[U-Boot] [PATCH 0/4] onenand: OneNAND board dependent probe and Samsung targets fixes
This patch sets add board dependent onenand probes. Several fixes for GONI and C210_universal targets have been added.
I'd like to ask other users of OneNAND infrastructure to _TEST_ if changes made on the onenand_base common code haven't broken anything.
Tested at: Samsung S5PC110 GONI Samsung S5PC210 Universal
Lukasz Majewski (4): onenand:samsung Target dependent OneNAND chip probe function onenand:samsung OneNAND chip probe functions added for GONI and C210_Universal onenand: Replace ONENAND_IS_MLC() test with ONENAND_HAS_4KB() onenand: samsung: Enable support OneNAND support at Samsung's S5PC210_Universal
board/samsung/goni/onenand.c | 1 + board/samsung/universal_c210/onenand.c | 2 + drivers/mtd/onenand/onenand_base.c | 88 +++++++++++++++++++++++-------- drivers/mtd/onenand/samsung.c | 10 ++++ include/configs/s5pc210_universal.h | 1 + include/linux/mtd/onenand.h | 5 ++ include/linux/mtd/samsung_onenand.h | 2 + 7 files changed, 86 insertions(+), 23 deletions(-)
Separate callback for probing OneNAND memory chip. If no special function is defined, default implementation will be used.
This approach gives more flexibility for OneNAND device probing.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- ./tools/checkpatch.pl - total: 0 errors, 0 warnings, 108 lines checked
NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE
--- drivers/mtd/onenand/onenand_base.c | 43 +++++++++++++++++++++++++++++----- drivers/mtd/onenand/samsung.c | 10 ++++++++ include/linux/mtd/onenand.h | 1 + include/linux/mtd/samsung_onenand.h | 2 + 4 files changed, 49 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 24e02c2..a557d48 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -2505,23 +2505,24 @@ out: }
/** - * onenand_probe - [OneNAND Interface] Probe the OneNAND device + * onenand_chip_probe - [OneNAND Interface] Probe the OneNAND chip * @param mtd MTD device structure * * OneNAND detection method: * Compare the the values from command with ones from register */ -static int onenand_probe(struct mtd_info *mtd) +static int onenand_chip_probe(struct mtd_info *mtd) { struct onenand_chip *this = mtd->priv; - int bram_maf_id, bram_dev_id, maf_id, dev_id, ver_id; - int density; + int bram_maf_id, bram_dev_id, maf_id, dev_id; int syscfg;
/* Save system configuration 1 */ syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + /* Clear Sync. Burst Read mode to read BootRAM */ - this->write_word((syscfg & ~ONENAND_SYS_CFG1_SYNC_READ), this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg & ~ONENAND_SYS_CFG1_SYNC_READ), + this->base + ONENAND_REG_SYS_CFG1);
/* Send the command for reading device ID from BootRAM */ this->write_word(ONENAND_CMD_READID, this->base + ONENAND_BOOTRAM); @@ -2546,13 +2547,38 @@ static int onenand_probe(struct mtd_info *mtd) /* Read manufacturer and device IDs from Register */ maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); - ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); - this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
/* Check OneNAND device */ if (maf_id != bram_maf_id || dev_id != bram_dev_id) return -ENXIO;
