[U-Boot] [PATCH v4 01/12] SPEAr : Adding README.spear in doc
README.spear contains information about SPEAr architecture and build options etc
Signed-off-by: Vipin vipin.kumar@st.com --- doc/README.spear | 53 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 53 insertions(+), 0 deletions(-) create mode 100644 doc/README.spear
diff --git a/doc/README.spear b/doc/README.spear new file mode 100644 index 0000000..59e9a95 --- /dev/null +++ b/doc/README.spear @@ -0,0 +1,53 @@ + +SPEAr (Structured Processor Enhanced Architecture). + +SPEAr600 is also known as SPEArPlus and SPEAr300 is also known as SPEArBasic + +The SPEAr SoC family also embeds a customizable logic that could be programmed
Could be changed to "The SPEAr SoC family embeds customizable logic that can be programmed"
+one-time by a customer at silicon mask level (i.e. not at runtime!).
+We are now adding the support in u-boot for two SoC: SPEAr600 and SPEAr3xx.
This could be moved to 2nd sentence.
+Pls note that SPEAr300/310/320 differs only for the default customization.
This is not needed.
+ +All 4 SoCs share common peripherals. + +1. ARM926ejs core based (sp600 has two cores, the 2nd handled only in Linux) +2. FastEthernet (sp600 has Gbit version, but same controller - GMAC) +3. USB Host +4. USB Device +5. NAND controller (FSMC) +6. Serial NOR ctrl +7. I2C +8. SPI +9. CLCD +10. others .. + +sp600 is not customized by default. +sp3xx are differently customized.
Please explain what you mean by customizing and differently customizing
+sp300 is more oriented to TELECOM/video (it has tdm, i2s, ITU i/f support) +sp310 for networking (a part GMAC in fixed part, it has 5 MACB ctrls in +custom) +sp320 for industrial (SPP ctrl, CAN ctrl, 2 MACBs, ...) + +Everything is supported in Linux. +u-boot is not currently supporting all peripeharls (just a few). + Please list what is supported.
+More description can be found on Internet, for example here: + +http://embedded-system.net/spear-basic-customizable-arm-based-soc-stmicroele...
This is press release and will likely be short lived. Please change this to something from www.st.com
Tom
Tom
