[PATCH v2 0/2] ARM: zynq: Start to use unified configurations
over the time there are a lot of zynq configurations which are almost the same. It just increasing amount of time for building/testing/maintaining that's why this patch starts to use xilinx_zynq_virt_defconfig which is all in one configurations which can be used on all zynq board. The series contains two patches. The first which setup device tree name for SPL FIT image selection. The second which removes all xilinx/avnet/myirtech configurations with extending defconfig and OF_LIST which ensures that u-boot.img contains DTS files for all these boards.
Thanks, Michal
Changes in v2: - Add tags from Tom and Simon - Fix azure/gitlab/travis builds - azure untested - hooks updated by https://github.com/swarren/uboot-test-hooks/pull/29 - Update documentation
Michal Simek (2): Makefile: Add environment variable DEVICE_TREE to header ARM: zynq: Switch to single zynq configurations
.azure-pipelines.yml | 6 +- .gitlab-ci.yml | 6 +- .travis.yml | 6 +- Makefile | 14 ++++- arch/arm/mach-zynq/spl.c | 8 ++- configs/xilinx_zynq_virt_defconfig | 19 +++++- configs/zynq_cc108_defconfig | 61 ------------------ configs/zynq_dlc20_rev1_0_defconfig | 76 ---------------------- configs/zynq_microzed_defconfig | 66 ------------------- configs/zynq_minized_defconfig | 67 -------------------- configs/zynq_picozed_defconfig | 54 ---------------- configs/zynq_z_turn_defconfig | 67 -------------------- configs/zynq_zc702_defconfig | 83 ------------------------ configs/zynq_zc706_defconfig | 87 -------------------------- configs/zynq_zc770_xm010_defconfig | 61 ------------------ configs/zynq_zc770_xm011_defconfig | 48 -------------- configs/zynq_zc770_xm011_x16_defconfig | 48 -------------- configs/zynq_zc770_xm012_defconfig | 50 --------------- configs/zynq_zc770_xm013_defconfig | 53 ---------------- configs/zynq_zed_defconfig | 70 --------------------- configs/zynq_zybo_defconfig | 69 -------------------- configs/zynq_zybo_z7_defconfig | 66 ------------------- doc/board/xilinx/zynq.rst | 3 +- 23 files changed, 48 insertions(+), 1040 deletions(-) delete mode 100644 configs/zynq_cc108_defconfig delete mode 100644 configs/zynq_dlc20_rev1_0_defconfig delete mode 100644 configs/zynq_microzed_defconfig delete mode 100644 configs/zynq_minized_defconfig delete mode 100644 configs/zynq_picozed_defconfig delete mode 100644 configs/zynq_z_turn_defconfig delete mode 100644 configs/zynq_zc702_defconfig delete mode 100644 configs/zynq_zc706_defconfig delete mode 100644 configs/zynq_zc770_xm010_defconfig delete mode 100644 configs/zynq_zc770_xm011_defconfig delete mode 100644 configs/zynq_zc770_xm011_x16_defconfig delete mode 100644 configs/zynq_zc770_xm012_defconfig delete mode 100644 configs/zynq_zc770_xm013_defconfig delete mode 100644 configs/zynq_zed_defconfig delete mode 100644 configs/zynq_zybo_defconfig delete mode 100644 configs/zynq_zybo_z7_defconfig
Users have option to overwrite default device tree (CONFIG_DEFAULT_DEVICE_TREE) via environment variable DEVICE_TREE.
Feature has been added long time ago by commit 74de8c9a1672 ("dts/Makefile: Build the user specified dts") for a little bit different reason.
But this variable can be also used for different purpose like choosing proper configuration from FIT image in SPL. And this is the functionality I would like to use on Xilinx Zynq devices that current u-boot.img can be composed in the same way based on OF_LIST and different configuration is taken based on platform specific SPL. SPL requires low level ps7_init_gpl configuration that's why different boards require different SPL with fixed board_fit_config_name_match().
