAD(0x24, PIN_INPUT, 1) /* (A8) MCU_OSPI0_D6.MCU_HYPERBUS0_DQ6 */ - J721E_WKUP_IOPAD(0x28, PIN_INPUT, 1) /* (A7) MCU_OSPI0_D7.MCU_HYPERBUS0_DQ7 */ - >; - }; - - mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_OSPI0_CLK */ - J721E_WKUP_IOPAD(0x002c, PIN_OUTPUT, 0) /* MCU_OSPI0_CSn0 */ - J721E_WKUP_IOPAD(0x000c, PIN_INPUT, 0) /* MCU_OSPI0_D0 */ - J721E_WKUP_IOPAD(0x0010, PIN_INPUT, 0) /* MCU_OSPI0_D1 */ - J721E_WKUP_IOPAD(0x0014, PIN_INPUT, 0) /* MCU_OSPI0_D2 */ - J721E_WKUP_IOPAD(0x0018, PIN_INPUT, 0) /* MCU_OSPI0_D3 */ - J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_OSPI0_D4 */ - J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_OSPI0_D5 */ - J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_OSPI0_D6 */ - J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_OSPI0_D7 */ - J721E_WKUP_IOPAD(0x0008, PIN_INPUT, 0) /* MCU_OSPI0_DQS */ - >; - }; -}; - -&wkup_pmx2 { - wkup_i2c0_pins_default: wkup-i2c0-default-pins { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x98, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ - J721E_WKUP_IOPAD(0x9c, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ - >; - }; -}; - -&main_pmx0 { - main_i2c0_pins_default: main-i2c0-default-pins { - pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ - >; - }; -}; - -&hbmc { - /* OSPI and HBMC are muxed inside FSS, Bootloader will enable - * appropriate node based on board detection - */ - status = "disabled"; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_fss0_hpb0_pins_default>; - ranges = <0x00 0x00 0x05 0x00000000 0x4000000>, /* 64MB Flash on CS0 */ - <0x01 0x00 0x05 0x04000000 0x800000>; /* 8MB RAM on CS1 */ - - flash@0,0 { - compatible = "cypress,hyperflash", "cfi-flash"; - reg = <0x00 0x00 0x4000000>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "hbmc.tiboot3"; - reg = <0x0 0x100000>; - }; - - partition@100000 { - label = "hbmc.tispl"; - reg = <0x100000 0x200000>; - }; - - partition@300000 { - label = "hbmc.u-boot"; - reg = <0x300000 0x400000>; - }; - - partition@700000 { - label = "hbmc.env"; - reg = <0x700000 0x40000>; - }; - - partition@800000 { - label = "hbmc.rootfs"; - reg = <0x800000 0x3800000>; - }; - }; - }; -}; - -&mailbox0_cluster0 { - status = "okay"; - interrupts = <436>; - - mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { - ti,mbox-rx = <0 0 0>; - ti,mbox-tx = <1 0 0>; - }; - - mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 { - ti,mbox-rx = <2 0 0>; - ti,mbox-tx = <3 0 0>; - }; -}; - -&mailbox0_cluster1 { - status = "okay"; - interrupts = <432>; - - mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { - ti,mbox-rx = <0 0 0>; - ti,mbox-tx = <1 0 0>; - }; - - mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 { - ti,mbox-rx = <2 0 0>; - ti,mbox-tx = <3 0 0>; - }; -}; - -&mcu_r5fss0_core0 { - mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core0>; - memory-region = <&mcu_r5fss0_core0_dma_memory_region>, - <&mcu_r5fss0_core0_memory_region>; -}; - -&mcu_r5fss0_core1 { - mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core1>; - memory-region = <&mcu_r5fss0_core1_dma_memory_region>, - <&mcu_r5fss0_core1_memory_region>; -}; - -&main_r5fss0_core0 { - mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core0>; - memory-region = <&main_r5fss0_core0_dma_memory_region>, - <&main_r5fss0_core0_memory_region>; -}; - -&main_r5fss0_core1 { - mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core1>; - memory-region = <&main_r5fss0_core1_dma_memory_region>, - <&main_r5fss0_core1_memory_region>; -}; - -&main_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - exp_som: gpio@21 { - compatible = "ti,tca6408"; - reg = <0x21>; - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = "USB2.0_MUX_SEL", "CANUART_MUX1_SEL0", - "CANUART_MUX2_SEL0", "CANUART_MUX_SEL1", - "UART/LIN_MUX_SEL", "TRC_D17/AUDIO_REFCLK_SEL", - "GPIO_LIN_EN", "CAN_STB"; - }; -}; - -&wkup_i2c0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_i2c0_pins_default>; - clock-frequency = <400000>; - - eeprom@50 { - compatible = "atmel,24c256"; - reg = <0x50>; - }; -}; - -&ospi0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_fss0_ospi0_pins_default>; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0x0>; - spi-tx-bus-width = <8>; - spi-rx-bus-width = <8>; - spi-max-frequency = <25000000>; - cdns,tshsl-ns = <60>; - cdns,tsd2d-ns = <60>; - cdns,tchsh-ns = <60>; - cdns,tslch-ns = <60>; - cdns,read-delay = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "ospi.tiboot3"; - reg = <0x0 0x100000>; - }; - - partition@100000 { - label = "ospi.tispl"; - reg = <0x100000 0x200000>; - }; - - partition@300000 { - label = "ospi.u-boot"; - reg = <0x300000 0x400000>; - }; - - partition@700000 { - label = "ospi.env"; - reg = <0x700000 0x40000>; - }; - - partition@740000 { - label = "ospi.env.backup"; - reg = <0x740000 0x40000>; - }; - - partition@800000 { - label = "ospi.rootfs"; - reg = <0x800000 0x37c0000>; - }; - - partition@3fc0000 { - label = "ospi.phypattern"; - reg = <0x3fc0000 0x40000>; - }; - }; - }; -}; diff --git a/arch/arm/dts/k3-j7200-thermal.dtsi b/arch/arm/dts/k3-j7200-thermal.dtsi deleted file mode 100644 index e7e3a643a6f..00000000000 --- a/arch/arm/dts/k3-j7200-thermal.dtsi +++ /dev/null @@ -1,47 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 - -#include <dt-bindings/thermal/thermal.h> - -thermal_zones: thermal-zones { - mcu_thermal: mcu-thermal { - polling-delay-passive = <250>; /* milliseconds */ - polling-delay = <500>; /* milliseconds */ - thermal-sensors = <&wkup_vtm0 0>; - - trips { - wkup_crit: wkup-crit { - temperature = <125000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; - - mpu_thermal: mpu-thermal { - polling-delay-passive = <250>; /* milliseconds */ - polling-delay = <500>; /* milliseconds */ - thermal-sensors = <&wkup_vtm0 1>; - - trips { - mpu_crit: mpu-crit { - temperature = <125000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; - - main_thermal: main-thermal { - polling-delay-passive = <250>; /* milliseconds */ - polling-delay = <500>; /* milliseconds */ - thermal-sensors = <&wkup_vtm0 2>; - - trips { - c7x_crit: c7x-crit { - temperature = <125000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; -}; diff --git a/arch/arm/dts/k3-j7200.dtsi b/arch/arm/dts/k3-j7200.dtsi deleted file mode 100644 index ef73e6d7e85..00000000000 --- a/arch/arm/dts/k3-j7200.dtsi +++ /dev/null @@ -1,164 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for J7200 SoC Family - * - * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/soc/ti,sci_pm_domain.h> - -#include "k3-pinctrl.h" - -/ { - model = "Texas Instruments K3 J7200 SoC"; - compatible = "ti,j7200"; - interrupt-parent = <&gic500>; - #address-cells = <2>; - #size-cells = <2>; - - chosen { }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - cpu-map { - cluster0: cluster0 { - core0 { - cpu = <&cpu0>; - }; - - core1 { - cpu = <&cpu1>; - }; - }; - - }; - - cpu0: cpu@0 { - compatible = "arm,cortex-a72"; - reg = <0x000>; - device_type = "cpu"; - enable-method = "psci"; - i-cache-size = <0xc000>; - i-cache-line-size = <64>; - i-cache-sets = <256>; - d-cache-size = <0x8000>; - d-cache-line-size = <64>; - d-cache-sets = <256>; - next-level-cache = <&L2_0>; - }; - - cpu1: cpu@1 { - compatible = "arm,cortex-a72"; - reg = <0x001>; - device_type = "cpu"; - enable-method = "psci"; - i-cache-size = <0xc000>; - i-cache-line-size = <64>; - i-cache-sets = <256>; - d-cache-size = <0x8000>; - d-cache-line-size = <64>; - d-cache-sets = <256>; - next-level-cache = <&L2_0>; - }; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - cache-level = <2>; - cache-unified; - cache-size = <0x100000>; - cache-line-size = <64>; - cache-sets = <1024>; - next-level-cache = <&msmc_l3>; - }; - - msmc_l3: l3-cache0 { - compatible = "cache"; - cache-level = <3>; - cache-unified; - }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - - psci: psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - }; - - a72_timer0: timer-cl0-cpu0 { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */ - <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */ - <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */ - <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */ - }; - - pmu: pmu { - compatible = "arm,cortex-a72-pmu"; - interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; - }; - - cbass_main: bus@100000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */ - <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */ - <0x00 0x00700000 0x00 0x00700000 0x00 0x00001000>, /* ESM */ - <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* timesync router */ - <0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */ - <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */ - <0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */ - <0x00 0x70000000 0x00 0x70000000 0x00 0x00800000>, /* MSMC RAM */ - <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */ - <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */ - - /* MCUSS_WKUP Range */ - <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, - <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, - <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, - <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, - <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, - <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, - <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, - <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, - <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, - <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, - <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, - <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, - <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; - - cbass_mcu_wakeup: bus@28380000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, /* MCU NAVSS*/ - <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, /* First peripheral window */ - <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, /* CTRL_MMR0 */ - <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, /* MCU R5F Core0 */ - <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, /* MCU R5F Core1 */ - <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, /* MCU SRAM */ - <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, /* WKUP peripheral window */ - <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, /* MMRs, remaining NAVSS */ - <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, /* CPSW */ - <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, /* OSPI register space */ - <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, /* FSS OSPI0/1 data region 0 */ - <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS OSPI0 data region 3 */ - <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3 */ - }; - }; - - #include "k3-j7200-thermal.dtsi" -}; - -/* Now include the peripherals for each bus segments */ -#include "k3-j7200-main.dtsi" -#include "k3-j7200-mcu-wakeup.dtsi" diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index fe8e84c9214..4db5654ca1c 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -15,7 +15,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_ENV_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-common-proc-board" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-j7200-common-proc-board" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -96,6 +96,7 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y +CONFIG_OF_UPSTREAM=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_CCF=y
On Tue, 21 May 2024 at 11:18, Aniket Limaye a-limaye@ti.com wrote:
Move to using OF_UPSTREAM config and thus using the devicetree-rebasing subtree.
