[U-Boot] [PATCH v2] powerpc/85xx: enable some P1/P2 boards mtdparts for nor flash
Enable these boards mtdparts for nor flash: p1020rdb-pd, p1021rdb-pc, p1022ds, p1025twr, and p2020rdb-pc.
Signed-off-by: Xie Xiaobo X.Xie@freescale.com Signed-off-by: Yangbo Lu yangbo.lu@freescale.com Cc: Scott Wood scottwood@freescale.com --- Changes for v2: - changed commit message - fixed max line length problem in code --- include/configs/P1022DS.h | 12 ++++++++++++ include/configs/p1_p2_rdb_pc.h | 31 +++++++++++++++++++++++++++++++ include/configs/p1_twr.h | 12 ++++++++++++ 3 files changed, 55 insertions(+)
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 139d4fe..4480270 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -620,6 +620,18 @@ #endif
/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=e8000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=e8000000.nor:48m(ramdisk)," \ + "14m(diagnostic),2m(dink),6m(kernel),58112k(fs)," \ + "512k(dtb),768k(u-boot)" + +/* * Environment */ #ifdef CONFIG_SPIFLASH diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 07b6179..1ed8838 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -77,6 +77,16 @@ #define __SW_BOOT_NAND 0x44 #define __SW_BOOT_PCIE 0x74 #define CONFIG_SYS_L2_SIZE (256 << 10) +/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ec000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ec000000.nor:128k(dtb),6016k(kernel)," \ + "57088k(fs),1m(vsc7385-firmware),1280k(u-boot)" #endif
#if defined(CONFIG_P1021RDB) @@ -95,6 +105,17 @@ #define __SW_BOOT_NAND 0xec #define __SW_BOOT_PCIE 0x6c #define CONFIG_SYS_L2_SIZE (256 << 10) +/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ef000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ef000000.nor:256k(vsc7385-firmware)," \ + "256k(dtb),4608k(kernel),9728k(fs)," \ + "256k(qe-ucode-firmware),1280k(u-boot)" #endif
#if defined(CONFIG_P1024RDB) @@ -142,6 +163,16 @@ #define __SW_BOOT_NAND 0xe8 #define __SW_BOOT_PCIE 0xa8 #define CONFIG_SYS_L2_SIZE (512 << 10) +/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ef000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ef000000.nor:256k(vsc7385-firmware)," \ + "256k(dtb),4608k(kernel),9984k(fs),1280k(u-boot)" #endif
#ifdef CONFIG_SDCARD diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index c296a07..d3093f5 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -389,6 +389,18 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif /* CONFIG_TWR-P1025 */
/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ec000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ec000000.nor:256k(vsc7385-firmware)," \ + "256k(dtb),5632k(kernel),57856k(fs)," \ + "256k(qe-ucode-firmware),1280k(u-boot)" + +/* * Environment */ #ifdef CONFIG_SYS_RAMBOOT
Any comment? Thanks a lot.
Best regards, Yangbo Lu
-----Original Message----- From: Yangbo Lu [mailto:yangbo.lu@freescale.com] Sent: Tuesday, July 29, 2014 3:22 PM To: u-boot@lists.denx.de Cc: Lu Yangbo-B47093; Xie Xiaobo-R63061; Wood Scott-B07421 Subject: [PATCH v2] powerpc/85xx: enable some P1/P2 boards mtdparts for nor flash
/* + * Dynamic MTD Partition support with mtdparts */ #define +CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define +CONFIG_CMD_MTDPARTS #define CONFIG_FLASH_CFI_MTD #define MTDIDS_DEFAULT +"nor0=e8000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=e8000000.nor:48m(ramdisk)," \ + "14m(diagnostic),2m(dink),6m(kernel),58112k(fs)," \ + "512k(dtb),768k(u-boot)" + +/* * Environment */ #ifdef CONFIG_SPIFLASH diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 07b6179..1ed8838 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -77,6 +77,16 @@ #define __SW_BOOT_NAND 0x44 #define __SW_BOOT_PCIE 0x74 #define CONFIG_SYS_L2_SIZE (256 << 10) +/* + * Dynamic MTD Partition support with mtdparts */ #define +CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define +CONFIG_CMD_MTDPARTS #define CONFIG_FLASH_CFI_MTD #define MTDIDS_DEFAULT +"nor0=ec000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ec000000.nor:128k(dtb),6016k(kernel)," \ + "57088k(fs),1m(vsc7385-firmware),1280k(u-boot)" #endif
#if defined(CONFIG_P1021RDB) @@ -95,6 +105,17 @@ #define __SW_BOOT_NAND 0xec #define __SW_BOOT_PCIE 0x6c #define CONFIG_SYS_L2_SIZE (256 << 10) +/* + * Dynamic MTD Partition support with mtdparts */ #define +CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define +CONFIG_CMD_MTDPARTS #define CONFIG_FLASH_CFI_MTD #define MTDIDS_DEFAULT +"nor0=ef000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ef000000.nor:256k(vsc7385-firmware)," \ + "256k(dtb),4608k(kernel),9728k(fs)," \ + "256k(qe-ucode-firmware),1280k(u-boot)" #endif
#if defined(CONFIG_P1024RDB) @@ -142,6 +163,16 @@ #define __SW_BOOT_NAND 0xe8 #define __SW_BOOT_PCIE 0xa8 #define CONFIG_SYS_L2_SIZE (512 << 10) +/* + * Dynamic MTD Partition support with mtdparts */ #define +CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define +CONFIG_CMD_MTDPARTS #define CONFIG_FLASH_CFI_MTD #define MTDIDS_DEFAULT +"nor0=ef000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ef000000.nor:256k(vsc7385-firmware)," \ + "256k(dtb),4608k(kernel),9984k(fs),1280k(u-boot)" #endif
/* + * Dynamic MTD Partition support with mtdparts */ #define +CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define +CONFIG_CMD_MTDPARTS #define CONFIG_FLASH_CFI_MTD #define MTDIDS_DEFAULT +"nor0=ec000000.nor" +#define MTDPARTS_DEFAULT "mtdparts=ec000000.nor:256k(vsc7385-firmware)," \ + "256k(dtb),5632k(kernel),57856k(fs)," \ + "256k(qe-ucode-firmware),1280k(u-boot)" + +/* * Environment */ #ifdef CONFIG_SYS_RAMBOOT -- 1.8.5
CCing York as he's the 85xx custodian.
-Scott
Changes for v2:
- Dynamic MTD Partition support with mtdparts */ #define
- Environment
#endif
#endif
#endif
- Environment
1.8.5
Scott Wood
Yangbo Lu
yangbo.luļ¼ freescale.com