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org ---
I have done it in this way but maybe there is any smarter way how this can be done. Also macro name can change if you want.
--- Makefile | 14 +++++++++++++- arch/arm/mach-zynq/spl.c | 8 ++++++-- 2 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 55aa90cf17fa..97166aefbf50 100644 --- a/Makefile +++ b/Makefile @@ -483,6 +483,7 @@ endif version_h := include/generated/version_autogenerated.h timestamp_h := include/generated/timestamp_autogenerated.h defaultenv_h := include/generated/defaultenv_autogenerated.h +dt_h := include/generated/dt.h
no-dot-config-targets := clean clobber mrproper distclean \ help %docs check% coccicheck \ @@ -1768,7 +1769,7 @@ endif # prepare2 creates a makefile if using a separate output directory prepare2: prepare3 outputmakefile cfg
-prepare1: prepare2 $(version_h) $(timestamp_h) \ +prepare1: prepare2 $(version_h) $(timestamp_h) $(dt_h) \ include/config/auto.conf ifeq ($(wildcard $(LDSCRIPT)),) @echo >&2 " Could not find linker script." @@ -1834,12 +1835,23 @@ define filechk_defaultenv.h xxd -i ; echo ", 0x00" ; ) endef
+define filechk_dt.h + (if test -n "$${DEVICE_TREE}"; then \ + echo #define DEVICE_TREE "$(DEVICE_TREE)"; \ + else \ + echo #define DEVICE_TREE CONFIG_DEFAULT_DEVICE_TREE; \ + fi) +endef + $(version_h): include/config/uboot.release FORCE $(call filechk,version.h)
$(timestamp_h): $(srctree)/Makefile FORCE $(call filechk,timestamp.h)
+$(dt_h): $(srctree)/Makefile FORCE + $(call filechk,dt.h) + $(defaultenv_h): $(CONFIG_DEFAULT_ENV_FILE:"%"=%) FORCE $(call filechk,defaultenv.h)
diff --git a/arch/arm/mach-zynq/spl.c b/arch/arm/mach-zynq/spl.c index 96ba90fb7a76..e89e46c1038d 100644 --- a/arch/arm/mach-zynq/spl.c +++ b/arch/arm/mach-zynq/spl.c @@ -6,6 +6,7 @@ #include <debug_uart.h> #include <hang.h> #include <spl.h> +#include <generated/dt.h>
#include <asm/io.h> #include <asm/spl.h> @@ -89,8 +90,11 @@ void spl_board_prepare_for_boot(void) int board_fit_config_name_match(const char *name) { /* Just empty function now - can't decide what to choose */ - debug("%s: %s\n", __func__, name); + debug("%s: Check %s, default %s\n", __func__, name, DEVICE_TREE);
- return 0; + if (!strcmp(name, DEVICE_TREE)) + return 0; + + return -1; } #endif
There are a lot of zynq configurations which can be merged together and use only one for all. The similar change has been done for ZynqMP by commit be1b6c32d940 ("arm64: zynqmp: Use zynqmp_virt platform")
Build SPL with u-boot.img for zc706 like this. export DEVICE_TREE=zynq-zc706 && make xilinx_zynq_virt_defconfig && make -j8 u-boot.img is generic for all boards.
Tested on Zybo, zc702, zc706, zc770-xm011-x16, cc108 and microzed.
