[PATCH v1 0/2] TPS65224 PMIC driver
Add support for TPS65224 PMIC in U-boot. This includes driver for PMIC and regulator.
The driver was tested on Ti's custom AM62A EVM using U-boot's pmic list, regulator list, regulator enable, regulator disable and regulator value commands. Regulator output voltages were verified.
Logs from running the above commands, => pmic list | Name | Parent name | Parent uclass @ seq | pmic@48 | i2c@4900000 | i2c @ 0 | status: 0 | watchdog@12 | i2c@20000000 | i2c @ 1 | status: 0 => reg list | Device | regulator-name | Parent | buck12 | buck12 | pmic@48 | buck3 | buck3 | pmic@48 | buck4 | buck4 | pmic@48 | ldo1 | ldo1 | pmic@48 | ldo2 | ldo2 | pmic@48 | ldo3 | ldo3 | pmic@48 => regulator dev buck12 dev: buck12 @ buck12 => regulator enable => regulator value 1500000 => regulator disable
Bhargav Raviprakash (2): driver: power: add support for TPS65224 driver: power: regulator: add support for TPS65224 regulator
drivers/power/pmic/Kconfig | 6 + drivers/power/pmic/Makefile | 1 + drivers/power/pmic/tps65224.c | 141 ++++++ drivers/power/regulator/Kconfig | 10 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/tps65224_regulator.c | 472 +++++++++++++++++++ include/power/tps65224.h | 56 +++ 7 files changed, 687 insertions(+) create mode 100644 drivers/power/pmic/tps65224.c create mode 100644 drivers/power/regulator/tps65224_regulator.c create mode 100644 include/power/tps65224.h
Added support for PMIC TPS65224. Includes driver for pmic, and disabling Watchdog.
Signed-off-by: Bhargav Raviprakash bhargav.r@ltts.com --- drivers/power/pmic/Kconfig | 6 ++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/tps65224.c | 141 ++++++++++++++++++++++++++++++++++ include/power/tps65224.h | 54 +++++++++++++ 4 files changed, 202 insertions(+) create mode 100644 drivers/power/pmic/tps65224.c create mode 100644 include/power/tps65224.h
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 4a6f0ce093..b06bd31823 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -378,6 +378,12 @@ config PMIC_TPS65941 The TPS65941 is a PMIC containing a bunch of SMPS & LDOs. This driver binds the pmic children.
+config PMIC_TPS65224 + bool "Enable driver for Texas Instruments TPS65224 PMIC" + help + The TPS65224 is a PMIC containing a bunch of SMPS & LDOs. + This driver binds the pmic children. + config PMIC_TPS65219 bool "Enable driver for Texas Instruments TPS65219 PMIC" depends on DM_PMIC diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 0b3b3d62d0..cec16e57d3 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -33,6 +33,7 @@ obj-$(CONFIG_PMIC_STPMIC1) += stpmic1.o obj-$(CONFIG_PMIC_TPS65217) += pmic_tps65217.o obj-$(CONFIG_PMIC_TPS65219) += tps65219.o obj-$(CONFIG_PMIC_TPS65941) += tps65941.o +obj-$(CONFIG_PMIC_TPS65224) += tps65224.o obj-$(CONFIG_POWER_TPS65218) += pmic_tps65218.o