+ return 0; +} + +/** + * onenand_probe - [OneNAND Interface] Probe the OneNAND device + * @param mtd MTD device structure + * + * OneNAND detection method: + * Compare the the values from command with ones from register + */ +int onenand_probe(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int maf_id, dev_id, ver_id; + int density; + int ret; + + ret = this->chip_probe(mtd); + if (ret) + return ret; + + /* Read manufacturer and device IDs from Register */ + maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); + dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); + ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY); + /* Flash device information */ mtd->name = onenand_print_device_info(dev_id, ver_id); this->device_id = dev_id; @@ -2659,6 +2685,9 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) if (!this->write_bufferram) this->write_bufferram = onenand_write_bufferram;
+ if (!this->chip_probe) + this->chip_probe = onenand_chip_probe; + if (!this->block_markbad) this->block_markbad = onenand_default_block_markbad; if (!this->scan_bbt) diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c index 20b4912..1f4bd81 100644 --- a/drivers/mtd/onenand/samsung.c +++ b/drivers/mtd/onenand/samsung.c @@ -590,6 +590,16 @@ static void s3c_set_width_regs(struct onenand_chip *this) } #endif
+int s5pc110_chip_probe(struct mtd_info *mtd) +{ + return 0; +} + +int s5pc210_chip_probe(struct mtd_info *mtd) +{ + return 0; +} + void s3c_onenand_init(struct mtd_info *mtd) { struct onenand_chip *this = mtd->priv; diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 5465562..dea42f4 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -101,6 +101,7 @@ struct onenand_chip { size_t count); unsigned short (*read_word) (void __iomem *addr); void (*write_word) (unsigned short value, void __iomem *addr); + int (*chip_probe)(struct mtd_info *mtd); void (*mmcontrol) (struct mtd_info *mtd, int sync_read); int (*block_markbad)(struct mtd_info *mtd, loff_t ofs); int (*scan_bbt)(struct mtd_info *mtd); diff --git a/include/linux/mtd/samsung_onenand.h b/include/linux/mtd/samsung_onenand.h index 021fa27..ddb29bb 100644 --- a/include/linux/mtd/samsung_onenand.h +++ b/include/linux/mtd/samsung_onenand.h @@ -127,5 +127,7 @@ struct samsung_onenand {
/* common initialize function */ extern void s3c_onenand_init(struct mtd_info *); +extern int s5pc110_chip_probe(struct mtd_info *); +extern int s5pc210_chip_probe(struct mtd_info *);
#endif
- onenand_probe - [OneNAND Interface] Probe the OneNAND device
- onenand_chip_probe - [OneNAND Interface] Probe the OneNAND chip
- @param mtd MTD device structure
- OneNAND detection method:
- Compare the the values from command with ones from register
- int density;
- struct onenand_chip *this = mtd->priv;
- int maf_id, dev_id, ver_id;
- int density;
- int ret;
- ret = this->chip_probe(mtd);
- if (ret)
return ret;
- /* Read manufacturer and device IDs from Register */
- maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID);
- dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID);
- /* Flash device information */ mtd->name = onenand_print_device_info(dev_id, ver_id); this->device_id = dev_id;
- if (!this->chip_probe)
- if (!this->block_markbad) this->block_markbad = onenand_default_block_markbad; if (!this->scan_bbt)
Will there be a problem if you used the default chip_probe() method from the driver ?
- int (*chip_probe)(struct mtd_info *mtd); void (*mmcontrol) (struct mtd_info *mtd, int sync_read); int (*block_markbad)(struct mtd_info *mtd, loff_t ofs); int (*scan_bbt)(struct mtd_info *mtd);
#endif
- int density;
- int density;
- int ret;
- if (ret)
return ret;
Samsung SoCs have their own OneNAND controller and difficult to access OneNAND directly. instead it provides the registers which is mapped OneNAND registers. e.g., Manufacture ID, device ID and so on.
Yes it's Samsung SoCs specific. that's reason introduce chip_probe function. it's same as kernel.
