[PATCH 0/5] arm: dts: stm32mp157c-odyssey-som: sync SDMMC2 with Linux and TF‑A
This patchset updates the properties of the SDMMC2 device tree node so that they match their Linux kernel and Trusted Firmware A counterparts. Two differences will remain: — in the Linux kernel device tree, the VQMMC supply is incorrectly set to v3v3 (buck4) instead of vdd (buck3); — in the TF‑A device tree, only the “default” pinctrl is configured.
Additionally, this patchset enables SDMMC2 in SPL.
Grzegorz Szymaszek (5): arm: dts: stm32mp157c-odyssey-som: fix the basic SDMMC2 properties arm: dts: stm32mp157c-odyssey-som: enable all SDMMC2 data lanes arm: dts: stm32mp157c-odyssey-som: set the SDMMC2 VQMMC supply arm: dts: stm32mp157c-odyssey-som: enable the SDMMC2 eMMC HS DDR mode arm: dts: stm32mp157c-odyssey-som: enable SDMMC2 in SPL
.../dts/stm32mp157c-odyssey-som-u-boot.dtsi | 21 +++++++++++++++++++ arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 15 +++++++------ 2 files changed, 30 insertions(+), 6 deletions(-)
The SDMMC2 interface hosts an eMMC. Replace the interface properties that would only apply to SD cards—“broken-cd” and “disable-wp”—with relevant ones: “non-removable”, “no-sd” and “no-sdio”.
Signed-off-by: Grzegorz Szymaszek gszymaszek@short.pl Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index 83ff2e7ce1..5c758b0f72 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -263,8 +263,9 @@ pinctrl-0 = <&sdmmc2_b4_pins_a>; pinctrl-1 = <&sdmmc2_b4_od_pins_a>; pinctrl-2 = <&sdmmc2_b4_sleep_pins_a>; - broken-cd; - disable-wp; + non-removable; + no-sd; + no-sdio; st,neg-edge; bus-width = <4>; vmmc-supply = <&v3v3>;
Hi Grzegorz
- broken-cd;
- disable-wp;
- non-removable;
- no-sd;
- no-sdio; st,neg-edge; bus-width = <4>; vmmc-supply = <&v3v3>;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Add the “sdmmc2_d47_pins_d” pins to the SDMMC2 pinctrls. Increase the bus width from four to eight.
Signed-off-by: Grzegorz Szymaszek gszymaszek@short.pl Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index 5c758b0f72..5801b7a968 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -260,14 +260,14 @@
&sdmmc2 { pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc2_b4_pins_a>; - pinctrl-1 = <&sdmmc2_b4_od_pins_a>; - pinctrl-2 = <&sdmmc2_b4_sleep_pins_a>; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_d>; + pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_d>; + pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_d>; non-removable; no-sd; no-sdio; st,neg-edge; - bus-width = <4>; + bus-width = <8>; vmmc-supply = <&v3v3>; status = "okay"; };
Hi Grzegorz
- pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_d>;
- pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_d>;
- pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_d>; non-removable; no-sd; no-sdio; st,neg-edge;
- bus-width = <4>;
- bus-width = <8>; vmmc-supply = <&v3v3>; status = "okay";
Thanks Patrice
Set the SDMMC2 VQMMC supply to vdd (buck3). Note that in the corresponding Linux kernel device tree, the supply is set to v3v3 (buck4), which is wrong.
Signed-off-by: Grzegorz Szymaszek gszymaszek@short.pl Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index 5801b7a968..76a364d4ca 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -269,6 +269,7 @@ st,neg-edge; bus-width = <8>; vmmc-supply = <&v3v3>; + vqmmc-supply = <&vdd>; status = "okay"; };
Hi Grzegorz
Do you intend to send similar patch to kernel mailing list to fix it ?
- vqmmc-supply = <&vdd>; status = "okay";
Thanks Patrice
I’m sorry for not replying, I missed this question. FWIW, yes, I’ve had sent a patch[1] and it has since been applied at least on stm32-next and some stable branches.
[1]: https://lore.kernel.org/linux-arm-kernel/YLj4AMTCi84yO9GO@nx64de-df6d00/
All the best!
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index 76a364d4ca..0dfdc29db6 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -270,6 +270,7 @@ bus-width = <8>; vmmc-supply = <&v3v3>; vqmmc-supply = <&vdd>; + mmc-ddr-3_3v; status = "okay"; };
Your commit message is missing
- mmc-ddr-3_3v; status = "okay";
Signed-off-by: Grzegorz Szymaszek gszymaszek@short.pl Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- .../dts/stm32mp157c-odyssey-som-u-boot.dtsi | 21 +++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi index 6be728846e..4ff848350d 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi @@ -123,3 +123,24 @@ u-boot,dm-pre-reloc; }; }; + +&sdmmc2 { + u-boot,dm-spl; +}; + +&sdmmc2_b4_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&sdmmc2_d47_pins_d { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +};
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
Grzegorz Szymaszek
Patrice CHOTARD
