[U-Boot] [PATCH] driver/nand: Update SRAM initialize logic for IFC.
IFC controller v1.1.0 requires internal SRAM initialize by reading NAND flash. Higher controller versions have provided "SRAM init" bit in NCFGR register space.
update SRAM initialize logic to reflect the same.
Also print error message in case of Page read error.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- drivers/mtd/nand/fsl_ifc_nand.c | 26 +++++++++++++++++++++++--- include/fsl_ifc.h | 2 ++ 2 files changed, 25 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 27f5177..af32cfc 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -806,12 +806,29 @@ static void fsl_ifc_select_chip(struct mtd_info *mtd, int chip) { }
-static void fsl_ifc_sram_init(void) +static void fsl_ifc_sram_init(uint32_t ver) { struct fsl_ifc *ifc = ifc_ctrl->regs; uint32_t cs = 0, csor = 0, csor_8k = 0, csor_ext = 0; + uint32_t ncfgr = 0; long long end_tick;
+ if (ver > FSL_IFC_V1_1_0) { + ncfgr = ifc_in32(&ifc->ifc_nand.ncfgr); + ifc_out32(&ifc->ifc_nand.ncfgr, ncfgr | IFC_NAND_SRAM_INIT_EN); + + /* wait for SRAM_INIT bit to be clear or timeout */ + end_tick = usec2ticks(IFC_TIMEOUT_MSECS * 1000) + get_ticks(); + while (end_tick > get_ticks()) { + ifc_ctrl->status = + ifc_in32(&ifc->ifc_nand.nand_evter_stat); + + if (!(ifc_ctrl->status & IFC_NAND_SRAM_INIT_EN)) + return; + } + printf("fsl-ifc: Failed to Initialise SRAM\n"); + } + cs = ifc_ctrl->cs_nand >> IFC_NAND_CSEL_SHIFT;
/* Save CSOR and CSOR_ext */ @@ -856,6 +873,9 @@ static void fsl_ifc_sram_init(void)
ifc_out32(&ifc->ifc_nand.nand_evter_stat, ifc_ctrl->status);
+ if (ifc_ctrl->status & ~IFC_NAND_EVTER_STAT_OPC) + printf("fsl-ifc: Failed to Initialise SRAM\n"); + /* Restore CSOR and CSOR_ext */ ifc_out32(&ifc_ctrl->regs->csor_cs[cs].csor, csor); ifc_out32(&ifc_ctrl->regs->csor_cs[cs].csor_ext, csor_ext); @@ -1010,8 +1030,8 @@ static int fsl_ifc_chip_init(int devnum, u8 *addr) }
ver = ifc_in32(&ifc_ctrl->regs->ifc_rev); - if (ver == FSL_IFC_V1_1_0) - fsl_ifc_sram_init(); + if (ver >= FSL_IFC_V1_1_0) + fsl_ifc_sram_init(ver);
ret = nand_scan_ident(mtd, 1, NULL); if (ret) diff --git a/include/fsl_ifc.h b/include/fsl_ifc.h index 630e4b4..b353b04 100644 --- a/include/fsl_ifc.h +++ b/include/fsl_ifc.h @@ -367,6 +367,8 @@ */ /* Auto Boot Mode */ #define IFC_NAND_NCFGR_BOOT 0x80000000 +/* SRAM INIT EN */ +#define IFC_NAND_SRAM_INIT_EN 0x20000000 /* Addressing Mode-ROW0+n/COL0 */ #define IFC_NAND_NCFGR_ADDR_MODE_RC0 0x00000000 /* Addressing Mode-ROW0+n/COL0+n */
Prabhakar Kushwaha