ifeq ($(CONFIG_$(SPL_)POWER_LEGACY),y) diff --git a/drivers/power/pmic/tps65224.c b/drivers/power/pmic/tps65224.c new file mode 100644 index 0000000000..450769de61 --- /dev/null +++ b/drivers/power/pmic/tps65224.c @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Texas Instruments Incorporated, <www.ti.com> + */ +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <log.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/tps65224.h> +#include <dm/device.h> + +static const struct pmic_child_info pmic_children_info[] = { + { .prefix = "ldo", .driver = TPS65224_LDO_DRIVER }, + { .prefix = "buck", .driver = TPS65224_BUCK_DRIVER }, + { }, +}; + +static int tps65224_write(struct udevice *dev, uint reg, const uint8_t *buff, + int len) +{ + if (dm_i2c_write(dev, reg, buff, len)) { + pr_err("write error to device: %p register: %#x!\n", dev, reg); + return -EIO; + } + + return 0; +} + +static int tps65224_read(struct udevice *dev, uint reg, uint8_t *buff, int len) +{ + if (dm_i2c_read(dev, reg, buff, len)) { + pr_err("read error from device: %p register: %#x!\n", dev, reg); + return -EIO; + } + + return 0; +} + +static int tps65224_bind(struct udevice *dev) +{ + ofnode regulators_node; + int children; + + if (dev->driver_data == TPS65224_WD) + return 0; + + regulators_node = dev_read_subnode(dev, "regulators"); + if (!ofnode_valid(regulators_node)) { + debug("%s: %s regulators subnode not found!\n", __func__, + dev->name); + return -ENXIO; + } + + debug("%s: '%s' - found regulators subnode\n", __func__, dev->name); + + children = pmic_bind_children(dev, regulators_node, pmic_children_info); + if (!children) + printf("%s: %s - no child found\n", __func__, dev->name); + + /* Probe all the child devices */ + return dm_scan_fdt_dev(dev); +} + +static int stop_watchdog(struct udevice *wd_i2c_dev) +{ + int ret; + + /* Maintain WD long window */ + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65224_WD_MODE_REG); + if (ret < 0) { + debug("failed to read i2c reg (%d)\n", ret); + return ret; + } + + ret &= ~TPS65224_WD_PWRHOLD_MASK; + ret |= TPS65224_WD_PWRHOLD_MASK; + ret = dm_i2c_reg_write(wd_i2c_dev, TPS65224_WD_MODE_REG, ret); + if (ret) { + debug("%s: %s write WD_PWRHOLD fail!\n", __func__, wd_i2c_dev->name); + return ret; + } + + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65224_WD_MODE_REG); + if (ret < 0) { + debug("failed to read back i2c reg (%d)\n", ret); + return ret; + } + + /* Disable WD */ + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65224_WD_THR_CFG); + if (ret < 0) { + debug("failed to read i2c reg (%d)\n", ret); + return ret; + } + + ret &= ~TPS65224_WD_EN_MASK; + ret = dm_i2c_reg_write(wd_i2c_dev, TPS65224_WD_THR_CFG, ret); + if (ret) { + debug("%s: %s write WD_EN fail!