link error while u-boot-spl build : undefined ref to `printf` or `strcmp` etc.
Hello,
When I build u-boot, I get this error at the end. (during u-boot-spl build).
I've been fixing some link errors by adding config values but I can't figure out what is wrong with this.
Below is the final command for u-boot-spl build and the error messages.
Can any expert tell me what can be wrong here?
( cd spl && aarch64-none-elf-gcc -nostdlib -nostartfiles -fuse-linker-plugin -flto=28 -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -std=gnu11 -fshort-wchar -fno-strict-aliasing -fno-PIE -Os -flto=28 -fno-stack-protector -fno-delete-null-pointer-checks -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-maybe-uninitialized -fmacro-prefix-map=./= -g -fstack-usage -Wno-format-nonliteral -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=date-time -Wno-packed-not-aligned -ffunction-sections -fdata-sections -fno-stack-protector -D__KERNEL__ -D__UBOOT__ -DCONFIG_SPL_BUILD -D__ARM__ -mstrict-align -fno-common -ffixed-r9 -mgeneral-regs-only -fno-common -ffixed-x18 -pipe -march=armv8-a+crc -D__LINUX_ARM_ARCH__=8 -Ispl/include -Iinclude -I./arch/arm/include -include ./include/linux/kconfig.h -nostdinc -isystem /opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1/include -Wl,-T -Wl,u-boot-spl.lds -Wl,--gc-sections -Wl,-Bstatic -Wl,--gc-sections -Wl,--no-dynamic-linker -Wl,--build-id=none -Wl,-Ttext -Wl,0x4000000 arch/arm/cpu/armv8/start.o -Wl,--whole-archive arch/arm/cpu/armv8/built-in.o arch/arm/cpu/built-in.o arch/arm/lib/built-in.o board/etri/ab21m/built-in.o common/spl/built-in.o common/init/built-in.o common/built-in.o cmd/built-in.o env/built-in.o disk/built-in.o drivers/built-in.o dts/built-in.o fs/built-in.o keep-syms-lto.o -L /opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1 -lgcc -Wl,--no-whole-archive -Wl,-Map,u-boot-spl.map -o u-boot-spl )
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /tmp/u-boot-spl.GeKfJh.ltrans0.ltrans.o: in function `alloc_simple':
/home/ckim/U-BOOT/u-boot/spl/../common/malloc_simple.c:29: undefined reference to `printf'
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /tmp/u-boot-spl.GeKfJh.ltrans0.ltrans.o: in function `device_bind_by_name':
/home/ckim/U-BOOT/u-boot/spl/../drivers/core/lists.c:31: undefined reference to `strcmp'
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /tmp/u-boot-spl.GeKfJh.ltrans0.ltrans.o: in function `board_init_r':
/home/ckim/U-BOOT/u-boot/spl/../common/spl/spl.c:697: undefined reference to `timer_init'
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /home/ckim/U-BOOT/u-boot/spl/../common/spl/spl.c:690: undefined reference to `hang'
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/../lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /home/ckim/U-BOOT/u-boot/spl/../common/spl/spl.c:633: undefined reference to `printf'
collect2: error: ld returned 1 exit status
make[1]: *** [scripts/Makefile.spl:509: spl/u-boot-spl] Error 1
make: *** [Makefile:1984: spl/u-boot-spl] Error 2
Thank you.
Chan Kim
Hi Chan,
On 11/21/21 1:45 PM, Chan Kim wrote:
[Please note: This e-mail is from an EXTERNAL e-mail address]
Hello,
Could you try to enable CONFIG_SPL_LIBCOMMON_SUPPORT and CONFIG_SPL_LIBGENERIC_SUPPORT Kconfig options?
Ovidiu
Thank you.
Chan Kim
Hi Ovidiu,
Thank you so much, with those two configs added, u-boot-spl was finally built ok (The remaining 3 or 4 link errors are all gone together) Thank you,
Best regards, Chan Kim
-----Original Message----- From: Ovidiu Panait ovidiu.panait@windriver.com Sent: Monday, November 22, 2021 12:30 AM To: Chan Kim ckim@etri.re.kr; U-Boot Mailing List u-boot@lists.denx.de Subject: Re: link error while u-boot-spl build : undefined ref to `printf` or `strcmp` etc.
Hi Chan,
Hello,
build).
common
Ispl/include
-Iinclude -I./arch/arm/include -include ./include/linux/kconfig.h -nostdinc -isystem /opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/. ./lib/ gcc/aarch64-none-elf/10.2.1/include -Wl,-T -Wl,u-boot-spl.lds -Wl,--gc-sections -Wl,-Bstatic -Wl,--gc-sections -Wl,--no-dynamic-linker -Wl,--build-id=none -Wl,-Ttext -Wl,0x4000000 arch/arm/cpu/armv8/start.o -Wl,--whole-archive arch/arm/cpu/armv8/built-in.o arch/arm/cpu/built-in.o arch/arm/lib/built-in.o board/etri/ab21m/built-in.o common/spl/built-in.o common/init/built-in.o common/built-in.o cmd/built-in.o env/built-in.o disk/built-in.o drivers/built-in.o dts/built-in.o fs/built-in.o keep-syms-lto.o -L /opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/. ./lib/ gcc/aarch64-none-elf/10.2.1 -lgcc -Wl,--no-whole-archive -Wl,-Map,u-boot-spl.map -o u-boot-spl )
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/. ./lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /tmp/u-boot-spl.GeKfJh.ltrans0.ltrans.o: in function `alloc_simple':
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/. ./lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /tmp/u-boot-spl.GeKfJh.ltrans0.ltrans.o: in function `board_init_r':
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/. ./lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /home/ckim/U-BOOT/u-boot/spl/../common/spl/spl.c:690: undefined reference to `hang'
/opt/arm-toolchains/gcc-arm-10.2-2020.11-x86_64-aarch64-none-elf/bin/. ./lib/ gcc/aarch64-none-elf/10.2.1/../../../../aarch64-none-elf/bin/ld: /home/ckim/U-BOOT/u-boot/spl/../common/spl/spl.c:633: undefined reference to `printf'
Ovidiu
Thank you.
Chan Kim
Chan Kim
Ovidiu Panait