Signed-off-by: Aniket Limaye a-limaye@ti.com
Boot logs: https://gist.github.com/aniket-l/aab91bb12d2495c54da094fca49c369f
Changes in v2:
- Rebased to next
- Removed dependency on binman templating series [1] as per [2]
arch/arm/dts/Makefile | 1 - arch/arm/dts/k3-j7200-binman.dtsi | 2 +- .../k3-j7200-common-proc-board-u-boot.dtsi | 14 +- arch/arm/dts/k3-j7200-common-proc-board.dts | 396 ----- arch/arm/dts/k3-j7200-main.dtsi | 1284 ----------------- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 647 --------- arch/arm/dts/k3-j7200-som-p0.dtsi | 327 ----- arch/arm/dts/k3-j7200-thermal.dtsi | 47 - arch/arm/dts/k3-j7200.dtsi | 164 --- configs/j7200_evm_a72_defconfig | 3 +- 10 files changed, 8 insertions(+), 2877 deletions(-) delete mode 100644 arch/arm/dts/k3-j7200-common-proc-board.dts delete mode 100644 arch/arm/dts/k3-j7200-main.dtsi delete mode 100644 arch/arm/dts/k3-j7200-mcu-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-j7200-som-p0.dtsi delete mode 100644 arch/arm/dts/k3-j7200-thermal.dtsi delete mode 100644 arch/arm/dts/k3-j7200.dtsi
Acked-by: Sumit Garg sumit.garg@linaro.org
-Sumit
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f7032f1e175..ea8fee8e25c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1194,7 +1194,6 @@ dtb-$(CONFIG_SOC_K3_AM654) += \
dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-r5-common-proc-board.dtb \
k3-j7200-common-proc-board.dtb \ k3-j7200-r5-common-proc-board.dtb \ k3-j721e-sk.dtb \ k3-j721e-r5-sk.dtb \
diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi index 06db8659876..b6e0aa37971 100644 --- a/arch/arm/dts/k3-j7200-binman.dtsi +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -180,7 +180,7 @@
#ifdef CONFIG_TARGET_J7200_A72_EVM
-#define SPL_J7200_EVM_DTB "spl/dts/k3-j7200-common-proc-board.dtb" +#define SPL_J7200_EVM_DTB "spl/dts/ti/k3-j7200-common-proc-board.dtb" #define J7200_EVM_DTB "u-boot.dtb"
&binman { diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 485f17c5f06..045ef170e17 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -26,8 +26,12 @@ &cbass_mcu_wakeup { bootph-all;
chipid@43000014 {
wkup_conf: bus@43000000 { bootph-all;
chipid: chipid@14 {
bootph-all;
@@ -40,14 +44,6 @@ };
&mcu_udmap {
reg = <0x0 0x285c0000 0x0 0x100>,
<0x0 0x284c0000 0x0 0x4000>,
<0x0 0x2a800000 0x0 0x40000>,
<0x0 0x284a0000 0x0 0x4000>,
<0x0 0x2aa00000 0x0 0x40000>,
<0x0 0x28400000 0x0 0x2000>;
reg-names = "gcfg", "rchan", "rchanrt", "tchan",
"tchanrt", "rflow"; bootph-all;
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts deleted file mode 100644 index cee2b4b0eb8..00000000000 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ /dev/null @@ -1,396 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/
-/dts-v1/;
-#include "k3-j7200-som-p0.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/net/ti-dp83867.h> -#include <dt-bindings/phy/phy.h>
-#include "k3-serdes.h"
compatible = "ti,j7200-evm", "ti,j7200";
model = "Texas Instruments J7200 EVM";
aliases {
serial0 = &wkup_uart0;
serial1 = &mcu_uart0;
serial2 = &main_uart0;
serial3 = &main_uart1;
serial5 = &main_uart3;
mmc0 = &main_sdhci0;
mmc1 = &main_sdhci1;
chosen {
stdout-path = "serial2:115200n8";
evm_12v0: fixedregulator-evm12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "evm_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
vsys_3v3: fixedregulator-vsys3v3 {
/* Output of LM5140 */
regulator-name = "vsys_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&evm_12v0>;
regulator-boot-on;
vsys_5v0: fixedregulator-vsys5v0 {
regulator-name = "vsys_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vdd_mmc1: fixedregulator-sd {
/* Output of TPS22918 */
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vsys_3v3>;
gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
vdd_sd_dv: gpio-regulator-TLV71033 {
/* Output of TLV71033 */
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vsys_5v0>;
gpios = <&main_gpio0 55 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
-&wkup_pmx0 {
mcu_uart0_pins_default: mcu-uart0-default-pins {
J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) MCU_UART0_RXD */
J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) MCU_UART0_TXD */
J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) MCU_UART0_CTSn */
J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) MCU_UART0_RTSn */
wkup_uart0_pins_default: wkup-uart0-default-pins {
J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */
J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */
-&wkup_pmx2 {
mcu_cpsw_pins_default: mcu-cpsw-default-pins {
J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
J721E_WKUP_IOPAD(0x0004, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
J721E_WKUP_IOPAD(0x0008, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
J721E_WKUP_IOPAD(0x000c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
J721E_WKUP_IOPAD(0x0010, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
J721E_WKUP_IOPAD(0x0014, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
J721E_WKUP_IOPAD(0x002c, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
J721E_WKUP_IOPAD(0x0018, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */
J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
wkup_gpio_pins_default: wkup-gpio-default-pins {
J721E_WKUP_IOPAD(0x70, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */
mcu_mdio_pins_default: mcu-mdio1-default-pins {
J721E_WKUP_IOPAD(0x0034, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */
J721E_WKUP_IOPAD(0x0030, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */
-&main_pmx0 {
main_uart0_pins_default: main-uart0-default-pins {
J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */
J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */
J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */
J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */
main_uart1_pins_default: main-uart1-default-pins {
J721E_IOPAD(0xb8, PIN_INPUT, 0) /* (T18) UART1_RXD */
J721E_IOPAD(0xbc, PIN_INPUT, 0) /* (T20) UART1_TXD */
main_uart3_pins_default: main-uart3-default-pins {
J721E_IOPAD(0x60, PIN_INPUT, 11) /* (T15) MCAN8_TX.UART3_CTSn */
J721E_IOPAD(0x30, PIN_INPUT, 11) /* (Y18) MCAN2_TX.UART3_RXD */
main_i2c1_pins_default: main-i2c1-default-pins {
J721E_IOPAD(0xdc, PIN_INPUT_PULLUP, 3) /* (U3) ECAP0_IN_APWM_OUT.I2C1_SCL */
J721E_IOPAD(0xe0, PIN_INPUT_PULLUP, 3) /* (T3) EXT_REFCLK1.I2C1_SDA */
main_mmc1_pins_default: main-mmc1-default-pins {
J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */
J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */
J721E_IOPAD(0xfc, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
J721E_IOPAD(0xf8, PIN_INPUT, 0) /* (M19) MMC1_DAT0 */
J721E_IOPAD(0xf4, PIN_INPUT, 0) /* (N21) MMC1_DAT1 */
J721E_IOPAD(0xf0, PIN_INPUT, 0) /* (N20) MMC1_DAT2 */
J721E_IOPAD(0xec, PIN_INPUT, 0) /* (N19) MMC1_DAT3 */
J721E_IOPAD(0xe4, PIN_INPUT, 8) /* (V1) TIMER_IO0.MMC1_SDCD */
vdd_sd_dv_pins_default: vdd-sd-dv-default-pins {
J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */
-&main_pmx1 {
main_usbss0_pins_default: main-usbss0-default-pins {
J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */
-&wkup_uart0 {
/* Wakeup UART is used by System firmware */
pinctrl-0 = <&wkup_uart0_pins_default>;
-&mcu_uart0 {
status = "okay";
pinctrl-0 = <&mcu_uart0_pins_default>;
-&main_uart0 {
status = "okay";
/* Shared with ATF on this platform */
power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
pinctrl-0 = <&main_uart0_pins_default>;
-&main_uart1 {
status = "okay";
/* Default pinmux */
pinctrl-0 = <&main_uart1_pins_default>;
-&main_uart2 {
/* MAIN UART 2 is used by R5F firmware */
-&main_uart3 {
/* Shared with MCAN Interface */
status = "okay";
pinctrl-0 = <&main_uart3_pins_default>;
-&main_gpio0 {
status = "okay";
-&wkup_gpio0 {
status = "okay";
pinctrl-0 = <&wkup_gpio_pins_default>;
-&mcu_cpsw {
pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>;
-&davinci_mdio {
phy0: ethernet-phy@0 {
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
-&cpsw_port1 {
phy-mode = "rgmii-rxid";
phy-handle = <&phy0>;
-&main_i2c0 {
status = "okay";
exp1: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
exp2: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
- The j7200 CPB board is identical to the CPB used for J721E, the SOMs can be
- swapped on the CPB.