Thank you, Kyungmin Park
#endif
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- ./tools/checkpatch.pl - total: 0 errors, 0 warnings, 17 lines checked
--- board/samsung/goni/onenand.c | 1 + board/samsung/universal_c210/onenand.c | 2 ++ 2 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/board/samsung/goni/onenand.c b/board/samsung/goni/onenand.c index 8d3769b..9dd80fa 100644 --- a/board/samsung/goni/onenand.c +++ b/board/samsung/goni/onenand.c @@ -33,4 +33,5 @@ void onenand_board_init(struct mtd_info *mtd)
this->base = (void *)CONFIG_SYS_ONENAND_BASE; this->options |= ONENAND_RUNTIME_BADBLOCK_CHECK; + this->chip_probe = s5pc110_chip_probe; } diff --git a/board/samsung/universal_c210/onenand.c b/board/samsung/universal_c210/onenand.c index 20e1dc5..5b92308 100644 --- a/board/samsung/universal_c210/onenand.c +++ b/board/samsung/universal_c210/onenand.c @@ -24,6 +24,7 @@ #include <common.h> #include <linux/mtd/mtd.h> #include <linux/mtd/onenand.h> +#include <linux/mtd/samsung_onenand.h>
void onenand_board_init(struct mtd_info *mtd) { @@ -31,4 +32,5 @@ void onenand_board_init(struct mtd_info *mtd)
this->base = (void *)CONFIG_SYS_ONENAND_BASE; this->options |= ONENAND_RUNTIME_BADBLOCK_CHECK; + this->chip_probe = s5pc210_chip_probe; }
This replacement is for causing 4KB page size devices to work properly with u-boot.
The old ONENAND_IS_MLC() behavior has been preserved by explicitly setting ONENAND_HAS_4KB_PAGE for those devices.
This change makes the onenand_base.c file more resembling the respective kernel sources.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- ./tools/checkpatch.pl - total: 0 errors, 0 warnings, 162 lines checked
--- drivers/mtd/onenand/onenand_base.c | 45 +++++++++++++++++++++++------------ include/linux/mtd/onenand.h | 4 +++ 2 files changed, 33 insertions(+), 16 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index a557d48..d049473 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -367,7 +367,7 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2);
- if (ONENAND_IS_MLC(this)) + if (ONENAND_IS_4KB_PAGE(this)) ONENAND_SET_BUFFERRAM0(this); else /* Switch to the next data buffer */ @@ -395,7 +395,7 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, case FLEXONENAND_CMD_RECOVER_LSB: case ONENAND_CMD_READ: case ONENAND_CMD_READOOB: - if (ONENAND_IS_MLC(this)) + if (ONENAND_IS_4KB_PAGE(this)) dataram = ONENAND_SET_BUFFERRAM0(this); else dataram = ONENAND_SET_NEXT_BUFFERRAM(this); @@ -893,7 +893,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, while (!ret) { /* If there is more to load then start next load */ from += thislen; - if (!ONENAND_IS_MLC(this) && read + thislen < len) { + if (!ONENAND_IS_4KB_PAGE(this) && read + thislen < len) { this->main_buf = buf + thislen; this->command(mtd, ONENAND_CMD_READ, from, writesize); /* @@ -927,7 +927,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, oobcolumn = 0; }
- if (ONENAND_IS_MLC(this) && (read + thislen < len)) { + if (ONENAND_IS_4KB_PAGE(this) && (read + thislen < len)) { this->command(mtd, ONENAND_CMD_READ, from, writesize); ret = this->wait(mtd, FL_READING); if (unlikely(ret)) @@ -944,13 +944,13 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, /* Set up for next read from bufferRAM */ if (unlikely(boundary)) this->write_word(ONENAND_DDP_CHIP1, this->base + ONENAND_REG_START_ADDRESS2); - if (!ONENAND_IS_MLC(this)) + if (!ONENAND_IS_4KB_PAGE(this)) ONENAND_SET_NEXT_BUFFERRAM(this); buf += thislen; thislen = min_t(int, writesize, len - read); column = 0;
