[U-Boot] [PATCH] powerpc/p1010rdb: add p1010rdb-pb support with updating p1010rdb-pa
- Rename old P1010RDB board as P1010RDB-PA. - Add support for new P1010RDB-PB board. - Enable IFC flash access in case of SD boot via hwconfig or mux command. - Some optimization and code cleanup. For more details, see board/freescale/p1010rdb/README.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- board/freescale/p1010rdb/law.c | 2 - board/freescale/p1010rdb/p1010rdb.c | 332 ++++++++++++++++++++++++++++++------ board/freescale/p1010rdb/tlb.c | 4 - boards.cfg | 41 +++-- include/configs/P1010RDB.h | 113 +++++++++--- 5 files changed, 391 insertions(+), 101 deletions(-)
diff --git a/board/freescale/p1010rdb/law.c b/board/freescale/p1010rdb/law.c index 0045127..ed41a05 100644 --- a/board/freescale/p1010rdb/law.c +++ b/board/freescale/p1010rdb/law.c @@ -9,11 +9,9 @@ #include <asm/mmu.h>
struct law_entry law_table[] = { -#ifndef CONFIG_SDCARD SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_IFC), SET_LAW(CONFIG_SYS_CPLD_BASE_PHYS, LAW_SIZE_128K, LAW_TRGT_IF_IFC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_IFC), -#endif };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 06aa800..7f30ccb 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -21,10 +21,8 @@ #include <asm/fsl_serdes.h> #include <asm/fsl_ifc.h> #include <asm/fsl_pci.h> - -#ifndef CONFIG_SDCARD #include <hwconfig.h> -#endif +#include <i2c.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -33,10 +31,30 @@ DECLARE_GLOBAL_DATA_PTR; #define MUX_CPLD_TDM 0x01 #define MUX_CPLD_SPICS0_FLASH 0x00 #define MUX_CPLD_SPICS0_SLIC 0x02 +#define PMUXCR1_IFC_MASK 0x00ffff00 +#define PMUXCR1_SDHC_MASK 0x00fff000 +#define PMUXCR1_SDHC_ENABLE 0x00555000 + +enum { + MUX_TYPE_IFC, + MUX_TYPE_SDHC, + MUX_TYPE_SPIFLASH, + MUX_TYPE_TDM, + MUX_TYPE_CAN, + MUX_TYPE_CS0_NOR, + MUX_TYPE_CS0_NAND, +}; + +enum { + I2C_READ_BANK, + I2C_READ_PCB_VER, +}; + +static uint sd_ifc_mux;
-#ifndef CONFIG_SDCARD struct cpld_data { u8 cpld_ver; /* cpld revision */ +#if defined(CONFIG_P1010RDB_PA) u8 pcba_ver; /* pcb revision number */ u8 twindie_ddr3; u8 res1[6]; @@ -51,53 +69,18 @@ struct cpld_data { u8 por1; /* POR Options */ u8 por2; /* POR Options */ u8 por3; /* POR Options */ -}; - -void cpld_show(void) -{ - struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); - - printf("CPLD: V%x.%x PCBA: V%x.0\n", - in_8(&cpld_data->cpld_ver) & 0xF0, - in_8(&cpld_data->cpld_ver) & 0x0F, - in_8(&cpld_data->pcba_ver) & 0x0F); - -#ifdef CONFIG_DEBUG - printf("twindie_ddr =%x\n", - in_8(&cpld_data->twindie_ddr3)); - printf("bank_sel =%x\n", - in_8(&cpld_data->bank_sel)); - printf("usb2_sel =%x\n", - in_8(&cpld_data->usb2_sel)); - printf("porsw_sel =%x\n", - in_8(&cpld_data->porsw_sel)); - printf("tdm_can_sel =%x\n", - in_8(&cpld_data->tdm_can_sel)); - printf("tdm_can_sel =%x\n", - in_8(&cpld_data->tdm_can_sel)); - printf("spi_cs0_sel =%x\n", - in_8(&cpld_data->spi_cs0_sel)); - printf("bcsr0 =%x\n", - in_8(&cpld_data->bcsr0)); - printf("bcsr1 =%x\n", - in_8(&cpld_data->bcsr1)); - printf("bcsr2 =%x\n", - in_8(&cpld_data->bcsr2)); - printf("bcsr3 =%x\n", - in_8(&cpld_data->bcsr3)); -#endif -} +#elif defined(CONFIG_P1010RDB_PB) + u8 rom_loc; #endif +};
int board_early_init_f(void) { ccsr_gpio_t *pgpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR); -#ifndef CONFIG_SDCARD struct fsl_ifc *ifc = (void *)CONFIG_SYS_IFC_ADDR;