- main_i2c1 of J7200 is connected to the CPB i2c bus labeled as i2c3.
- The i2c1 of the CPB (as it is labeled) is not connected to j7200.
-&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
exp3: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "CODEC_RSTz", "CODEC_SPARE1", "UB926_RESETn",
"UB926_LOCK", "UB926_PWR_SW_CNTRL",
"UB926_TUNER_RESET", "UB926_GPIO_SPARE", "";
-&main_sdhci0 {
/* eMMC */
status = "okay";
non-removable;
ti,driver-strength-ohm = <50>;
disable-wp;
-&main_sdhci1 {
/* SD card */
status = "okay";
pinctrl-0 = <&main_mmc1_pins_default>;
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
disable-wp;
-&serdes_ln_ctrl {
idle-states = <J7200_SERDES0_LANE0_PCIE1_LANE0>, <J7200_SERDES0_LANE1_PCIE1_LANE1>,
<J7200_SERDES0_LANE2_QSGMII_LANE1>, <J7200_SERDES0_LANE3_IP4_UNUSED>;
-&usb_serdes_mux {
idle-states = <1>; /* USB0 to SERDES lane 3 */
-&usbss0 {
pinctrl-0 = <&main_usbss0_pins_default>;
ti,vbus-divider;
ti,usb2-only;
-&usb0 {
dr_mode = "otg";
maximum-speed = "high-speed";
-&tscadc0 {
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
-&serdes_refclk {
clock-frequency = <100000000>;
-&serdes0 {
serdes0_pcie_link: phy@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz0 1>, <&serdes_wiz0 2>;
serdes0_qsgmii_link: phy@1 {
reg = <2>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_QSGMII>;
resets = <&serdes_wiz0 3>;
-&pcie1_rc {
reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
phys = <&serdes0_pcie_link>;
phy-names = "pcie-phy";
num-lanes = <2>;
-&pcie1_ep {
num-lanes = <2>;
-}; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi deleted file mode 100644 index 264913f8328..00000000000 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ /dev/null @@ -1,1284 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for J7200 SoC Family Main Domain peripherals
- Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/
serdes_refclk: serdes-refclk {
#clock-cells = <0>;
compatible = "fixed-clock";
-&cbass_main {
msmc_ram: sram@70000000 {
reg = <0x00 0x70000000 0x00 0x100000>;
#size-cells = <1>;
ranges = <0x00 0x00 0x70000000 0x100000>;
atf-sram@0 {
reg = <0x00 0x20000>;
scm_conf: scm-conf@100000 {
compatible = "ti,j721e-system-controller", "syscon", "simple-mfd";
reg = <0x00 0x00100000 0x00 0x1c000>;
#size-cells = <1>;
ranges = <0x00 0x00 0x00100000 0x1c000>;
serdes_ln_ctrl: mux-controller@4080 {
mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */
<0x4088 0x3>, <0x408c 0x3>; /* SERDES0 lane2/3 select */
cpsw0_phy_gmii_sel: phy@4044 {
compatible = "ti,j7200-cpsw5g-phy-gmii-sel";
ti,qsgmii-main-ports = <1>;
reg = <0x4044 0x10>;
#phy-cells = <1>;
usb_serdes_mux: mux-controller@4000 {
mux-reg-masks = <0x4000 0x8000000>; /* USB0 to SERDES0 lane 1/3 mux */
gic500: interrupt-controller@1800000 {
compatible = "arm,gic-v3";
#size-cells = <2>;
ranges;
#interrupt-cells = <3>;
reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */
<0x00 0x01900000 0x00 0x100000>, /* GICR */
<0x00 0x6f000000 0x00 0x2000>, /* GICC */
<0x00 0x6f010000 0x00 0x1000>, /* GICH */
<0x00 0x6f020000 0x00 0x2000>; /* GICV */
/* vcpumntirq: virtual CPU interface maintenance interrupt */
interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
gic_its: msi-controller@1820000 {
compatible = "arm,gic-v3-its";
reg = <0x00 0x01820000 0x00 0x10000>;
socionext,synquacer-pre-its = <0x1000000 0x400000>;
msi-controller;
#msi-cells = <1>;
main_gpio_intr: interrupt-controller@a00000 {
reg = <0x00 0x00a00000 0x00 0x800>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <131>;
ti,interrupt-ranges = <8 392 56>;
main_navss: bus@30000000 {
#size-cells = <2>;
ranges = <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>;
ti,sci-dev-id = <199>;
dma-coherent;
dma-ranges;
main_navss_intr: interrupt-controller@310e0000 {
reg = <0x00 0x310e0000 0x00 0x4000>;
ti,intr-trigger-type = <4>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <213>;
ti,interrupt-ranges = <0 64 64>,
<64 448 64>,
<128 672 64>;
main_udmass_inta: msi-controller@33d00000 {
compatible = "ti,sci-inta";
reg = <0x00 0x33d00000 0x00 0x100000>;
#interrupt-cells = <0>;
interrupt-parent = <&main_navss_intr>;
msi-controller;
ti,sci = <&dmsc>;
ti,sci-dev-id = <209>;
ti,interrupt-ranges = <0 0 256>;
secure_proxy_main: mailbox@32c00000 {
#mbox-cells = <1>;
reg = <0x00 0x32c00000 0x00 0x100000>,
<0x00 0x32400000 0x00 0x100000>,
<0x00 0x32800000 0x00 0x100000>;
interrupt-names = "rx_011";
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
hwspinlock: spinlock@30e00000 {
compatible = "ti,am654-hwspinlock";
reg = <0x00 0x30e00000 0x00 0x1000>;
#hwlock-cells = <1>;
mailbox0_cluster0: mailbox@31f80000 {
compatible = "ti,am654-mailbox";
reg = <0x00 0x31f80000 0x00 0x200>;
#mbox-cells = <1>;
ti,mbox-num-users = <4>;
ti,mbox-num-fifos = <16>;
mailbox0_cluster1: mailbox@31f81000 {
reg = <0x00 0x31f81000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster2: mailbox@31f82000 {
reg = <0x00 0x31f82000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster3: mailbox@31f83000 {
reg = <0x00 0x31f83000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster4: mailbox@31f84000 {
reg = <0x00 0x31f84000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster5: mailbox@31f85000 {
reg = <0x00 0x31f85000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster6: mailbox@31f86000 {
reg = <0x00 0x31f86000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster7: mailbox@31f87000 {
reg = <0x00 0x31f87000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster8: mailbox@31f88000 {
reg = <0x00 0x31f88000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster9: mailbox@31f89000 {
reg = <0x00 0x31f89000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster10: mailbox@31f8a000 {
reg = <0x00 0x31f8a000 0x00 0x200>;
#mbox-cells = <1>;
mailbox0_cluster11: mailbox@31f8b000 {
reg = <0x00 0x31f8b000 0x00 0x200>;
#mbox-cells = <1>;
main_ringacc: ringacc@3c000000 {
reg = <0x00 0x3c000000 0x00 0x400000>,
<0x00 0x38000000 0x00 0x400000>,
<0x00 0x31120000 0x00 0x100>,
<0x00 0x33000000 0x00 0x40000>,
<0x00 0x31080000 0x00 0x40000>;
reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg";
ti,num-rings = <1024>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <211>;
main_udmap: dma-controller@31150000 {
compatible = "ti,j721e-navss-main-udmap";
reg = <0x00 0x31150000 0x00 0x100>,
<0x00 0x34000000 0x00 0x100000>,
<0x00 0x35000000 0x00 0x100000>;
#dma-cells = <1>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <212>;
ti,ringacc = <&main_ringacc>;
<0x0f>, /* TX_HCHAN */
<0x10>; /* TX_UHCHAN */
<0x0b>, /* RX_HCHAN */
<0x0c>; /* RX_UHCHAN */
cpts@310d0000 {
compatible = "ti,j721e-cpts";
reg = <0x00 0x310d0000 0x00 0x400>;
reg-names = "cpts";
clocks = <&k3_clks 201 1>;
interrupts-extended = <&main_navss_intr 391>;
ti,cpts-periodic-outputs = <6>;
ti,cpts-ext-ts-inputs = <8>;
cpsw0: ethernet@c000000 {
compatible = "ti,j7200-cpswxg-nuss";
#size-cells = <2>;
reg = <0x00 0xc000000 0x00 0x200000>;
ranges = <0x00 0x00 0x00 0xc000000 0x00 0x200000>;
clocks = <&k3_clks 19 33>;
power-domains = <&k3_pds 19 TI_SCI_PD_EXCLUSIVE>;
dmas = <&main_udmap 0xca00>,
<&main_udmap 0xca01>,
<&main_udmap 0xca02>,
<&main_udmap 0xca03>,
<&main_udmap 0xca04>,
<&main_udmap 0xca05>,
<&main_udmap 0xca06>,
<&main_udmap 0xca07>,
<&main_udmap 0x4a00>;
"rx";
ethernet-ports {
#size-cells = <0>;
cpsw0_port1: port@1 {
reg = <1>;
ti,mac-only;
label = "port1";
cpsw0_port2: port@2 {
reg = <2>;
ti,mac-only;
label = "port2";
cpsw0_port3: port@3 {
reg = <3>;
ti,mac-only;
label = "port3";
cpsw0_port4: port@4 {
reg = <4>;
ti,mac-only;
label = "port4";
cpsw5g_mdio: mdio@f00 {
#size-cells = <0>;
cpts@3d000 {
clocks = <&k3_clks 19 16>;
interrupts-extended = <&gic500 GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
/* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */
main_timerio_input: pinctrl@104200 {
reg = <0x0 0x104200 0x0 0x50>;
pinctrl-single,function-mask = <0x000001ff>;
/* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */
main_timerio_output: pinctrl@104280 {
reg = <0x0 0x104280 0x0 0x20>;
pinctrl-single,function-mask = <0x0000001f>;
main_pmx0: pinctrl@11c000 {
reg = <0x00 0x11c000 0x00 0x10c>;
main_pmx1: pinctrl@11c11c {
reg = <0x00 0x11c11c 0x00 0xc>;
main_uart0: serial@2800000 {
reg = <0x00 0x02800000 0x00 0x100>;
interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 146 2>;
main_uart1: serial@2810000 {
reg = <0x00 0x02810000 0x00 0x100>;
interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 278 2>;