Signed-off-by: Michal Simek michal.simek@xilinx.com Update zynq platform
Changes in v2: - Fix azure/gitlab/travis builds - azure untested - hooks updated by https://github.com/swarren/uboot-test-hooks/pull/29 - Update documentation
.azure-pipelines.yml | 6 +- .gitlab-ci.yml | 6 +- .travis.yml | 6 +- configs/xilinx_zynq_virt_defconfig | 19 +++++- configs/zynq_cc108_defconfig | 61 ------------------ configs/zynq_dlc20_rev1_0_defconfig | 76 ---------------------- configs/zynq_microzed_defconfig | 66 ------------------- configs/zynq_minized_defconfig | 67 -------------------- configs/zynq_picozed_defconfig | 54 ---------------- configs/zynq_z_turn_defconfig | 67 -------------------- configs/zynq_zc702_defconfig | 83 ------------------------ configs/zynq_zc706_defconfig | 87 -------------------------- configs/zynq_zc770_xm010_defconfig | 61 ------------------ configs/zynq_zc770_xm011_defconfig | 48 -------------- configs/zynq_zc770_xm011_x16_defconfig | 48 -------------- configs/zynq_zc770_xm012_defconfig | 50 --------------- configs/zynq_zc770_xm013_defconfig | 53 ---------------- configs/zynq_zed_defconfig | 70 --------------------- configs/zynq_zybo_defconfig | 69 -------------------- configs/zynq_zybo_z7_defconfig | 66 ------------------- doc/board/xilinx/zynq.rst | 3 +- 21 files changed, 29 insertions(+), 1037 deletions(-) delete mode 100644 configs/zynq_cc108_defconfig delete mode 100644 configs/zynq_dlc20_rev1_0_defconfig delete mode 100644 configs/zynq_microzed_defconfig delete mode 100644 configs/zynq_minized_defconfig delete mode 100644 configs/zynq_picozed_defconfig delete mode 100644 configs/zynq_z_turn_defconfig delete mode 100644 configs/zynq_zc702_defconfig delete mode 100644 configs/zynq_zc706_defconfig delete mode 100644 configs/zynq_zc770_xm010_defconfig delete mode 100644 configs/zynq_zc770_xm011_defconfig delete mode 100644 configs/zynq_zc770_xm011_x16_defconfig delete mode 100644 configs/zynq_zc770_xm012_defconfig delete mode 100644 configs/zynq_zc770_xm013_defconfig delete mode 100644 configs/zynq_zed_defconfig delete mode 100644 configs/zynq_zybo_defconfig delete mode 100644 configs/zynq_zybo_z7_defconfig
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 86480581a24e..2ec8009bfbc2 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -227,11 +227,11 @@ jobs: TEST_PY_BD: "qemu-x86_64" TEST_PY_TEST_SPEC: "not sleep" BUILDMAN: "^qemu-x86_64$" - zynq_zc702: - TEST_PY_BD: "zynq_zc702" + xilinx_zynq_virt: + TEST_PY_BD: "xilinx_zynq_virt" TEST_PY_ID: "--id qemu" TEST_PY_TEST_SPEC: "not sleep" - BUILDMAN: "^zynq_zc702$" + BUILDMAN: "^xilinx_zynq_virt$" xilinx_versal_virt: TEST_PY_BD: "xilinx_versal_virt" TEST_PY_ID: "--id qemu" diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 55943bb3a245..89033587f240 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -320,13 +320,13 @@ qemu-x86_64 test.py: BUILDMAN: "^qemu-x86_64$" <<: *buildman_and_testpy_dfn
-zynq_zc702 test.py: +xilinx_zynq_virt test.py: tags: [ 'all' ] variables: - TEST_PY_BD: "zynq_zc702" + TEST_PY_BD: "xilinx_zynq_virt" TEST_PY_TEST_SPEC: "not sleep" TEST_PY_ID: "--id qemu" - BUILDMAN: "^zynq_zc702$" + BUILDMAN: "^xilinx_zynq_virt$" <<: *buildman_and_testpy_dfn
xilinx_versal_virt test.py: diff --git a/.travis.yml b/.travis.yml index 7ab855acb212..7b239d68d7c7 100644 --- a/.travis.yml +++ b/.travis.yml @@ -504,13 +504,13 @@ matrix: BUILDMAN="^qemu-x86_64$" TOOLCHAIN="i386" BUILD_ROM="yes" - - name: "test/py zynq_zc702" + - name: "test/py xilinx_zynq_virt" env: - - TEST_PY_BD="zynq_zc702" + - TEST_PY_BD="xilinx_zynq_virt" TEST_PY_TEST_SPEC="not sleep" QEMU_TARGET="arm-softmmu" TEST_PY_ID="--id qemu" - BUILDMAN="^zynq_zc702$" + BUILDMAN="^xilinx_zynq_virt$" - name: "test/py xilinx_versal_virt" env: - TEST_PY_BD="xilinx_versal_virt" diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index ece619f239b2..2e9f3a0f7508 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -11,13 +11,17 @@ CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_FPGA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 # CONFIG_BOOTM_NETBSD is not set +CONFIG_CMD_IMLS=y CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_DFU=y @@ -28,12 +32,14 @@ CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_OF_BOARD=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-zc706" +CONFIG_OF_LIST="zynq-zc702 zynq-zc706 zynq-zc770-xm010 zynq-zc770-xm011 zynq-zc770-xm011-x16 zynq-zc770-xm012 zynq-zc770-xm013 zynq-cc108 zynq-microzed zynq-minized zynq-picozed zynq-zed zynq-zturn zynq-zybo zynq-zybo-z7 zynq-dlc20-rev1.0" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y @@ -52,11 +58,19 