[PATCH v2 1/3] lmb: Fix lmb property's defination under struct lmb
Under struct lmb {} the lmb property's should be defined only if CONFIG_LMB_MEMORY_REGIONS is defined.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: - Also fix lib/lmb.c
include/lmb.h | 2 +- lib/lmb.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index ab277ca80004..1476d78c2823 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -68,7 +68,7 @@ struct lmb_region { struct lmb { struct lmb_region memory; struct lmb_region reserved; -#if !IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) +#if IS_ENABLED(CONFIG_LMB_MEMORY_REGIONS) struct lmb_property memory_regions[CONFIG_LMB_MEMORY_REGIONS]; struct lmb_property reserved_regions[CONFIG_LMB_RESERVED_REGIONS]; #endif diff --git a/lib/lmb.c b/lib/lmb.c index f72996a4248e..f21fe672ae96 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -108,7 +108,7 @@ void lmb_init(struct lmb *lmb) #if IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) lmb->memory.max = CONFIG_LMB_MAX_REGIONS; lmb->reserved.max = CONFIG_LMB_MAX_REGIONS; -#else +#elif IS_ENABLED(CONFIG_LMB_MEMORY_REGIONS) lmb->memory.max = CONFIG_LMB_MEMORY_REGIONS; lmb->reserved.max = CONFIG_LMB_RESERVED_REGIONS; lmb->memory.region = lmb->memory_regions;
With commit ce39ee28ec31 ("zynqmp: Do not place u-boot to reserved memory location"), the function board_get_usable_ram_top() is allocating MMU_SECTION_SIZE of about 2MB using lmb_alloc(). But we dont have this much memory in case of mini U-Boot.
Keep these functions which use lmb under CONFIG_LMB so that they are compiled and used only when LMB is enabled.
(no changes since v1)
board/xilinx/zynqmp/zynqmp.c | 3 +++ boot/image-board.c | 4 ++++ 2 files changed, 7 insertions(+)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 242e143cbfd7..77dc70872d92 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -497,6 +497,7 @@ int dram_init(void) return 0; }
+#if defined(CONFIG_LMB) ulong board_get_usable_ram_top(ulong total_size) { phys_size_t size; @@ -518,6 +519,8 @@ ulong board_get_usable_ram_top(ulong total_size)
return reg + size; } +#endif + #else int dram_init_banksize(void) { diff --git a/boot/image-board.c b/boot/image-board.c index 0d2e0fc9692e..a3a3e28c3319 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -541,6 +541,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, return 0; }
+#if defined(CONFIG_LMB) /** * boot_ramdisk_high - relocate init ramdisk * @lmb: pointer to lmb handle, will be used for memory mgmt @@ -634,6 +635,7 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, error: return -1; } +#endif
int boot_get_setup(bootm_headers_t *images, u8 arch, ulong *setup_start, ulong *setup_len) @@ -827,6 +829,7 @@ int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, return 0; }
+#if defined(CONFIG_LMB) /** * boot_get_cmdline - allocate and initialize kernel cmdline * @lmb: pointer to lmb handle, will be used for memory mgmt @@ -934,6 +937,7 @@ int image_setup_linux(bootm_headers_t *images)
return 0; } +#endif
void genimg_print_size(uint32_t size) {
There is no need to have LMB enabled that's why save some space by disabling it.
aarch64: (for 6/6 boards) all -1550.0 rodata -140.7 text -1409.3 xilinx_zynqmp_mini: all -2001 rodata -185 text -1816 xilinx_zynqmp_mini_qspi: all -2001 rodata -185 text -1816 xilinx_zynqmp_mini_emmc0: all -2649 rodata -237 text -2412 xilinx_zynqmp_mini_emmc1: all -2649 rodata -237 text -2412
Changes in v2: - new patch in series
configs/xilinx_zynqmp_mini_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 73f6eee039df..7c25a54046df 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -58,3 +58,4 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set +# CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index ac28eb1b8222..f18207a270ec 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -65,3 +65,4 @@ CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set # CONFIG_EFI_LOADER is not set +# CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index e586790c6047..507717dabb2d 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -65,3 +65,4 @@ CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set # CONFIG_EFI_LOADER is not set +# CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 78c9d29af095..e45ccb9ff8ed 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -68,3 +68,4 @@ CONFIG_SPI=y CONFIG_ZYNQMP_GQSPI=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set +# CONFIG_LMB is not set
Michal Simek