main_uart2: serial@2820000 {
reg = <0x00 0x02820000 0x00 0x100>;
interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 279 2>;
main_uart3: serial@2830000 {
reg = <0x00 0x02830000 0x00 0x100>;
interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 280 2>;
main_uart4: serial@2840000 {
reg = <0x00 0x02840000 0x00 0x100>;
interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 281 2>;
main_uart5: serial@2850000 {
reg = <0x00 0x02850000 0x00 0x100>;
interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 282 2>;
main_uart6: serial@2860000 {
reg = <0x00 0x02860000 0x00 0x100>;
interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 283 2>;
main_uart7: serial@2870000 {
reg = <0x00 0x02870000 0x00 0x100>;
interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 284 2>;
main_uart8: serial@2880000 {
reg = <0x00 0x02880000 0x00 0x100>;
interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 285 2>;
main_uart9: serial@2890000 {
reg = <0x00 0x02890000 0x00 0x100>;
interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 286 2>;
main_i2c0: i2c@2000000 {
reg = <0x00 0x2000000 0x00 0x100>;
interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 187 1>;
power-domains = <&k3_pds 187 TI_SCI_PD_SHARED>;
main_i2c1: i2c@2010000 {
reg = <0x00 0x2010000 0x00 0x100>;
interrupts = <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 188 1>;
power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>;
main_i2c2: i2c@2020000 {
reg = <0x00 0x2020000 0x00 0x100>;
interrupts = <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 189 1>;
power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>;
main_i2c3: i2c@2030000 {
reg = <0x00 0x2030000 0x00 0x100>;
interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 190 1>;
power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>;
main_i2c4: i2c@2040000 {
reg = <0x00 0x2040000 0x00 0x100>;
interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 191 1>;
power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>;
main_i2c5: i2c@2050000 {
reg = <0x00 0x2050000 0x00 0x100>;
interrupts = <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 192 1>;
power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>;
main_i2c6: i2c@2060000 {
reg = <0x00 0x2060000 0x00 0x100>;
interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 193 1>;
power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>;
main_sdhci0: mmc@4f80000 {
compatible = "ti,j7200-sdhci-8bit", "ti,j721e-sdhci-8bit";
reg = <0x00 0x04f80000 0x00 0x260>, <0x00 0x4f88000 0x00 0x134>;
interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>;
clock-names = "clk_ahb", "clk_xin";
clocks = <&k3_clks 91 0>, <&k3_clks 91 3>;
ti,otap-del-sel-legacy = <0x0>;
ti,otap-del-sel-mmc-hs = <0x0>;
ti,otap-del-sel-ddr52 = <0x6>;
ti,otap-del-sel-hs200 = <0x8>;
ti,otap-del-sel-hs400 = <0x5>;
ti,itap-del-sel-legacy = <0x10>;
ti,itap-del-sel-mmc-hs = <0xa>;
ti,strobe-sel = <0x77>;
ti,clkbuf-sel = <0x7>;
ti,trm-icp = <0x8>;
bus-width = <8>;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
mmc-hs400-1_8v;
dma-coherent;
main_sdhci1: mmc@4fb0000 {
compatible = "ti,j7200-sdhci-4bit", "ti,j721e-sdhci-4bit";
reg = <0x00 0x04fb0000 0x00 0x260>, <0x00 0x4fb8000 0x00 0x134>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 92 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 92 1>, <&k3_clks 92 2>;
ti,otap-del-sel-sd-hs = <0x0>;
ti,otap-del-sel-sdr12 = <0xf>;
ti,otap-del-sel-sdr25 = <0xf>;
ti,otap-del-sel-sdr50 = <0xc>;
ti,otap-del-sel-sdr104 = <0x5>;
ti,otap-del-sel-ddr50 = <0xc>;
ti,itap-del-sel-legacy = <0x0>;
ti,itap-del-sel-sd-hs = <0x0>;
ti,itap-del-sel-sdr12 = <0x0>;
ti,itap-del-sel-sdr25 = <0x0>;
ti,trm-icp = <0x8>;
dma-coherent;
serdes_wiz0: wiz@5060000 {
compatible = "ti,j721e-wiz-10g";
#size-cells = <1>;
power-domains = <&k3_pds 292 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 292 11>, <&k3_clks 292 85>, <&serdes_refclk>;
clock-names = "fck", "core_ref_clk", "ext_ref_clk";
num-lanes = <4>;
#reset-cells = <1>;
ranges = <0x5060000 0x0 0x5060000 0x10000>;
assigned-clocks = <&k3_clks 292 85>;
assigned-clock-parents = <&k3_clks 292 89>;
wiz0_pll0_refclk: pll0-refclk {
clocks = <&k3_clks 292 85>, <&serdes_refclk>;
clock-output-names = "wiz0_pll0_refclk";
#clock-cells = <0>;
assigned-clocks = <&wiz0_pll0_refclk>;
assigned-clock-parents = <&k3_clks 292 85>;
wiz0_pll1_refclk: pll1-refclk {
clock-output-names = "wiz0_pll1_refclk";
#clock-cells = <0>;
assigned-clocks = <&wiz0_pll1_refclk>;
wiz0_refclk_dig: refclk-dig {
clock-output-names = "wiz0_refclk_dig";
#clock-cells = <0>;
assigned-clocks = <&wiz0_refclk_dig>;
wiz0_cmn_refclk_dig_div: cmn-refclk-dig-div {
#clock-cells = <0>;
serdes0: serdes@5060000 {
compatible = "ti,j721e-serdes-10g";
reg = <0x05060000 0x00010000>;
reg-names = "torrent_phy";
resets = <&serdes_wiz0 0>;
reset-names = "torrent_reset";
clock-names = "refclk";
#size-cells = <0>;
pcie1_rc: pcie@2910000 {
compatible = "ti,j7200-pcie-host", "ti,j721e-pcie-host";
reg = <0x00 0x02910000 0x00 0x1000>,
<0x00 0x02917000 0x00 0x400>,
<0x00 0x0d800000 0x00 0x00800000>,
<0x00 0x18000000 0x00 0x00001000>;
reg-names = "intd_cfg", "user_cfg", "reg", "cfg";
interrupt-names = "link_state";
interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>;
device_type = "pci";
ti,syscon-pcie-ctrl = <&scm_conf 0x4074>;
max-link-speed = <3>;
num-lanes = <4>;
power-domains = <&k3_pds 240 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 240 6>;
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x0 0xff>;
cdns,no-bar-match-nbits = <64>;
vendor-id = <0x104c>;
device-id = <0xb00f>;
msi-map = <0x0 &gic_its 0x0 0x10000>;
dma-coherent;
ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>,
<0x02000000 0x0 0x18011000 0x00 0x18011000 0x0 0x7fef000>;
dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>;
pcie1_ep: pcie-ep@2910000 {
compatible = "ti,j7200-pcie-ep", "ti,j721e-pcie-ep";
<0x00 0x18000000 0x00 0x08000000>;
reg-names = "intd_cfg", "user_cfg", "reg", "mem";
num-lanes = <4>;
max-functions = /bits/ 8 <6>;
max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>;
dma-coherent;
usbss0: cdns-usb@4104000 {
compatible = "ti,j721e-usb";
reg = <0x00 0x4104000 0x00 0x100>;
dma-coherent;
power-domains = <&k3_pds 288 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 288 12>, <&k3_clks 288 3>;
clock-names = "ref", "lpm";
assigned-clocks = <&k3_clks 288 12>; /* USB2_REFCLK */
assigned-clock-parents = <&k3_clks 288 13>; /* HFOSC0 */
#size-cells = <2>;
ranges;
usb0: usb@6000000 {
compatible = "cdns,usb3";
reg = <0x00 0x6000000 0x00 0x10000>,
<0x00 0x6010000 0x00 0x10000>,
<0x00 0x6020000 0x00 0x10000>;
reg-names = "otg", "xhci", "dev";
interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */
<GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */
<GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; /* otgirq.0 */
interrupt-names = "host",
"peripheral",
"otg";
maximum-speed = "super-speed";
dr_mode = "otg";
cdns,phyrst-a-enable;
main_gpio0: gpio@600000 {
reg = <0x00 0x00600000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupt-parent = <&main_gpio_intr>;
interrupts = <145>, <146>, <147>, <148>,
<149>;
ti,ngpio = <69>;
power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 105 0>;
main_gpio2: gpio@610000 {
reg = <0x00 0x00610000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupts = <154>, <155>, <156>, <157>,
<158>;
ti,ngpio = <69>;
power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 107 0>;
main_gpio4: gpio@620000 {
reg = <0x00 0x00620000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupts = <163>, <164>, <165>, <166>,
<167>;
ti,ngpio = <69>;
power-domains = <&k3_pds 109 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 109 0>;
main_gpio6: gpio@630000 {
reg = <0x00 0x00630000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupts = <172>, <173>, <174>, <175>,
<176>;
ti,ngpio = <69>;
power-domains = <&k3_pds 111 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 111 0>;
main_spi0: spi@2100000 {
compatible = "ti,am654-mcspi","ti,omap4-mcspi";
reg = <0x00 0x02100000 0x00 0x400>;
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 266 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 266 1>;
main_spi1: spi@2110000 {
reg = <0x00 0x02110000 0x00 0x400>;
interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 267 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 267 1>;
main_spi2: spi@2120000 {
reg = <0x00 0x02120000 0x00 0x400>;