- if (!ONENAND_IS_MLC(this)) { + if (!ONENAND_IS_4KB_PAGE(this)) { /* Now wait for load */ ret = this->wait(mtd, FL_READING); onenand_update_bufferram(mtd, from, !ret); @@ -1024,7 +1024,8 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from,
stats = mtd->ecc_stats;
- readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + readcmd = ONENAND_IS_4KB_PAGE(this) ? + ONENAND_CMD_READ : ONENAND_CMD_READOOB;
while (read < len) { thislen = oobsize - column; @@ -1202,7 +1203,8 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from,
MTDDEBUG(MTD_DEBUG_LEVEL3, "onenand_bbt_read_oob: from = 0x%08x, len = %zi\n", (unsigned int) from, len);
/* Initialize return value */ ops->oobretlen = 0; @@ -1271,7 +1273,8 @@ static int onenand_verify_oob(struct mtd_info *mtd, const u_char *buf, loff_t to u_char *oob_buf = this->oob_buf; int status, i, readcmd;
this->command(mtd, readcmd, to, mtd->oobsize); onenand_update_bufferram(mtd, to, 0); @@ -1560,7 +1563,8 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to,
oobbuf = this->oob_buf;
- oobcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_PROG : ONENAND_CMD_PROGOOB; + oobcmd = ONENAND_IS_4KB_PAGE(this) ? + ONENAND_CMD_PROG : ONENAND_CMD_PROGOOB;
/* Loop until all data write */ while (written < len) { @@ -1577,7 +1581,7 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, memcpy(oobbuf + column, buf, thislen); this->write_bufferram(mtd, 0, ONENAND_SPARERAM, oobbuf, 0, mtd->oobsize);
- if (ONENAND_IS_MLC(this)) { + if (ONENAND_IS_4KB_PAGE(this)) { /* Set main area of DataRAM to 0xff*/ memset(this->page_buf, 0xff, mtd->writesize); this->write_bufferram(mtd, 0, ONENAND_DATARAM, @@ -2146,7 +2150,10 @@ static void onenand_check_features(struct mtd_info *mtd) /* Lock scheme */ switch (density) { case ONENAND_DEVICE_DENSITY_4Gb: - this->options |= ONENAND_HAS_2PLANE; + if (ONENAND_IS_DDP(this)) + this->options |= ONENAND_HAS_2PLANE; + else + this->options |= ONENAND_HAS_4KB_PAGE;
case ONENAND_DEVICE_DENSITY_2Gb: /* 2Gb DDP don't have 2 plane */ @@ -2168,6 +2175,9 @@ static void onenand_check_features(struct mtd_info *mtd) }
if (ONENAND_IS_MLC(this)) + this->options |= ONENAND_HAS_4KB_PAGE; + + if (ONENAND_IS_4KB_PAGE(this)) this->options &= ~ONENAND_HAS_2PLANE;
if (FLEXONENAND(this)) { @@ -2181,6 +2191,9 @@ static void onenand_check_features(struct mtd_info *mtd) printk(KERN_DEBUG "Chip support all block unlock\n"); if (this->options & ONENAND_HAS_2PLANE) printk(KERN_DEBUG "Chip has 2 plane\n"); + if (this->options & ONENAND_HAS_4KB_PAGE) + printk(KERN_DEBUG "Chip has 4KiB pagesize\n"); + }
/** @@ -2584,6 +2597,9 @@ int onenand_probe(struct mtd_info *mtd) this->device_id = dev_id; this->version_id = ver_id;
+ /* Check OneNAND features */ + onenand_check_features(mtd); + density = onenand_get_density(dev_id); if (FLEXONENAND(this)) { this->dies = ONENAND_IS_DDP(this) ? 2 : 1; @@ -2606,7 +2622,7 @@ int onenand_probe(struct mtd_info *mtd) mtd->writesize = this->read_word(this->base + ONENAND_REG_DATA_BUFFER_SIZE); /* We use the full BufferRAM */ - if (ONENAND_IS_MLC(this)) + if (ONENAND_IS_4KB_PAGE(this)) mtd->writesize <<= 1;
mtd->oobsize = mtd->writesize >> 5; @@ -2637,9 +2653,6 @@ int onenand_probe(struct mtd_info *mtd) else mtd->size = this->chipsize;
- /* Check OneNAND features */ - onenand_check_features(mtd); - mtd->flags = MTD_CAP_NANDFLASH; mtd->erase = onenand_erase; mtd->read = onenand_read; diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index dea42f4..bb4a4a6 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -140,6 +140,9 @@ struct onenand_chip { #define ONENAND_IS_DDP(this) \ (this->device_id & ONENAND_DEVICE_IS_DDP)