\n", __func__, wd_i2c_dev->name); + return ret; + } + + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65224_WD_THR_CFG); + if (ret < 0) { + debug("failed to read back i2c reg (%d)\n", ret); + return ret; + } + + return 0; +} + +static int tps65224_probe(struct udevice *dev) +{ + if (dev->driver_data == TPS65224_WD) + return stop_watchdog(dev); + + return 0; +} + +static struct dm_pmic_ops tps65224_ops = { + .read = tps65224_read, + .write = tps65224_write, +}; + +static const struct udevice_id tps65224_ids[] = { + { .compatible = "ti,tps65224", .data = TPS65224 }, + { .compatible = "ti,tps65224_watchdog", .data = TPS65224_WD }, + { } +}; + +U_BOOT_DRIVER(pmic_tps65224) = { + .name = "tps65224_pmic", + .id = UCLASS_PMIC, + .of_match = tps65224_ids, + .bind = tps65224_bind, + .probe = tps65224_probe, + .ops = &tps65224_ops, +}; diff --git a/include/power/tps65224.h b/include/power/tps65224.h new file mode 100644 index 0000000000..7b52796a64 --- /dev/null +++ b/include/power/tps65224.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef _POWER_TPS65224_H_ +#define _POWER_TPS65224_H_ + +#define TPS65224 0x0 +#define TPS65224_WD 0x20 + +/* I2C device address for pmic tps65224 */ +#define TPS65224_I2C_ADDR (0x12 >> 1) +#define TPS65224_LDO_NUM 3 +#define TPS65224_BUCK_NUM 4 + +/* Drivers name */ +#define TPS65224_LDO_DRIVER "tps65224_ldo" +#define TPS65224_BUCK_DRIVER "tps65224_buck" + +#define TPS65224_BUCK_VOLT_MASK 0xFF +#define TPS65224_BUCK1_VOLT_MAX_HEX 0xFD +#define TPS65224_BUCK234_VOLT_MAX_HEX 0x45 +#define TPS65224_BUCK_VOLT_MAX 3300000 +#define TPS65224_BUCK_MODE_MASK 0x1 + +#define TPS65224_LDO_VOLT_MASK (0x3F << 1) +#define TPS65224_LDO_VOLT_MAX_HEX 0x3A +#define TPS65224_LDO_VOLT_MIN_HEX 0x4 +#define TPS65224_LDO1_VOLT_MAX 3300000 +#define TPS65224_LDO23_VOLT_MAX 3400000 +#define TPS65224_LDO_MODE_MASK 0x1 +#define TPS65224_LDO_BYPASS_EN 0x80 +#define TP65224_BUCK_CONF_SLEW_MASK 0x3 + +/* BYPASS is bit7 of VOUT TPS65224_LDO_BYP_MASK */ +#define TPS65224_LDO123_BYP_CONFIG 7 + +#define TPS65224_LDO123_VOLT_BYP_MIN 2200000 +#define TPS65224_LDO123_VOLT_BYP_MAX 3600000 +#define TPS65224_LDO1_VOLT_MIN 1200000 +#define TPS65224_LDO23_VOLT_MIN 600000 +#define TPS65224_LDO4_VOLT_MIN 1200000 +#define TPS65224_LDO1_VSET_MIN 0x0C +#define TPS65224_LDO23_VSET_MIN 0x00 +#define TPS65224_LDO123_VSET_MIN 0x0 +#define TPS65224_LDO1_VSET_MAX 0x36 +#define TPS65224_LDO23_VSET_MAX 0x38 +#define TPS65224_LDO123_STEP 50000 +#define TPS65224_LDO4_STEP 25000 + +#define TPS65224_WD_MODE_REG 0x406 +#define TPS65224_WD_PWRHOLD_MASK BIT(2) +#define TPS65224_WD_THR_CFG 0x409 +#define TPS65224_WD_EN_MASK BIT(6) + +#endif // _POWER_TPS65224_H_
Added support for PMIC TPS65224 regulators. Includes driver for buck and ldo.
Signed-off-by: Bhargav Raviprakash bhargav.r@ltts.com --- drivers/power/regulator/Kconfig | 10 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/tps65224_regulator.c | 472 +++++++++++++++++++ include/power/tps65224.h | 6 +- 4 files changed, 487 insertions(+), 2 deletions(-) create mode 100644 drivers/power/regulator/tps65224_regulator.c
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index eb5aa38c1c..cb86025a22 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -408,6 +408,16 @@ config DM_REGULATOR_TPS65941 be configured in multi phase modes & 4 LDOs. The driver implements get/set api for value and enable.