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 268 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 268 1>;
main_spi3: spi@2130000 {
reg = <0x00 0x02130000 0x00 0x400>;
interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 269 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 269 1>;
main_spi4: spi@2140000 {
reg = <0x00 0x02140000 0x00 0x400>;
interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 270 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 270 1>;
main_spi5: spi@2150000 {
reg = <0x00 0x02150000 0x00 0x400>;
interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 271 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 271 1>;
main_spi6: spi@2160000 {
reg = <0x00 0x02160000 0x00 0x400>;
interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 272 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 272 1>;
main_spi7: spi@2170000 {
reg = <0x00 0x02170000 0x00 0x400>;
interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 273 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 273 1>;
watchdog0: watchdog@2200000 {
compatible = "ti,j7-rti-wdt";
reg = <0x0 0x2200000 0x0 0x100>;
clocks = <&k3_clks 252 1>;
power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 252 1>;
assigned-clock-parents = <&k3_clks 252 5>;
watchdog1: watchdog@2210000 {
reg = <0x0 0x2210000 0x0 0x100>;
clocks = <&k3_clks 253 1>;
power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 253 1>;
assigned-clock-parents = <&k3_clks 253 5>;
main_timer0: timer@2400000 {
reg = <0x00 0x2400000 0x00 0x400>;
interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 49 1>;
assigned-clocks = <&k3_clks 49 1>;
assigned-clock-parents = <&k3_clks 49 2>;
power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer1: timer@2410000 {
reg = <0x00 0x2410000 0x00 0x400>;
interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 50 1>;
assigned-clocks = <&k3_clks 50 1>, <&k3_clks 313 0>;
assigned-clock-parents = <&k3_clks 50 2>, <&k3_clks 313 1>;
power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer2: timer@2420000 {
reg = <0x00 0x2420000 0x00 0x400>;
interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 51 1>;
assigned-clocks = <&k3_clks 51 1>;
assigned-clock-parents = <&k3_clks 51 2>;
ti,timer-pwm;
main_timer3: timer@2430000 {
reg = <0x00 0x2430000 0x00 0x400>;
interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 52 1>;
assigned-clocks = <&k3_clks 52 1>, <&k3_clks 314 0>;
assigned-clock-parents = <&k3_clks 52 2>, <&k3_clks 314 1>;
power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer4: timer@2440000 {
reg = <0x00 0x2440000 0x00 0x400>;
interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 53 1>;
assigned-clocks = <&k3_clks 53 1>;
assigned-clock-parents = <&k3_clks 53 2>;
power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer5: timer@2450000 {
reg = <0x00 0x2450000 0x00 0x400>;
interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 54 1>;
assigned-clocks = <&k3_clks 54 1>, <&k3_clks 315 0>;
assigned-clock-parents = <&k3_clks 54 2>, <&k3_clks 315 1>;
power-domains = <&k3_pds 54 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer6: timer@2460000 {
reg = <0x00 0x2460000 0x00 0x400>;
interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 55 1>;
assigned-clocks = <&k3_clks 55 1>;
assigned-clock-parents = <&k3_clks 55 2>;
power-domains = <&k3_pds 55 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer7: timer@2470000 {
reg = <0x00 0x2470000 0x00 0x400>;
interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 57 1>;
assigned-clocks = <&k3_clks 57 1>, <&k3_clks 316 0>;
assigned-clock-parents = <&k3_clks 57 2>, <&k3_clks 316 1>;
power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer8: timer@2480000 {
reg = <0x00 0x2480000 0x00 0x400>;
interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 58 1>;
assigned-clocks = <&k3_clks 58 1>;
assigned-clock-parents = <&k3_clks 58 2>;
power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer9: timer@2490000 {
reg = <0x00 0x2490000 0x00 0x400>;
interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 59 1>;
assigned-clocks = <&k3_clks 59 1>, <&k3_clks 317 0>;
assigned-clock-parents = <&k3_clks 59 2>, <&k3_clks 317 1>;
power-domains = <&k3_pds 59 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer10: timer@24a0000 {
compatible = "ti,am654-timer";
reg = <0x00 0x24a0000 0x00 0x400>;
interrupts = <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 60 1>;
assigned-clocks = <&k3_clks 60 1>;
assigned-clock-parents = <&k3_clks 60 2>;
power-domains = <&k3_pds 60 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer11: timer@24b0000 {
reg = <0x00 0x24b0000 0x00 0x400>;
interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 62 1>;
assigned-clocks = <&k3_clks 62 1>, <&k3_clks 318 0>;
assigned-clock-parents = <&k3_clks 62 2>, <&k3_clks 318 1>;
power-domains = <&k3_pds 62 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer12: timer@24c0000 {
reg = <0x00 0x24c0000 0x00 0x400>;
interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 63 1>;
assigned-clocks = <&k3_clks 63 1>;
assigned-clock-parents = <&k3_clks 63 2>;
power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer13: timer@24d0000 {
reg = <0x00 0x24d0000 0x00 0x400>;
interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 64 1>;
assigned-clocks = <&k3_clks 64 1>, <&k3_clks 319 0>;
assigned-clock-parents = <&k3_clks 64 2>, <&k3_clks 319 1>;
power-domains = <&k3_pds 64 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer14: timer@24e0000 {
reg = <0x00 0x24e0000 0x00 0x400>;
interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 65 1>;
assigned-clocks = <&k3_clks 65 1>;
assigned-clock-parents = <&k3_clks 65 2>;
power-domains = <&k3_pds 65 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer15: timer@24f0000 {
reg = <0x00 0x24f0000 0x00 0x400>;
interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 66 1>;
assigned-clocks = <&k3_clks 66 1>, <&k3_clks 320 0>;
assigned-clock-parents = <&k3_clks 66 2>, <&k3_clks 320 1>;
power-domains = <&k3_pds 66 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer16: timer@2500000 {
reg = <0x00 0x2500000 0x00 0x400>;
interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 67 1>;
assigned-clocks = <&k3_clks 67 1>;
assigned-clock-parents = <&k3_clks 67 2>;
power-domains = <&k3_pds 67 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer17: timer@2510000 {
reg = <0x00 0x2510000 0x00 0x400>;
interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 68 1>;
assigned-clocks = <&k3_clks 68 1>, <&k3_clks 321 0>;
assigned-clock-parents = <&k3_clks 68 2>, <&k3_clks 321 1>;
power-domains = <&k3_pds 68 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer18: timer@2520000 {
reg = <0x00 0x2520000 0x00 0x400>;
interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 69 1>;
assigned-clocks = <&k3_clks 69 1>;
assigned-clock-parents = <&k3_clks 69 2>;
power-domains = <&k3_pds 69 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_timer19: timer@2530000 {
reg = <0x00 0x2530000 0x00 0x400>;
interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 70 1>;
assigned-clocks = <&k3_clks 70 1>, <&k3_clks 322 0>;
assigned-clock-parents = <&k3_clks 70 2>, <&k3_clks 322 1>;
power-domains = <&k3_pds 70 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
main_r5fss0: r5fss@5c00000 {
#size-cells = <1>;
ranges = <0x5c00000 0x00 0x5c00000 0x20000>,
<0x5d00000 0x00 0x5d00000 0x20000>;
power-domains = <&k3_pds 243 TI_SCI_PD_EXCLUSIVE>;
main_r5fss0_core0: r5f@5c00000 {
reg = <0x5c00000 0x00010000>,
<0x5c10000 0x00010000>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <245>;
ti,sci-proc-ids = <0x06 0xff>;
resets = <&k3_reset 245 1>;
firmware-name = "j7200-main-r5f0_0-fw";
ti,loczrama = <1>;
main_r5fss0_core1: r5f@5d00000 {
reg = <0x5d00000 0x00008000>,
<0x5d10000 0x00008000>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <246>;
ti,sci-proc-ids = <0x07 0xff>;
resets = <&k3_reset 246 1>;
firmware-name = "j7200-main-r5f0_1-fw";
ti,loczrama = <1>;
main_esm: esm@700000 {
reg = <0x0 0x700000 0x0 0x1000>;
ti,esm-pins = <656>, <657>;
-}; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi deleted file mode 100644 index 3fc588b848c..00000000000 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ /dev/null @@ -1,647 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for J7200 SoC Family MCU/WAKEUP Domain peripherals
-&cbass_mcu_wakeup {
dmsc: system-controller@44083000 {
compatible = "ti,k2g-sci";
ti,host-id = <12>;