/* Clock configuration to access CPLD using IFC(GPCM) */ setbits_be32(&ifc->ifc_gcr, 1 << IFC_GCR_TBCTL_TRN_TIME_SHIFT); -#endif /* * Reset PCIe slots via GPIO4 */ @@ -109,7 +92,6 @@ int board_early_init_f(void)
int board_early_init_r(void) { -#ifndef CONFIG_SDCARD const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; const u8 flash_esel = find_tlb_idx((void *)flashbase, 1);
@@ -133,7 +115,7 @@ int board_early_init_r(void) CONFIG_SYS_FLASH_BASE_PHYS + 0x1000000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, flash_esel+1, BOOKE_PAGESZ_16M, 1); -#endif + return 0; }
@@ -144,13 +126,201 @@ void pci_init_board(void) } #endif /* ifdef CONFIG_PCI */
+int config_board_mux(int ctrl_type) +{ + ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u8 tmp; + +#if defined(CONFIG_P1010RDB_PA) + struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); + + switch (ctrl_type) { + case MUX_TYPE_IFC: + i2c_set_bus_num(I2C_PCA9557_BUS_NUM); + tmp = 0xf0; + i2c_write(I2C_PCA9557_ADDR1, 3, 1, &tmp, 1); + tmp = 0x01; + i2c_write(I2C_PCA9557_ADDR1, 1, 1, &tmp, 1); + sd_ifc_mux = MUX_TYPE_IFC; + clrbits_be32(&gur->pmuxcr, PMUXCR1_IFC_MASK); + debug("pin mux is configured for IFC, SDHC disabled\n"); + break; + case MUX_TYPE_SDHC: + i2c_set_bus_num(I2C_PCA9557_BUS_NUM); + tmp = 0xf0; + i2c_write(I2C_PCA9557_ADDR1, 3, 1, &tmp, 1); + tmp = 0x05; + i2c_write(I2C_PCA9557_ADDR1, 1, 1, &tmp, 1); + sd_ifc_mux = MUX_TYPE_SDHC; + clrsetbits_be32(&gur->pmuxcr, PMUXCR1_SDHC_MASK, + PMUXCR1_SDHC_ENABLE); + debug("pin mux is configured for SDHC, IFC disabled\n"); + break; + case MUX_TYPE_SPIFLASH: + out_8(&cpld_data->spi_cs0_sel, MUX_CPLD_SPICS0_FLASH); + break; + case MUX_TYPE_TDM: + out_8(&cpld_data->tdm_can_sel, MUX_CPLD_TDM); + out_8(&cpld_data->spi_cs0_sel, MUX_CPLD_SPICS0_SLIC); + break; + case MUX_TYPE_CAN: + out_8(&cpld_data->tdm_can_sel, MUX_CPLD_CAN_UART); + break; + default: + break; + } +#elif defined(CONFIG_P1010RDB_PB) + uint orig_bus = i2c_get_bus_num(); + i2c_set_bus_num(I2C_PCA9557_BUS_NUM); + + switch (ctrl_type) { + case MUX_TYPE_IFC: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + clrbits_8(&tmp, 0x04); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x04); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + sd_ifc_mux = MUX_TYPE_IFC; + clrbits_be32(&gur->pmuxcr, PMUXCR1_IFC_MASK); + break; + case MUX_TYPE_SDHC: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + setbits_8(&tmp, 0x04); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x04); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + sd_ifc_mux = MUX_TYPE_SDHC; + clrsetbits_be32(&gur->pmuxcr, PMUXCR1_SDHC_MASK, + PMUXCR1_SDHC_ENABLE); + break; + case MUX_TYPE_SPIFLASH: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + clrbits_8(&tmp, 0x80); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x80); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + break; + case MUX_TYPE_TDM: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + setbits_8(&tmp, 0x82); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x82); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + break; + case MUX_TYPE_CAN: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + clrbits_8(&tmp, 0x02); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x02); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + break; + case MUX_TYPE_CS0_NOR: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + clrbits_8(&tmp, 0x08); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x08); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + break; + case MUX_TYPE_CS0_NAND: + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &tmp, 1); + setbits_8(&tmp, 0x08); + i2c_write(I2C_PCA9557_ADDR2, 1, 1, &tmp, 1); + i2c_read(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + clrbits_8(&tmp, 0x08); + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &tmp, 1); + break; + default: + break; + } + i2c_set_bus_num(orig_bus); +#endif + return 0; +} + +#ifdef CONFIG_P1010RDB_PB +int i2c_pca9557_read(int type) +{ + u8 val; + + i2c_set_bus_num(I2C_PCA9557_BUS_NUM); + i2c_read(I2C_PCA9557_ADDR2, 0, 1, &val, 1); + + switch (type) { + case I2C_READ_BANK: + val = (val & 0x10) >> 4; + break; + case I2C_READ_PCB_VER: + val = ((val & 0x60) >> 5) + 1; + break; + default: + break; + } + + return val; +} +#endif + int checkboard(void) { struct cpu_type *cpu; + struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); + u8 val;
cpu = gd->arch.cpu; - printf("Board: %sRDB\n", cpu->name); +#if defined(CONFIG_P1010RDB_PA) + printf("Board: %sRDB-PA, ", cpu->name); +#elif defined(CONFIG_P1010RDB_PB) + printf("Board: %sRDB-PB, ", cpu->name); + i2c_set_bus_num(I2C_PCA9557_BUS_NUM); + i2c_init(CONFIG_SYS_FSL_I2C_SPEED, CONFIG_SYS_FSL_I2C_SLAVE); + val = 0x0; /* no polarity inversion */ + i2c_write(I2C_PCA9557_ADDR2, 2, 1, &val, 1); +#endif + +#ifdef CONFIG_SDCARD + /* switch to IFC to read info from CPLD */ + config_board_mux(MUX_TYPE_IFC); +#endif
+#if defined(CONFIG_P1010RDB_PA) + val = (in_8(&cpld_data->pcba_ver) & 0xF); + printf("PCB: v%x.0\n", val); +#elif defined(CONFIG_P1010RDB_PB) + val = in_8(&cpld_data->cpld_ver); + printf("CPLD: v%x.%x, ", val >> 4, val & 0xf); + printf("PCB: v%x.0, ", i2c_pca9557_read(I2C_READ_PCB_VER)); + val = in_8(&cpld_data->rom_loc) & 0xf; + puts("Boot from: "); + switch (val) { + case 0xf: + config_board_mux(MUX_TYPE_CS0_NOR); + printf("NOR vBank%d\n", i2c_pca9557_read(I2C_READ_BANK)); + break; + case 0xe: + puts("SDHC\n"); + val = 0x60; /* set pca9557 pin input/output */ + i2c_write(I2C_PCA9557_ADDR2, 3, 1, &val, 1); + break; + case 0x5: + config_board_mux(MUX_TYPE_IFC); + config_board_mux(MUX_TYPE_CS0_NAND); + puts("NAND\n"); + break; + case 0x6: + config_board_mux(MUX_TYPE_IFC); + puts("SPI\n"); + break; + default: + puts("unknown\n"); + break; + } +#endif return 0; }
@@ -246,6 +416,16 @@ void fdt_del_sdhc(void *blob) } }
+void fdt_del_ifc(void *blob) +{ + int nodeoff = 0; + + while ((nodeoff = fdt_node_offset_by_compatible(blob, 0, + "fsl,ifc")) >= 0) { + fdt_del_node(blob, nodeoff); + } +} + void fdt_disable_uart1(void *blob) { int nodeoff; @@ -289,9 +469,13 @@ void ft_board_setup(void *blob, bd_t *bd) fdt_del_flexcan(blob); fdt_del_node_and_alias(blob, "ethernet2"); } -#ifndef CONFIG_SDCARD - /* disable sdhc due to sdhc bug */ - fdt_del_sdhc(blob); + + /* Delete IFC node as IFC pins are multiplexing with SDHC */ + if (sd_ifc_mux != MUX_TYPE_IFC) + fdt_del_ifc(blob); + else + fdt_del_sdhc(blob); + if (hwconfig_subarg_cmp("fsl_p1010mux", "tdm_can", "can")) { fdt_del_tdm(blob); fdt_del_spi_slic(blob); @@ -309,14 +493,26 @@ void ft_board_setup(void *blob, bd_t *bd) fdt_del_flexcan(blob); fdt_disable_uart1(blob); } +} #endif + +#ifdef CONFIG_SDCARD +int board_mmc_init(bd_t *bis) +{ + config_board_mux(MUX_TYPE_SDHC); + return -1; +} +#else +void board_reset(void) +{ + /* mux to IFC to enable CPLD for reset */ + if (sd_ifc_mux != MUX_TYPE_IFC) + config_board_mux(MUX_TYPE_IFC); } #endif