+config DM_REGULATOR_TPS65224 + bool "Enable driver for TPS65224 PMIC regulators" + depends on PMIC_TPS65224 + help + This enables implementation of driver-model regulator uclass + features for REGULATOR TPS65224 and the family of TPS65224 PMICs. + TPS65224 series of PMICs have 4 single phase BUCKs that can also + be configured in multi phase modes & 3 LDOs. The driver implements + get/set api for value and enable. + config DM_REGULATOR_SCMI bool "Enable driver for SCMI voltage domain regulators" depends on DM_REGULATOR diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index d9e0cd5949..d4b9b7233f 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS62360) += tps62360_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMIC1) += stpmic1.o obj-$(CONFIG_DM_REGULATOR_TPS65941) += tps65941_regulator.o +obj-$(CONFIG_DM_REGULATOR_TPS65224) += tps65224_regulator.o obj-$(CONFIG_DM_REGULATOR_SCMI) += scmi_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_ANATOP) += anatop_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS65219) += tps65219_regulator.o diff --git a/drivers/power/regulator/tps65224_regulator.c b/drivers/power/regulator/tps65224_regulator.c new file mode 100644 index 0000000000..2f8c803778 --- /dev/null +++ b/drivers/power/regulator/tps65224_regulator.c @@ -0,0 +1,472 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 + * Texas Instruments Incorporated, <www.ti.com> + * + */ +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <log.h> +#include <linux/delay.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/tps65224.h> + +static const char tps65224_buck_ctrl[TPS65224_BUCK_NUM] = {0x4, 0x6, 0x8, 0xA}; +static const char tps65224_buck_vout[TPS65224_BUCK_NUM] = {0xE, 0x10, 0x12, + 0x14}; +static const char tps65224_ldo_ctrl[TPS65224_BUCK_NUM] = {0x1D, 0x1E, 0x1F}; +static const char tps65224_ldo_vout[TPS65224_BUCK_NUM] = {0x23, 0x24, 0x25}; + +static int tps65224_buck_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_plat *uc_pdata; + + uc_pdata = dev_get_uclass_plat(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= TPS65224_BUCK_MODE_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= TPS65224_BUCK_MODE_MASK; + else + ret &= ~TPS65224_BUCK_MODE_MASK; + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int tps65224_buck_volt2val(int idx, int uV) +{ + if (uV > TPS65224_BUCK_VOLT_MAX) + return -EINVAL; + + if (idx > 0) { + if (uV >= 1200000) + return (uV - 1200000) / 50000 + 0x1B; + else if (uV >= 500000) + return (uV - 500000) / 25000; + else + return -EINVAL; + } + + if (uV >= 1660000) + return (uV - 1660000) / 20000 + 0xAB; + else if (uV >= 1100000) + return (uV - 1100000) / 10000 + 0x73; + else if (uV >= 600000) + return (uV - 600000) / 5000 + 0x0F; + else if (uV >= 500000) + return (uV - 500000) / 20000 + 0x0A; + else + return -EINVAL; +} + +static int tps65224_buck_val2volt(int idx, int val) +{ + if (idx > 0) { + if (val > TPS65224_BUCK234_VOLT_MAX_HEX) + return -EINVAL; + else if (val >= 0x1B) + return 1200000 + (val - 0x1B) * 50000; + else if (val >= 0x00) + return 500000 + (val - 0x00) * 25000; + else + return -EINVAL; + } + + if (val > TPS65224_BUCK1_VOLT_MAX_HEX) + return -EINVAL; + else if (val >= 0xAB) + return 1660000 + (val - 0xAB) * 20000; + else if (val >= 0x73) + return 1100000 + (val - 0x73) * 10000; + else if (val >= 0xF) + return 600000 + (val - 0xF) * 5000; + else if (val >= 0xA) + return 500000 + (val - 0xA) * 20000; + else + return -EINVAL; +} + +int tps65224_lookup_slew(int id) +{ + switch (id) { + case 0: + return 10000; + case 1: + return 5000; + case 2: + return 2500; + case 3: + return 1250; + default: + return -1; + } +} + +static int tps65224_buck_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret, idx, delta, uwait, slew; + struct dm_regulator_uclass_plat *uc_pdata; + + idx = dev->driver_data; + idx = (idx == 12) ? 