+#define ONENAND_IS_4KB_PAGE(this) \ + (this->options & ONENAND_HAS_4KB_PAGE) + #define ONENAND_IS_2PLANE(this) (0)
/* @@ -148,6 +151,7 @@ struct onenand_chip { #define ONENAND_HAS_CONT_LOCK (0x0001) #define ONENAND_HAS_UNLOCK_ALL (0x0002) #define ONENAND_HAS_2PLANE (0x0004) +#define ONENAND_HAS_4KB_PAGE (0x0008) #define ONENAND_RUNTIME_BADBLOCK_CHECK (0x0200) #define ONENAND_PAGEBUF_ALLOC (0x1000) #define ONENAND_OOBBUF_ALLOC (0x2000)
Enable OneNAND support for C210 universal.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- ./tools/checkpatch.pl - total: 0 errors, 0 warnings, 7 lines checked
--- include/configs/s5pc210_universal.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 4031016..18831ee 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -232,6 +232,7 @@ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
#define CONFIG_USE_ONENAND_BOARD_INIT +#define CONFIG_SAMSUNG_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x0C000000
#define CONFIG_ENV_IS_IN_MMC 1
Several fixes for GONI and Exynos4210 (C210_universal) targets have been added.
Tested at: Samsung S5PC110 GONI Samsung Exynos4210 (S5PC210 Universal)
Lukasz Majewski (4): onenand:samsung Target dependent OneNAND chip probe function onenand:samsung OneNAND chip probe functions added for GONI and Exynos4210 onenand: Replace ONENAND_IS_MLC() test with ONENAND_HAS_4KB() onenand: samsung: Enable support OneNAND support at Samsung's Exynos4210
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- drivers/mtd/onenand/onenand_base.c | 43 +++++++++++++++++++++++++++++----- drivers/mtd/onenand/samsung.c | 10 ++++++++ include/linux/mtd/onenand.h | 1 + include/linux/mtd/samsung_onenand.h | 2 + 4 files changed, 49 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 06f187f..0b375e6 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -2501,23 +2501,24 @@ out: }
/* Send the command for reading device ID from BootRAM */ this->write_word(ONENAND_CMD_READID, this->base + ONENAND_BOOTRAM); @@ -2542,13 +2543,38 @@ static int onenand_probe(struct mtd_info *mtd) /* Read manufacturer and device IDs from Register */ maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); - ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); - this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
+ return 0; +} + +/** + * onenand_probe - [OneNAND Interface] Probe the OneNAND device + * @param mtd MTD device structure + * + * OneNAND detection method: + * Compare the the values from command with ones from register + */ +int onenand_probe(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int maf_id, dev_id, ver_id; + int density; + int ret; + + ret = this->chip_probe(mtd); + if (ret) + return ret; + + /* Read manufacturer and device IDs from Register */ + maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); + dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); + ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY); + /* Flash device information */ mtd->name = onenand_print_device_info(dev_id, ver_id); this->device_id = dev_id; @@ -2655,6 +2681,9 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) if (!this->write_bufferram) this->write_bufferram = onenand_write_bufferram;
+ if (!this->chip_probe) + this->chip_probe = onenand_chip_probe; + if (!this->block_markbad) this->block_markbad = onenand_default_block_markbad; if (!this->scan_bbt) diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c index ff59064..c9d33ec 100644 --- a/drivers/mtd/onenand/samsung.c +++ b/drivers/mtd/onenand/samsung.c @@ -589,6 +589,16 @@ static void s3c_set_width_regs(struct onenand_chip *this) } #endif
#endif
