[U-Boot] Please pull u-boot-dm
Hi Tom,
I was unable to get signed tags working, but here is a list of changes:
- MPC83xx device tree additions (CPU and RAM) - Fix sandbox build error - Sync bitrev with Linux - Various ofnode/DT improvements
The following changes since commit 40e44c8bf516e7071c9b80113473be5757e8c3f3:
Merge branch 'master' of git://git.denx.de/u-boot-coldfire (2018-09-16 10:32:33 -0400)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to 75629a25087cd9897305375421abe2248bc40e72:
dm: uclass: Adding missing child_pre_probe description (2018-09-18 13:27:10 -0600)
---------------------------------------------------------------- Andy Shevchenko (1): sandbox: Build with -fPIC
Bin Meng (3): lib: bitrev: Sync with Linux kernel v4.17 sandbox: Enable bitrev library build dm: uclass: Adding missing child_pre_probe description
Cédric Le Goater (1): dm: core: fix devfdt_remap_addr_index()
Jens Wiklander (2): ofnode: add ofnode_by_prop_value() test: ofnode: test ofnode_by_prop_value()
Mario Six (17): ram: Add driver for MPC83xx powerpc: Add read*_*/write*_* macros sysreset: Add get_status method test: Add tests for sysreset_get_status board_f: Add reset status printing mpc83xx: Add sysreset driver clk: Add MPC83xx clock driver timer: Sort Makefile entries timer: Add MPC83xx timer driver common: board_f: Sort includes init: Fix documentation board_f: Use static print_cpuinfo if CONFIG_CPU is active cpu: Fix cpu.h documentation cpu: Add cpu_probe_all method test: Add tests for CPU uclass cpu: Add MPC83xx CPU driver misc: Add MPC83xx serdes driver
Masahiro Yamada (1): dm: fix alignment of help message of "dm" command
Michael Heimpold (1): binman: fix a few typos in documentation
Rajan Vaja (2): dm: core: Move "/clock" node scan into function dm: core: Scan "/firmware" node by default
Documentation/devicetree/bindings/clk/fsl,mpc83xx-clk.txt | 23 + Documentation/devicetree/bindings/cpu/fsl,mpc83xx.txt | 34 + .../devicetree/bindings/misc/fsl,mpc83xx-serdes.txt | 24 + .../bindings/ram/fsl,mpc83xx-mem-controller.txt | 314 +++++++ .../devicetree/bindings/timer/fsl,mpc83xx-timer.txt | 21 + MAINTAINERS | 11 + arch/Kconfig | 1 + arch/powerpc/cpu/mpc83xx/cpu.c | 9 +- arch/powerpc/cpu/mpc83xx/cpu_init.c | 2 + arch/powerpc/cpu/mpc83xx/serdes.c | 4 + arch/powerpc/cpu/mpc83xx/spd_sdram.c | 4 + arch/powerpc/cpu/mpc83xx/speed.c | 4 + arch/powerpc/include/asm/arch-mpc83xx/soc.h | 74 ++ arch/powerpc/include/asm/config.h | 2 +- arch/powerpc/include/asm/fsl_mpc83xx_serdes.h | 4 + arch/powerpc/include/asm/global_data.h | 4 + arch/powerpc/include/asm/io.h | 18 + arch/powerpc/include/asm/processor.h | 2 + arch/powerpc/lib/Makefile | 4 + arch/powerpc/lib/interrupts.c | 5 +- arch/sandbox/config.mk | 1 + arch/sandbox/dts/test.dts | 12 + common/board_f.c | 58 +- drivers/clk/Kconfig | 6 + drivers/clk/Makefile | 1 + drivers/clk/mpc83xx_clk.c | 410 +++++++++ drivers/clk/mpc83xx_clk.h | 379 ++++++++ drivers/core/fdtaddr.c | 2 +- drivers/core/of_access.c | 27 + drivers/core/ofnode.c | 14 + drivers/core/root.c | 35 +- drivers/cpu/Kconfig | 7 + drivers/cpu/Makefile | 2 + drivers/cpu/cpu-uclass.c | 23 + drivers/cpu/cpu_sandbox.c | 61 ++ drivers/cpu/mpc83xx_cpu.c | 349 ++++++++ drivers/cpu/mpc83xx_cpu.h | 126 +++ drivers/misc/Kconfig | 7 + drivers/misc/Makefile | 1 + drivers/misc/mpc83xx_serdes.c | 185 ++++ drivers/misc/mpc83xx_serdes.h | 232 +++++ drivers/ram/Kconfig | 9 + drivers/ram/Makefile | 1 + drivers/ram/mpc83xx_sdram.c | 1096 +++++++++++++++++++++++ drivers/sysreset/Kconfig | 5 + drivers/sysreset/Makefile | 9 +- drivers/sysreset/sysreset-uclass.c | 10 + drivers/sysreset/sysreset_mpc83xx.c | 212 +++++ drivers/sysreset/sysreset_mpc83xx.h | 103 +++ drivers/sysreset/sysreset_sandbox.c | 16 + drivers/timer/Kconfig | 7 + drivers/timer/Makefile | 17 +- drivers/timer/mpc83xx_timer.c | 249 +++++ include/cpu.h | 35 +- include/dm/of_access.h | 16 + include/dm/ofnode.h | 14 + include/dm/uclass.h | 1 + include/dt-bindings/clk/mpc83xx-clk.h | 33 + include/dt-bindings/memory/mpc83xx-sdram.h | 161 ++++ include/init.h | 34 +- include/linux/bitrev.h | 102 ++- include/mpc83xx.h | 6 + include/sysreset.h | 17 + lib/bitrev.c | 28 +- test/dm/Makefile | 1 + test/dm/cmd_dm.c | 2 +- test/dm/cpu.c | 45 + test/dm/ofnode.c | 27 + test/dm/sysreset.c | 20 + tools/binman/README | 8 +- 70 files changed, 4695 insertions(+), 91 deletions(-) create mode 100644 Documentation/devicetree/bindings/clk/fsl,mpc83xx-clk.txt create mode 100644 Documentation/devicetree/bindings/cpu/fsl,mpc83xx.txt create mode 100644 Documentation/devicetree/bindings/misc/fsl,mpc83xx-serdes.txt create mode 100644 Documentation/devicetree/bindings/ram/fsl,mpc83xx-mem-controller.txt create mode 100644 Documentation/devicetree/bindings/timer/fsl,mpc83xx-timer.txt create mode 100644 arch/powerpc/include/asm/arch-mpc83xx/soc.h create mode 100644 drivers/clk/mpc83xx_clk.c create mode 100644 drivers/clk/mpc83xx_clk.h create mode 100644 drivers/cpu/cpu_sandbox.c create mode 100644 drivers/cpu/mpc83xx_cpu.c create mode 100644 drivers/cpu/mpc83xx_cpu.h create mode 100644 drivers/misc/mpc83xx_serdes.c create mode 100644 drivers/misc/mpc83xx_serdes.h create mode 100644 drivers/ram/mpc83xx_sdram.c create mode 100644 drivers/sysreset/sysreset_mpc83xx.c create mode 100644 drivers/sysreset/sysreset_mpc83xx.h create mode 100644 drivers/timer/mpc83xx_timer.c create mode 100644 include/dt-bindings/clk/mpc83xx-clk.h create mode 100644 include/dt-bindings/memory/mpc83xx-sdram.h create mode 100644 test/dm/cpu.c
On Wed, Sep 19, 2018 at 8:13 AM Simon Glass sjg@chromium.org wrote:
Hi Tom,
Last time I wanted to have a try, but looks there was no enough documentation to start with. If we can have some detailed instructions about signed tags, that would be helpful.
Regards, Bin
On Tue, Sep 18, 2018 at 06:13:24PM -0600, Simon Glass wrote:
Hi Tom,
I assume you read the link from before, can you talk about the issues a bit more? Thanks!
Bin Meng