-#ifndef CONFIG_SDCARD int misc_init_r(void) { - struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
if (hwconfig_subarg_cmp("fsl_p1010mux", "tdm_can", "can")) { @@ -324,7 +520,7 @@ int misc_init_r(void) MPC85xx_PMUXCR_CAN1_UART | MPC85xx_PMUXCR_CAN2_TDM | MPC85xx_PMUXCR_CAN2_UART); - out_8(&cpld_data->tdm_can_sel, MUX_CPLD_CAN_UART); + config_board_mux(MUX_TYPE_CAN); } else if (hwconfig_subarg_cmp("fsl_p1010mux", "tdm_can", "tdm")) { clrbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_CAN2_UART | MPC85xx_PMUXCR_CAN1_UART); @@ -332,13 +528,39 @@ int misc_init_r(void) MPC85xx_PMUXCR_CAN1_TDM); clrbits_be32(&gur->pmuxcr2, MPC85xx_PMUXCR2_UART_GPIO); setbits_be32(&gur->pmuxcr2, MPC85xx_PMUXCR2_UART_TDM); - out_8(&cpld_data->tdm_can_sel, MUX_CPLD_TDM); - out_8(&cpld_data->spi_cs0_sel, MUX_CPLD_SPICS0_SLIC); + config_board_mux(MUX_TYPE_TDM); } else { /* defaultly spi_cs_sel to flash */ - out_8(&cpld_data->spi_cs0_sel, MUX_CPLD_SPICS0_FLASH); + config_board_mux(MUX_TYPE_SPIFLASH); }
+ if (hwconfig("esdhc")) + config_board_mux(MUX_TYPE_SDHC); + else if (hwconfig("ifc")) + config_board_mux(MUX_TYPE_IFC); + +#ifdef CONFIG_P1010RDB_PB + setbits_be32(&gur->pmuxcr2, MPC85xx_PMUXCR2_GPIO01_DRVVBUS); +#endif return 0; } -#endif + +static int pin_mux_cmd(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + if (argc < 2) + return CMD_RET_USAGE; + if (strcmp(argv[1], "ifc") == 0) + config_board_mux(MUX_TYPE_IFC); + else if (strcmp(argv[1], "sdhc") == 0) + config_board_mux(MUX_TYPE_SDHC); + else + return CMD_RET_USAGE; + return 0; +} + +U_BOOT_CMD( + mux, 2, 0, pin_mux_cmd, + "configure multiplexing pin for IFC/SDHC bus in runtime", + "bus_type (e.g. mux sdhc)" +); diff --git a/board/freescale/p1010rdb/tlb.c b/board/freescale/p1010rdb/tlb.c index 77a8043..a7af0f6 100644 --- a/board/freescale/p1010rdb/tlb.c +++ b/board/freescale/p1010rdb/tlb.c @@ -42,7 +42,6 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 1, BOOKE_PAGESZ_1M, 1),
#ifndef CONFIG_SPL_BUILD -#ifndef CONFIG_SDCARD SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_16M, 1), @@ -51,7 +50,6 @@ struct fsl_e_tlb_entry tlb_table[] = { CONFIG_SYS_FLASH_BASE_PHYS + 0x1000000, MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 3, BOOKE_PAGESZ_16M, 1), -#endif
#ifdef CONFIG_PCI /* *I*G* - PCI */ @@ -66,7 +64,6 @@ struct fsl_e_tlb_entry tlb_table[] = { #endif #endif
-#ifndef CONFIG_SDCARD /* *I*G - Board CPLD */ SET_TLB_ENTRY(1, CONFIG_SYS_CPLD_BASE, CONFIG_SYS_CPLD_BASE_PHYS, MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -75,7 +72,6 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 7, BOOKE_PAGESZ_1M, 1), -#endif
#if defined(CONFIG_SYS_RAMBOOT) || defined(CONFIG_SPL) SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, diff --git a/boards.cfg b/boards.cfg index be810c7..e2d3cdc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -783,21 +783,32 @@ MPC8572DS_36BIT powerpc mpc85xx mpc8572ds freesca MPC8572DS_NAND powerpc mpc85xx mpc8572ds freescale - MPC8572DS:NAND C29XPCIE powerpc mpc85xx c29xpcie freescale - C29XPCIE:C29XPCIE,36BIT C29XPCIE_SPIFLASH powerpc mpc85xx c29xpcie freescale - C29XPCIE:C29XPCIE,36BIT,SPIFLASH -P1010RDB_36BIT_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND -P1010RDB_36BIT_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND_SECBOOT,SECURE_BOOT -P1010RDB_36BIT_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT -P1010RDB_36BIT_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SECURE_BOOT -P1010RDB_36BIT_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SDCARD -P1010RDB_36BIT_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SPIFLASH -P1010RDB_36BIT_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SPIFLASH,SECURE_BOOT -P1010RDB_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,NAND -P1010RDB_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,NAND_SECBOOT,SECURE_BOOT -P1010RDB_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB -P1010RDB_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SECURE_BOOT -P1010RDB_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SDCARD -P1010RDB_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SPIFLASH -P1010RDB_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SPIFLASH,SECURE_BOOT -P1011RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB +P1010RDB-PA_36BIT_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT,NAND +P1010RDB-PA_36BIT_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT,NAND_SECBOOT,SECURE_BOOT +P1010RDB-PA_36BIT_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT +P1010RDB-PA_36BIT_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT,SECURE_BOOT +P1010RDB-PA_36BIT_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT,SDCARD +P1010RDB-PA_36BIT_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT,SPIFLASH +P1010RDB-PA_36BIT_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,36BIT,SPIFLASH,SECURE_BOOT +P1010RDB-PA_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,NAND +P1010RDB-PA_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA +P1010RDB-PA_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,SDCARD +P1010RDB-PA_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,SPIFLASH +P1010RDB-PA_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PA,SPIFLASH,SECURE_BOOT +P1010RDB-PB_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB +P1010RDB-PB_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,NAND +P1010RDB-PB_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,SDCARD +P1010RDB-PB_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,SPIFLASH +P1010RDB-PB_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,SECURE_BOOT +P1010RDB-PB_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT +P1010RDB-PB_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,SPIFLASH,SECURE_BOOT +P1010RDB-PB_36BIT_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT +P1010RDB-PB_36BIT_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT,SECURE_BOOT +P1010RDB-PB_36BIT_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT,NAND +P1010RDB-PB_36BIT_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT,NAND_SECBOOT,SECURE_BOOT +P1010RDB-PB_36BIT_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT,SDCARD +P1010RDB-PB_36BIT_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT,SPIFLASH +P1010RDB-PB_36BIT_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB_PB,36BIT,SPIFLASH,SECURE_BOOT P1011RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT P1011RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT,SDCARD P1011RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT,SPIFLASH diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index ba3f7c2..8bb52af 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -120,7 +120,11 @@ #endif
