[U-Boot] [PATCH v2] armv8: ls1028a: add more personalities support
Add LS1027A, LS1018A and LS1017A personalities support to LS1028A processor soc family.
LS1028A processor is the prime personality of LS1028A soc family. LS1027A processor is a lower funtionality version of QorIQ LS1028A which does not support the multimedia subsystems, such as LCD controller, GPU, and eDP PHY. The QorIQ LS1018A and LS1017A are low power versions of the QorIQ LS1028A and LS1027A processors, respectively which integrate single 64-bit Arm A72 core.
Signed-off-by: Tang Yuantian andy.tang@nxp.com --- v2: - refine description arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 +++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 3e2a24fe80..dee96afe2d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -58,6 +58,9 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LS1026A, LS1026A, 2), CPU_TYPE_ENTRY(LS2040A, LS2040A, 4), CPU_TYPE_ENTRY(LS1012A, LS1012A, 1), + CPU_TYPE_ENTRY(LS1017A, LS1017A, 1), + CPU_TYPE_ENTRY(LS1018A, LS1018A, 1), + CPU_TYPE_ENTRY(LS1027A, LS1027A, 2), CPU_TYPE_ENTRY(LS1028A, LS1028A, 2), CPU_TYPE_ENTRY(LS1088A, LS1088A, 8), CPU_TYPE_ENTRY(LS1084A, LS1084A, 8), diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h
--- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -83,6 +83,9 @@ enum boot_src get_boot_src(void); /* LS1043A/LS1023A 23x23 package silicon has different value of VAR_PER */ #define SVR_LS1043A_P23 0x879202 #define SVR_LS1023A_P23 0x87920A +#define SVR_LS1017A 0x870B24 +#define SVR_LS1018A 0x870B20 +#define SVR_LS1027A 0x870B04 #define SVR_LS1028A 0x870B00 #define SVR_LS1046A 0x870700 #define SVR_LS1026A 0x870708
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Yuantian Tang Sent: Wednesday, September 18, 2019 2:21 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: [U-Boot] [PATCH v2] armv8: ls1028a: add more personalities support
Please update subject to be more specific about Soc personalities. Something like armv8: ls1028a: add LS1027A, LS1018A, LS1017A support you can skip this line in description
--priyankajain
v2:
- CPU_TYPE_ENTRY(LS1017A, LS1017A, 1),
- CPU_TYPE_ENTRY(LS1018A, LS1018A, 1),
- CPU_TYPE_ENTRY(LS1027A, LS1027A, 2), CPU_TYPE_ENTRY(LS1028A, LS1028A, 2), CPU_TYPE_ENTRY(LS1088A, LS1088A, 8), CPU_TYPE_ENTRY(LS1084A, LS1084A, 8),
2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cpriyanka.jain%40nxp.com%7Cad5af7711fa6403 9450208d73c16cc16%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C 637043940922465590&sdata=dtSR0EQhGhJYBzhKAOWWGCMRbxYax%2F uuJmKY%2FKAhQBY%3D&reserved=0
Hi Priyanka,
Please see my reply inline.
-----Original Message----- From: Priyanka Jain Sent: 2019年9月25日 13:05 To: Andy Tang andy.tang@nxp.com; Priyanka Jain priyanka.jain@nxp.com Cc: Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH v2] armv8: ls1028a: add more personalities support
Any reason it must be put in patch subject?
BR, Andy
--priyankajain
v2:
2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists .de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cpriyanka.jain%40nxp.com%7Cad5af7711fa64
03
7C
%2F
-----Original Message----- From: Andy Tang Sent: Wednesday, September 25, 2019 11:06 AM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH v2] armv8: ls1028a: add more personalities support
Hi Priyanka,
It’s a suggestion as subject are supposed to specific summary about the content of patch "Add more personalities" is a bit vague --priyankajain
BR, Andy
--priyankajain
v2:
- CPU_TYPE_ENTRY(LS1027A, LS1027A, 2), CPU_TYPE_ENTRY(LS1028A, LS1028A, 2), CPU_TYPE_ENTRY(LS1088A, LS1088A, 8), CPU_TYPE_ENTRY(LS1084A, LS1084A, 8), diff --git
2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flis ts .de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cpriyanka.jain%40nxp.com%7Cad5af7711fa64
03
9450208d73c16cc16%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0% 7C
%2F
Hi Priyanka,
-----Original Message----- From: Priyanka Jain Sent: 2019年9月25日 13:43 To: Andy Tang andy.tang@nxp.com Cc: u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH v2] armv8: ls1028a: add more personalities support
Hi Priyanka,
We can put the "more personalities" in subject or in description. Either way is ok. I prefer to put it in description. Subject should be as concise as possible.
Thanks for your suggestion. BR, Andy
BR, Andy
--priyankajain
v2:
2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fli s ts .de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cpriyanka.jain%40nxp.com%7Cad5af7711f
a64
03
7C
ax
%2F
<snip>
Slight update in description. Applied to fsl-qoriq master, awaiting upstream.
Thanks priyankajain
Andy Tang
Priyanka Jain
Yuantian Tang