mbox-names = "rx", "tx";
mboxes = <&secure_proxy_main 11>,
<&secure_proxy_main 13>;
reg-names = "debug_messages";
reg = <0x00 0x44083000 0x00 0x1000>;
k3_pds: power-controller {
compatible = "ti,sci-pm-domain";
#power-domain-cells = <2>;
k3_clks: clock-controller {
compatible = "ti,k2g-sci-clk";
#clock-cells = <2>;
k3_reset: reset-controller {
compatible = "ti,sci-reset";
#reset-cells = <2>;
mcu_timer0: timer@40400000 {
status = "reserved";
reg = <0x00 0x40400000 0x00 0x400>;
interrupts = <GIC_SPI 816 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 35 1>;
assigned-clocks = <&k3_clks 35 1>;
assigned-clock-parents = <&k3_clks 35 2>;
power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer1: timer@40410000 {
reg = <0x00 0x40410000 0x00 0x400>;
interrupts = <GIC_SPI 817 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 71 1>;
assigned-clocks = <&k3_clks 71 1>, <&k3_clks 308 0>;
assigned-clock-parents = <&k3_clks 71 2>, <&k3_clks 308 1>;
power-domains = <&k3_pds 71 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer2: timer@40420000 {
reg = <0x00 0x40420000 0x00 0x400>;
interrupts = <GIC_SPI 818 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 72 1>;
assigned-clocks = <&k3_clks 72 1>;
assigned-clock-parents = <&k3_clks 72 2>;
power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer3: timer@40430000 {
reg = <0x00 0x40430000 0x00 0x400>;
interrupts = <GIC_SPI 819 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 73 1>;
assigned-clocks = <&k3_clks 73 1>, <&k3_clks 309 0>;
assigned-clock-parents = <&k3_clks 73 2>, <&k3_clks 309 1>;
power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer4: timer@40440000 {
reg = <0x00 0x40440000 0x00 0x400>;
interrupts = <GIC_SPI 820 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 74 1>;
assigned-clocks = <&k3_clks 74 1>;
assigned-clock-parents = <&k3_clks 74 2>;
power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer5: timer@40450000 {
reg = <0x00 0x40450000 0x00 0x400>;
interrupts = <GIC_SPI 821 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 75 1>;
assigned-clocks = <&k3_clks 75 1>, <&k3_clks 310 0>;
assigned-clock-parents = <&k3_clks 75 2>, <&k3_clks 310 1>;
power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer6: timer@40460000 {
reg = <0x00 0x40460000 0x00 0x400>;
interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 76 1>;
assigned-clocks = <&k3_clks 76 1>;
assigned-clock-parents = <&k3_clks 76 2>;
ti,timer-pwm;
mcu_timer7: timer@40470000 {
reg = <0x00 0x40470000 0x00 0x400>;
interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 77 1>;
assigned-clocks = <&k3_clks 77 1>, <&k3_clks 311 0>;
assigned-clock-parents = <&k3_clks 77 2>, <&k3_clks 311 1>;
power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer8: timer@40480000 {
reg = <0x00 0x40480000 0x00 0x400>;
interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 78 1>;
assigned-clocks = <&k3_clks 78 1>;
assigned-clock-parents = <&k3_clks 78 2>;
power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_timer9: timer@40490000 {
reg = <0x00 0x40490000 0x00 0x400>;
interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 79 1>;
assigned-clocks = <&k3_clks 79 1>, <&k3_clks 312 0>;
assigned-clock-parents = <&k3_clks 79 2>, <&k3_clks 312 1>;
power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
mcu_conf: syscon@40f00000 {
reg = <0x00 0x40f00000 0x00 0x20000>;
#size-cells = <1>;
ranges = <0x00 0x00 0x40f00000 0x20000>;
phy_gmii_sel: phy@4040 {
compatible = "ti,am654-phy-gmii-sel";
reg = <0x4040 0x4>;
#phy-cells = <1>;
chipid@43000014 {
compatible = "ti,am654-chipid";
reg = <0x00 0x43000014 0x00 0x4>;
/* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */
mcu_timerio_input: pinctrl@40f04200 {
compatible = "pinctrl-single";
reg = <0x0 0x40f04200 0x0 0x28>;
#pinctrl-cells = <1>;
pinctrl-single,register-width = <32>;
pinctrl-single,function-mask = <0x0000000F>;
/* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */
mcu_timerio_output: pinctrl@40f04280 {
reg = <0x0 0x40f04280 0x0 0x28>;
wkup_pmx0: pinctrl@4301c000 {
/* Proxy 0 addressing */
reg = <0x00 0x4301c000 0x00 0x34>;
pinctrl-single,function-mask = <0xffffffff>;
wkup_pmx1: pinctrl@4301c038 {
reg = <0x00 0x4301c038 0x00 0x8>;
wkup_pmx2: pinctrl@4301c068 {
reg = <0x00 0x4301c068 0x00 0xec>;
wkup_pmx3: pinctrl@4301c174 {
reg = <0x00 0x4301c174 0x00 0x20>;
mcu_ram: sram@41c00000 {
compatible = "mmio-sram";
reg = <0x00 0x41c00000 0x00 0x100000>;
ranges = <0x00 0x00 0x41c00000 0x100000>;
#size-cells = <1>;
wkup_uart0: serial@42300000 {
compatible = "ti,j721e-uart", "ti,am654-uart";
reg = <0x00 0x42300000 0x00 0x100>;
interrupts = <GIC_SPI 897 IRQ_TYPE_LEVEL_HIGH>;
clock-frequency = <48000000>;
current-speed = <115200>;
power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 287 2>;
clock-names = "fclk";
mcu_uart0: serial@40a00000 {
reg = <0x00 0x40a00000 0x00 0x100>;
interrupts = <GIC_SPI 846 IRQ_TYPE_LEVEL_HIGH>;
clock-frequency = <96000000>;
power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 149 2>;
wkup_gpio_intr: interrupt-controller@42200000 {
compatible = "ti,sci-intr";
reg = <0x00 0x42200000 0x00 0x400>;
ti,intr-trigger-type = <1>;
interrupt-controller;
#interrupt-cells = <1>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <137>;
ti,interrupt-ranges = <16 960 16>;
wkup_gpio0: gpio@42110000 {
compatible = "ti,j721e-gpio", "ti,keystone-gpio";
reg = <0x00 0x42110000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupt-parent = <&wkup_gpio_intr>;
interrupts = <103>, <104>, <105>, <106>, <107>, <108>;
#interrupt-cells = <2>;
ti,ngpio = <85>;
ti,davinci-gpio-unbanked = <0>;
power-domains = <&k3_pds 113 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 113 0>;
clock-names = "gpio";
wkup_gpio1: gpio@42100000 {
reg = <0x00 0x42100000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupts = <112>, <113>, <114>, <115>, <116>, <117>;
ti,ngpio = <85>;
power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 114 0>;
mcu_navss: bus@28380000 {
#size-cells = <2>;
ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>;
dma-coherent;
dma-ranges;
ti,sci-dev-id = <232>;
mcu_ringacc: ringacc@2b800000 {
compatible = "ti,am654-navss-ringacc";
reg = <0x00 0x2b800000 0x00 0x400000>,
<0x00 0x2b000000 0x00 0x400000>,
<0x00 0x28590000 0x00 0x100>,
<0x00 0x2a500000 0x00 0x40000>,
<0x00 0x28440000 0x00 0x40000>;
ti,num-rings = <286>;
ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */
ti,sci = <&dmsc>;
ti,sci-dev-id = <235>;
msi-parent = <&main_udmass_inta>;
mcu_udmap: dma-controller@285c0000 {
compatible = "ti,j721e-navss-mcu-udmap";
reg = <0x00 0x285c0000 0x00 0x100>,
<0x00 0x2a800000 0x00 0x40000>,
<0x00 0x2aa00000 0x00 0x40000>;
reg-names = "gcfg", "rchanrt", "tchanrt";
#dma-cells = <1>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <236>;
ti,ringacc = <&mcu_ringacc>;
ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */
<0x0f>; /* TX_HCHAN */
ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */
<0x0b>; /* RX_HCHAN */
ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */
secure_proxy_mcu: mailbox@2a480000 {
compatible = "ti,am654-secure-proxy";
#mbox-cells = <1>;
reg-names = "target_data", "rt", "scfg";
reg = <0x0 0x2a480000 0x0 0x80000>,
<0x0 0x2a380000 0x0 0x80000>,
<0x0 0x2a400000 0x0 0x80000>;
* Marked Disabled:
* Node is incomplete as it is meant for bootloaders and
* firmware on non-MPU processors
mcu_cpsw: ethernet@46000000 {
compatible = "ti,j721e-cpsw-nuss";
#size-cells = <2>;
reg = <0x00 0x46000000 0x00 0x200000>;
reg-names = "cpsw_nuss";
ranges = <0x00 0x00 0x00 0x46000000 0x00 0x200000>;
dma-coherent;
clocks = <&k3_clks 18 21>;
clock-names = "fck";
power-domains = <&k3_pds 18 TI_SCI_PD_EXCLUSIVE>;
dmas = <&mcu_udmap 0xf000>,
<&mcu_udmap 0xf001>,
<&mcu_udmap 0xf002>,
<&mcu_udmap 0xf003>,
<&mcu_udmap 0xf004>,
<&mcu_udmap 0xf005>,
<&mcu_udmap 0xf006>,
<&mcu_udmap 0xf007>,
<&mcu_udmap 0x7000>;
dma-names = "tx0", "tx1", "tx2", "tx3",
"tx4", "tx5", "tx6", "tx7",
"rx";
ethernet-ports {
#size-cells = <0>;
cpsw_port1: port@1 {
reg = <1>;
ti,mac-only;
label = "port1";
ti,syscon-efuse = <&mcu_conf 0x200>;
phys = <&phy_gmii_sel 1>;
davinci_mdio: mdio@f00 {
compatible = "ti,cpsw-mdio","ti,davinci_mdio";
reg = <0x00 0xf00 0x00 0x100>;
#size-cells = <0>;
bus_freq = <1000000>;
cpts@3d000 {
compatible = "ti,am65-cpts";
reg = <0x00 0x3d000 0x00 0x400>;
clocks = <&k3_clks 18 2>;
clock-names = "cpts";
interrupts-extended = <&gic500 GIC_SPI 858 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "cpts";
