[U-Boot] [PATCH 0/2]
1/2: refactors a little because NDS32 actually need not the symbolic link 2/2: introduce a new config to avoid broken symbolic links.
Masahiro Yamada (2): nds32: include <asm/arch-*/*.h> instead of <asm/arch/*.h> kbuild: create symbolic link only for ARM, SPARC, PowerPC, x86
arch/Kconfig | 6 ++++++ arch/powerpc/Kconfig | 3 +++ include/configs/adp-ag101.h | 2 +- include/configs/adp-ag101p.h | 2 +- include/configs/adp-ag102.h | 2 +- scripts/Makefile.autoconf | 2 ++ 6 files changed, 14 insertions(+), 3 deletions(-)
There are only two SoC-specific headers for this architecture: - arch/nds32/include/asm/arch-ag101/ag101.h - arch/nds32/include/asm/arch-ag102/ag102.h
Those two have different file names, so there is no advantage to include them via symbolic linked directory.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/configs/adp-ag101.h | 2 +- include/configs/adp-ag101p.h | 2 +- include/configs/adp-ag102.h | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/adp-ag101.h b/include/configs/adp-ag101.h index e318c75..f70ee10 100644 --- a/include/configs/adp-ag101.h +++ b/include/configs/adp-ag101.h @@ -9,7 +9,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#include <asm/arch/ag101.h> +#include <asm/arch-ag101/ag101.h>
/* * CPU and Board Configuration Options diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 24904b0..60a5038 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -9,7 +9,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
/* * CPU and Board Configuration Options diff --git a/include/configs/adp-ag102.h b/include/configs/adp-ag102.h index 39f7a3c..ffd5d33 100644 --- a/include/configs/adp-ag102.h +++ b/include/configs/adp-ag102.h @@ -8,7 +8,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#include <asm/arch/ag102.h> +#include <asm/arch-ag102/ag102.h>
The symbolic link to SoC/CPU specific header directory is created during the build, while it is only necessary for ARM, SPARC, x86, and some CPUs of PowerPC. For the other architectures, it just results in a broken symbolic link.
Introduce CONFIG_CREATE_ARCH_SYMLINK to not create unneeded symbolic links.
arch/Kconfig | 6 ++++++ arch/powerpc/Kconfig | 3 +++ scripts/Makefile.autoconf | 2 ++ 3 files changed, 11 insertions(+)
diff --git a/arch/Kconfig b/arch/Kconfig index 200588a..c495267 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -1,3 +1,6 @@ +config CREATE_ARCH_SYMLINK + bool + config HAVE_GENERIC_BOARD bool
@@ -18,6 +21,7 @@ config ARC
config ARM bool "ARM architecture" + select CREATE_ARCH_SYMLINK select HAVE_PRIVATE_LIBGCC select HAVE_GENERIC_BOARD select SUPPORT_OF_CONTROL @@ -83,9 +87,11 @@ config SH
config SPARC bool "SPARC architecture" + select CREATE_ARCH_SYMLINK
config X86 bool "x86 architecture" + select CREATE_ARCH_SYMLINK select HAVE_PRIVATE_LIBGCC select HAVE_GENERIC_BOARD select SYS_GENERIC_BOARD diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index 3b3f446..18451d3 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -22,9 +22,11 @@ config MPC8260
config MPC83xx bool "MPC83xx" + select CREATE_ARCH_SYMLINK
config MPC85xx bool "MPC85xx" + select CREATE_ARCH_SYMLINK
config MPC86xx bool "MPC86xx" @@ -34,6 +36,7 @@ config 8xx
config 4xx bool "PPC4xx" + select CREATE_ARCH_SYMLINK
endchoice
diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index f054081..a17e374 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -106,6 +106,7 @@ include/config.h: scripts/Makefile.autoconf create_symlink FORCE # Otherwise, create a symbolic link to arch/$(ARCH)/include/asm/arch-$(SOC). PHONY += create_symlink create_symlink: +ifeq ($(CONFIG_CREATE_ARCH_SYMLINK),y) ifneq ($(KBUILD_SRC),) $(Q)mkdir -p include/asm $(Q)if [ -d $(KBUILD_SRC)/arch/$(ARCH)/mach-$(SOC)/include/mach ]; then \ @@ -122,6 +123,7 @@ else fi; \ ln -fsn $$dest arch/$(ARCH)/include/asm/arch endif +endif
PHONY += FORCE FORCE:
Dne 26.5.2015 v 14:32 Masahiro Yamada napsal(a):
'ifdef CONFIG_CREATE_ARCH_SYMLINK' is shorter and maybe easier to read.
But you confused me, I thought this was a kernel patch at first :).
Michal
Hi Michal (Marek),
2015-05-26 16:14 GMT+09:00 Michal Marek mmarek@suse.cz:
OK.
Sorry, it was not intentional.
U-Boot uses Kbuild and often cherry-picks kbuild-updates from Linux. Some of your credits exists in U-boot's git history.
U-Boot also uses scripts/get_maintainer.pl, this is why you were automatically listed in CC.
I wish I could omit a particular address from the get_maintainer.pl output...
Masahiro Yamada
Michal Marek