/* controller 2, Slot 2, tgtid 2, Base address 9000 */ +#if defined(CONFIG_P1010RDB_PA) #define CONFIG_SYS_PCIE2_NAME "PCIe Slot" +#elif defined(CONFIG_P1010RDB_PB) +#define CONFIG_SYS_PCIE2_NAME "mini PCIe Slot" +#endif #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 @@ -203,25 +207,24 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 #define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 #define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 - #define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 #define CONFIG_SYS_DDR_SR_CNTR 0x00000000 #define CONFIG_SYS_DDR_RCW_1 0x00000000 #define CONFIG_SYS_DDR_RCW_2 0x00000000 -#define CONFIG_SYS_DDR_CONTROL 0x470C0000 /* Type = DDR3 */ -#define CONFIG_SYS_DDR_CONTROL_2 0x04401010 +#define CONFIG_SYS_DDR_CONTROL 0xc70c0008 /* Type = DDR3 */ +#define CONFIG_SYS_DDR_CONTROL_2 0x24401000 #define CONFIG_SYS_DDR_TIMING_4 0x00000001 -#define CONFIG_SYS_DDR_TIMING_5 0x03402400 +#define CONFIG_SYS_DDR_TIMING_5 0x02401400
-#define CONFIG_SYS_DDR_TIMING_3_800 0x00020000 -#define CONFIG_SYS_DDR_TIMING_0_800 0x00330004 -#define CONFIG_SYS_DDR_TIMING_1_800 0x6f6B4644 +#define CONFIG_SYS_DDR_TIMING_3_800 0x00030000 +#define CONFIG_SYS_DDR_TIMING_0_800 0x00110104 +#define CONFIG_SYS_DDR_TIMING_1_800 0x6f6b8644 #define CONFIG_SYS_DDR_TIMING_2_800 0x0FA888CF #define CONFIG_SYS_DDR_CLK_CTRL_800 0x03000000 -#define CONFIG_SYS_DDR_MODE_1_800 0x40461520 -#define CONFIG_SYS_DDR_MODE_2_800 0x8000c000 +#define CONFIG_SYS_DDR_MODE_1_800 0x00441420 +#define CONFIG_SYS_DDR_MODE_2_800 0x00000000 #define CONFIG_SYS_DDR_INTERVAL_800 0x0C300100 -#define CONFIG_SYS_DDR_WRLVL_CONTROL_800 0x8655A608 +#define CONFIG_SYS_DDR_WRLVL_CONTROL_800 0x8675f608
/* settings for DDR3 at 667MT/s */ #define CONFIG_SYS_DDR_TIMING_3_667 0x00010000 @@ -256,10 +259,6 @@ extern unsigned long get_sdram_size(void); * 0xffe0_0000 0xffef_ffff CCSR 1M non-cacheable */
-/* In case of SD card boot, IFC interface is not available because of muxing */ -#ifdef CONFIG_SDCARD -#define CONFIG_SYS_NO_FLASH -#else /* * IFC Definitions */ @@ -322,6 +321,8 @@ extern unsigned long get_sdram_size(void); | CSPR_MSEL_NAND \ | CSPR_V) #define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#if defined(CONFIG_P1010RDB_PA) #define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ @@ -329,13 +330,25 @@ extern unsigned long get_sdram_size(void); | CSOR_NAND_PGS_512 /* Page Size = 512b */ \ | CSOR_NAND_SPRZ_16 /* Spare size = 16 */ \ | CSOR_NAND_PB(32)) /* 32 Pages Per Block */ +#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024) +#elif defined(CONFIG_P1010RDB_PB) +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ + | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ + | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ + | CSOR_NAND_PB(128)) /*Pages Per Block = 128 */ +#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) +#endif
#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE #define CONFIG_CMD_NAND -#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024)
+#if defined(CONFIG_P1010RDB_PA) /* NAND Flash Timing Params */ #define CONFIG_SYS_NAND_FTIM0 FTIM0_NAND_TCCST(0x01) | \ FTIM0_NAND_TWP(0x0C) | \ @@ -350,6 +363,23 @@ extern unsigned long get_sdram_size(void); FTIM2_NAND_TWHRE(0x0f) #define CONFIG_SYS_NAND_FTIM3 FTIM3_NAND_TWW(0x04)
+#elif defined(CONFIG_P1010RDB_PB) +/* support MT29F16G08ABABAWP 4k-pagesize 2G-bytes NAND */ +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07)| \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32)| \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 +#endif + #define CONFIG_SYS_NAND_DDR_LAW 11
