[PATCH 1/1] net: use log_err() for 'No ethernet found' message
Write the 'No ethernet found' message via the log drivers. This allows suppressing it during output via the syslog driver.
This fixes the problem reported in:
[PATCH 0/4] log: Fix the syslog spam when running tests https://lists.denx.de/pipermail/u-boot/2020-September/426343.html
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- net/eth-uclass.c | 6 +++--- net/eth_legacy.c | 4 ++-- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 0d9b75a9a2..396418eb39 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -273,7 +273,7 @@ int eth_init(void) if (!current) { current = eth_get_dev(); if (!current) { - printf("No ethernet found.\n"); + log_err("No ethernet found.\n"); return -ENODEV; } } @@ -414,7 +414,7 @@ int eth_initialize(void) */ uclass_first_device_check(UCLASS_ETH, &dev); if (!dev) { - printf("No ethernet found.\n"); + log_err("No ethernet found.\n"); bootstage_error(BOOTSTAGE_ID_NET_ETH_START); } else { char *ethprime = env_get("ethprime"); @@ -449,7 +449,7 @@ int eth_initialize(void) } while (dev);
if (!num_devices) - printf("No ethernet found.\n"); + log_err("No ethernet found.\n"); putc('\n'); }
diff --git a/net/eth_legacy.c b/net/eth_legacy.c index 992d1880bf..6e0c058761 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -261,7 +261,7 @@ int eth_initialize(void) }
if (!eth_devices) { - puts("No ethernet found.\n"); + log_err("No ethernet found.\n"); bootstage_error(BOOTSTAGE_ID_NET_ETH_START); } else { struct eth_device *dev = eth_devices; @@ -319,7 +319,7 @@ int eth_init(void) struct eth_device *old_current;
if (!eth_current) { - puts("No ethernet found.\n"); + log_err("No ethernet found.\n"); return -ENODEV; }
-- 2.28.0
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org