0 : (idx - 1); + + uc_pdata = dev_get_uclass_plat(dev); + + if (op == PMIC_OP_GET) + *uV = 0; + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + ret &= TPS65224_BUCK_VOLT_MASK; + ret = tps65224_buck_val2volt(idx, ret); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + *uV = ret; + return 0; + } + + /* + * Compute the delta voltage, find the slew rate and wait + * for the appropriate amount of time after voltage switch + */ + if (*uV > ret) + delta = *uV - ret; + else + delta = ret - *uV; + + slew = pmic_reg_read(dev->parent, uc_pdata->ctrl_reg + 1); + if (slew < 0) + return ret; + + slew &= TP65224_BUCK_CONF_SLEW_MASK; + slew = tps65224_lookup_slew(slew); + if (slew <= 0) + return ret; + + uwait = delta / slew; + + hex = tps65224_buck_volt2val(idx, *uV); + if (hex < 0) + return hex; + + ret &= 0x0; + ret = hex; + + ret = pmic_reg_write(dev->parent, adr, ret); + + udelay(uwait); + + return ret; +} + +static int tps65224_ldo_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_plat *uc_pdata; + + uc_pdata = dev_get_uclass_plat(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= TPS65224_LDO_MODE_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= TPS65224_LDO_MODE_MASK; + else + ret &= ~TPS65224_LDO_MODE_MASK; + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int tps65224_ldo_volt2val(int idx, int uV) +{ + int base = TPS65224_LDO1_VOLT_MIN; + int max = TPS65224_LDO1_VOLT_MAX; + int offset = TPS65224_LDO1_VSET_MIN; + int step = TPS65224_LDO123_STEP; + + if (idx > 0) { + base = TPS65224_LDO23_VOLT_MIN; + max = TPS65224_LDO23_VOLT_MAX; + offset = TPS65224_LDO23_VSET_MIN; + step = TPS65224_LDO123_STEP; + } + + if (uV > max) + return -EINVAL; + else if (uV >= base) + return (uV - base) / step + offset; + else + return -EINVAL; +} + +static int tps65224_ldo_val2volt(int idx, int val) +{ + int reg_base = TPS65224_LDO1_VSET_MIN; + int reg_max = TPS65224_LDO1_VSET_MAX; + int base = TPS65224_LDO1_VOLT_MIN; + int max = TPS65224_LDO1_VOLT_MAX; + int step = TPS65224_LDO123_STEP; + int mask = TPS65224_LDO_VOLT_MASK >> 1; + + if (idx > 0) { + base = TPS65224_LDO23_VOLT_MIN; + max = TPS65224_LDO23_VOLT_MAX; + reg_base = TPS65224_LDO123_VSET_MIN; + reg_max = TPS65224_LDO23_VSET_MAX; + step = TPS65224_LDO123_STEP; + } + + val = val >> 1; + if (val > mask || val < 0) + return -EINVAL; + else if (val >= reg_max) + return max; + else if (val <= reg_base) + return base; + else if (val >= 0) + return base + (step * (val - reg_base)); + else + return -EINVAL; +} + +static int tps65224_ldo_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret, ret_volt; + struct dm_regulator_uclass_plat *uc_pdata; + int idx; + + idx = dev->driver_data - 1; + uc_pdata = dev_get_uclass_plat(dev); + + if (op == PMIC_OP_GET) + *uV = 0; + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + ret &= TPS65224_LDO_VOLT_MASK; + + ret_volt = tps65224_ldo_val2volt(idx, ret); + + if (ret_volt < 0) + return ret_volt; + + if (op == PMIC_OP_GET) { + *uV = ret_volt; + return 0; + } + + /* LDO1 in BYPASS mode only supports 2.2V min to 3.6V max */ + if (idx == 0 && (ret & BIT(TPS65224_LDO123_BYP_CONFIG)) && + *uV < TPS65224_LDO1_VOLT_BYP_MIN) + return -EINVAL; + + /* LDO2 & LDO3 in BYPASS mode supports 1.5V min to 5.5V max */ + if (idx > 0 && (ret & BIT(TPS65224_LDO123_BYP_CONFIG)) && + *uV < TPS65224_LDO23_VOLT_BYP_MIN) + return -EINVAL; + + hex = tps65224_ldo_volt2val(idx, *uV); + if (hex < 0) + return hex; + + hex = hex << TPS65224_LDO_MODE_MASK; + + ret &= ~TPS65224_LDO_VOLT_MASK; + ret |= hex; + + ret = pmic_reg_write(dev->parent, adr, ret); + + return ret; +} + +static int tps65224_ldo_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_plat *uc_pdata; + int idx; + + uc_pdata = dev_get_uclass_plat(dev); + uc_pdata->type = REGULATOR_TYPE_LDO; + + idx = dev->driver_data; + if (idx == 1 || idx == 2 || idx == 3) { + debug("Single phase regulator\n"); + } else { + printf("Wrong ID for regulator\n"); + return -EINVAL; + } + + uc_pdata->ctrl_reg = tps65224_ldo_ctrl[idx - 1]; + uc_pdata->volt_reg = tps65224_ldo_vout[idx - 1]; + + return 0; +} + +static int tps65224_buck_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_plat *uc_pdata; + int idx; + + uc_pdata = dev_get_uclass_plat(dev); + uc_pdata->type = REGULATOR_TYPE_BUCK; + + idx = dev->driver_data; + if (idx == 1 || idx == 2 || idx == 3 || idx == 4) { + debug("Single phase regulator\n"); + } else if (idx == 12) { + idx = 1; + } else { + printf("Wrong ID for regulator\n"); + return -EINVAL; + } + + uc_pdata->ctrl_reg = tps65224_buck_ctrl[idx - 1]; + uc_pdata->volt_reg = tps65224_buck_vout[idx - 1]; + + return 0; +} + +static int ldo_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = tps65224_ldo_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int ldo_set_value(struct udevice *dev, int uV) +{ + return tps65224_ldo_val(dev, PMIC_OP_SET, &uV); +} + +static int ldo_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + ret = tps65224_ldo_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int ldo_set_enable(struct udevice *dev, bool enable) +{ + return tps65224_ldo_enable(dev, PMIC_OP_SET, &enable); +} + +static int buck_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = tps65224_buck_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int buck_set_value(struct udevice *dev, int uV) +{ + return tps65224_buck_val(dev, PMIC_OP_SET, &uV); +} + +static int buck_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + ret = tps65224_buck_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int buck_set_enable(struct udevice *dev, bool enable) +{ + return tps65224_buck_enable(dev, PMIC_OP_SET, &enable); +} + +static const struct dm_regulator_ops tps65224_ldo_ops = { + .get_value = ldo_get_value, + .set_value = ldo_set_value, + .get_enable = ldo_get_enable, + .set_enable = ldo_set_enable, +}; + +U_BOOT_DRIVER(tps65224_ldo) = { + .name = TPS65224_LDO_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &tps65224_ldo_ops, + .probe = tps65224_ldo_probe, +}; + +static const struct dm_regulator_ops tps65224_buck_ops = { + .get_value = buck_get_value, + .set_value = buck_set_value, + .get_enable = buck_get_enable, + .set_enable = buck_set_enable, +}; + +U_BOOT_DRIVER(tps65224_buck) = { + .name = TPS65224_BUCK_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &tps65224_buck_ops, + .probe = tps65224_buck_probe, +}; diff --git a/include/power/tps65224.h b/include/power/tps65224.h index 7b52796a64..8236b72bd5 100644 --- a/include/power/tps65224.h +++ b/include/power/tps65224.h @@ -33,8 +33,10 @@ /* BYPASS is bit7 of VOUT TPS65224_LDO_BYP_MASK */ #define TPS65224_LDO123_BYP_CONFIG 7
-#define TPS65224_LDO123_VOLT_BYP_MIN 2200000 -#define TPS65224_LDO123_VOLT_BYP_MAX 3600000 +#define TPS65224_LDO1_VOLT_BYP_MIN 2200000 +#define TPS65224_LDO1_VOLT_BYP_MAX 3600000 +#define TPS65224_LDO23_VOLT_BYP_MIN 1500000 +#define TPS65224_LDO23_VOLT_BYP_MAX 5500000 #define TPS65224_LDO1_VOLT_MIN 1200000 #define TPS65224_LDO23_VOLT_MIN 600000 #define TPS65224_LDO4_VOLT_MIN 1200000
Bhargav Raviprakash