ti,cpts-ext-ts-inputs = <4>;
ti,cpts-periodic-outputs = <2>;
mcu_i2c0: i2c@40b00000 {
compatible = "ti,j721e-i2c", "ti,omap4-i2c";
reg = <0x00 0x40b00000 0x00 0x100>;
interrupts = <GIC_SPI 852 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 194 1>;
power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>;
mcu_i2c1: i2c@40b10000 {
reg = <0x00 0x40b10000 0x00 0x100>;
interrupts = <GIC_SPI 853 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 195 1>;
power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>;
wkup_i2c0: i2c@42120000 {
reg = <0x00 0x42120000 0x00 0x100>;
interrupts = <GIC_SPI 896 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&k3_clks 197 1>;
power-domains = <&k3_pds 197 TI_SCI_PD_SHARED>;
mcu_spi0: spi@40300000 {
compatible = "ti,am654-mcspi", "ti,omap4-mcspi";
reg = <0x00 0x040300000 0x00 0x400>;
interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 274 0>;
mcu_spi1: spi@40310000 {
reg = <0x00 0x040310000 0x00 0x400>;
interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 275 0>;
mcu_spi2: spi@40320000 {
reg = <0x00 0x040320000 0x00 0x400>;
interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 276 0>;
fss: syscon@47000000 {
compatible = "syscon", "simple-mfd";
reg = <0x00 0x47000000 0x00 0x100>;
#size-cells = <2>;
ranges;
hbmc_mux: hbmc-mux {
compatible = "mmio-mux";
#mux-control-cells = <1>;
mux-reg-masks = <0x4 0x2>; /* HBMC select */
hbmc: hyperbus@47034000 {
compatible = "ti,am654-hbmc";
reg = <0x00 0x47034000 0x00 0x100>,
<0x05 0x00000000 0x01 0x0000000>;
power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 102 0>;
assigned-clocks = <&k3_clks 102 5>;
assigned-clock-rates = <333333333>;
#size-cells = <1>;
mux-controls = <&hbmc_mux 0>;
ospi0: spi@47040000 {
compatible = "ti,am654-ospi", "cdns,qspi-nor";
reg = <0x0 0x47040000 0x0 0x100>,
<0x5 0x00000000 0x1 0x0000000>;
interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>;
cdns,fifo-depth = <256>;
cdns,fifo-width = <4>;
cdns,trigger-address = <0x0>;
clocks = <&k3_clks 103 0>;
assigned-clocks = <&k3_clks 103 0>;
assigned-clock-parents = <&k3_clks 103 2>;
assigned-clock-rates = <166666666>;
power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <0>;
tscadc0: tscadc@40200000 {
compatible = "ti,am3359-tscadc";
reg = <0x00 0x40200000 0x00 0x1000>;
interrupts = <GIC_SPI 860 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 0 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 0 1>;
assigned-clocks = <&k3_clks 0 3>;
assigned-clock-rates = <60000000>;
dmas = <&main_udmap 0x7400>,
<&main_udmap 0x7401>;
dma-names = "fifo0", "fifo1";
adc {
#io-channel-cells = <1>;
compatible = "ti,am3359-adc";
mcu_r5fss0: r5fss@41000000 {
compatible = "ti,j7200-r5fss";
ti,cluster-mode = <1>;
#size-cells = <1>;
ranges = <0x41000000 0x00 0x41000000 0x20000>,
<0x41400000 0x00 0x41400000 0x20000>;
power-domains = <&k3_pds 249 TI_SCI_PD_EXCLUSIVE>;
mcu_r5fss0_core0: r5f@41000000 {
compatible = "ti,j7200-r5f";
reg = <0x41000000 0x00010000>,
<0x41010000 0x00010000>;
reg-names = "atcm", "btcm";
ti,sci = <&dmsc>;
ti,sci-dev-id = <250>;
ti,sci-proc-ids = <0x01 0xff>;
resets = <&k3_reset 250 1>;
firmware-name = "j7200-mcu-r5f0_0-fw";
ti,atcm-enable = <1>;
ti,btcm-enable = <1>;
ti,loczrama = <1>;
mcu_r5fss0_core1: r5f@41400000 {
reg = <0x41400000 0x00008000>,
<0x41410000 0x00008000>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <251>;
ti,sci-proc-ids = <0x02 0xff>;
resets = <&k3_reset 251 1>;
firmware-name = "j7200-mcu-r5f0_1-fw";
ti,loczrama = <1>;
mcu_crypto: crypto@40900000 {
compatible = "ti,j721e-sa2ul";
reg = <0x00 0x40900000 0x00 0x1200>;
power-domains = <&k3_pds 265 TI_SCI_PD_SHARED>;
#size-cells = <2>;
ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>;
dmas = <&mcu_udmap 0xf501>, <&mcu_udmap 0x7502>,
<&mcu_udmap 0x7503>;
dma-names = "tx", "rx1", "rx2";
rng: rng@40910000 {
compatible = "inside-secure,safexcel-eip76";
reg = <0x00 0x40910000 0x00 0x7d>;
interrupts = <GIC_SPI 945 IRQ_TYPE_LEVEL_HIGH>;
status = "disabled"; /* Used by OP-TEE */
wkup_vtm0: temperature-sensor@42040000 {
compatible = "ti,j7200-vtm";
reg = <0x00 0x42040000 0x00 0x350>,
<0x00 0x42050000 0x00 0x350>;
power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>;
#thermal-sensor-cells = <1>;
mcu_esm: esm@40800000 {
compatible = "ti,j721e-esm";
reg = <0x00 0x40800000 0x00 0x1000>;
ti,esm-pins = <95>;
bootph-pre-ram;
-}; diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi deleted file mode 100644 index 5a300d4c8ba..00000000000 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ /dev/null @@ -1,327 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
-/dts-v1/;
-#include "k3-j7200.dtsi"
memory@80000000 {
device_type = "memory";
/* 4G RAM */
reg = <0x00 0x80000000 0x00 0x80000000>,
<0x08 0x80000000 0x00 0x80000000>;
reserved_memory: reserved-memory {
#size-cells = <2>;
ranges;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>;
alignment = <0x1000>;
no-map;
mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
compatible = "shared-dma-pool";
reg = <0x00 0xa0000000 0x00 0x100000>;
no-map;
mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 {
reg = <0x00 0xa0100000 0x00 0xf00000>;
no-map;
mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 {
reg = <0x00 0xa1000000 0x00 0x100000>;
no-map;
mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 {
reg = <0x00 0xa1100000 0x00 0xf00000>;
no-map;
main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 {
reg = <0x00 0xa2000000 0x00 0x100000>;
no-map;
main_r5fss0_core0_memory_region: r5f-memory@a2100000 {
reg = <0x00 0xa2100000 0x00 0xf00000>;
no-map;
main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 {
reg = <0x00 0xa3000000 0x00 0x100000>;
no-map;
main_r5fss0_core1_memory_region: r5f-memory@a3100000 {
reg = <0x00 0xa3100000 0x00 0xf00000>;
no-map;
rtos_ipc_memory_region: ipc-memories@a4000000 {
reg = <0x00 0xa4000000 0x00 0x00800000>;
no-map;
-&wkup_pmx0 {
mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-default-pins {
pinctrl-single,pins = <
J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (B6) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */
J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C8) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */
J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 1) /* (D6) MCU_OSPI0_CSn0.MCU_HYPERBUS0_CSn0 */
J721E_WKUP_IOPAD(0x30, PIN_OUTPUT, 1) /* (D7) MCU_OSPI0_CSn1.MCU_HYPERBUS0_RESETn */
J721E_WKUP_IOPAD(0x8, PIN_INPUT, 1) /* (B7) MCU_OSPI0_DQS.MCU_HYPERBUS0_RWDS */
J721E_WKUP_IOPAD(0xc, PIN_INPUT, 1) /* (D8) MCU_OSPI0_D0.MCU_HYPERBUS0_DQ0 */
J721E_WKUP_IOPAD(0x10, PIN_INPUT, 1) /* (C7) MCU_OSPI0_D1.MCU_HYPERBUS0_DQ1 */
J721E_WKUP_IOPAD(0x14, PIN_INPUT, 1) /* (C5) MCU_OSPI0_D2.MCU_HYPERBUS0_DQ2 */
J721E_WKUP_IOPAD(0x18, PIN_INPUT, 1) /* (A5) MCU_OSPI0_D3.MCU_HYPERBUS0_DQ3 */
J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 1) /* (A6) MCU_OSPI0_D4.MCU_HYPERBUS0_DQ4 */
J721E_WKUP_IOPAD(0x20, PIN_INPUT, 1) /* (B8) MCU_OSPI0_D5.MCU_HYPERBUS0_DQ5 */
J721E_WKUP_IOPAD(0x24, PIN_INPUT, 1) /* (A8) MCU_OSPI0_D6.MCU_HYPERBUS0_DQ6 */
J721E_WKUP_IOPAD(0x28, PIN_INPUT, 1) /* (A7) MCU_OSPI0_D7.MCU_HYPERBUS0_DQ7 */
mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-default-pins {
J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_OSPI0_CLK */
J721E_WKUP_IOPAD(0x002c, PIN_OUTPUT, 0) /* MCU_OSPI0_CSn0 */
J721E_WKUP_IOPAD(0x000c, PIN_INPUT, 0) /* MCU_OSPI0_D0 */
J721E_WKUP_IOPAD(0x0010, PIN_INPUT, 0) /* MCU_OSPI0_D1 */
J721E_WKUP_IOPAD(0x0014, PIN_INPUT, 0) /* MCU_OSPI0_D2 */
J721E_WKUP_IOPAD(0x0018, PIN_INPUT, 0) /* MCU_OSPI0_D3 */
J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_OSPI0_D4 */
J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_OSPI0_D5 */
J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_OSPI0_D6 */
J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_OSPI0_D7 */
J721E_WKUP_IOPAD(0x0008, PIN_INPUT, 0) /* MCU_OSPI0_DQS */
-&wkup_pmx2 {
wkup_i2c0_pins_default: wkup-i2c0-default-pins {
J721E_WKUP_IOPAD(0x98, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */
J721E_WKUP_IOPAD(0x9c, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */
-&main_pmx0 {
main_i2c0_pins_default: main-i2c0-default-pins {
J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */
J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */
-&hbmc {
/* OSPI and HBMC are muxed inside FSS, Bootloader will enable
* appropriate node based on board detection
pinctrl-names = "default";