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/goni/onenand.c | 1 + board/samsung/universal_c210/onenand.c | 2 ++ 2 files changed, 3 insertions(+), 0 deletions(-)
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- drivers/mtd/onenand/onenand_base.c | 45 +++++++++++++++++++++++------------ include/linux/mtd/onenand.h | 4 +++ 2 files changed, 33 insertions(+), 16 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 0b375e6..480ae7a 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -367,7 +367,7 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2);
- if (ONENAND_IS_MLC(this)) { + if (ONENAND_IS_4KB_PAGE(this)) { /* Set main area of DataRAM to 0xff*/ memset(this->page_buf, 0xff, mtd->writesize); this->write_bufferram(mtd, 0, ONENAND_DATARAM, @@ -2140,7 +2144,10 @@ static void onenand_check_features(struct mtd_info *mtd) /* Lock scheme */ switch (density) { case ONENAND_DEVICE_DENSITY_4Gb: - this->options |= ONENAND_HAS_2PLANE; + if (ONENAND_IS_DDP(this)) + this->options |= ONENAND_HAS_2PLANE; + else + this->options |= ONENAND_HAS_4KB_PAGE;
case ONENAND_DEVICE_DENSITY_2Gb: /* 2Gb DDP don't have 2 plane */ @@ -2162,6 +2169,9 @@ static void onenand_check_features(struct mtd_info *mtd) }
if (FLEXONENAND(this)) { @@ -2175,6 +2185,9 @@ static void onenand_check_features(struct mtd_info *mtd) printk(KERN_DEBUG "Chip support all block unlock\n"); if (this->options & ONENAND_HAS_2PLANE) printk(KERN_DEBUG "Chip has 2 plane\n"); + if (this->options & ONENAND_HAS_4KB_PAGE) + printk(KERN_DEBUG "Chip has 4KiB pagesize\n"); + }
/** @@ -2580,6 +2593,9 @@ int onenand_probe(struct mtd_info *mtd) this->device_id = dev_id; this->version_id = ver_id;
+ /* Check OneNAND features */ + onenand_check_features(mtd); + density = onenand_get_density(dev_id); if (FLEXONENAND(this)) { this->dies = ONENAND_IS_DDP(this) ? 2 : 1; @@ -2602,7 +2618,7 @@ int onenand_probe(struct mtd_info *mtd) mtd->writesize = this->read_word(this->base + ONENAND_REG_DATA_BUFFER_SIZE); /* We use the full BufferRAM */ - if (ONENAND_IS_MLC(this)) + if (ONENAND_IS_4KB_PAGE(this)) mtd->writesize <<= 1;
mtd->oobsize = mtd->writesize >> 5; @@ -2633,9 +2649,6 @@ int onenand_probe(struct mtd_info *mtd) else mtd->size = this->chipsize;
Enable OneNAND support for Exynos4210 (C210 universal).
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- include/configs/s5pc210_universal.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 8286680..1301275 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -233,6 +233,7 @@ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
Is anyone interested in being a OneNAND custodian?
I've taken some OneNAND patches in the past, but it's a completely separate subsystem from NAND, and nobody seems interested in changing that. I not only have no hardware, but also no documentation other than marketing materials. I lack the context to properly review OneNAND patches.
-Scott
Thanks Scott. Now I'm no more work on OneNAND. It's almost fixed and no more new features. These patches are syncing internal tree with mainline one. and no more changes.
So please until this time, handle this patches.
Next time, Mr. Kang handle both samsung and onenand together. How do you think?
-Scott
-Scott
Hi Scott,
Some of our targets still use that kind of memory (Goni and Universal C210). I can volunteer as a OneNAND custodian.
-Scott
Hi Scott,
Wolfgang, is this OK with you?
-Scott
Dear Scott Wood,
Yes, of course.
I plan to post a status summary / custodian update tomorrow.
To all new custodians: I need you SSH public keys.
participants (6)
Kyungmin Park
Kyungmin Park
Lukasz Majewski
Scott Wood