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x0 CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_ZYNQ=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_MARVELL=y CONFIG_PHY_REALTEK=y @@ -64,6 +78,7 @@ CONFIG_PHY_XILINX=y CONFIG_MII=y CONFIG_ZYNQ_GEM=y CONFIG_ZYNQ_SERIAL=y +CONFIG_ZYNQ_SPI=y CONFIG_ZYNQ_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y @@ -76,3 +91,5 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y +CONFIG_DISPLAY=y +CONFIG_SPL_GZIP=y diff --git a/configs/zynq_cc108_defconfig b/configs/zynq_cc108_defconfig deleted file mode 100644 index 417711719962..000000000000 --- a/configs/zynq_cc108_defconfig +++ /dev/null @@ -1,61 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0000000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-cc108" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_ISSI=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig deleted file mode 100644 index d52b4b8396b4..000000000000 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ /dev/null @@ -1,76 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_IDENT_STRING=" Xilinx Zynq DLC20 Rev1.0" -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-dlc20-rev1.0" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_CADENCE=y -CONFIG_MISC=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x0 -CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_REALTEK=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig deleted file mode 100644 index d4b484fda5d1..000000000000 --- a/configs/zynq_microzed_defconfig +++ /dev/null @@ -1,66 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-microzed" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03FD -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_minized_defconfig b/configs/zynq_minized_defconfig deleted file mode 100644 index 6c936aa07d06..000000000000 --- a/configs/zynq_minized_defconfig +++ /dev/null @@ -1,67 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-minized" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig deleted file mode 100644 index f9db660c8c31..000000000000 --- a/configs/zynq_picozed_defconfig +++ /dev/null @@ -1,54 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-picozed" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig deleted file mode 100644 index 8a22ecb729a5..000000000000 --- a/configs/zynq_z_turn_defconfig +++ /dev/null @@ -1,67 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zturn" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_LED=y -CONFIG_LED_GPIO=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03FD -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig deleted file mode 100644 index cba34326bd44..000000000000 --- a/configs/zynq_zc702_defconfig +++ /dev/null @@ -1,83 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_IDENT_STRING=" Xilinx Zynq ZC702" -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc702" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_CADENCE=y -CONFIG_LED=y -CONFIG_LED_GPIO=y -CONFIG_MISC=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x0 -CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_ISSI=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig deleted file mode 100644 index 146ef7d23434..000000000000 --- a/configs/zynq_zc706_defconfig +++ /dev/null @@ -1,87 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_IDENT_STRING=" Xilinx Zynq ZC706" -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SPL_FIT_PRINT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_FPGA_SUPPORT=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc706" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_CADENCE=y -CONFIG_MISC=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x0 -CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_ISSI=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y -CONFIG_WDT=y -CONFIG_WDT_CDNS=y -CONFIG_SPL_GZIP=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig deleted file mode 100644 index 563985f42a81..000000000000 --- a/configs/zynq_zc770_xm010_defconfig +++ /dev/null @@ -1,61 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM010" -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm010" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_ISSI=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_SST=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_SPI=y -CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig deleted file mode 100644 index d64f3d0c8df3..000000000000 --- a/configs/zynq_zc770_xm011_defconfig +++ /dev/null @@ -1,48 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM011" -# CONFIG_SPL_FS_FAT is not set -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_NAND_LOCK_UNLOCK=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -CONFIG_CMD_CACHE=y -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm011" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_BLK=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -# CONFIG_MMC is not set -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_ZYNQ=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_ZYNQ_SERIAL=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig deleted file mode 100644 index 7720d09c4f1d..000000000000 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ /dev/null @@ -1,48 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM011 x16" -# CONFIG_SPL_FS_FAT is not set -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_NAND_LOCK_UNLOCK=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -CONFIG_CMD_CACHE=y -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm011-x16" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_BLK=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -# CONFIG_MMC is not set -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_ZYNQ=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_DEBUG_UART_ANNOUNCE=y -CONFIG_ZYNQ_SERIAL=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig deleted file mode 100644 index f40a496d5418..000000000000 --- a/configs/zynq_zc770_xm012_defconfig +++ /dev/null @@ -1,50 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM012" -# CONFIG_SPL_FS_FAT is not set -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_IMLS=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_ADDR=0xE20E0000 -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_BLK=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -# CONFIG_MMC is not set -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_ZYNQ_SERIAL=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig deleted file mode 100644 index 3b73f4408cf6..000000000000 --- a/configs/zynq_zc770_xm013_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM013" -# CONFIG_SPL_FS_FAT is not set -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm013" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_BLK=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -# CONFIG_MMC is not set -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_ISSI=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig deleted file mode 100644 index 18b39b5e8def..000000000000 --- a/configs/zynq_zed_defconfig +++ /dev/null @@ -1,70 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zed" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig deleted file mode 100644 index fe1c412b4688..000000000000 --- a/configs/zynq_zybo_defconfig +++ /dev/null @@ -1,69 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y -CONFIG_DISPLAY=y diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig deleted file mode 100644 index 1dee7570628f..000000000000 --- a/configs/zynq_zybo_z7_defconfig +++ /dev/null @@ -1,66 +0,0 @@ -CONFIG_ARM=y -CONFIG_SPL_SYS_DCACHE_OFF=y -CONFIG_ARCH_ZYNQ=y -CONFIG_SYS_TEXT_BASE=0x4000000 -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x200000 -CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=100000000 -CONFIG_DEBUG_UART=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_CUSTOM_LDSCRIPT=y -CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_USE_PREBOOT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FPGA_LOADBP=y -CONFIG_CMD_FPGA_LOADFS=y -CONFIG_CMD_FPGA_LOADMK=y -CONFIG_CMD_FPGA_LOADP=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo-z7" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_FPGA_XILINX=y -CONFIG_FPGA_ZYNQPL=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_SF_DEFAULT_SPEED=30000000 -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_PHY_REALTEK=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y -CONFIG_DEBUG_UART_ZYNQ=y -CONFIG_ZYNQ_SERIAL=y -CONFIG_ZYNQ_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_ULPI_VIEWPORT=y -CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Xilinx" -CONFIG_USB_GADGET_VENDOR_NUM=0x03fd -CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_FUNCTION_THOR=y diff --git a/doc/board/xilinx/zynq.rst b/doc/board/xilinx/zynq.rst index 3f0513ed362a..6a09df1d15f8 100644 --- a/doc/board/xilinx/zynq.rst +++ b/doc/board/xilinx/zynq.rst @@ -32,7 +32,8 @@ Building
configure and build for zc702 board::
- $ make zynq_zc702_config + $ export DEVICE_TREE=zynq-zc702 + $ make xilinx_zynq_virt_defconfig $ make
Bootmode
po 9. 3. 2020 v 14:29 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
Changes in v2:
-- 2.25.1
Applied both. M
Michal Simek
Michal Simek