/* Set up IFC registers for boot location NOR/NAND */ @@ -410,7 +440,6 @@ extern unsigned long get_sdram_size(void); FTIM2_GPCM_TCH(0x0) | \ FTIM2_GPCM_TWP(0x1f)) #define CONFIG_SYS_CS3_FTIM3 0x0 -#endif /* CONFIG_SDCARD */
#if defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_SYS_RAMBOOT @@ -482,9 +511,20 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_FSL_I2C2_SPEED 400000 #define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 +#define I2C_PCA9557_ADDR1 0x18 +#define I2C_PCA9557_ADDR2 0x19 +#define I2C_PCA9557_BUS_NUM 0
/* I2C EEPROM */ -#undef CONFIG_ID_EEPROM +#if defined(CONFIG_P1010RDB_PB) +#define CONFIG_ID_EEPROM +#ifdef CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#endif +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#endif /* enable read and write access to EEPROM */ #define CONFIG_CMD_EEPROM #define CONFIG_SYS_I2C_MULTI_EEPROMS @@ -567,12 +607,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_LBA48 #endif /* #ifdef CONFIG_FSL_SATA */
-/* SD interface will only be available in case of SD boot */ -#ifdef CONFIG_SDCARD #define CONFIG_MMC -#define CONFIG_DEF_HWCONFIG esdhc -#endif - #ifdef CONFIG_MMC #define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION @@ -613,9 +648,14 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) #define CONFIG_ENV_IS_IN_NAND +#if defined(CONFIG_P1010RDB_PA) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) /* 3*16=48K for env */ +#elif defined(CONFIG_P1010RDB_PB) +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_ENV_RANGE (32 * CONFIG_ENV_SIZE) /* new block size 512K */ +#endif #define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) -#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) #define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) @@ -708,7 +748,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_HAS_ETH2 #endif
-#define CONFIG_HOSTNAME P1010RDB #define CONFIG_ROOTPATH "/opt/nfsroot" #define CONFIG_BOOTFILE "uImage" #define CONFIG_UBOOTPATH u-boot.bin/* U-Boot image on TFTP server */ @@ -747,7 +786,31 @@ extern unsigned long get_sdram_size(void); "ext2load usb 0:4 $loadaddr $bootfile;" \ "ext2load usb 0:4 $fdtaddr $fdtfile;" \ "ext2load usb 0:4 $ramdiskaddr $ramdiskfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + CONFIG_BOOTMODE + +#if defined(CONFIG_P1010RDB_PA) +#define CONFIG_BOOTMODE \ + "boot_bank0=i2c dev 0; i2c mw 18 1 f1; i2c mw 18 3 f0;" \ + "mw.b ffb00011 0; mw.b ffb00009 0; reset\0" \ + "boot_bank1=i2c dev 0; i2c mw 18 1 f1; i2c mw 18 3 f0;" \ + "mw.b ffb00011 0; mw.b ffb00009 1; reset\0" \ + "boot_nand=i2c dev 0; i2c mw 18 1 f9; i2c mw 18 3 f0;" \ + "mw.b ffb00011 0; mw.b ffb00017 1; reset\0" + +#elif defined(CONFIG_P1010RDB_PB) +#define CONFIG_BOOTMODE \ + "boot_bank0=i2c dev 0; i2c mw 18 1 fe; i2c mw 18 3 0;" \ + "i2c mw 19 1 2; i2c mw 19 3 e1; reset\0" \ + "boot_bank1=i2c dev 0; i2c mw 18 1 fe; i2c mw 18 3 0;" \ + "i2c mw 19 1 12; i2c mw 19 3 e1; reset\0" \ + "boot_nand=i2c dev 0; i2c mw 18 1 fc; i2c mw 18 3 0;" \ + "i2c mw 19 1 8; i2c mw 19 3 f7; reset\0" \ + "boot_spi=i2c dev 0; i2c mw 18 1 fa; i2c mw 18 3 0;" \ + "i2c mw 19 1 0; i2c mw 19 3 f7; reset\0" \ + "boot_sd=i2c dev 0; i2c mw 18 1 f8; i2c mw 18 3 0;" \ + "i2c mw 19 1 4; i2c mw 19 3 f3; reset\0" +#endif
#define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \
Shengzhou Liu