pinctrl-0 = <&mcu_fss0_hpb0_pins_default>;
ranges = <0x00 0x00 0x05 0x00000000 0x4000000>, /* 64MB Flash on CS0 */
<0x01 0x00 0x05 0x04000000 0x800000>; /* 8MB RAM on CS1 */
flash@0,0 {
compatible = "cypress,hyperflash", "cfi-flash";
reg = <0x00 0x00 0x4000000>;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "hbmc.tiboot3";
reg = <0x0 0x100000>;
partition@100000 {
label = "hbmc.tispl";
reg = <0x100000 0x200000>;
partition@300000 {
label = "hbmc.u-boot";
reg = <0x300000 0x400000>;
partition@700000 {
label = "hbmc.env";
reg = <0x700000 0x40000>;
partition@800000 {
label = "hbmc.rootfs";
reg = <0x800000 0x3800000>;
-&mailbox0_cluster0 {
status = "okay";
interrupts = <436>;
mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
ti,mbox-rx = <2 0 0>;
ti,mbox-tx = <3 0 0>;
-&mailbox0_cluster1 {
status = "okay";
interrupts = <432>;
mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
-&mcu_r5fss0_core0 {
mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core0>;
memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
<&mcu_r5fss0_core0_memory_region>;
-&mcu_r5fss0_core1 {
mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core1>;
memory-region = <&mcu_r5fss0_core1_dma_memory_region>,
<&mcu_r5fss0_core1_memory_region>;
-&main_r5fss0_core0 {
mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core0>;
memory-region = <&main_r5fss0_core0_dma_memory_region>,
<&main_r5fss0_core0_memory_region>;
-&main_r5fss0_core1 {
mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core1>;
memory-region = <&main_r5fss0_core1_dma_memory_region>,
<&main_r5fss0_core1_memory_region>;
-&main_i2c0 {
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
exp_som: gpio@21 {
compatible = "ti,tca6408";
reg = <0x21>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "USB2.0_MUX_SEL", "CANUART_MUX1_SEL0",
"CANUART_MUX2_SEL0", "CANUART_MUX_SEL1",
"UART/LIN_MUX_SEL", "TRC_D17/AUDIO_REFCLK_SEL",
"GPIO_LIN_EN", "CAN_STB";
-&wkup_i2c0 {
status = "okay";
pinctrl-0 = <&wkup_i2c0_pins_default>;
eeprom@50 {
compatible = "atmel,24c256";
reg = <0x50>;
-&ospi0 {
status = "okay";
pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
flash@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <8>;
spi-rx-bus-width = <8>;
spi-max-frequency = <25000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <4>;
partitions {
#address-cells = <1>;
#size-cells = <1>;
partition@0 {
label = "ospi.tiboot3";
partition@100000 {
label = "ospi.tispl";
partition@300000 {
label = "ospi.u-boot";
partition@700000 {
label = "ospi.env";
partition@740000 {
label = "ospi.env.backup";
reg = <0x740000 0x40000>;
partition@800000 {
label = "ospi.rootfs";
reg = <0x800000 0x37c0000>;
partition@3fc0000 {
label = "ospi.phypattern";
reg = <0x3fc0000 0x40000>;
-}; diff --git a/arch/arm/dts/k3-j7200-thermal.dtsi b/arch/arm/dts/k3-j7200-thermal.dtsi deleted file mode 100644 index e7e3a643a6f..00000000000 --- a/arch/arm/dts/k3-j7200-thermal.dtsi +++ /dev/null @@ -1,47 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0
-#include <dt-bindings/thermal/thermal.h>
-thermal_zones: thermal-zones {
mcu_thermal: mcu-thermal {
polling-delay-passive = <250>; /* milliseconds */
polling-delay = <500>; /* milliseconds */
thermal-sensors = <&wkup_vtm0 0>;
trips {
wkup_crit: wkup-crit {
temperature = <125000>; /* milliCelsius */
hysteresis = <2000>; /* milliCelsius */
type = "critical";
mpu_thermal: mpu-thermal {
thermal-sensors = <&wkup_vtm0 1>;
trips {
mpu_crit: mpu-crit {
type = "critical";
main_thermal: main-thermal {
thermal-sensors = <&wkup_vtm0 2>;
trips {
c7x_crit: c7x-crit {
type = "critical";
-}; diff --git a/arch/arm/dts/k3-j7200.dtsi b/arch/arm/dts/k3-j7200.dtsi deleted file mode 100644 index ef73e6d7e85..00000000000 --- a/arch/arm/dts/k3-j7200.dtsi +++ /dev/null @@ -1,164 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
-#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/soc/ti,sci_pm_domain.h>
-#include "k3-pinctrl.h"
model = "Texas Instruments K3 J7200 SoC";
compatible = "ti,j7200";
interrupt-parent = <&gic500>;
#size-cells = <2>;
chosen { };
cpus {
#size-cells = <0>;
cpu-map {
cluster0: cluster0 {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
cpu0: cpu@0 {
compatible = "arm,cortex-a72";
reg = <0x000>;
device_type = "cpu";
enable-method = "psci";
i-cache-size = <0xc000>;
i-cache-line-size = <64>;
i-cache-sets = <256>;
d-cache-size = <0x8000>;
d-cache-line-size = <64>;
d-cache-sets = <256>;
next-level-cache = <&L2_0>;
cpu1: cpu@1 {
reg = <0x001>;
L2_0: l2-cache0 {
compatible = "cache";
cache-level = <2>;
cache-unified;
cache-size = <0x100000>;
cache-sets = <1024>;
next-level-cache = <&msmc_l3>;
msmc_l3: l3-cache0 {
cache-level = <3>;
cache-unified;
firmware {
optee {
compatible = "linaro,optee-tz";
method = "smc";
psci: psci {
compatible = "arm,psci-1.0";
method = "smc";
a72_timer0: timer-cl0-cpu0 {
compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */
<GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */
<GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */
<GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */
pmu: pmu {
compatible = "arm,cortex-a72-pmu";
interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>;
cbass_main: bus@100000 {
#size-cells = <2>;
ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */
<0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */
<0x00 0x00700000 0x00 0x00700000 0x00 0x00001000>, /* ESM */
<0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* timesync router */
<0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */
<0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */
<0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */
<0x00 0x70000000 0x00 0x70000000 0x00 0x00800000>, /* MSMC RAM */
<0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */
<0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */
/* MCUSS_WKUP Range */
<0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>,
<0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>,
<0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>,
<0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>,
<0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>,
<0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>,
<0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>,
<0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>,
<0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>,
<0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>,
<0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>,
<0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>,
<0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>;
cbass_mcu_wakeup: bus@28380000 {
compatible = "simple-bus";
#address-cells = <2>;
#size-cells = <2>;
ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, /* MCU NAVSS*/
<0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, /* First peripheral window */
<0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, /* CTRL_MMR0 */
<0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, /* MCU R5F Core0 */
<0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, /* MCU R5F Core1 */
<0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, /* MCU SRAM */
<0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, /* WKUP peripheral window */
<0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, /* MMRs, remaining NAVSS */
<0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, /* CPSW */
<0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, /* OSPI register space */
<0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, /* FSS OSPI0/1 data region 0 */
<0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS OSPI0 data region 3 */
<0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3 */
#include "k3-j7200-thermal.dtsi"
-/* Now include the peripherals for each bus segments */ -#include "k3-j7200-main.dtsi" -#include "k3-j7200-mcu-wakeup.dtsi" diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index fe8e84c9214..4db5654ca1c 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -15,7 +15,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_ENV_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-common-proc-board" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-j7200-common-proc-board" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -96,6 +96,7 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y +CONFIG_OF_UPSTREAM=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_CCF=y -- 2.34.1
Aniket Limaye
Sumit Garg
